Das sind meine Bios einstellungen...das meiste ist auf Auto gestellt...
.:AI Tweaker:.
AI Overclock Tuner [Manual]
CPU Ratio Setting [08.5]
FSB Frequency [333]
PCI-E Frequency [100]
FSB Strap to North Bridge [Auto]
DRAM Frequency [1066Mhz]
DRAM Timing Control [Manual]
1st Information : X-X-X-XX-X-XX-X-X
CAS# Latency [5]
DRAM RAS# to CAS# Delay [5]
DRAM RAS# Precharge [5]
DRAM RAS# Activate to Precharge [15]
RAS# to RAS# Delay []
Row Refresh Cycle Time []
Write Recovery Time []
Read to Precharge Time []
2nd Information : X-X-X-X-X-X-X
READ to WRITE Delay (S/D) []
Write to Read Delay (S) []
WRITE to READ Delay (D) []
READ to READ Delay (S) []
READ to READ Delay (D) []
WRITE to WRITE Delay (S) [] <--- alles AUTO
WRITE to WRITE Delay (D) []
3rd Information : XX-X-X-X-X
WRITE to PRE Delay []
READ to PRE Delay []
PRE to PRE Delay []
ALL PRE to ACT Delay []
ALL PRE to REF Delay []
DRAM Static Read Control [Disabled]
DRAM Read Training [Disabled]
MEM. OC Charger [Enabled]
AI Clock Twister [Auto]
AI Transaction Booster [Auto]
******** Please key in numbers directly! ********
CPU Voltage [1,175]
CPU GTL Voltage Reference [Auto]
CPU PLL Voltage [Auto]
FSB Termination Voltage [Auto]
DRAM Voltage [2.0]
NB Voltage [Auto]
NB GTL Reference [Auto]
SBridge Voltage [Auto]
PCIE SATA Voltage [Auto]
Load Line Calibration [Auto]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Performance Mode]
.:Advanced - CPU Configuration:.
C1E Suppport [Enabled]
Max CPUID Value Limit [Disabled]
CPU TM Function [Enabled]
Execute Disable Bit [Enabled]
Intel (R) SpeedStep (TM) Tech [Enabled]
Ist der Vcore nicht einwenig hoch für "nur" 2.8ghz?
ich hoffe ich mach meine cpu damit nicht kaputt
