Crysis Demo Benchmark Thread
169.13
AMD X2 6000+EE
2GB Corsair 4-4-4-12
Leadtek 8800GT
CPU:
DX9 1280x1024, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=1, Time Of Day= 9
Global Game Quality: High
Play Time: 46.18s, Average FPS: 32.48
Min FPS: 4.56 at frame 196, Max FPS: 50.55 at frame 118
Average Tri/Sec: 29472468, Tri/Frame: 907444
GPU:
Play Time: 56.67s, Average FPS: 35.29
Min FPS: 24.38 at frame 163, Max FPS: 46.88 at frame 973
Average Tri/Sec: 33652268, Tri/Frame: 953592
kurze frage,weis es nicht einzuschätzen im vergleich zu vista, sind die werte ok? 1280x1024 alles auf high 16q , windows xp 32bit, 8800gts12mb
Naja, AA war ganz ganz sicher nicht an!
1280x1024 DX9 Xp Alle Einstellungen @ High.
die 800core macht die Karte selbst bei diesen Temps nicht mit.
@MiniMe1978
Bilder max. 900px Breite, bitte ändern ;)
Beginning Run #1 on Map-island, Demo-benchmark_gpu
Demo Loops=3, Time Of Day= 9
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 77.15s, Average FPS: 25.92
Min FPS: 3.93 at frame 140, Max FPS: 45.84 at frame 1603
Average Tri/Sec: -24769612, Tri/Frame: -955445
Recorded/Played Tris ratio: -0.96
!TimeDemo Run 1 Finished.
Play Time: 59.02s, Average FPS: 33.89
Min FPS: 3.93 at frame 140, Max FPS: 47.21 at frame 75
Average Tri/Sec: -32344406, Tri/Frame: -954476
!TimeDemo Run 2 Finished.
Play Time: 57.87s, Average FPS: 34.56
Min FPS: 3.93 at frame 140, Max FPS: 47.84 at frame 69
Average Tri/Sec: -32916470, Tri/Frame: -952439
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
21.12.2007 14:42:45 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 3422,5
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Play Time: 81.89s, Average FPS: 24.42
Min FPS: 2.99 at frame 139, Max FPS: 38.83 at frame 989
Average Tri/Sec: -18567748, Tri/Frame: -760234
Recorded/Played Tris ratio: -1.21
Play Time: 67.85s, Average FPS: 29.48
Average Tri/Sec: -22350500, Tri/Frame: -758256
Play Time: 66.61s, Average FPS: 30.02
Average Tri/Sec: -22746970, Tri/Frame: -757603
Completed All Tests
21.12.2007 14:15:10 - XP
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 2975
ich blaub ich brauch nen intel
wow selten so eine turbine gehört
Hab mich am Anfang des Videos auch gefragt wo der Lärm her kommt. :)
Mich würde ja mal brennend ein 1680*1050 / all High / DX10 / 64-Bit /3870 Crossfire run interessieren.
Könnte ich mir vor lauter Langeweile und dem Maximus in der Post gut als Lückenfüller zur Next-Gen vorstellen.
Tim
Hab auch mal gebencht:
Intel C2D E6400@3200Mhz
ATI HD2900XT@900/1000Mhz
Alles High
Kein AA
1440*900
CPU Bench:
GPU Bench:
Wieso haben einige Minuswerte bei triangels per frame???
Irgendwie is bei mir die Performance seit dem 8.1er gesunken. Kann das einer bestätigen?
bye Hübie
@dertimaushh
Also wenn alles glatt geht kann ich morgen mal Crysis testen. 1680x1050 usw.
Vista müsste ich allerdings erst wieder draufhauen, hat mich geärgert und ist runtergeflogen. Hab im Moment nur XP32bit drauf. Mit 2gb RAM ist mir das auch lieber.
bye Hübie
Hab Crysis mit dem 8.1 gebencht, aber vllt kann ichs noch mal mit dem 7.12 benchen.
Edit:
Crysis GPU Bench Vergleich zwischen 8.1 und 7.12
8.1
7.12
Fazit:
Bis auf die Min. FPS nehmen sich die beiden Treiber nichts.
Crysis Demo ohne Config-Tweaks etc.
Core 2 Duo E8400 4205MHz
nVidia 8800GTS 512MB 872/1115MHz
2 x 2GB DDR2 467MHz 5-4-4-15 2T
Forceware 169.38 HQ, keine Optimierungen, 16xAF
Vista 64Bit
Ingame alles auf High u. 1680x1050
CPU
GPU
Kannst du auch nochmal ohne AF testen? Mit dem Sys aus meiner Sig und Ohne AF habe ich im GPU Bench auch genau 31 FPS, also teste doch bitte nochmal ohne AF :d
Hier bitteschön. :)
Vista 64Bit + noAF
XP 32Bit + noAF
Forceware 169.21 HQ, keine Optimierungen, 16xAF
XP Prof. 32Bit
CPU
GPU
Unter XP etwa 5Fps mehr.
Woot? Da hast du mal glatt 10 FPS mehr Average als ich?! Argh. Magst ma ohne Graka OC testen? XP x64 Edition haste nicht am start oder?! :d Aber danke schonmal für die Tests!
DFI LANParty UT P35 T2R
2 GB A-DATA Vitesta Extreme Edition PC2 9600
@ DDR2 1200 @ 5-5-4-9
8800 GT @ 750-1875-1000
Windows XP Pro DX9 @ High
Forceware 169.21
GPU
28.02.2008 17:21:58 - XP
Play Time: 46.75s, Average FPS: 42.78
Min FPS: 32.50 at frame 170, Max FPS: 55.29 at frame 987
Average Tri/Sec: 42108028, Tri/Frame: 984378
Recorded/Played Tris ratio: 0.93
Play Time: 42.18s, Average FPS: 47.42
Min FPS: 32.50 at frame 170, Max FPS: 55.93 at frame 989
Average Tri/Sec: 47207116, Tri/Frame: 995581
Recorded/Played Tris ratio: 0.92
Play Time: 42.15s, Average FPS: 47.45
Min FPS: 32.50 at frame 170, Max FPS: 57.51 at frame 1003
Average Tri/Sec: 47288068, Tri/Frame: 996531
Completed All Tests
27.02.2008 20:13:58 - XP
Run #1- DX9 1280x1024 AA=No AA, 32 bit test, Quality: High ~~ Overall Average FPS: 4743,5
CPU
28.02.2008 17:36:46 - XP
Beginning Run #1 on Map-island, Demo-benchmark_cpu
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
Play Time: 40.05s, Average FPS: 37.45
Min FPS: 10.81 at frame 196, Max FPS: 51.98 at frame 85
Average Tri/Sec: 36555372, Tri/Frame: 975999
Recorded/Played Tris ratio: 0.74
Play Time: 34.57s, Average FPS: 43.39
Min FPS: 10.81 at frame 196, Max FPS: 54.81 at frame 108
Average Tri/Sec: 42456352, Tri/Frame: 978533
Play Time: 34.53s, Average FPS: 43.44
Min FPS: 10.81 at frame 196, Max FPS: 55.64 at frame 115
Average Tri/Sec: 42428896, Tri/Frame: 976696
Completed All Tests
Mein Abschiedsbeitrag bei Luxx:
Eine Sapphire HD 3870 Silent @ 918/1323 (kein Voltmod, Serienkühler),
P4D mit 4160 MHz @ 1,375V (boxed *g*), 2GB DDR2 @ 780MHz (1T,4,4,4,12)
Crysis untweaked in 1280*1024 mit 4xAA, 8xAF & VSync, alles high, XP Pro
CPU: 26,5 avg
GPU: 29,2 avg
ahm, jo, wollte erst was dazu schreiben, aber dann...
Keine Lust mehr, einen Laden zu unterstützen, in dem überdrehte Mods technische Desinformation in die Foren knallen, und sachliche Erwiderungen einfach per Löschknopf entfernen, und unterstützt durch ein paar Proleten mit Flamerei ohne Ende Threads zuzumüllen.
Schade irgendwie, weil 'ne menge guter Threads da sind, die meisten Leute Ok sind, und das Luxx eine Fundgrube an Infos ist. Aber ich lass mich nicht von einem pubertären Hampelmann vorführen, und ich schreib nicht mühsam Erklärungen zur Technik, damit ein affiges Arschloch die löscht, um Fanboygelaber gegen alle Realität abzuschirmen.
Macht euch keinen Kopp, in deutschen Foren ist es seltsam geworden. Man siehst's halt meist nur nicht, weil der allmächtige Löschknopf alle Spuren der durchgeknallten Zensoren tilgt.
Gutes Nächtle noch, ich bin dann weg.
Gut so, einen realitätsverweigernden Fanboy weniger. Sieht man jetzt sogar an seinem Abschiedsbeitrag.
Hm, variieren bei euch die Min FPS so extrem zwischen verschiedenen Durchgängen?
Innerhalb eines Durchgangs (also 1x .bat starten) sind die immer 100% identisch, wenn ich dann das ganze noch mal laufen lasse bekomme ich aber ganz andere Werte. Z.B. habe ich im ersten Durchgang bei jedem Run 17,10 Min FPS, im nächsten dann schon nur 14,XX, in dem danach dann 19,XX.
1280*1024 mit 4xAA, 8xAF/ high/ shadows med., postprocessing med./ XP Pro
c2d E6750 @ 3080MHz/ 2Gig RAM/ PowerColor HD 4850
avg. fps: 40.11, min. fps: 25.47, max. fps: 48.04
lang lang ists her...
von xmas feier wieder da ... und ma crysis bench angehaun..
bekommt ihr mim 18048er auch weniger fps als mit früheren (zb 177er) Treibern unter vista64?
