[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
flach, günstig, A-Dies zum 98% je nach Stock
G.Skill Ripjaws S5 schwarz DIMM Kit 32GB, DDR5-6000, CL32-38-38-96, on-die ECC
F5-6000J3238F16GX2-RS5K
oder als AMD
G.Skill Flare X5 schwarz DIMM Kit 32GB, DDR5-6000, CL32-38-38-96, on-die ECC
F5-6000J3238F16GX2-FX5
minmal höher, minimal günstiger, sollten M-Die sein:
TeamGroup T-Force VULCAN rot DIMM Kit 32GB, DDR5-6000, CL38-38-38-78, on-die ECC
FLRD532G6000HC38ADC01
M-Dies
Kingston FURY Beast DIMM Kit 32GB, DDR5-5600, CL36-38-38, on-die ECC
KF556C36BBEK2-32
laufen auch easy auf >6000
https://www.alternate.de/Corsair/DIMM-32-GB-DDR5-5600-Kit-Arbeitsspeicher/html/product/1806738
Was sagst du zu denen ? :)
ich würde mir keine "alten" Samsung Module mehr kaufen. Die gehen per OC sicher sicher auch auf 6000 aber bei Intel bitte immer SK Hynix ;) laufen einfach besser. Wenn güstig dann die die oben genannten Kingston. Wenn wenig Bock auf OC dann gleich direkt mind. 6000er.
Die hier meinst du ? Kingston FURY Beast DIMM Kit 32GB, DDR5 (gehen wir direkt auf 6000mhz)
Da heute meine greens kommen sollen, landen meine 6000er Beast bald im Marktplatz ;)
wenn du lieber gleich 6000er magst, dann würde ich entweder diese (müssten M-Dies sein) nehmen:
(da kannst sicher 6400 und bisl mehr rausholen)
oder A-Dies für noch mehr Takt (OC, musst Hand anlegen aber da wären sicher >7000 drin)
oder unkompliziert 6400 (auch A-Dies, wenn du jetzt nicht ewig diverse Settings einstellen willst sondern einfach XMP laden und vielleicht Spannungen etwas korrigieren und 2-3 wichtige Settings optimieren und gut)
wichtig, immer diese Kits nehmen, "ähnliche" Kits mit z.b. 36-36-36 haben dann oft andere ICs drauf und dann wird's schwierig oder sie laufen mitunter gerade so innerhalb der Specs.
Bei G.Skill wären aber die Trident-Z mit den gleichen Timings auch immer die gleichen SK Hynix ICs. Ältere 6400er waren M-Dies, sollten mittlerweile aber alle auf die A-Dies umgestellt sein.
Ich hatte im Nov 2021 dieses Kit gekauft: https://www.alternate.de/G-Skill/DIMM-32-GB-DDR5-5600-Kit-Arbeitsspeicher/html/product/1794017
Inzwischen gibt's ja eine deutlich bessere Verfügbarkeit auch von noch schnelleren Kits zu teilweise besserem Preis. Lohnt sich hier perspektivisch ein Umstieg wenn ich nicht gerade auf Benchmark Ergebnisse scharf bin? Vermutlich macht das im Spielebetrieb kaum einen Unterschied wenn ich jetzt z.B. ein 6400er Kit kaufe?
*edit*
Warum ist das Kit von mir immer noch so teuer :fresse: Es gibt doch inzwischen fast gleichwertige für die Hälfte oder übersehe ich was?
Ich bin nicht wirklich fündig geworden und dachte ich frage Euch mal, was haltet Ihr von diesem Speicher Kit:
AX5
U7200C3416G-DCLARWH
ADATA XPG LANCER RGB White Edition DIMM Kit 32GB, DDR5-7200, CL34-46-46, on-die ECC
Der Preis schein"verlcoekend" mit 275,- €
Ich wollte eigendlich den
G. Skill - F5-6800J3445G16GX2-TZ5RK kaufen der liegt bei 250,- €
Wie verhält es sich qualitativ? Die G. Skill sind ja scheinbar recht gut.
Ist für das MB Z790 AORUS Elite AX gedacht, mit einem 13900K.
Ich schwanke für mein AM5 System immer noch zwischen den beiden Modulen. Welches ist empfehlenswerter?
G.Skill Trident Z5 RGB F5-6400J3239G16GX2-TZ5RK & Kingston Fury Renegade KF564C32RSAK2-32
WWW Reviews
Netac Shadow Z RGB NTZCD5P80DP-32S (2).jpeg Netac Shadow Z RGB NTZCD5P80DP-32S (3).png
Ein weiterer Artikel für den Startbeitrag zur Speicherskalierung von Raptor Lake (bis DDR5-7200):
Ich bin nicht wirklich fündig geworden und dachte ich frage Euch mal, was haltet Ihr von diesem Speicher Kit: AX5U7200C3416G-DCLARWH
Der Preis schein"verlcoekend" mit 275,- € Ich wollte eigendlich den G. Skill F5-6800J3445G16GX2-TZ5RK kaufen der liegt bei 250,- €
Ausgehend von den Spezifikationen sollten die ADATA nicht verkehrt sein. Persönliche Erfahrungen mit diesem Kit hab ich jedoch nicht.
Die meisten User würden die von einem Samsung basierten Kit wie diesen Dominator Platinum vermutlich eher abraten. Die Hynix basierten Kits sind beim OC leichter zu handhaben und das DRAM Training der meisten Mainboards ist inzwischen auch besser für diese optimiert. Daher würde man hier eher zu den verlinkten Trident Z5 Neo greifen.
No ne Frage an Euch. Bei mir traf nun der F5-6800J34445G16GX2-TZ5RS ein.In der Kompatibilitätsliste ist jedoch
der F5-6800J34445G16GX2-TZ5RK. Das ist doch so hoffe ich wurst, oder? Sollte ja nur die Farbe sein?!
Ich frage nur, da der Speicher bei mir im BIOS und PC nur mit 4800 Mhz angezeigt wird. Spannung 1,296 Volt,
also Standardeinstellung. Nicht im BIOS veränder, außer das notwendige BIOS Update auf die neuste Version.
Oder ist ds irgendwie dynamisch, da sich die Spannung auch immer verändert. Es ist kein Last vorhanden, alles
unter Win 11.
No question for you. The F5-6800J34445G16GX2-TZ5R S has now arrived for me. However, there is in the compatibility list
the F5-6800J34445G16GX2-TZ5R K. I hope so, isn't it? Should it just be the color?!
I only ask because the memory is only displayed with 4800 Mhz in my BIOS and PC. voltage 1.296 volts ,
so default setting. Do not change anything in the BIOS, except for the necessary BIOS update to the latest version.
Or is it somehow dynamic, since the tension is always changing. There is no load, everything
under Win11.
K is black and S is Silver. Color is the only difference. You need to enable XMP in bios.
Startbeitrag überarbeitet und aufgeräumt. Die OC-Liste ist mangels Beteiligung ganz raus geflogen.
Immer auf der Suche nach etwas günstigerem RAM mit OC Potential hab ich für meinen Bruder zusammen mit einem neuen ASRock B760M PG Riptide (BLCK OC) folgenden RAM bestellt, den S5 hatte ich schon und der X5 war gerade mit verfügbar. Ich tippe auch auf A-Die (kommen heute).
ca. 172€
Edit: doch (wieder?!) M-Die aus Jan/23, da gibt es sowohl als auch, A-Die aus Dez/22 auch schon gesehen
Jetzt habe ich gerade noch einmal geschaut, da ich diese Woche noch einmal RAM bestellen muss, ob bei folgenden M-Dies drauf sind oder schon A-Dies?
Quasi günstigerer geht ja immer, primär muss es kein OC RAM werden aber wenn z.B. 6400-6600 "easy" heraus spängen, wäre das ja nicht verkehrt. Bei Kingston würde ich ab 6400 auch A-Dies vermuten (siehe letztes Review).
150-160€
TeamGroup T-Force VULCAN schwarz DIMM Kit 32GB, DDR5-6000, CL38-38-38-78
Kingston FURY Beast DIMM Kit 32GB, DDR5-6000, CL36-38-38
CL40 und CL36-36-36 klammere ich aktuell immer noch aus, abseits von Kingston Modulen würde ich da immer noch Samsung ICs vermuten.
Ganz günstige M-Dies wären die hier, aber ob die 6400 stabil können weiß ich nicht, bisher keine Kingston Erfahrung.
136€
M-Die nochmals bestätigt: https://www.mydealz.de/deals/cashback-eff-13132-kingston-hynix-m-32gb-2x16gb-ddr5-5600cl40-2117854
Habt ihr vielleicht noch ein paar "Geheimtipps" (die auch sofort lieferbar sind fernab Aliexpress) oder Erfahrung zu den oben genannten Modellen, ob sich da bei aktuellen Batches Bestückung geändert hat?
Ich hab die gekauft (waren für 193€ bei Alternate drin), wie erkenne ich denn ob die A- bzw. M-Dies haben?
Da ich erstmal eh nur das XMP Profil nutze vermutlich irrelevant, aber will es aus Prinzip wissen :d
CPU-Z zeigt das hier an
Bin ja schon froh, dass das 6400er Profil auf meinem Aorus z690 Pro überhaupt problemlos läuft, man hört ja, dass das Board über 6.000 häufig Probleme macht.
Danke, hatte noch im ersten Post geschaut und das wohl gezielt überlesen :rolleyes2:
In meinem Fall sind es A-Dies.
