[Sammelthread] Clevo Barebone - Upgrade & Modifikationen (alle Modelle)
Hier bitte alles rein zum Thema Grafikkarten Upgrades, Mod-Biose etc bei Clevo Barbones :wink:
...Startbeitrag wird natürlich noch ausgebaut!
HIGH-END-DTR (Desktop CPU)
# 17,3" Clevo P570WMx (Release Q4/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/091. EC firmware 1.02.05 for both P570WM and P570WM3.
2. Solve “sometimes system enters CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update BIOS to 1.02.08 or later version.
4. Please refer to the content of readme_EC.txt to update firmware.
2013/03/091. System BIOS 1.02.08 for P570WM3 only.
2. Solve “sometimes system enter CMOS setup automatically during Windows restart procedure” issue.
3. It is necessary to update EC firmware to version 1.02.05 or later.
4. Please refer to the content of readme.txt to update BIOS.
2013/03/091. System BIOS 1.02.08 for P570WM only.
2013/01/191. System BIOS 1.02.06 for P570WM3 only.
2. Solve “in Windows 8 UEFI the position of S4 resume logo is incorrect” issue.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM3_W8FW.zip
to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme.txt to update firmware.
2013/01/191. System BIOS 1.02.06 for P570WM only.
3. If your machine's BIOS or EC verson is not 1.02.xx then it is necessary to download P570WM_W8FW.zip
2013/01/191. EC firmware for both P570WM and P570WM3.
2. Support AMD HD7970M VGA card.
3. If your machine's BIOS or EC version is not 1.02.xx than it is necessary to download P570WM_W8FW.zip
or P570WM3_W8FW.zip (depends on model) to update EC, BIOS and VBIOS one by one.
4. Please follow the instruction of readme_EC.txt to update firmware.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01 for P570WM3 only.
2. Support Windows 8.
3. It is necessary to update EC firmware first, system BIOS is the second, VBIOS is the last one.
4. Please read the file readme_1st.txt to update firmware correctly, the wrong order will cause
system hangs or no screen symptom.
2012/12/151. System BIOS 1.02.05, EC 1.02.02, GTX680M VBIOS 80.04.67.00.01, GTX670MX VBIOS 80.04.67.00.06 for P570WM only.
2012/12/071. System BIOS 1.00.02 for P570WM3 only.
2. Solve "sometimes LAN can't work properly" issue.
3. Please follow the instruction of readme.txt to update firmware.
2012/12/071. System BIOS 1.00.02 for P570WM only.
LINKS:
[Sammelthread] 17,3" Clevo P570WM(3) SLI/CFX High-End DTR (2012)
# 17,3" Clevo X7200 (Release Q3/2010) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/10/281. VBIOS for nVIDIA Quadro 5010M VGA card.
2. Solve "sometimes screen flickers" issue.
3. Run update.bat in pure DOS environment to update VBIOS.
2011/09/231. EC firmware 1.00.08.
2. Modify fan table.
3. Run update.bat in pure DOS environment to update EC firmware.
2011/07/081. System BIOS 1.00.12.
2. Update RAID ROM to 10.5.0.1034.
2011/06/101. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support GTX580 VGA card.
3. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
2011/05/201. System BIOS 1.00.10.
2. Support nVIDIA Quadro 5010M VGA card.
2011/03/251. System BIOS 1.00.09.
2. Support V4.x M/B.
2011/03/111. AMD HD6970M VBIOS BR39257.008.
2. Solve DVI to D-sub function doesn’t work issue.
3. If there is only one VGA card inside, please run One_card.bat.
4. Run master.bat to flash VBIOS of master VGA card, Run slave.bat to flash VBIOS of slave VGA card.
2011/02/251. System BIOS 1.00.08 and EC firmware 1.00.06.
2. Support AMD Mobility Radeon HD 6970M VGA card.
2010/11/051. System BIOS 1.00.05 and EC firmware 1.00.03.
2. Support nVIDIA Quadro FX3800M VGA card.
2010/10/151. System BIOS 1.00.04 and EC firmware 1.00.02.
2. Support new version M/B.
2010/09/301. System BIOS 1.00.03.
2. Solve "system can't identify nVIDIA GTX 460M VGA card correctly" issue.
LINKS:
[How-to-Video] AMD Radeon HD 7970M CrossFireX Installation in EUROCOM Panther 2.0 (X7200)
# 17,1" Clevo D90xF (Release Q2/2009) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/05/251. System BIOS 1.00.09 and EC firmware 1.00.04.
2. Support nVIDIA GTX 480M VGA card.
2010/03/301. System BIOS 1.00.06.
2. Support nVIDIA Quadro FX3700M VGA card.
2010/01/221. System BIOS 1.00.05.
2. Add “Turbo Boost Enable/Disable” item.
2009/10/161. System BIOS 1.00.03.
2. Support Windows 7.
2009/07/24nVIDIA GTX 280M VBIOS 62.92.91.00.01.
2009/07/241. System BIOS 1.00.02 and EC firmware 1.00.02.
2. Update RAID OPROM.
3. Solve “sometimes system has no display after resuming from Standby mode” issue.
4. Run step1.bat to update EC firmware, run step2.bat to update system BIOS.
LINKS:
[User-Review] 17,1" Clevo D900F Gamer/Workstation Notebook
[How-to-Video] NVIDIA GeForce GTX 680M upgrade in EUROCOM D900F Panther
# 17,1" Clevo D90xC (Release Q2/2007) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2008/12/121. KBC/EC firmware for VISTA keyboard only.
2. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
3. It is necessary to upgrade BIOS to 1.00.22 or later.
2008/12/121. KBC/EC firmware for Windows XP keyboard only.
2008/12/121. Solve “system can’t identify BT device correctly when the BT cable exists” issue.
2. It is necessary to update H8 firmware to 1.00.13/13N or later.
2008/10/201. KBC/EC firmware for VISTA keyboard only.
2. When system working temperature reaches fan on point but the system can’t receive normal
fan speed information, it will alarm for one minute then shut down.
2008/10/201. KBC/EC firmware for XP keyboard only.
2008/10/14Support Q9550 CPU.
2008/09/10Support nVIDIA NB9x series VGA.
2008/07/22Support 9800M GT VGA card.
2008/06/121. KBC/EC firmware for XP keyboard only.
2. Solve "sometimes system can't boot up" issue.
2008/06/121. KBC/EC firmware for VISTA keyboard only.
2008/05/20Solve “system sometimes can’t boot up after installing PCI-Express card” issue.
2008/04/30 1. KBC/EC firmware for VISTA keyboard only.
2. Solve "sometimes system can't identify hard drive" issue.
2008/04/301. KBC/EC firmware for XP keyboard only.
2008/03/21Support both partnet board and daughter board.
2008/03/12Solve "in Windows press Fn+F7 causes system beeps" issue.
2008/03/121. KBC/EC firmware for VISTA keyboard only.
2. Solve VGA temperature probe inaccuracy issue.
2008/03/121. KBC/EC firmware for XP keyboard only.
2008/01/21Solve “install total 2GB memory will cause VISTA hangs up after resuming from standby mode” issue.
2007/12/181. KBC/EC firmware for XP keyboard only.
2. Support nVIDIA GeForce 8800M GTX (BIOS and hardware need to support).
2007/12/18Support nVIDIA GeForce 8800M GTX (KBC/EC firmware and hardware need to support).
2007/11/19Solve “external USB keyboard doesn’t work during POST and CMOS setup” issue.
2007/10/291. KBC/EC firmware for VISTA keyboard only.
2. Add VGA card fan monitor function.
3. Solve "sometimes system can't boot up" issue.
2007/10/291. KBC/EC firmware for Windows XP keyboard only.
2007/10/291. Solve "system stops on POST when the ODD is unavailable" issue.
2. Solve "sometimes system S3 resume doesn't work by Q6700 CPU + RAID enable" issue.
2007/08/231. Solve “system can’t recognize nVIDIA GeForce 8700M GT VGA card” issue.
2. Add VGA card information item in CMOS.
3. Solve “VISTA show incorrect CPU speed” issue.
2007/07/161. Solve "4GB system RAM + single VGA card cause system hangs up on POST" issue.
2. Solve "single VGA + AHCI mode enable cause system can't boot up from HDD/USB dongle" issue.
3. Solve "system hangs up on POST if the Blu-ray or HD-DVD is installed" issue.
LINKS:
[User-Review] CLEVO D901C ...8700GT SLI trifft Quadcore
SLI/CFX GAMER NOTEBOOK (Mobil CPU)
# 17,3" Clevo P370EMx (Release Q3/2012) 01.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2013/03/081. System BIOS 1.02.08 for P370EM3 only.
2. Update ME to 8.1.0.1248.
3. Please refer to the content of readme.txt to update firmware.
2013/01/261. System BIOS 1.02.08 for P370EM only.
2. Support eDP panel.
2013/01/261. K5000M VGA card VBIOS 80.04.67.00.07 for P370EM only.
2. Solve “POST screen flickers” issue.
3. Please refer to the contect of readme_nVBIOS.txt to update firmware.
2013/01/261. GTX670MX VGA card VBIOS 80.04.67.00.06 for P370EM only.
2012/12/151. EC firmware 1.02.09 for both P370EM and P370EM3.
2. Solve sometime can’t pass production line test program issue.
3. It is necessary to follow the instruction of readme_EC.txt to update firmware.
2012/11/241. EC firmware 1.02.08 for both P370EM and P370EM3.
2. Support Windows 7 and Windows 8.
2012/11/241. System BIOS 1.02.06 for P370EM only.
3. Because 1.02.xx version BIOS can't work with 1.00.xx version EC, so it is necessary to make sure
the EC firmware of machine is 1.02.xx, if the EC firmware of machine is 1.00.xx then the system will
not boot up after update 1.02.xx system BIOS.
4. It is necessary to follow the instruction of readme.txt to update system BIOS.
2012/11/241. System BIOS 1.02.06 for P370EM3 only.
2012/10/121. EC firmware 1.00.06 for P370EM only.
2. Solve “sometimes system shows zero battery capacity” issue.
3. Run ecflash.bat in pure DOS environment to update firmware.
2012/09/281. System BIOS 1.00.02.
2. Solve GTX670MX VGA card can't be identified issue.
3. Please follow the instruction of readme_BIOS.txt to update firmware.
LINKS:
[Sammelthread] 17,3" Clevo P370EM(3) SLI/CFX Gamer Notebook (2012)
# 18,4" Clevo P180HM (Release Q3/2011) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/07/061. System BIOS 1.01.04.
2. Solve "system can't identify GTX670M VGA" issue.
3. Run flash.bat in pure DOS environment to update BIOS.
2011/11/181. EC firmware 1.00.05.
2. Modify the timing of LED initiation.
2011/11/041. System BIOS 1.01.03.
2. Support UEFI.
3. Run update.bat in pure DOS environment to update system BIOS.
2011/10/211. System BIOS 1.01.02 and EC firmware 1.00.04.
2. Update CPU micro code.
3. Modify fan table.
2011/10/071. EC firmware 1.00.03.
2. Modify Touch Sensor LED initial control.
LINKS:
# 18,4" Clevo X8100 (Release Q1/2010) 03.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2011/02/251. System BIOS 1.00.14.
2. Correct the VGA card model name in CMOS setup.
2010/10/221. System BIOS 1.00.13.
2. Solve “GTX 460M SLI can’t work properly” issue.
2010/09/101. EC firmware 1.00.08.
2. Modify nVIDIA VGA fan table.
2010/07/151. System BIOS 1.00.11 and EC firmware 1.00.07.
2. Support ATI HD5870 VGA.
2010/05/071. System BIOS 1.00.07 and EC firmware 1.00.04.
2. Solve "system can't identigy i7 940XM CPU correctly" issue.
2010/04/151. System BIOS 1.00.06.
2. Solve “some RAM modules cause no display after system resumes” issue.
2010/03/301. System BIOS 1.00.04 and EC firmware 1.00.02.
2010/02/051. System BIOS 1.00.02.
