[Sammelthread] Asus Maximus III Formula (P55) [2]
Inhalt
1.Algemeines
1.1 Bilder
1.2 Lieferumfang
1.3 OC-Verhalten
1.4 Spezifikationen
2.Information
2.1 Previews / Reviews
2.2 Preisvergleich
2.3 Kompatibele RAMs
2.4 kompatibelen LuftKühler
2.3 Overclocking Ergebnisse
3.Downloads
3.1 Bios
3.2 Treiber
3.3 Software
1. Agemeines
Bilder
ein Dank an Ace.KIA. für die Bilder.
Lieferumfang:
-ROG Maximus III Formula Motherboard
-1xMulti-funktional module (2-port USB 2.0 and 1-port ESATA
-SupremeFX X-FI Audio Card
-1xASUS Q-Shild (I/O shield)
-3x Serial ATA signal cables
-1xROG Connect cable
-1xSLI Cable
-1x 2-1 Asus Q-Connector Kit
-cable ties,User Guide, ROG Support DVD,1xROG Theme label,1ROG cable label(12-in-1)
Spezifikation:
CPU:
Intel sockel 1156 i5-750 Prozessor i7-860/870 Prozessor (Lynnfield)
Chipsatz:
Intel P55 Express Chipsatz
Intel® P55 (PCH) Southbridge
Speicher:
4 x 240 dimm,Max.16GB,DDR3-1066, DDR3-1333,1600,1800,2000,2133(OC) non-Ecc, un-buffered memory modules
Supports Intel Extreme Memory Profile (XMP)
Erweiterungs-Slots:
3xPCIe x16slot
-2xPCIe 2.0 (red) support single at x16 or dual at x8 mode
-1xPCIe 1.0 (white) support at 4x mode
2xPCIex1
2xPCI 2.2
Multi-GPU Unterstützung:
SLI,CrossfireX
Storage:
Intel® P55 (PCH)
-6 x SATA 3.0 GB/s ports
-Intel Matrix Storage Technology supports Raid0,1, 5 and 10
JMicron 322 controller and 2x Jmicron 363 controllers:
-2xSATA 3.0GB/s port (red) RAID 0 and 1(SPD_HDD1SPD_HDD2)
-1xExternal SATA 3.0 GB/s ports (SATA On-the Go)
-2xSATA 3.0 GB/s port (whit) -SATA_0DD1+SATA_0DD2
Audio:
SupremeFX X-Fi
-8channel High Definition Audio CODEC
-EAX Advance HD 4.0
-X-FI CMOSS -3D
-X-FI Crystalizer
-Creativ ALchemy
-1x S/PDIF out header,Coaxial/Optical S/PDIF,Blue-ray support
LAN:
1xGigabit Lan (Realtek RTL8110SC)
Overclocking Features
Extreme Engine Power Design
- 16-phase CPU power
- 3-phase VTT power
- 3-phase Memory power
ROG Connect
CPU Level Up
Memory Level Up
Speeding HDD
iROG
Extreme Tweaker
Loadline Calibration
Intelligent overclocking tools:
- ASUS AI Booster Utility
- O.C. Profile
Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
Special Features
MemOK!
MemPerfect
ProbeIt
Onboard Switches: Power / Reset / Clr CMOS (at rear)
Q-Fan Plus
ASUS EPU
ASUS MyLogo3
ASUS Fan Xpert
ASUS EZ Flash 2
ASUS CrashFree BIOS 3
ASUS Q-Connector
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
ASUS Q-Slot
ASUS Q-DIMM
Information
Board
http://www.asus.com/product.aspx?P_ID=0ODEkxv4cmlXkqmr&templete=2
Review
http://www.google.de/url?sa=t&source=web&ct=res&cd=2&url=http%3A%2F%2Fwww.overclockersclub.com%2Freviews%2Fasus_rog_maximusiii_formula_preview%2F&ei=3WDGSpu1HoK64QaF57THAQ&usg=AFQjCNEbdV8MRKATUoV2cPAaJTEQ3MJMqw
Preisvergleich >ASUS MAXIMUS III FORMULAR:
http://preisvergleich.hardwareluxx.de/a459238.html
BIOS Empfehlung: 1006AKTUELLES
Kompatibele RAMs/Liste
ftp://ftp.asus.com.tw/pub/asus/mb/LGA1156/Maximus_III_Formula/M3F-QVL.zip
Code:
4x2gb G.Skill (F3-12800CL9D-4GBNQ) CL9-9-9-24 Vdimm=1.50V
2x2Gb G.Skill(F3-12800CL7D-4GBRH, Ripjaws-Series) CL7-7-7-21 VDimm=1,6V
2x2Gb Corsair  (CMG4GX3M2A2000C8, Dominator GT) CL8-8-8-24
2x2Gb G.Skill (F3-17066CL8D-4GBPS) CL8-8-8-24
2x2GB Kingston HyperX KHX1600C8D3K2/4GX
4x2GB exceleram DIMM Kit 4GB PC3-16000U CL9-9-9-24 (DDR3-2000) (EX3-42000X2-GO) 1,65v
Code:
Zalman CNPS 9900Apasst sehr gut darauf und stört die Ram slots nicht.
