[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
G. SKILL F5-6000J3238G-32GX2-TZ5N kann mir einer sagen, ob das Samsung Speicher ist. Auf der Homepage bei Gigabyte gibt es da keine Information.
Lg
Es werden, wie bei den meisten 6000+ Low-CAS Modellen, eher Hynix ICs drauf sein. Sonst schau einfach im Startbeitrag vorbei, dort sind unzählige Reviews mit IC-Angabe verlinkt.
Edit: Es kommt auch gleich noch ein weiteres WWW Roundup.
Hallo zusammen,
ich möchte mir eine neue Workstation zusammenbauen und bin auf eine Problematik beim ddr5 ram gestossen, die mir gar nicht bewusst war. Für einige Anwendungen brauche ich viel Arbeitsspeicher, deshalb habe ich vor 128-256gb zu installieren. Anscheinend fährt aber bei mehr als 2 Riegeln die Geschwindigkeit stark runter. Wird dieses "Problem" evtl. irgendwann gelöst, oder ist das einfach so und man kann es sich eigentlich sparen, schnelleren ram zu kaufen?
Ich warte zwar noch auf die nächste threadripper Generation, würde mir aber evtl. schon dieses Jahr alle anderen Komponenten kaufen. Da gibt es ja jetzt auch expo und xmp für Intel. Ist das wichtig, wenn man nur den angegebenen takt nutzen möchte und nicht übertaktet?
Würde mich über ein paar Infos von euch freuen :)
Guten Abend zusammen,
habe jetzt G.Skill Trident F5-6600 34-40-40-105 auf einem Gigabyte Elite AX Z690 Board mit 13700K installiert. (Sind Hynix Module drauf)
XPM geht schon mal nicht. Habe ein wenig probiert und 6400 MHZ CL36-40-40-105 bootet. Wärt ihr mit solchen werten zufrieden? Oder Mainboard und Ram zurück?
Habe einen Thermalgrizzly Contact Frame verbaut. Schrauben locker angezogen... liegen ggf hier noch ein paar MHZ versteckt?
Grüße und danke!
[Manta] DDR5 | 32GB (Dual) | XSky RGB U-DIMM | Gaming Speicher 6600MHz M-Die Schwarz
Die V-Color-Unterstützung war ausgezeichnet. Ich war besorgt, dass das Kit nicht M-Die sein könnte, denn die Hersteller haben begonnen, ihre neuen Kits mit A-Die zu versehen, die vorher M-Die für dasselbe Kit waren.
Ich möchte unbedingt ein M-Die-Kit für meine 7950x, da ich bereits ein A-Die-Kit von ihnen besitze. M-Die mit 6400MHz SOLLTE bessere Timings haben.
Ich habe den Support kontaktiert und sie sagten, dass sie A-Die- und M-Die-Kits für diesen 6600-MHz-RAM haben. Sie haben das Kit, das sie mir schicken, in HWInfo überprüft und zu 100 % bestätigt, dass es ein M-Die-Kit ist, und mir einen Screenshot von HWInfo geschickt.
Außerdem übertrifft ihr RAM in Online-Bewertungen so gut wie alle anderen.
Ich kann sie nur empfehlen :)
Übersetzt mit www.DeepL.com/Translator (kostenlose Version)
Habe mich nochmal an die Timings gesetzt.
Das war XMP Asus optimized - da bin ich gestartet.
Das kommt mittlerweile raus.
Geht da noch was? Wenn ja wo ? (Team Delta RGB White 32GB DDR5 6400-40) Ja sind 2 unterschiedliche AIDA Versionen, sollte aber nicht zwingend den Unterschied machen. Die 5,7GHZ sind übrigens nicht allcore, nur 4 P Kerne.
Ich will jetzt nicht extra einen neuen Thread aufmachen, deshalb frage ich hier mal nach einer kurzen Kaufberatung.
X670E Taichi (Auf der Website steht 4 x DDR5 DIMMs, supports up to 6600+(OC)), aber das ist vermutlich alles nur Theorie.
7700x (Platzhalter für den 7x00x3d demnächst)
Welchen Ram würdet ihr da empfehlen? 32GB, max 350€. Wenn die Performance über 6000 eh nicht so gut skaliert beim Gaming, wie man das aktuell von allen Seiten mitkriegt, würde ich auch einen günstigeren nehmen. Ich spiele viel Assetto Corsa Competizione, das skaliert zumindest gut mit den x3d Prozessoren.
Ich hätte sonst einfach einen der üblichen DDR5 6000 cl30 genommen mit Expo. Das sollte ja safe laufen und hat eventuell auch noch ein paar Reserven. Mit 250€ auch nicht wirklich teuer.
@Pasn Das ist eine solide Wahl und schon fast so eine Art Standardempfehlung. Die 6000 sollten praktisch immer OOB laufen und Spielraum für OC gäbe es bei Bedarf auch noch.
Hi Leute,
Kann es sein dass DDR5 Speicher bei 1.35v schon zu heiß wird? Und zwar habe ich aktuell die Corsair Vengeance 6000 CL36 drin. Und seit dem ich die 4090FE habe, bekomme ich (nicht reproduzierbar) sehr unregelmäßig aber doch mehr als einmal Abstürze in manchen Games. RDR2 oder Ghost Recon Wildlands beispielsweise.
XMP 1 und 2 funktionieren soweit, also bootet normal, alle Benchmarks laufen durch... Als Temperatur bekomme ich laut SPD so maximal 60°C, wobei man ja laut Igor nochmal 18° draufrechnen sollte. Wäre aber eigentlich immer noch unproblematisch mit knapp 80°C Hotspot.
Nun ist die FE gerade wegen einer Lüfterthematik bei NVidia und ich habe eine PNY 4090 im Rechner. Damit habe ich keinerlei Abstürze mehr.
Warum komme ich darauf? Die FE bläst durch den oberen Lüfter und ihre Abmessungen die heiße Luft direkt auf die vdimms. Die PNY hat alle Lüfter unten und der Cut Through ist auch weiter hinten, so dass nicht direkt auf die RAM Module geblasen wird.
Die eigentliche Frage ist, kann diese Theorie stimmen, oder befinde ich mich damit auf dem Holzweg? Kann ich versuchen, die Module bei 6000 CL36 auch mit 1.25v zu betreiben, oder ist das zum Scheitern verurteilt?
Noch ein anderer Gedanke: In der Kompatibilitätsliste zum Asus Prime-A Z690 tauchen die Vengeance nicht auf. Wohl aber die GSkill F5-6000J3238F16GX2-RS5W, die ich mir mal bestellt habe, weil sie gerade ziemlich günstig sind. Was ist eigentlich schneller, CL36-36-36 oder CL32-38-38?
System siehe links, bis auf die PNY 4090.
Hi Leute,
Wie warm werden denn die Speicher lt. SPD wenn die PNY 4090 beim selben Spiel ihr Werk tut? Und wie sieht der Absturz denn aus? Crash to Desktop oder Shutdown/Reboot?
Danke für Deine Antwort. Also mit der PNY bleiben sie laut OSD so im 50 bis 55° Bereich, mehr habe ich noch nicht gesehen. In beiden Fällen (RDR2 und GR Wildlands) ist es ein Crash to Desktop.
Würde mich etwas wundern wenn die 5 °C zu einem Crash RAM bedingt führen würden. Wenn das nächste mal sowas passieren sollte, Gehäuse aufmachen Irgendwie einen Lüfter vor die RAMS stellen und das selbe Game nochmal spielen. Ist natürlich schwer bei sporadischen abstürzen. MHMHM wo ich Seasonic lese. Ich hatte ein 850er Prime Ultra Titan mit einer RTX 2070 Super nie Probleme, dann gings mit einer 3080 los aber Shutdown / Reboot aus einem Game heraus. Stabi Tests Aida / oder auch 3D mark war aber alles fein. Ging durch undervolten der GPU dann besser. Später bekam ich das Bequiet Dark Power Pro 12 1500W und die Reboots waren weg. Nicht das das Game (Star Wars Squadrons - ist eh ne Diva in Stabilität bei den Grafik Settings) gar nicht abstürzte aber "nur" noch Crash to Desktop ab und an. Habe später gelesen das manche Netzteile ein Problem mit Spannungsspitzen der 3080/3090 haben. Daher lässt mich dein Fall aufhorchen. Muss aber gar nichts bedeuten, die 4090 PNY läuft ja Sahne wie du meintest.
Ja damit bisher noch keine Probleme, toi toi toi. Über die Feiertage hab ich was mehr Zeit, da kann ich das dann Mal über ein zwei Stunden in-game am Stück testen.
Nimm doch mal Karhu Ramtester - das werden die SPD Temperaturen auch gut warm . Würde dann minimum 20 25 minuten laufen lassen. Bei mir werden die dann so knapp 60°C. Wenn dann Fehler auftreten sollte Karhu das auch anzeigen wenn der RAM alleine temperatur bedingt Probs macht .
Hat dieses Kit zufällig jemand im Einsatz?
Patriot VIPER VENOM DIMM Kit 32GB, DDR5-6000, CL36-36-36-76
Sollen Hynix sein (lt. Mydealz usern), mehr hab ich dazu nicht gefunden.
Für mich wirken die super bzgl. price to performance.
Suche grad ein gutes Hynix kit für das Apex.
Hatte mir G.Skill Trident Z5, DDR5-6000, CL36-36-36-96 die laut Z690 Apex QVL Hynix sein sollen (und früher auch angeblich gewesen sind) geholt, im Überaschungsei war dann aber Samsung. :sneaky: Produktionsdatum Dezember 2022.
Ich glaub grad bei den 6000er ist es mittlerweile ein Glücksspiel, ich hab ältere 6000er mit Hynix M, wenn man recht sicher gehen will dann pack etwas Geld drauf und hol dir die 6400er, soweit ich weiß ist da recht sicher Hynix drauf
Hat zufällig jemand folgende Kombination im einsatz und kann berichten ob das funktioniert:
Corsair Vengeance schwarz DIMM Kit 32GB, DDR5-7200, CL34-44-44-96, on-die ECC
CMK32GX5M2X7200C34
mit einem dieser Mainboards:
MSI Pro Z790-A WIFI
GIGABYTE Z790 AORUS Elite AX
ASRock Z790 Steel Legend WiFi
Hi Leute,
So, habe jetzt den GSkill drin, absolut null Unterschied. Lässt sich trotz Hynix noch nicht mal auf 6200 übertakten. (Corsair hat Samsung drauf, der ging wenigstens bis 6200 bench stable) Also eigentlich ist es dann wohl egal welchen ich behalte. Muss nur entscheiden ob mir die LED Bänder auf dem Corsair wirklich gefallen. Der GSkill ist schön dezent.
Ich kann nix zu einem eventuellen Hitzeproblem sagen, aber das die Z690 im puncto RAM OC nicht gut gehen ist doch mittlerweile allgemein bekannt.
Ich kann bestätigen, diese 170€ Viper Sticks sind tatsächlich SK Hynix. Super bang for buck.:-)
ich habe auch die Patriot VIPER VENOM DIMM Kit 32GB, DDR5-6000, CL36-36-36-76 mit SK Hynix
