[Sammelthread] ASUS Maximus V Extreme R.O.G (Z77)
( Preisvergleich | Produktseite | PDF-Manual | Memory-QVL )
--- ASUS Republic of Gamers Microsite ---
--- ASUS Maximus V Extreme R.O.G @ hwbot ---
--- ASUS Australia - Hands On Preview (+ OC-Primer) ---
---> mehr Bilder im User Review
Specifications
CPUIntel Socket 1155 Core i7/i5/i3/Pentium/Celeron processors
Sandy Bridge (32nm) & Ivy Bridge (22nm)
Intel Turbo Boost Technology 2.0
ChipsetIntel Z77
PLX PEX8747
PLX PEX8608
Expansion Slots5x PCIe 2.0/3.0 x16 (at 16, 8+8, 8+8+8 or 8+8+8+8 Lanes)
1x PCIe 2.0 x4
1x Mini-PCIe
Anbindung:
Graphics1) Intel HD Graphics
Multi VGA Output
- HDMI (1920x1200 @ 60Hz)
- DisplayPort (2560x1600 @ 60Hz)
- Thunderbolt (2560x1600 @ 60Hz)
2) Multi Graphics Technology
4-Way NVIDIA SLI technology
4-Way ATI CrossFireX technology
Memory4x DDR3-1066 / 1333 / 1600 / 1866-2000-2133-2200-2400-2600-2666-2800 (OC) Non-ECC U-DIMM
Dual Channel Memory Architecture
Support for Extreme Memory Profile (XMP v1.3) memory modules
ThunderboltIntel DSL3310
Single Channel
6 daisy chainable devies
VGA enabled
AudioRealtek ALC898 HD-Audio Codec
2 / 4 / 5.1 / 7.1 Channel
Support for S/PDIF In/Out
Networking1x Intel 82579V Gigabit-Ethernet (10/100/1000 Mbit)
AzureWave AW-NB111H (802.11a/b/g/n Dual Band WiFi)
Bluetooth V4.0 & V3.0+HS
Storage InterfaceSouth Bridge: 2x SATA 6Gb/s, 4x SATA 3GB/s, RAID 0/1/5/10
ASMedia ASM1064: 4x SATA 6Gb/s
USBChipset: 4x USB 3.0 (2x back, 2x internal)
Chipset: 8x USB 2.0 (4x back, 4x internal)
ASMedia ASM1042: 4x USB 3.0 (2x back, 2x mid)
Internal I/O Connectors2x USB 3.0
2x USB 2.0
6x SATA 6Gb/s
3x SATA 3Gb/s
S/PDIF-Out
Frontpanel Audio (AAFP)
OC Key
2x Subzero Sense
2x VGA Hotwire(s)
Slow Mode
15x ProbeIt measure points
7x ProbeIt cable
3x Thermal Sensor
Power-on button
Reset button
ROG Connect switch
LN2 Mode switch
Go Button
BIOS Switch button
mPCIe Combo header
Fan:
2x CPU (4pin)
3x Chassis (4pin)
3x Optional (4pin)
Power Connector:
24-pin EATX
8-pin ATX 12V
4-pin ATX 12V
6-pin EZ_PLUG
4-pin EZ_PLUG
Back Panel ConnectorsPS/2 keyboard/mouse combo
Thunderbolt
DisplayPort
HDMI
LAN (RJ45)
4x USB 3.0
4x USB 2.0
1x Optical S/PDIF out
1x Optical S/PDIF in
5x Audio
Clear CMOS button(s)
ROG Connect On/ Off
I/O ControllerNuvoton NCT6779D
H/W MonitoringCPU/System fan fail warning
CPU/System fan speed detection
CPU/System fan speed control
CPU overheating warning
System voltage detection
CPU/System temperature detection
BIOS2x 64Mb UEFI AMI BIOS (Cfon EN25F64)
PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a
Multi-Language
Unique FeaturesmPCIe Combo™ (mPCIe/mSATA combo card)
ROG OC Key
- OSD TweakIt
- OSD Monitor
ROG Connect :
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt
Extreme Engine Digi+ II :
- 8 -phase CPU power design + 4 -phase iGPU power design
- 2 -phase Memory power design
ROG Extreme OC kit :
- Subzero Sense
- VGA Hotwire
- Slow Mode
- LN2 Mode
- PCIe x16 Lane Switch
- EZ Plug
ProbeIt
UEFI BIOS features :
- ROG BIOS Print
- GPU.DIMM Post
iROG
Extreme Tweaker
Loadline Calibration
USB BIOS Flashback
Overclocking Protection :
- ASUS C.P.R.(CPU Parameter Recall)
ASUS TurboV EVO :
- TurboV
ASUS EPU :
- EPU
ASUS Wi-Fi GO!
- Wi-Fi GO! Function: DLNA Media Hub, Smart Motion Control, Remote Desktop, Remote Keyboard & Mouse, File Transfer, Capture & Send
ASUS Exclusive Features :
- AI Suite II
- Ai Charger+
- USB Charger+
- USB 3.0 Boost
- Disk Unlocker
ASUS Quiet Thermal Solution :
- ASUS Fan Xpert 2
ASUS EZ DIY :
- ASUS O.C. Profile
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
ASUS Q-Design :
- ASUS Q-Shield
- ASUS Q-Code
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector
Bundle SoftwareKaspersky Anti-Virus
DAEMON Tools Pro Standard
ROG CPU-Z
Mem TweakIt
ASUS AI Suite II
ASUS WebStorage
ASUS Utilities
Form FactorE-ATX Form Factor; 30.5cm x 27.2cm
Lieferumfang
  • Mainboard
  • User's manual
  • I/O Shield
  • 2x SATA 3Gb/s cable(s)
  • 6x SATA 6Gb/s cable(s)
  • 3-Way SLI bridge(s)
  • 4-Way SLI bridge(s)
  • SLI bridge(s)
  • CrossFire cable(s)
  • Q-connector(s) (2 in 1)
  • 2-port USB 2.0 and eSATA module(s)
  • ROG Connect cable(s)
  • ProbeIt cable set(s)
  • 12 in 1 ROG Cable Label(s)
  • mPCIe Combo card(s) with dual band WiFi 802.11 a/b/g/n module + Bluetooth v4.0/3.0+HS module
  • 2-in-1 RF Cable(s)
  • 2x Wi-Fi Ring Moving Antenna(s)
  • OC Key(s)
  • OC Key cable(s)
Schema
BIOS
1) Bilder
2) Spannungen
CPU VCore Offset-0.635 bis +0.635V, in 0.005V Schritten
iGPU Voltage Offset-0.635 bis +0.635V, in 0.005V Schritten
VCCSA Voltage0.800 bis 1.700V, in 0.00625V Schritten
VCCIO Voltage0.900 bis 1.550V, in 0.00625V Schritten
2nd VCCIO Voltage0.400 bis 1.700V, in 0.00625V Schritten
CPU PLL Voltage1.250 bis 2.500V, in 0.00625V Schritten
Skew Driving Voltage0.275 bis 1.600V, in 0.00625V Schritten
PCH 1.05V Voltage0.800 bis 1.600V, in 0.00625V Schritten
VTTDDR Voltage0.625 bis 1.100V, in 0.00625V Schritten
DDR3 Voltage1.200 bis 1.920V, in 0.005V Schritten
Achtung: Beim BIOS Update gehen die gespeicherten OC Profile verloren (diese sind nicht auf/abwärtskompatibel).
3) BIOS Downloads: (ME-Updater v8.1)
4. Unofficial BIOS Downloads (Nutzung auf eigene Gefahr!)
5. Unofficial ME Updates (Nutzung auf eigene Gefahr!)
News & Reviews
Hardwareluxx News: Asus stellt Maximus V Extreme vor
Hardwareluxx News: ASUS gibt Preis und Verfügbarkeit des Maximus V Extreme bekannt
International Reviews
00) Hardwareluxx Review: Test: ASUS Maximus V Extreme
01) Guru3d
02) Overclock3D
03) t-break
04) Hardware.Info (UK)
05) Hartware.net
06) ocaholic
07) Gamezoom
08) McZonk - User Review @ PCGHX
09) Bjorn3d
10) Techpowerup
11) --> bitte weitere Review Links im Thread posten!
Hardwareluxx CPU-Kühler & RAM-Kompatibilitätsliste
1) CPU-Kühler
2) RAM
  • Hersteller | Modell | Preisvergleich | kompatibel | Einschränkungen / Anmerkungen
  • Hersteller | Modell | Preisvergleich | inkompatibel | Grund
  • GeIL | EVO Leggera GEL316GB1866C9DL | 2x8GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-1600C9Q-32GXM | 4x8GB | DDR3-1600 CL9 | Preisvergleich | kompatibel
  • G.Skill | RipJawsX F3-17600CL9D-4GBXLD | 2x4GB | DDR3-2200 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • G.Skill | Sniper F3-1866C10Q-32GSR | 4x8GB | DDR3-1866 CL10 | Preisvergleich | kompatibel
  • G.Skill | TridentX F3-2400C10D-8GTX | 2x4GB | DDR3-2400 CL10 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator GT CMT12GX3M3A2000C9 | 3x4GB | DDR3-2000 CL9 | Preisvergleich | kompatibel (User: emissary42)
  • Corsair | Dominator CMD8GX3M2A1600C8 | 2x4GB | DDR3-1600 CL8 | Preisvergleich | kompatibel
  • Corsair | Dominator CMP16GX3M4X1866C9 | 4x4GB | DDR3-1866 CL9 | Preisvergleich | kompatibel
  • Corsair | Vengeance CMZ32GX3M4X1600C10 | 4x8GB | DDR3-1600 CL10 | Preisvergleich | kompatibel
  • Mushkin | Blackline Ridgeback 998826 | 3x2GB | DDR3-1600 CL6 | Preisvergleich | kompatibel (User: emissary42)
  • Mushkin | Blackline Frostbyte 996829 | 2x2GB | DDR3-2000 CL7 | Preisvergleich | kompatibel (User: emissary42)
  • Kingston | HyperX Genesis KHX2133C11D3K4/16GX | 4x4GB | DDR3-2133 CL11 | Preisvergleich | kompatibel (Review: GameZoom)
  • Kingston | HyperX LoVo KHX1600C9D3LK2-8GX | 2x4GB | DDR3-1600 CL9 1.35v | Preisvergleich | kompatibel (User: emissary42)
  • Samsung | Green MV-3V4G3D | 2x4GB | DDR3L-1600 CL11 | Preisvergleich | kompatibel (User: emissary42)
3) Mainboard
Wer mir die Arbeit abnehmen möchte, kann seinen Eintrag gern direkt in diesem Format posten. Danke.
Nützliche Links (im Forum & im WWW)
INCOMING... Mini-Review?
Zum User Review: Mangels Interesses hier im Thread, habe ich das Vorhaben kurz nach den Aufnahmen und Tests verworfen. Deshalb wird es von mir nicht mehr fertig gestellt.
Vintage Gallery
Mein Testsetup
CPUIntel Core i5-3570K
MainboardASUS Maximus V Extreme R.O.G (BIOS 704)
Memory2x2GB G.Skill RipajwsX F3-17600CL9D-4GBXLD (PSC X)
2x4GB G.Skill F3-14900CL8D-8GBXM (Samsung HCH9)
2x4GB Samsung Green 30nm MV-3V4G3D (Samsung HYK0)
2x2GB Kingston HyperX T1 DDR3-2000 CL8 (KHX2000C8D3T1K2/4GX, Elpida Hyper)
2x2GB GeIL Ultra DDR3-2133 CL9 (GUP34GB2133C9DC, Epida BBSE)
CoolingThermaltake FRIO CL-P0564 (CPU)
230mm Cooler Master (Mainboard-Rückseite)
140mm Corsair AF (Chipsatz)
Power SupplySuper Flower Golden Green 400W (SF-400P14XE)
HDDWestern Digital Raptor 74GB
PeripheryAvocent Switchview DVI
Razer Diamondback
Microsoft Natural Keyboard 4000
SoftwareMicrosoft Windows 7 Pro SP1, aktuelle Treiber
Vergleichswerte
1) AMD FM1 Plattform: AMD A8-3870K, Gigabyte A75-UD4H, 4GB G.Skill RipjawsX @ DDR3-1866 (OC:2200)
2) Intel LGA1366 Plattform: Intel Core i7-980X, Gigabyte X58A-OC, 6GB Kingston HyperX @ DDR3-1333 (OC: 1600)
3) Intel LGA1155 Plattform: Intel Core i5-3570K, ASUS Maximus V Extreme (Z77), 4GB RipjawsX @ DDR3-1600 CL9
4) Intel Pentium G2120 (simuliert): Intel Core i5-3570K @ 3.1Ghz (2c2t), sonst siehe 3)
Benchmarks - synthetisch
Bonus - Memory Overclocking
1) G.Skill RipjawsX F3-17600CL9D-4GBXLD (2x2GB DDR3-2200 CL9-11-9-28, PSC)
DDR3-2500 | CL9-11-9-28-1T | 1.65v | 2x2GB | Screen
2) G.Skill RipjawsX F3-14900CL8D-8GBXM (2x4GB DDR3-1866 CL8-9-9-27, Samsung HCH9)
DDR3-2000 | CL8-9-9-21-1T | 1.575v | 2x4GB | Screen
3) G.Skill ECO F3-12800CL7D-4GBECO (2x2GB DDR3-1600 CL7-8-7-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.637v | 2x2GB | Screen
4) G.Skill Sniper F3-14900CL9D-8GBSR (2x4GB DDR3-1866 CL9-10-9-29, Hynix CFR)
DDR3-2500 | CL11-12-11-26-1T | 1.60v | 2x4GB | Screen
5) Samsung Green MV-3V4G3D (2x4GB DDR3-1600 CL11-11-11-31, HYK0)
DDR3-2400 | CL9-11-11-26-1T | 1.625v | 1x4GB | Screen
6) Mushkin Blackline Ridgeback 998826 (3x2GB DDR3-1600 CL6-8-6-24, PSC)
DDR3-2300 | CL9-11-9-28-1T | 1.650v | 2x2GB | Screen
7) G.Skill TridentX F3-2400C10D-8GTX (2x4GB DDR3-2400 CL10-12-12-31)
DDR3-2200 | 9-10-10-26-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2400 | 10-11-11-26-1T | 1.563v | 2x4GB | emissary42 | Screen
DDR3-2500 | 10-12-12-28-1T | 1.563v | 2x4GB | emissary42 | Screen
8) Kingston HyperX LoVo KHX1600C9D3LK2-8GX (2x4GB DDR3-1600 CL9-9-9-24 1.35v)
DDR3-2133 | 10-12-11-28-1T | 1.500v | 2x4GB | emissary42 | Screen
DDR3-2200 | 10-12-11-28-1T | 1.538v | 2x4GB | emissary42 | Screen
DDR3-2400 | 11-13-12-31-1T | 1.525v | 2x4GB | emissary42 | Screen
9) Mushkin Blackline Frostbyte 996829 (2x2GB DDR3-2000 CL7-10-8-27 1.65v, PSC)
DDR3-2060 | 6-9-6-24 1T | 1.650v | 2x2GB | emissary42 | Screen
DDR3-2284 | 7-10-7-26 1T | 1.650v| 2x2GB | emissary42 | Screen
DDR3-2400 | 8-11-8-28 2T | 1.700v| 2x2GB | emissary42 | Screen
10) Corsair Dominator GT CMT12GX3M3A2000C9 (3x4GB DDR3-2000 CL9-10-9-28 1.65v, Hynix CFR)
DDR3-2600 | 11-13-12-29 1T | 1.650v | 3x4Gb | emissary42 | Screen
DDR3-2666 | 11-13-13-31 1T | 1.650v| 2x4GB | emissary42 | Screen
WORK IN PROGRESS!​
Taucht der Onboard Sound denn im Gerätemanager neben den HDMI Geräten auf?
Kannst du im Windows Mixer die analoge Ausgabe auswählen?
(Screen ist von einem anderen Board)
Und wie sieht es im Gerätemanager aus? Taucht der Onboard Sound dort als Gerät auf?
Wenn nicht, ist der Onboard Sound im BIOS wirklich aktiviert? (siehe Handbuch 3-33)
Die vernickelte Version von dem Kühler liegt bei mir auch noch im Schrank.
Bin am überlegen ob ich den verkaufe oder ob ich mir ein gebrauchtes Board besorge und ihn selbst wieder verwende.
Nein habe ich im Moment noch nicht, aber ich habe schon darüber nachgedacht einen zu schreiben.
