obs er das mit dem CE durchbringt ist ne andere sache, aber es hört sich stark danach an als ob er das vorhath-h-e schrieb:Wir warten ab . . . wenn er es "richtig" vertreiben will hängt da ganz schön was dran! Habt Ihr ne Ahnung wie lange es dauert bis ein CE - Zeichen genehmigt ist ;-)
Final release will be out soon........First we'll do some beta testing and get a CE (European) certificate so as we can sell it in Europe.......In the mintime we have to get some other certificates for International selling as well so as to sell worldwide......One step at a time.......Europe of caurce will have it first and VERY soon I suppose....Other countrie's users could buy online off caurse via an online European shop and fortunately we have offers for resalers all over Europe.....
Some technical info :
Can produce up to 4.22 Volts and up 2.11 Volts separate each other.....
The - max - 4.22 Volts line can produce 25+ A (actually 29 A)......and 34+ A at 3.6 Volts output......A total of 125 Watts power for this line......
The - max - 2.11 Volts line can produce 18+ A (actually 19 A)......and 22+ A at 1.8 Volts output......A total of 40 Watts power for this line......
They are both short cirquit protected and overvoltage protected....
The mainboard(the one on the photos given above) is also thermal protected by it shelf......
At load of 25 A one line and 6 A the other line , it produces about 52 - 54*C of heat.....We are gonna play with 12 A and 3 A max with 2 x 512MB Ram sticks so you'll encode no problem.....
You can feed with this thing , TWO computers at the SAME time , thas 4 x 512MB Rams sticks......It's capable of giving this watage with "joy" IF your PSU's 5Volts line is strong enough to feed it.....
NOMATTER what PSU you have , you'll get the max 4.22Volts for REAL and NOT maybe 3.7 or 3.8 or 3.9 or 4.0 or 4.1 or we will see......You'll GET them......
The whole box will be a 3.5" bay and it will consists of pure alouminum of 1.5mm fatness which will be the heatsing as well as the masiff aluminum where the transistors and the Mos-Fets are screwed on......
That's for now......and we will continue........
E D I T 1. : The front panel face will be in black and alouminum Lian-Lee colors - anodized......
The PCB's will be black with gold(or something like that) letters and components drawing......
E D I T 2. : The MAX voltage faulse at full load a.k.a. 25 A is 10mVolts......
wirtste aber nicht bekommen :PTobiasAlt schrieb:na mal sehn, ein Testsample würde ja mal reichen
denke ich auch, leider//mAr schrieb:wirtste aber nicht bekommen :P
TobiasAlt schrieb:@Alex
na dann müssen wir wohl noch warten bis es das Ding mal gibt