2. Update code base.
LINKS:
[How-to-Video] NVIDIA GeForce GTX 680M Upgrade in EUROCOM X8100 Leopard
[How-to-Video] AMD Radeon HD 7970M upgrade in 18.4" EUROCOM X8100 Leopard Notebook
17" GAMER NOTEBOOK
# 17,3" Clevo P170EM (Release Q2/2012) 03.05.13
TECHNISCHE DATEN: (Modell C)
BIOS CHANGELOG:
releasechanges
2013/04/151. System BIOS 1.02.17 for P170EM only.
2. Solve “in UEFI mode can’t display CMOS setup screen when the external display is connected to machine” issue.
2013/02/091. System BIOS 1.02.16 for P170EM only.
2. Solve “Fn+F7 can’t work properly in Non-UEFI OS” issue.
2012/10/301. System BIOS 1.02.14 for P170EM only.
2012/10/301. EC firmware 1.02.12 for P170EM only.
3. It is necessary to follow the instruction of readme.txt to update firmware.
2012/10/121. EC firmware 1.00.10 for P170EM only.
2. Solve "power USB port charge function can't work" issue.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmwa
2012/09/281. EC firmware 1.00.09 for P170EM only.
2. Support both old and new matrix keyboards.
3. Follow the instruction of readme_EC.txt to update firmware.
2012/08/311. System BIOS 1.00.10 for P170EM only.
2. Solve sometimes system stops on POST issue.
3. If the BIOS version of machine is 1.00.03 or early, please update to 1.00.04 before executing next step.
4. Refer to the instruction of readme.txt to update BIOS + ME firmware.
5. To downgrade BIOS will cause system can't boot up if the BIOS of machine is version 1.00.07 or later.
2012/08/241. EC firmware 1.00.08 for P170EM only.
2. Add new keyboard matrix.
3. Please refer to the instruction of readme_EC.txt to update firmware.
2012/07/271. System BIOS 1.00.07 for P170EM only.
2. Solve “sometimes no display after system resumes from S4” issue.
2012/07/111. EC firmware 1.00.06 for P170EM.
3. Please follow the instruction of file readme_EC.txt to update firmware.
2012/06/151. System BIOS 1.00.05 for P17xEM only.
2. Solve "system can't identify GTX680M VGA" issue.
3. Update Intel Sandy Bridge Processor microcode.
4. Run update.bat in pure DOS environment to start procedure.
2012/06/081. EC firmware 1.00.05 for P17xEM only.
3. Please read file "Update SOP.txt" to update firmware.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P170EM only.
2. It is necessary to refer to readme.txt to update firmware.
3. Update ME to 1441.
4. Update PXE ROM to 2.46.
5. Enable Intel CPU VT function support.
LINKS:
[Sammelthread] 17,3" Clevo P170EM(3) Gamer Notebook (2012)
# 17,3" Clevo P170HMx (Release Q1/2011) 04.05.13
TECHNISCHE DATEN: (Modell C & D)
BIOS CHANGELOG:
releasechanges
2011/10/281. EC firmware 1.00.09 for both P170HM and P170HM3.
2. Solve “sometimes get incorrect CPU thermal information” issue.
2. Run update.bat in pure DOS environment to update VBIOS.
2011/09/161. EC firmware 1.00.08.
3. Run flash.bat in pure DOS environment to update EC firmware.
2011/09/091. System BIOS 1.01.10 for P170HM only.
2011/09/091. System BIOS 1.01.05 for P17xHM3 only.
2011/08/111. System BIOS 1.01.03 for P17xHM3 only.
2011/08/051. System BIOS for P170HMxx only (except P170HM3).
2011/06/101. System BIOS 1.01.07 for P170HM only.
2. Update Intel RAID ROM to 10.5.0.1034.
2011/05/271. System BIOS 1.01.02 for P170HM3 only.
2. The BIOS password will not be cleared after BIOS update.
2011/05/061. System BIOS 1.01.06 for P170HM only.
2. Add new VGA card identification.
2011/04/221. EC firmware 1.00.05.
2. Solve “enter S4/S5 in DC mode, the Wake on LAN function can’t work after plugging in AC power” issue.
2011/03/181. EC firmware 1.00.03.
2. Solve “sometimes system VGA SMBus detection can’t work properly” issue.
2011/02/251. System BIOS 1.01.02 for P170HM only.
2. Support Intel B3 version chipset.
2011/01/141. System BIOS 1.00.02 and EC firmware 1.00.02 for P170HM only.
2. Solve “sometimes system spends several seconds to boot up” issue.
3. Run step1.bat to update system BIOS, run step2.bat to update EC firmware.
LINKS:
[Prema Mod] P1x0HMx Mod-BIOS
[GUIDE] - Blind-Flashing AMD 7970M modded vBIOS for Clevo P1xxHM Laptops
# 17,3" Clevo W88xCU (Release Q3/2010) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2010/10/081. System BIOS 1.00.05.
2. Solve the audio problem of BIOS 1.00.04.
2010/09/141. System BIOS 1.00.04.
2. Solve "Windows Experience Index is incorrect" issue.
2010/08/061. System BIOS 1.00.03.
2. Solve “system can’t identify Intel K0 stepping CPU” issue.
2010/07/091. EC firmware 1.00.02.
2. Solve "sometimes EC reports incorrect EC version to BIOS" issue.
# 17,3" Clevo W870CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/03/03ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/11/261. EC firmware 1.00.14 for W87xCU only.
2. Solve "sometimes system can't identify i7-940XM CPU" issue.
2010/10/221. EC firmware 1.00.11 for W87xCU only.
2. Solve “under clone mode the GTX 460M/470M VGA cause screen flashes symptom after pressing Silent key” issue.
2010/10/081. System BIOS 1.00.18 for W87xCU only.
2. Solve the audio issue of BIOS 1.00.17.
2010/09/201. System BIOS 1.00.17 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 470M VGA card" issue.
2010/09/171. System BIOS 1.00.15 for W87xCU only.
2. Solve "system can't identify nVIDIA GTX 460M VGA card" issue.
2010/08/201. System BIOS 1.00.14 for W87xCU only.
2. Update Intel CPU micro code table.
2010/06/181. System BIOS 1.00.13 for W87xCU only.
2. Solve “HDMI audio has no function with nVIDIA GTS 360M” issue.
2010/05/21VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/04/301. System BIOS 1.00.12 for W87xCU only.
2. Solve “the CMOS setup screen shows incorrect ATI VBIOS version” issue.
2010/02/251. Sysem BIOS 1.00.10 and EC firmware 1.00.10 for W87xCU only.
2. Base on V4.1 and later version main board to support Arrandale CPU.
2009/12/111. System BIOS 1.00.05 for W87xCU only.
2. Solve system can't show 4GB system memory issue
LINKS:
26.06.10 [User-Review] Clevo W870CU / XMG7.c - bis zu 3,8GHz
15" GAMER NOTEBOOK
# 15,6" Clevo P15xEMx (Release Q2/2012) 04.05.13
TECHNISCHE DATEN: (Modell A & B)
BIOS CHANGELOG:
releasechanges
2013/03/231. System BIOS 1.02.17 for P150EM only.
2013/03/151. System BIOS 1.02.17 for P151EM1 only.
2013/01/191. System BIOS 1.02.16 for P150EM only.
2. Update VBIOS to 2143.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017).
2013/01/191. System BIOS 1.02.16 for P151EM1 only.
3. Update LAN option ROM (Legacy PXE 2.51, UEFI PXE 2017.
2012/10/301. EC firmware 1.02.11 for P151EM1 only.
2012/10/301. System BIOS 1.02.14 for P151EM1 only.
2012/10/301. EC firmware 1.02.11 for P150EM only.
2012/10/301. System BIOS 1.02.14 for P150EM only.
2012/10/121. EC firmware 1.00.09 for P150EM only.
3. It is necessary to refer to the instruction of readme_EC.txt to update firmware.
2012/09/281. EC firmware 1.00.08 for P150EM only.
2012/09/071. System BIOS 1.00.10 for P151EM1 only.
2012/09/071. System BIOS 1.00.10 for P150EM only.
2012/08/311. EC firmware 1.00.07 for P151EM1 only.