Sound macht auf meinem Board auch massive probleme. Ausgabe ist kein Problem, aber Aufnahme. Mikrofon läuft nicht über mic eingang, nur über realtek high definition. Unter win 7 lief alles problemlos. Seit win 8 nicht mehr.
[Edit] Manager hab ich nun, aber mic geht immer noch nicht. vielleicht ich der Anschluss im Axxxxx....
Kram den thread mal wieder raus. Hat schon jemand versucht, Windows 10 zu installieren? Bekomme immer bei 25% nen BSOD und scheine nicht der Einzige zu sein.
Nicht nur versucht sondern installiert, war kein Problem.
Hast Du das neuste bios drauf?
Hast Du Update oder clean installiert?
Ich habe nur ein Problem: das Frontpanel wird nicht mehr erkannt. Wenn ich mein headset einstecke reagiert das board nicht. Wäre blöd, so muss ich immer zwischen Headset und 5.1 hinten am Rechner umstecken.
Denke mal das liegt am Treiber, als ich 10 frisch drauf hatte, war erst gar kein Sound da. Dann habe ich mir den 8.1 Treiber von der Asus homepage gesaugt, jetzt habe ich wenigstens Sound am I/O panel. Hoffe da kommt noch ein Treiber der das behebt.
hat irgendwer Win10 auf dem M5E laufen und kann das empfehlen? Was gibt es so zu beachten?
Danke,
Crav3n
Ja habe ich und kann ich empfehlen. Nach meiner Erfahrung musst Du nichts besonderes beachten - natürlich solltest Du vorher das neuste bios (1903) installiert haben
Du musst aber damit rechnen das manche der Tools nicht mehr laufen werden, der USB3 booster zum Beispiel.
Man kann aber sagen das board läuft echt spitze unter Win10, hat bisher keine Probleme gemacht - und ich bin schon seit release von Win10 dabei.
Hab jetzt erstmal Win7 drauf, bin noch am grübeln ob ich nochmal switche ^^
Ich hab aber noch ein anderes Problem er will nicht mit beiden RAM Blöcken starten, er nimmt nur einen von beiden, HyperX Savage HX324C11SRK2/8 Arbeitsspeicher 8GB (2400MHz, CL11) DDR3-RAM Kit (2x4GB). Er sagt immer kein Speicher installert (Fehler Code 55) wenn ich beide rein stecke, wenn ich nur eins rein stecke startet er ganz normal
-.- irgendwelche Tipps oder brauche ich anderen RAM
Hab jetzt mal mit DRAM Voltage 1.700V gestartet, ergibt auch keine Änderung.
Kann mir denn jemand ein 16GB(2x8GB) RAM Kit empfehlen welches funktioniert, wenn ich meins nicht zum laufen kriege? Die in der QVL finde ich nicht mehr oder haben Sammler Preise. Super wäre was in der Richtung ab 1866MHz und Rot oder Schwarz als Farbe.
Wenn du Stress mit deinem RAM hast, trag die Timings aus dem XMP komplett manuell ein, falls das M5E einen Scheiß auf die Secondaries gibt und statt dessen versucht diese selbst auszuwürfeln...
Das beliebteste noch verfügbare Kit aus der Zeit dürften wohl die F3-2400C10D-16GTX sein.
Falls du noch einen Sandy Bridge Prozessor verwendest, ist allerdings bei DDR3-2133 Schluss. Dann kannst du auch zu F3-2133C9D-16GXH oder F3-2133C9D-16GTX greifen. Preislich sollten sich die Kits alle nichts nehmen.
Ne meine Signatur ist alt, ich habe den PC jetzt umgerüstet auf Asus M5E, i7 3770k, Asus 290X.
Danke für den Tipp! Irgendwelche Tipps, erklärbär Videos, habe RAM noch nie übertaktet oder manuell eingestellt?
Im Startbeitrag sind ein allgemeiner und ein Memory Overclocking Guide verlinkt.
So habs jetzt mit den XMP Werten manuell eingetragen probiert, funktioniert auch nicht -.-
So nach unendlichen Versuchen, ob Bios ob raus und rein stecken, ob andere Slots:
Es funktioniert!
Keine Ahnung woran es nun gelegen hat, seit 24 Stunde laufen die RAMs und zwar so wie angegeben, Corsair Vengeance Pro rot DIMM Kit 16GB, DDR3-2133, CL11-11-11-27