Zalman CNPS10X Extreme belegt leider den 1 Ram slot.
Noctua NH-U12P SE2
Downloads
Bios
Aktuelle Bios gibt es direkt von FTP-Server
Wer kennt das Problem:
( Config: MIIIF / 720Watt Enermax / ATI5850 / 2x HDD / 4x2 GB RAM)
vorgestern den PC normal runtergefahren, gestern in der Früh ging nichts :(
Einschalten geht, alle Lüfter laufen an und drehen langsam
Netzteil oder das MoBo verreckt?!?
mmh, erste Vermutung wäre MoBo - oder CPU.
Netzteil kannst Du eigentlich ausschließen.
CPU war nie übertaktet und war sehr gut gekühlt.
Ich schick mal vorsichtshalber das MoBo zum Händler ein :)
hatte ich auch schon, cpu bitte mal aus dem sockel nehmen, dann wieder zusammenbauen und versuchen
alternativ die bios batterie für 30 min entfernen
Klar... nen CMOS/clear kannst Du noch mal probieren.
hallo
ich hatte meine HHD's raus genommen und komplett auf ssd's umgestellt und windows 7 neu aufgezogen und seit dem höre ich einmal in der stunde jemals um
.57 min sprich um 09:57, 10:57 usw. einen piepton vom MOBO.
weiß da jemand mehr?
grüsse
Kurze Frage... Ein Kumpel hat sich das Board gekauft und bemängelt, dass die opti. Maus leuchtet, obwohl der PC aus ist. Kann man dies im BIOS deaktivieren?
Es ist wohl die EuP Funktion. Jedoch beim aktivieren der Funktion, verliert das BIOS alle Einstellungen :(
Eigentlich ist die USB-Legacy Control (heißt das so?) für die Stromversorgung der USB Ports bei ausgeschaltetem PC zuständig.
mfg Ceres
Wäre mir neu, dass das Board das kann.
Und USB Legacy Support sollte damit gar nichts zu tun haben. USB LS schafft nur Abhilfe, wenn z.B. ein USB Gerät beim Booten nicht erkannt wird.
Zitat Wiki:
"Bei Betriebssystemen ohne USB-Unterstützung kann das BIOS nach Aktivieren von „USB Legacy Support“ (engl. etwa „USB-Unterstützung für Altlasten“) in seinen Einstellungen Abhilfe schaffen, dadurch erscheinen USB-Eingabegeräte wie "Mäuse" und Tastaturen dem Betriebssystem gegenüber als PS/2-Geräte. Je nach BIOS wird meist genau ein USB-Laufwerk (wie USB-Stick, USB-Kartenleser, USB-Festplatte, USB-Floppy) eingebunden. USB-CD/DVD-Laufwerke werden nur dann eingebunden, wenn von ihnen gebootet wird."
Das Problem sollte eher auf ein nicht richtig herunter gefahrenes System deuten, oder!?
Noch nie davon gelesen oder gehört beim MIIIF.
Vielleicht mal im Hersteller-Support Bereich nachfragen.