2. Support new keyboard matrix.
3. Please follow the instruction of readme_EC.txt to update firmware.
2012/08/241. EC firmware 1.00.07 for P150EM only.
2012/07/121. EC firmware 1.00.05 for P150EM only.
2. Modify VGA fan table.
3. Please follow the instruction of readme_EC.txt to update EC firmware.
2012/06/291. System BIOS 1.00.05 and EC 1.00.05 for P151EM1 only.
2. Update CPU microcode.
4. Please refer to readme_EC.txt before EC firmware update.
5. Run step1.bat in pure DOS environment to update EC firmware, run Step2.bat to update system BIOS.
2012/06/151. System BIOS 1.00.05 for P150EM only.
3. Update Intel Sandy Bridge Processors microcode.
2012/05/111. System BIOS 1.00.04 and EC firmware 1.00.04 for P151EM1 only.
2012/05/041. System BIOS 1.00.04 and EC firmware 1.00.04 for P150EM only.
LINKS:
28.06.12 notebookreview.com = P150EM Upgrading from 675M to 680M!
# 15,6" Clevo P15xHMx (Release Q1/2011) 04.05.13
BIOS CHANGELOG:
releasechanges
2011/11/041. EC firmware 1.00.13.
2. Solve “sometimes screen flickers” issue.
2011/09/161. EC firmware 1.00.12.
2011/09/091. System BIOS 1.01.14.
2. Solve “CMOS Boot Sequence can’t show some USB3.0 devices” issue.
3. Run update.bat in pure DOS evironment to update system BIOS.
2011/08/051. System BIOS 1.01.12.
2011/07/151. EC firmware 1.00.11.
2011/07/011. EC firmware 1.00.10.
2. Support ATI HD6990M VGA card.
2011/05/061. System BIOS 1.01.11 and EC firmware 1.00.07.
2. Support nVIDIA GTX560M VGA.
(need to update LAN driver to 6.0.26.6 or later)
2011/03/251. System BIOS 1.01.06 and EC firmware 1.00.04.
2. Solve F2 and F7 keys no function issue.
3. Modify DMI data.
2011/02/251. System BIOS 1.01.04.
2011/01/141. System BIOS 1.00.03 and EC firmware 1.00.02.
LINKS:
# 15,6" Clevo W860CU (Release Q4/2009) 04.05.13
TECHNISCHE DATEN:
BIOS CHANGELOG:
releasechanges
2012/3/3 ATI Mobility Radeon HD 5870 VGA BIOS TS35951018.
2010/10/29 1. EC firmware 1.00.11 for W86xCU/-3D only.
2010/9/20 1. System BIOS 1.00.18 for W86xCU and W86xCU-3D only.
2010/9/17 1. System BIOS 1.00.16 for W86xCU and W86xCU-3D only.
2010/8/6 1. System BIOS 1.00.15 for W86xCU/W86xCU-3D only.
2. Add Intel K0 stepping CPU micro code.
2010/6/11 1. System BIOS 1.00.14 for W86xCU only.
2. Solve "HDMI audio no function witn nVIDIA GTS 360M VGA card" issue.
2010/5/21 VBIOS 7015440002 for nVIDIA GeForce GTS 360M VGA card only.
2010/4/30 1. System BIOS 1.00.13 for W86xCU only.
2010/2/25 1. Sysem BIOS 1.00.11 and EC firmware 1.00.10 for W86xCU only.
2009/12/11 1. System BIOS for W86xCU only.
