[Sammelthread] Asus Sabertooth 990fx
Inhalt:
  • Spezifikationen
  • Bilder
  • Bios
  • Review´s / Test´s
  • Downloads
  • Kompatibilität
  • Preis
  • FAQ
Spezifikationen:
CPU
AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
Supports AM3+ 32 nm CPU
Supports CPU up to 8 cores
Supports CPU up to 140 W
AMD Cool 'n' Quiet™ Technology​
Chipset
AMD 990FX/SB950​
AMD 990FX/SB950
Memory
4 x DIMM, Max. 32GB, DDR3 1866/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory
Dual Channel Memory Architecture​
Expansion Slots
3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8) *1
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI​
Storage
AMD SB950 controller :
6 x SATA 6Gb/s port(s), brown
Support Raid 0, 1, 5, 10
JMicron® JMB362 controller :
2 x SATA 3Gb/s port(s), black
1 x Power eSATA 3Gb/s port(s), green
1 x eSATA 3Gb/s port(s), red​
LAN
Realtek® 8111E , 1 x Gigabit LAN Controller(s)​
Audio
Realtek® ALC 892 8-Channel High Definition Audio CODEC
- Supports : Jack-detection, Multi-streaming, Front Panel Jack-retasking
Audio Feature :
- Absolute Pitch 192kHz/ 24-bit True BD Lossless Sound
- Blu-ray audio layer Content Protection
- ASUS Noise Filter
- Optical S/PDIF out port(s) at back panel
IEEE 1394
VIA® 6308P controller
2 x IEEE 1394a port(s)
(1 at mid-board, 1 at back panel)​
USB Ports
ASMedia® USB 3.0 controller :
4 x USB 3.0 port(s) (2 at back panel, blue, 2 at mid-board)
14 x USB 2.0 port(s) (10 at back panel, black+red, 4 at mid-board)​
Special Features
ASUS Dual Intelligent Processors 2 with DIGI+ VRM
TUF ENGINE! Power Design :
- 8 +2 Digital Phase Power Design
- TUF Components (Alloy choke, Cap. & MOSFET; certified by military-standard)
- ASUS DIGI+ VRM Utility
- E.S.P. : Efficient Switching Power Design
Ultimate COOL! Thermal Solution :
- TUF CeraM!X Heatsink Coating Tech.
- TUF Thermal Radar​
ASUS Exclusive Features
- MemOK!
- AI Suite II
- Anti-Surge
- ESD Guards
- Front Panel USB 3.0 Support
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
ASUS EZ DIY :
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 2
- Multi-language BIOS
ASUS Q-Design :
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS Q-Connector​
Back I/O Ports
1 x PS/2 keyboard/mouse combo port(s)
1 x eSATA 3Gb/s
1 x IEEE 1394a
1 x LAN (RJ45) port(s)
2 x USB 3.0
10 x USB 2.0
1 x Optical S/PDIF out
6 x Audio jack(s)​
Internal I/O Ports
1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s) (19-pin, moss green)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
2 x SATA 3Gb/s connector(s)
1 x IEEE 1394a connector(s)
1 x CPU Fan connector(s) (4 -pin)
4 x Chassis Fan connector(s) (3 x 4 -pin, 1 x 3 -pin)
1 x Optional Fan connector(s) (4 -pin)
1 x S/PDIF out header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x MemOK! button(s)
1 x Clear CMOS jumper(s)​
Accessories
User's manual
ASUS Q-Shield
4 x SATA 6Gb/s cable(s)
1 x SLI bridge(s)
1 x Q-connector(s) (2 in 1)
1 x TUF Certification card(s)
1 x TUF 5 Year Warranty manual(s) (by region)​
BIOS
32 Mb Flash ROM, UEFI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS, ASUS EZ Flash 2,​
Manageability
WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
Support Disc Drivers
Anti-virus software (OEM version)
ASUS Update
ASUS Utilities​
Form Factor
ATX Form Factor
12 inch x 9.6 inch ( 30.5 cm x 24.4 cm )​
Bilder:
Bilder von Huddel (nochmals danke)
Bilder von JACK RABBITz
(Quelle: User Huddel, Asus, JACK RABBITz)
Bios:
(0402)
Review´s/Test´s
Deutsch
HWLUXX
hartware.net
pcgameshardware
Tom´s Hardware
Englisch
guru3d.com
hardwarecanucks.com
legitreviews.com
Downloads
ASUS Sabertooth Downloadbereich
Asus FTP-Server derzeit wieder mal offline :-(
Betabios 0607 -Fan ignore Bug gefixed, CPU-Lüfter Monitor lies sich nicht abschalten, dadurch kam eine Fehlermeldung beim Booten
Bios 0705
1. Enhance RAID expansion card compatibility.
2. Enable support for Spanish and Russian Language.
3. Enhance RAID0 performance with SB950 native SATA ports.
4. Enable support for UEFI RAID Driver to support RAID partition above 2.2TB
Bios 0810
Bios 0813
1. Improve memory compatibility
2. Improve system stability
Bios 0901
Probleme mit X6 CPU´s, Board startet nicht mehr!
Bios 1102
1.Improve system stability.
2.Enhance compatibility with some USB devices.
3.Patch system hanged when use AM3 1090T or 1100T CPU.
Bios 1208
Bios 1304
Bios 1503
Kompatibilität
Arbeitsspeicher
-Kingston HyperX 2133Mhz 4x 2GB
-G.Skill Ripjaws-X 8GB Kit
-G.SKILL 8GB Kit DDR3-1600 F3-12800CL8D-8GBECO / 1,35V
inkompatibler Arbeitsspeicher
-2x2GB G.Skill F3-10666CL8D-4GBRM 8-8-8-24 1,5v (kein Boot möglich)
Luftkühlung
-Prolimatech Megahalems (mit Retentionmodul)
Wasserkühlung für Chipsatz
Preis
HWLUXX
FAQ
Asus Supportforum
Ich hoffe das geht erstmal soweit (Ist mein erster Sammelthread :)), ich versuche alles aktuell zu halten, nun her mit den Erfahrungen und Informationen...
Hallo zusammen
Habe auch noch eine späte Frage zu diesem Mainboard mit verbauter Fx-9590 CPU.
Lange Zeit lief mein System in meiner Konstellation einwandfrei.
In letzter Zeit kam es immer wieder mal zum Hängenbleiben des Systems. Bildschirm fror ein, keine Mausbewegung oder Tastatureingabe mehr möglich.
Es half nur noch der Power oder Resetknopf für einen Neustart.
Zu keiner Zeit gab es einen Bluescreen oder eine sonstige Fehlermeldung, und danach lief immer alles wieder einwandfrei.
Vor wenigen Tagen wurde jedoch alles schlagartig dunkel, als ob jemand den Strom abgeschaltet hatte.
Danach war kein Neustart mehr möglich weil sich mein Netzteil verabschiedet hatte.
Bis zu diesem Zeitpunkt hatte ich ein 08/15 Netzteil (Xilence XP750) verbaut.
Ein anderes 700W Netzteil ausgeborgt und probiert. PC startet, jedoch hat sich das Einfrieren des Bildschirms auch damit schon wieder gezeigt.
Deshalb habe ich auch nichts weiter ausprobiert und mir erst einmal ein neues Netzteil bestellt das heute kommen soll.
Ein Corsair RM1000x.
Meine CPU wird durch eine komplett Wasserkühlung gekühlt was bisher immer einwandfrei funktionierte.
Inzwischen habe ich gelesen daß die Spannungsregler oder was auch immer unter den 3 großen Kühlkörpern des Mainboards steckt durch die kompakt Wasserkühlung und dadurch fehlende Zirkulation eines CPU Lüfters u.U. nicht ausreichend gekühlt werden.
Allerdings dachte ich bisher ist ein guter Airflow in meinem Cooler Master HAF 932 Big Tower eigendlich gegeben.
Zumal von der Seite im Gehäusedeckel auch ein 24er Lüfter ständig in richtung Mainboard und folglich auch die Kühlkörper des Mainboards bläst.
Muß ich mir da größere Gedanken machen daß mein Problem vielleicht doch an etwas anderem liegt?
Bisher gehe ich noch von Problemen aus die nur durch das bisherige 08/15 Netzteil ausgelöst wurden.
LG avatar001
Also ich habe dieses Mainboard ebenfalls noch im Einsatz und kann mich nicht beklagen. Habe sogar noch rev. 1.0. Das von Dir beschriebene Problem würde ich auch in Richtung Wärmeentwicklung tippen. Kenne ich so von zu hoch übertaktetem HT-Link & Co.. Ich habe allerdings eine normale Luftkühlung, kann Dir daher leider nicht helfen, ob die klare Tendenz zur Ursache Wasserkühlung vorliegt.
Und dieses Mainboard wird noch immer gebaut und verkauft, aktuell sogar mit NVME-Support in rev 3.0. Die Frage ist daher absolut zeitgemäß ;)
Ich danke dir schon mal für deine schnelle Antwort.
Angenommen die Kühlung der Spannungswandler, bzw. North.- und Southbridge hätte wärend des Betriebs nicht ausgereicht.
Kann dadurch mein altes Netzteil kaputt gegangen sein?
Ist dann zwangsläufig auch das Mainboard mit kaputt gegangen, bzw. erst das Mainboard durch Überhitzung, was dann im Anschluß erst das Netzteil mit zerstört hätte?
Oder muß das nicht unbedingt der Fall sein?
Würde mein PC nur durch Austausch des Netzteils dann überhaupt noch starten wenn diese Teile des Mainboards überhitzt wurden?
Oder ist das Zeichen daß das Board durch Überhitzung zerstört wurde das einfrieren des PC's wie oben beschrieben?
Ich habe hier die erste Revision des Sabertooth 990FX und beim Herumspielen ein kaputtes BIOS geflasht. Damit startet jetzt das System nicht mehr, es laufen nur noch die Lüfter an und auf dem Monitor erscheint links oben ein Cursor, das war's. Die üblichen Sachen wie CMOS Clear, alles außer einem RAM-Modul usw. habe ich schon durch. Leider unterstützt die erste Revision des Boards noch nicht das USB BIOS Flashback-Feature, das wurde wohl erst mit R2.0 eingeführt. Kennt jemand trotzdem eine Möglichkeit, wie ich das Board in diesem Zustand mit dem Original-BIOS flashen kann? :)
Mit einem USB-Stick.und der Flashback-Funktion. Im Handbuch steht mehr dazu.
Hallo in die Runde, entschuldigt bitte, wenn ich so einen uralten Thread wieder ausbuddel.
Nach wie vor bin ich sehr zufrieden mit meinem Sabertooth 990FX (mit AMD FX-8350).
Meine Frage: hat hier jemand 32 GB RAM auf seinem Sabertooth installiert?
Welche RAM-Riegel funktionieren denn für eine 32GB Konfiguration?
Hallo, ja auch sry wegen hochhol...
hab ein "Asus TUF Sabertooth 990FX/GEN3 R2.0" bekommen, das mit PLX Express 3.0 Brückenchip zum Lanes Mogeln.
Konnten die schon mit Extra Karte X4 NVME M.2 Booten, will da was aufsetzen für meinen PC2.
"Hab aktuell ne AquaComputer Kryo M.2 Evo rumliegen und noch eine 970 Evo Plus 1 TB da"
Der PLX gibt ja Lanes dazu, ja die teilen sich dann die Bandbreite über PCIe 2.0 zur CPU usw., aber bindet die Geräte ja erstmal voll an, nicht alles lastet die Bandbreite ja dann aus das es zu einem Flaschenhals kommt.
Ergo müsste es ja im obersten Slot bei 16 Lanes bleiben und in den darunter nicht runterregeln oder, Lese aber was von 16 + 16 + 8, wie ist das wenn man statt einer 16/8er eine 4er nimmt, oder eine Dual-NVME mit 8 Lanes?
Geht da evtl. auch sowas:
LINK EBAY
Man findet kaum Tests oder Erfahrungen zu dem Board, möchte mal schauen, was man da so machen kann, aber mit Windows 10.
Planung meiner Bestückung:
CPU bleibt der letzte K10, der Phenom X6 1100T
RAM 2x 8GB oder 4x 8GB 16/32GB
3.0 - 2.0x16 Red Devil Vega 64
x4 NVME M.2 Karte oder Dual x8
Alt-PCI Creative Audigy 2 ZS
x1 KillerNIC LAN 2100
Gruß:bigok:
Ich habs bei nem rev 1.0 per bios mod hinbekommen. Die späteren konnten es glaube ich schon ab Werk, waren ja die ersten UEFI-Bretter
In meinem aktuell verwendeten "Asus M5A99X Evo R2.0" wird die NVME Karte auch erkannt und kann in Windows, unter 7 auch benutzt werden, zum Booten hab ich aber nichts gefunden, das sie erkannt wird.
Aber nachteilig auch dort regelt er die GPU dann auf x8 runter...
Mir geht es vordergründig ums experimentieren und noch ein Ersatzboard für die Kiste zu haben, aber wollte da nun testweise auch mal auf Win10 umsteigen, wie er mit dem K10 und AM3+ performt.
Booten ging beim Sabertooth auch! Aber bei 1.0 eben nur mit Mod..
So hab das Board erstmal demontiert und soweit gereinigt.
Werde komplett neue Pads drauf machen, wohl auch auf NB/SB und den PLX, wird vermutlich ausreichend sein, die guten von Alphacool.
Problem ist auf dem NB ist richtig harter Kaugummi, habs schon mit Alkohol probiert, bekomme das Zeug nicht runter.
Gruß :bigok:
