devic
Semiprofi
- Spezifikationen
- Bilder
- BIOS
- Wichtige Informationen
- Wichtige Links / Downloads
CPU:
Chipsatz:
Speicher:
Erweiterungs-Slots:
Multi-GPU Unterstützung:
Storage:
Audio:
LAN:
Interne IO-Anschlüsse:
externe IO-Anschlüsse:
Lieferumfang:
- Intel Socket 775 Processors for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® dual-core/Celeron® dual-core /Celeron® Processors
- Support Intel® next generation 45nm Multi-Core CPU
- Compatible with Intel® 06/05B/05A processors
Chipsatz:
- Intel P45 Chipsatz
- Intel ICH10R Southbridge
Speicher:
- 4 x240-pin DIMM, Max. 16 GB, DDR2 1200/1066/800/667 Non-ECC,Un-buffered Memory
- Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
- When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
QVL-Liste siehe Wichtige Links / Downloads
Erweiterungs-Slots:
- 2 x PCIe 2.0 x16 (single max @16,dual @ x8 speed)
- 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
- 2 x PCI 2.2
- Unterstützt ATI CrossFireX™
Storage:
- 6 xSATA 3 Gb/s ports Intel Matrix Storage Technology supports Support RAID 0,1,5,10 Marvell® 88SE6121 controller
- 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
- 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
- Silicon Image Sil5723
- 2 x SATA 3.0 Gb/s ports
- Supports RAID 0, 1
Audio:
- SupremeFX X-Fi Audio Card
- ADI® AD2000B 8-channel High Definition Audio CODEC
- Creative X-Fi capability
- X-Fi interface - Coaxial/Optical S/PDIF out ports
LAN:
- Dual Gigabit LAN, both featuring AI NET2
- Support Teaming Technology
- 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
- 1 x Floppy disk drive connector
- 1 x IDE connector for two devices
- 6 x SATA connectors (Blue)
- 2 x Speeding HDD connectors (Black)
- 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
- 3 x thermal sensor connectors
- 1 x IEEE1394a connector
- 1 x Chassis Intrusion connector
- 24-pin ATX Power connector
- 8-pin ATX 12V Power connector
- 1 x En/Dis-able Clr CMOS
- 1 x LCD Poster connector
- 1 x ROG connector
- 1 x Power-on switch
- 1 x Reset switch
- System panel connector
- 1 x PS/2 Keyboard port(purple)
- 1 x eSATA port
- 2 x LAN (RJ45) ports
- 6 x USB 2.0/1.1 ports
- 1 x IEEE1394a port
- 1 x Clr CMOS switch
Lieferumfang:
- LCD Poster
- ASUS Optional Fan
- 3 in 1 ASUS Q-Connector Kit
- UltraDMA 133/100/66 cable
- Floppy disk drive cable
- SATA cables
- SATA power cables
- 2-port USB2.0 + IEEE 1394a module
- Q-Shield
- Cable Ties
- User's manual
Kompatible Kühler:
__________- Alpenfön Groß Clock'ner (nur mit leichtem Verbiegen der Lamellen!)
- Arctic Freezer 7 Pro
- Asus Silent Night 1+2
- Asus Triton 79
- Coolermaster Hyper 212
- Noctua NH-U-12P
- Scythe Mugen / Infinity
- Thermalright IFX-14 (HR-10 passt nur mit Bearbeitung)
- Thermalright Ultra 120 eXtreme / True Black
- Thermaltake Sonic Tower
- Xigmatek HDT-S1283 / Red Scorpion
- Zalman CNPS 9500 AT
- Zalman CNPS 9700 LED
- ZHEROtherm Nirvana NV 120
Kompatibler RAM:
__________- 2x 1GB A-DATA Vitesta Extreme DDR2-800
- 2x 1GB Corsair XMS2 DHX DDR2-800
- 2x 1GB Aeneon XTune DDR2-1066
- 2x 1GB Patriot Viper DDR2-1150
- 2x 1GB CompuStocx Diablo DDR2-1200
- 2x 1GB OCZ Flex XLC DDR2-1200
- 4x 1GB Crucial Ballistix (Tracer) DDR2-1066
- 4x 1GB Corsair Dominator DDR2-1066
- 4x 1GB OCZ Reaper HPC Edition DDR2-1200
- 2x 2GB Corsair DHX DDR2-800
- 2x 2GB OCZ XTC Platinum DDR2-1000
- 2x 2GB Apogee GT DDR2-1066
- 2x 2GB Corsair Dominator DDR2-1066
- 2x 2GB G.Skill F2 4GBPK DDR2-1066
- 2x 2GB G.Skill F2 4GBPI DDR2-1066
- 2x 2GB Patriot Viper DDR2-1066
- 2x 2GB Transcend aXeram DDR2-1066
- 2x 2GB G.Skill F2-4GBPI DDR2-1100
- 2x 2GB Mushkin XP2 DDR2-1100
- 2x 2GB Chaintech Apogee GT DDR2-1150
- 2x 2GB OCZ Flex II DDR2-1150
- 4x 2GB Transcend JetRam DDR2-800
- 4x 2GB Corsair Dominator DDR2-1066
- 4x 2GB OCZ Platinum XTC DDR2-1066
- 4x 2GB OCZ Reaper HPC Edition DDR2-1066
Die GTL-Einstellung:
Die GTL ist ein Teiler. Sie ergibt mit der VTT multipliziert einen Wert in mV. Bei den meisten Board benutzt man den Teiler um auf einen höheren/niedrigeren (eben für die CPU perfekte) Endvoltage zu kommen. Beim Maximus II Formula wird dieser Teiler jedoch gefixt und dafür vom Endwert in mV abgezogen. Das hat den Vorteil, dass sich der Endwert bei gleicheingestellter GTL nicht durch die variable VTT ändert.
Beispiel mit Asus P5Q Deluxe und vielen anderen Boards:
VTT x GTL = mV
1,1V x 0,63V = 693mV
Beispiel mit Asus Maximus II Formula:
VTT x fixed GTL = mV - mV
1,1V x 0,677 = 744,7mV - 50mV
Beide Beispiele kommen auf etwa das gleiche raus
Dickgedruckt = Jeweils im BIOS einstellbare Werte
__________Die GTL ist ein Teiler. Sie ergibt mit der VTT multipliziert einen Wert in mV. Bei den meisten Board benutzt man den Teiler um auf einen höheren/niedrigeren (eben für die CPU perfekte) Endvoltage zu kommen. Beim Maximus II Formula wird dieser Teiler jedoch gefixt und dafür vom Endwert in mV abgezogen. Das hat den Vorteil, dass sich der Endwert bei gleicheingestellter GTL nicht durch die variable VTT ändert.
VTT x GTL = mV
Northbridge Temperaturproblem beheben:
Um die zu hohen Temperaturen der Northbridge zu senken, muss der Anpressdruck des Kühlsystems verstärkt werden. Dazu muss das Board ausgebaut und umgedreht werden. Daraufhin werden unter die Schrauben, die die Heatpipekühlung auf der Northbridge halten einfach zwei Unterlegscheiben (0,5 - 1mm) gelegt. Das erhöht den Anpressdruck und senkt gleichzeitig die Temperaturen der Northbridge.
__________Um die zu hohen Temperaturen der Northbridge zu senken, muss der Anpressdruck des Kühlsystems verstärkt werden. Dazu muss das Board ausgebaut und umgedreht werden. Daraufhin werden unter die Schrauben, die die Heatpipekühlung auf der Northbridge halten einfach zwei Unterlegscheiben (0,5 - 1mm) gelegt. Das erhöht den Anpressdruck und senkt gleichzeitig die Temperaturen der Northbridge.
__________
OC-Ergebnisse:
