[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
@bberger
Die Chipbestückung kann sich bei gleicher Kit Bezeichnung mit der Zeit ändern. Die QVL werden nicht wirklich aktualisiert und sind deshalb auch nicht wirklich aussagekräftig. Die Angabe auf dem Sticker ist sehr genau und entsprechende Programme werden dir auch bestätigen, dass auf deinem Kit Hynix verbaut ist.
Mal sehen was der SPD morgen sagt, stutzig machen mich die 1.4V auf dem Kit (und die Sekundärtimings) vs die 1.35V typischerweise bei Hynix M-Die Kits bei 6000C30.
Wirst aber höchstwahrscheinlich Recht haben, ältere Kits waren ziemlich sicher Samsung, das hier dürfte etwas neuer sein.
Hatte es mir eigentlich bestellt um mich ein bisschen mit DR vs SR Benches für meinen Use-Case auseinanderzusetzen. Mal gucken.
Am liebsten wäre mir aktuell aber ein A-Die, DR-Rank Kit, weil vermutlich etwas "universeller" einsetzbar (falls ich doch noch auf nen Raptor-Lake Refresh umsteigen sollte später)
Gibt's da aktuelle, heiße Tipps zu nem brauchbaren Preis?
Er hat recht, steht doch schwarz auf weiß drauf das es mdies sind.
@bberger Kann sein, dass es Müll-M-Die ist. Aber dadurch, dass M-Die sehr sehr wenig streut, kann es gut sein, dass die das draufgepackt haben weil grad nix anderes da war und es ähnlich läuft wie 6000c32/6000c30 M-Die
Heute mit Shoop Cashback bei Galaxus die 5600er Kingston Value 32gb für ~115€
Hallo Leute,
was ist denn wohl dieser RAM VDDP wert? Ist der mit 1.95V correkt?
Es sind Corsair Vengeance RGB 32GB Kit DDR5-6000 CL30 verbaut worden.
Ist eine Versorgungsspannung vom Board für die DIMMs. Daraus macht Dein PMIC dann VDD und VDDQ. 1.95V ist gut. Minimal hoch, 1.8V ist Standard.
danke sehr ... dann versuche ich nochmal dran zu schrauben. :)
Hat hier wer die G.Skill F5-6400J3239G in Verbindung mit einem X670E Steel Legend durchgetestet?
Mich würde interessieren, welche Einstellungen definitiv funktionieren.
Hat jemand ein Link zu diesem hier
DDR5 SK Hynix A-die 32 GB 5600B
Danke für den tip, die Rams im link haben die Endung BA und durften die M-die sein.
Die A-die haben AA und sind die 216A Chips.
Also meine 16GB Sticks haben die Endung BA und sind 230A Chips und es sind Hynix A-Die.
Wenn ich die Pixel Bilder im Link richtig deute sollten es A-Dies sein:
AA/BA hat mi den ICs nichts zu tun, ist eher die Revision
HMCG88AGBUA081N = A-Die, unlocked PMIC - 5600MT/s
HMCG88MEBUA081N = M-Die, unlocked PMIC - 4800MT/s
Weiß jemand ob hier A -Dies drauf sind ?
Oder gibt es dahin gehend noch einen Spezial tip als Speicher.
Können nur A-Dies sein.
Aktuell auf AM5 ist es sowieso irrelevant ob man A-Dies oder M-Dies hat, da der AM5 IMC sein Limit deutlich früher erreicht, als beide vorherig genannten Memory ICs. Wenn Ryzen 8000 den Memory Controller upgraded wie von Zen+ auf Zen2 wird es wahrscheinlich sowieso dann die nächsten DDR5 ICs geben die ggf. wieder deutlich höher gehen.
Naja dann wären mdie ja sinnvoller wenn der takt eh limitiert. Dann kannst du wenigstens strammere Timings fahren.
Das war nicht die Frage .
Ich wollte lediglich wissen ob auf dem von mir verlinkten Speicher A Dies verbaut sind.
Das was mit der 8000ner Serie kommt muss man erstmal noch abwarten jedoch wird man mit solchen Speichern sicherlich auch das Limit erreichen.
Meine M-Dies hab ich aktuell bei 1,425 V bei 6200 CL 30,38,38 42 und Recht scharfen Subs .
Um die 6400 MHz an zu gehen Brauch wie es ausschaut an die 1,475-1,52 V wen ich das so scharf fahren möchte booten kann ich die 6400 ab 1,475 V sind auch kleinere Test möglich mehr V will ich denen aber nicht geben vor allem nicht wen man Prime laufen lassen möchte und so weiter.
Mit den A Dies kannst genauso und strammer bei weniger V .
Das haben hier schon einige aufgezeigt da gibt es auch eine OC Liste und da ist der A Die an der Spitze.
Ich war grade mental im Ryzen DDR5 OC Thread :°)
Aber ja sind ziemlich wahrscheinlich A-Die, wobei ich 100% nicht garantieren würde tbh
Wie @addey schon schrieb sind es A-Die. :)
Das sind meine EXPO Werte
Ist mir komplett neu, das A-dies die gleichen subs schaffen wie mdies oder nach deiner Aussage sogar bessere schaffen.
Doch das klappt schon, dieses AMD setting fahre ich zur Zeit mit meinem 8000er A Die Kit:
