CPU Interface Socket 939 Athlon 64
Chipset ATI RD480 Northbridge - ULi M1575 Southbridge
Bus Speeds 200 to 400MHz in 1MHz Increments
Memory Speeds DDR200, 266, 333, 400
(433, 466, 500 with Rev. E AMD)
PCIe Speeds 100 to 150MHz in 1MHz Increments
PCI/AGP Fixed at 33/66
Core Voltage Auto, 0.8V to 1.45V in 0.025V increments
PLUS 0.2V with vCore Over-voltage
(Maximum vCore 1.65V)
CPU Clock Multiplier 4X-25.5X in 0.5X increments
DRAM Voltage Auto, 2.65V to 3.2V in .05V to .1V increments
HyperTransport Frequency 1000MHz (1GHz)
HyperTransport Multiplier Auto, 1X to 5X
PCI Express Voltage 1.2V, 1.3V, 1.4V, 1.5V
Southbridge Overvoltage Enabled (+0.1v)
PEG Link Mode Auto, Disabled, Normal, Fast, Faster
PEG Bugger Length Auto, Short, Long, Longer, Longest
AI Overclocking Manual, Auto*, Standard*, Overclock Profile
*Set CPU Frequency and Other Parameters Automatically
Overclock Profile Options 3%, 5%, 10%, 15%, 20%, 30%
Memory Slots Four 184-pin DDR DIMM Slots
Dual-Channel Configuration
Regular Unbuffered or ECC Memory to 4GB Total
Expansion Slots 2 PCIe x16
1 PCIe x1
3 PCI Slots
1 Asus MVP Switch Card in Secondary (Black) PCIe Slot
Onboard SATA/RAID 4 SATA2 Drives by ULi M1575
(RAID 0, 1, 1+0, 5, JBOD)
Onboard IDE/IDE RAID Two Standard ATA133/100/66 (4 drives)
Onboard USB 2.0/IEEE-1394 8 USB 2.0 ports supported by ULi M1575
2 1394 Firewire by TI 1394
Onboard LAN 1 Gigabit Ethernet
PCI Ethernet by Marvel Yukon 88E8001
Onboard Audio Azalia HD Audio by ADI AD1986A Soundmax codec
BIOS Revision AMI 0037 (11/17/05) Beta