Grüße
hallo
grüsse
Habe ich noch nie gehört und hab hier 2 MIIIF am laufen wo auch des öfteren die SSD's gewechselt werden , bist du sicher das es vom Mobo kommt ?
blöde Frage aber hast du einen Rauchmelder / Feuermelder in dem Raum wo der PC steht ? wenn dort die 9Volt Blockbatterie fast leer ist gibt es ca. jede STD einen Signalton . Als wir daß das erste mal hatten wussten wir auch nicht woher der stündliche Piepston kam und hatte zuerst den Rechner verdächtigt allerdings piepste es auch wenn er aus war :) das schlimme ist das der Ton nur einmal ganz kurz ist und man ihn in dieser kurzen Zeit nicht Orten kann , naja hat 2 Tage gedauert bis wir drauf kamen woher der Ton kommt :)
Nein... das Problem haben wohl einige....
Ich habe das Problem bei mir gestern auch bemerkt. Rechner ist aus und die externe Festplatte läuft weiter.
Aber es scheint nur auf bestimmten (und eben nicht auf allen USB Ports) aufzutreten.
Also würde ich an deiner Stelle mal die Ports alle durchtesten.
Grüße
moin leute, hat jemand den MIPS ASUS Maximus III Formula Fusionblock montiert und kann mir die Maße geben, ich meine Lochabstand
Wie kann man diese ganzen bios Meldungen abschalten? Bei mir ist Windows in ca 15 Sek da aber die biosmeldungen brauche genau so lange. Von mir aus muss er nicht jedes mal all diese Festplatten überprüfen. 1 Sek zeit zum del drücken mehr brauche ich nicht.
Also was kann man da machen?
Den POST kannst du nicht abstellen.
Du kannst aber folgendes optieren:
  • First Boot Device: HDD (den Rest deaktiveren)
  • Schalte die anderen beiden onboard SATA Controller ab wenn du sie nicht brauchst
  • Deaktiviere die Firewire-Verbindung wenn du sie nicht brauchst
  • Deaktiviere das ROG Logo
  • Deaktiviere ROG-Connect wenn du es nicht brauchst
  • Deaktiviere SMART-Monitoring wenn du es nicht brauchst
  • Deaktiviere iROG wenn du es nicht brauchst
In der Summe bringt das natürlich nur minimale Auswirkungen auf die Gesamtbootzeit. Aber generell gilt für die Gesamtperformance, dass weniger=mehr ist.
P55 braucht auch so immer extrem lange zum initialisieren..
so heute ist er eingetroffen, der gute Maximus III
nun meine Frage, welchen Audio-Treiber muss ich nehmen, damit die X-Fi PCi x1 Karte ordnungsgemäß funktioniert?
und ein paar anderweitige hilfreiche Tipps wären auch willkommen, damit ich anfangs nichts falsches installiere oder einstelle, da es mein erstes Intel/Nvidia System ist,
Danke im Voraus
Geht auch, aber der von der Page ist ggf. neuer.
Schönen guten Abend,
Ich stehe vor einer schweren Entscheidung.
Ich habe mom. ein Gigabyte P55-UD5 und einen I5 750, habe mir noch günstig einen I7 860 und das Asus Maximus III Formula geschossen.
Eins von den beiden Board's + mein I5 750 bekommt ein Freund von mir, ich kann mir das "bessere OC" Board aussuchen.
Der I7 860 macht die 4 GHZ bei 1,27v mit auf dem Asus Maximus III Formula.
Jetzt ist meine Frage, ob mein Gigabyte die gleichen OC eigenschaften aufweist oder das Asus da doch das bessere Board ist.
Mir gehts nicht darum höher zu kommen als mit dem Asus, sondern die 4GHZ auch bei 1,27v zu schaffen..
Ich selber mag Asus eigentlich eher nicht, da ich damit bisher nur schlechte Erfahrungen gemacht habe.
Lasse mich da aber gerne des besseren belehren..
Hat einer von euch vllt schon einen ähnlichen vergleich machen können?
Lg, martin
Ich würde beim Asus bleiben, BIOS ist gut, OC mit Stromsparmechanismen klappt auch.. Der vcore darf man allerdings nur bedingt glauben, Asus gibt bei angezeigten 1.27v eher 1.29v aus, was aber für nen 860 mit HT ein sehr guter Wert ist.
Dazu ist die Optik vom Asus besser.
die 1,27v sind von CPU-Z
Optisch gefällt mir mein Gigabyte P55 UD5 besser, zumal es mehr anschlüsse hat.
Aber mir ist es eben wichtig die 1,27v für die 4GHZ zu haben und da überlege ich eben ob mein gigabyte das auch schafft.