2. Solve system can't show 4GB system memory issue.
LINKS:
10.01.11 [How-to-Video] Mount AMD Radeon HD6970M to EUROCOM Cougar Laptop (W860CU)
10.01.11 [Video-Review] EUROCOM W860CU Cougar HD 6970M
08.12.10 [User-Review] 15,6" Clevo W860CU Gamer Notebook
ANHANG
# Clevo Barebone - MXM3.0B Grafikkarten 16.09.12
nVidia GeForce GTX 280M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 285M (G92b/128SP) 1024MB (256Bit/GDDR3) 75W-TDP
_
nVidia GeForce GTX 460M (GF106/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 480M (GF100/352SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 485M (GF104/384SP) 2048MB (256Bit/GDDR5) 100W-TDP
_
nVidia GeForce GTX 560M (GF116/192SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 670M (GF114/336SP) 1536MB (192Bit/GDDR5) 75W-TDP
_
nVidia GeForce GTX 680M (GK104/1344SP) 4096MB (256Bit/GDDR5) 100W-TDP
_
ATI Mobility Radeon HD 5870 (RV840/800SP) 1024MB (128Bit/GDDR5) ~75W-TDP
_
AMD Radeon HD 6970M (RV940/960SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
AMD Radeon HD 7970M (Wimbledon XT/1280SP) 2048MB (256Bit/GDDR5) ~100W-TDP
_
Jopp, da hast du sicherlich recht. Naja, vielleicht kaufe ich mir doch mal ein neues Book, wenn das HM wirklich nicht mehr fix genug zum gamen ist..Aber bis dahin habe ich bestimmt meine Gaming Ambitionen komplett eingestellt, Kind Nummer 2 ist unterwegs und jünger werde ich auch nicht.. Und wenn es wirklich daddeln sein soll und es soll gut laufen, gehts auch mit der PS4 ;)
Ich bin in gewisser Weise schon nen Fan von den großen Konsolen ... anschalten und Gamen am großen TV, ohne "lästige" Einstellungen ... aber mir sind die beiden Konsolen einfach nicht "Next-Gen" genug, ich mach nen weiten Bogen um diese und würde die ~400€ wieder in neue VGA investieren.
Hallo zusammen,
wollte mal fragen was GPU-technisch das maximum (GTX485m und 2670m) für mein Clevo 150HM wäre, ohne das die CPU überfordert wird (genau Ausstattung siehe Signatur, und 8GB Ram sind schon in Arbeit :P).
AMD kommt nur in Frage, wenn es anständige Treiber gibt, die ohne probleme laufen, wobei das ohne Optimus normal kein Problem sein sollte, oder doch?
gruss
AMD 7970m - best bang for the buck ;)
Ansonsten, eben NVIDIA 680M GTX - doppelt so teuer, etwas besser übertaktbar und etwas schneller.. Aber die 7970m reicht dicke aus.. auch für BF4 ;)
Ansonsten folge meinem Sysprofile - einfach auf meine Signatur klicken, da siehst Benchmark Ergebnisse mit OC und eben Gamebenches mit etwas OC oder Standard Taktraten.
Wurde das Problem mit nicht funktionierendem hdmi audio gelöst, bei 150hm+7970m? Das hat anfangs nicht geklappt...
Wenn du eine 7970m der Revision 1.2 bekommst, könnte das ganze funktionieren. Ein paar im NBR als auch hier konnten HDMI zum laufen bringen.. Ich hab es bis heute nicht getestet, brauch es nicht ;)
Naja, hab nun BF4 @ Ultra im SP/MP mit 950/1400 laufen mit 60 FPS - die "alte Krücke" schlägt sich nach wie vor super für einen Kaufpreis komplett für 950 Euro kann ich micht nicht beschweren - hihi..
Hat wer einen Tipp welcher br Brenner was taugt oder sogar den alten sony optisch 5470 über für das p1x0hm? :-)
Hab aktuell den SN-506AB. Hab außer der Marke nichts zu beanstanden.
Samsung - ich mag sie nicht soooo arg, aber wenn er keine Scheiben ruiniert, wäre das eine Idee :)
Was für ein Tape nehm ich am besten für den Alutape Mod?
Ich will den jetzt auch mal ausprobieren :)
Klappt wunderbar, nimm das TESA Alutape aus dem OBI für 6,99!
Hab jetzt auch nochmal bei clevo angefragt. Werd wahrscheinlich eine 7970m bei denen für 240 EUR netto ordern...
Leider antworten die Mitarbeiter immer sehr knapp. Daher kann ich noch nicht in Erfahrung bringen, ob es die REV 1.2 wird.
Brauche ich ein anderes BIOS für den Blindflash der REV 1.2?
Danke + Gruß
es ist eine 4GB Version... aber dann ist das Risiko wohl doch zu hoch die zu kaufen, oder nicht?
Dell Karten sollten nicht im Clevo laufen, andersherum ja. Händler oder privat? Nicht das es eine Clevo Karte mit Alienware VBIOS ist ;)
Ok das risiko ist es mir dann wohl nicht Wert, ist ein privater Verkäufer ;) danke für die Hilfe :)
Kann mir ein p1x0HM Nutzer oder sonstiger Guru sagen, welcher der aktuellste Hotkey Treiber ist, den ich verwenden kann? Aktuell nutze ich noch was mit Version 3.3.xx - gibt es da noch was aktuelleres für das HM? Habe die neuen von der EM/SM Serie nie probiert, werden ja aber wohl nicht gehen, da die Hotkey Treiber ja deep level zugriff haben und meine Büchse ja nicht alles kann, was die neuen Books so können (Tastaur-Beleuchtung etc.)
Danke vorab :>
Danke vorab :>
Findest du hier was? https://www.pro-star.com/index.cfm?mainpage=download
Jo danke - aber eben nur meine Version :d Win7 32/64 (Ver. 3.3028) - scheint wohl keine aktuellere für die Büchse zu geben :)
Bei mir ist der Hotkey Treiber auch regelmäßig abgeschmiert. Nach sauberer Reinstallation hatte ich in den letzten Wochen keine Probleme mehr. Reinstalliert habe ich die gleiche Version wie du :-)
Grüsse
Supi ;)
Soooo, hab mal die Heatsink für das p1xxSM für die 8970M geordert.. Laut T|I Forum soll diese wohl perfekt auf die 7970M passen, nur die Wärmeleitpads sind halt falsch, aber das kann man ja korrigieren. Na dann warten wir mal ab..
Kannst ja mal berichten :-)
BTW: du hast doch auch einen 2920xm drin, nicht wahr? Hast du ein Costumbios von Prema laufen? Oder welche Besonderheiten hast du noch geflasht? :-)
Grüsse
Nee ich hab nur einen 2760qm drin - weil mir das Upgrade rein für das Gaming nicht unbedingt was bringt.
Rein Stock beim Gaming ist der 2760 genauso schnell - mit oc kriegt man ggf 2-7 fps mehr hin, aber das lohnt kaum meiner Meinung nach.. Wenn ich jetzt noch viel Prozessorlastiges machen würde, wäre es ja "sinniger" mit dem XM, rein spielen eher Sinnfrei in meinen Augen.
Supi ;)
Jep, nur bitte achtgeben: die pads langsam abziehen, falls es die von der bestehenden Kühlung sind. Neue sollten im set aber dabei sein. Ziehst du zu schnell, reißen sie oder verkleben mit sich selber. Ich hab schon geflucht deswegen ;-)
Meine aktuellen bei der 7970m sind durch die ganzen Wechsel wegen dem rma auch etwas fertig - daher der Wechsel auf die 8970er kühlgruppe ;-)
Korrekt eine Einheit mit dickeren Heatpipes :-)
Das wird dir gefallen. Ich bin schon gespannt auf die Temps, die du hast. Ich krieg meine 2 8970 nur noch in Extremfällen auf 80-82 grad (ingame Menüs ohne vsync mit 200 fps...und vergessen auf alt-tab). Meistens so zwischen 65 und 75 grad, auch wenn ich auf 975/1520 laufen lasse. Da hatte die 7970 schon oranges Glühen :-)
Also aktuell hab ich PK3 auf der AMD 7970m - max. Temp bei 99% GPU Last in BF4 (alles Ultra ohne MSAA zw. 65 und 120 fps @ 950/1400) => 76 °C ;) in 3DMark11 mit den Settings bleib ich bei 59/60 °C
Ich bin mal gespannt ob die einheit wirklich passt und was sie zu leisten vermag.. Wenn sie wirklich die Temps wie angenommen im TechInferno um ca. 8 Grad drückt, dann werd ich das vBIOS mit 1.05v nutzen und die Karte auf 1000/1400 bzw. 1000/1500 kaufen lassen.. die Temps sollten ja dann kein Problem sein.
Ich berichte sobald das Ding da ist.