Das haben viele andere vor dir genauso gemacht und damit ist die Auswahl eigentlich auch schon klar:
Ob die Bauhöhe relevant ist, hängt der Kühlung ab. Optik und Beleuchtung sind dann eher eine Frage des persönlichen Geschmacks.
Bei dem Link geht leider Kingston verloren, da die derzeit keine so engen EXPO-Profile anbieten - aber die verbauen grundsätzlich nur Hynix oder Micron (letzteres natürlich nur bei den lower-end Kits), ich habe mir z.B. dieses Kit (KF560C36BBEAK2-32) geholt und ist Hynix (M-Die).
(Mit A-Data habe ich dagegen weniger gute Erfahrungen gemacht, aber das ist ein anderes Thema...)
btw aus Neugier, weiß jemand, worum es sich bei dem Corsair CMH32GX5M2B6000Z30K handelt? Ein scheinbar eng verwandtes Kit ist leider Samsung, daher frage ich mich, ob das evtl. nur ein guter Bin der gleichen Chips ist.
Das wird gern behauptet, war aber weder in der DDR3 oder DDR4 Ära der Fall, noch gilt es für DDR5. Oft basieren solche Aussagen auf Erfahrungswerten mit einer gewissen Sample Size, doch als allgemeingültig sollte man sie deshalb nicht ansehen. Die sehr konservativen Spezifikationen sollen es vermutlich erlauben, die ICs bei Bedarf zu wechseln.
Auf den drei im Startbeitrag verlinkten Reviews waren jeweils H16M verbaut. Er soll generell eine gute Anlaufstelle für solche Informationen sein :hust:
S16B kann man auf solchen Spezifikationen nahezu komplett ausschließen. Es mag mir sehr viel Aufwand zwar möglich sein, sie dafür zu binnen, aber man kann diese Spezifikation einfacher/günstiger (=wirtschaftlicher) mit H16M oder H16A bedienen.
Danke! Ich hatte eh im Startbeitrag geschaut. Aber mit dem ganzen Codenamen (mit K am Ende) findet man da nichts.
Laut einem Reddit User ist die K-Version eine Update dieser Spezifikation. Teilweise soll sogar der Corsair Shop Non-K Kits an Personen verschicken, die eigentlich ein -K gekauft haben. Was auch immer also der Unterschied ist, es spielt für den Nutzer selbst vermutlich keine Rolle. Dazu würde auch passen, dass laut OCUK die EAN identisch ist. Eventuell ist es also schlicht Produktpolitik. Es wundert mich nur etwas, dass ein -K nun für die "grauen" Modelle verwendet wird.
Hey Community,
ich habe ein kleines Problemchen mit meinem Notebook. Der Arbeitsspeicher läuft nur im DDR5-4000 Modus. Ich hatte original 2x 8GB DDR5 Samsung Riegel drin. Diese habe ich durch 2x 16 GB Hynix Riegel getauscht. Mit beiden Kombinationen habe ich das Problem. Ich habe verschiedene BIOS Versionen und Hardresets probiert. Leider hat dies zu keiner Verbesserung geführt. Ich lade hier zwei Screenshots von CPU-Z hoch, damit ihr euch das ansehen könnt. Witzigerweise wird selbst der 4000er Modus nicht 100% JEDEC konform betrieben. Laut JEDEC müsste tRC den Wert 96 haben, eigenstellt ist er wiederum auf 95. Auch beim tRAS sind es 63 statt 64...
Habt ihr irgendwelche sonstigen Tipps? BIOS Batterie abklemmen? BIOS Factory Reset habe ich jedenfalls schon probiert. An den SPeichermodulen selbst kann es ja eigentlich nicht liegen. Komische Geschichte...
Hallo, ich bin es nochmal. Ich würde gerne meinen Speicher mit M DIEs gerne mit Typhoon tweaken. Weiß jemand, ob die orig. Hynix Riegel ein gelocktes SPD haben?
Wenn nicht, welche Timings kann ich bei 4000 anpeilen? Mehr wie 4000 geht leider nicht, doch die Timings dürften sich doch mit den Riegeln ganz gut straffen lassen?!
Du kannst mit Thaiphoon prüfen, ob das flashen mit deinem System möglich wäre. Siehe hier:
Danke, weshalb müssten die SO-DIMM Module per Adapter in ein handelsübliches Mainboard eingebaut werden? Geht das nicht im Laptop selbst?
Das hängt davon ab, ob dein System/Notebook solche Schreibzugriffe zulässt bzw eine entsprechende Option im UEFI vorhanden ist, um diese zu erlauben (oft nicht der Fall).
Möchte gerne meine OC-Timings direkt im Ram als auswählbares Profil abspeichern. Laut Kingston sollte das bei dem Beast DDR5 funktionieren, da ein programmierbarer PMIC verbaut ist. Wie genau mache ich das denn? Im Bios vom Strix B650E-i habe ich keine Funktion dafür gefunden. Wäre über Hilfe dankbar :bigok:
