[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5​
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den, von den DDR3 und DDR4 Modellen
bekannten, seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten
statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine
Identifikation der ICs mehr möglich.
Update: Bei neueren Modellen sind auch diese 5 Sternchen nicht mehr vorhanden.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Speed Bin | Die Revision
Micron Part Number Decoder (für IC Codes):
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWiNFO (ab 7.26), Passmark RAMMon (ab 3.0) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
Ich hätte ein Paar Fragen bezüglich XMP und EXPO.
Bei AMD Boards kann man sowohl EXPO als auch XMP Profile laden.
Ist das bei Intel Boards ebenfalls möglich?
Haben EXPO Kits grundsätzlich auch ein XMP Profil?
Ein 8200er Kit von Teamgroup (48GB) ist gelistet:
Dann ist das heute erst dazugekommen, weil als ich geschaut habe waren nur 6 Ergebnisse gelistet :°)
(Drauf klicken, vorausgewählt sind dann 48GB 8200 CL38)
Bei meinem Z690 Tomahawk kann ich das Expo Profil auswählen.
Danke für die Info. Hast du ein EXPO kit?
Ja, das gskill 5600 Cl30
F5-6400J3239F24G
G.Skill 24GB Module 6400 CL32
Werden aber iwie von Taiphoon nicht korrekt ausgelesen...
Code:
Prepared by Thaiphoon Burner Super Blaster
                         MEMORY MODULE
Manufacturer              : G.Skill
Series                    : Not determined
Part Number               : F5-6400J3239F24G
Serial Number             : Undefined
JEDEC DIMM Label          : 32GB 1Rx8 PC5-5600B-UA0-1110-XT
Architecture              : DDR5 SDRAM UDIMM
Speed Grade               : DDR5-5600B
Capacity                  : 32 GB (8 components)
Organization              : Symmetrical 4096M x64 (1 rank)
Register Manufacturer     : N/A
PMIC Model                : Richtek RTQ5132GQWF
Manufacturing Date        : May 22-26 / Week 21, 2023
Manufacturing Location    : Taipei, Taiwan
Revision / Raw Card       : 0000h / A0 (8 layers)
                        DRAM COMPONENTS
Manufacturer              : Hynix
Part Number               : H5CG58?GBDX???
Package                   : Standard Monolithic 82-ball FBGA
Die Density / Count       : 32 Gb  / 1 die
Composition               : 4096Mb x8 (128Mb x8 x 32 banks)
Input Clock Frequency     : 2800 MHz (0.357 ns)
Minimum Timing Delays     : 46-45-45-90-135
Read Latencies Supported  : 50T, 46T, 42T, 40T, 36T, 32T, 30T...
Supply Voltage            : VDD 1.10 V / VDDQ 1.10 V / VPP 1.80 V
EXPO Certified            : Not programmed
Performance XMP           : 3200 MHz / 32-39-39-102-141 / 1.35V
SPD Revision              : 1.1 / September 2022
SPD Extension Revision    : Intel XMP 3.0
                         SPD HUB DEVICE
Manufacturer              : Undefined
Model                     : SPD5118-Y1B000NCG
Revision                  : 0.0 (00h)
Device Type               : SPD0000
Temperature Sensor / Status : Not Incorporated / NA
Temperature Accuracy      : N/A
Temperature Resolution    : N/A
Current Temperature       : N/A
Write Protection          : All Blocks unprotected
Write Protection Override : Blocked
                         RAW SPD DUMP
000  30 11 12 02 05 01 20 62 00 00 00 00 B2 12 0D 00
010  00 00 00 00 65 01 F2 03 7A AD 00 00 00 00 80 3E
020  80 3E 80 3E 00 7D 80 BB 30 75 9A 01 DC 00 BE 00
030  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
040  00 00 00 00 00 00 88 13 08 88 13 08 20 4E 20 10
050  27 10 A4 2C 20 10 27 10 C4 09 04 4C 1D 0C 00 00
060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
070  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0C0  10 00 80 B3 80 21 8A 8C 82 13 00 00 00 00 00 00
0D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0E0  00 00 00 00 00 00 11 01 00 81 00 22 00 00 00 00
0F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
140  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
150  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
180  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
190  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
1F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 1E 5D
200  84 CD 00 23 21 00 00 00 00 46 35 2D 36 34 30 30
210  4A 33 32 33 39 46 32 34 47 20 20 20 20 20 20 20
220  20 20 20 20 20 20 20 00 80 AD 00 00 00 00 00 00
230  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
240  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
250  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
260  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
270  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
280  0C 4A 30 01 00 8A 8C 01 03 11 00 00 00 00 4C 76
290  31 2D 36 34 30 30 43 33 32 20 20 20 20 20 00 00
2A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 A3 41
2C0  30 27 27 00 22 38 01 FE EF 07 00 00 00 00 27 88
2D0  2F 88 2F 50 7C D8 AB 00 75 9A 01 DC 00 BE 00 00
2E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 3D 3E
300  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
310  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
320  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
330  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
340  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
350  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
360  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
370  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
380  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
390  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
3F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
                   SPD HUB REGISTER DUMP
000  00 00 00 00 00 00 00 00 00 00 00 07 00 00 00 00
010  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
020  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
040  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
080  04 00 00 00 23 00 00 00 24 00 00 00 00 00 00 00
090  00 00 00 00 CC D4 52 04 68 A2 4D 04 6C 0C 52 04
0A0  D0 A2 F0 00 54 FB 35 01 5C FB 35 01 D2 38 50 00
0B0  64 FB 35 01 63 39 50 00 5C FB 35 01 00 00 00 00
0C0  D4 28 4D 04 00 00 00 00 08 09 52 04 D0 08 52 04
0D0  84 08 52 04 54 09 52 04 98 CB 51 04 64 CB 51 04
0E0  18 CB 51 04 E4 CB 51 04 E8 CA 51 04 C0 9C 51 04
0F0  C0 9C 51 04 10 C8 51 04 DC C7 51 04 90 C7 51 04
WHinfo findet die Temp Sensoren.
Hallo Leute
Ich habe mir einen Ryzen 7800X3D bestellt und bin jetzt auf der Suche nach Arbeitsspeicher.
Welchen Arbeitsspreicher würdet ihr empfehlen? Auf welche Dies muss ich achten?
Sind 48GB Kits schlechter als 32GB Kits was die Timings und den Takt betrifft bzw. lassen sich diese schlechter übertakten?
Oder haben die 48er Kits sogar die "moderneren" Chips? Von der Kapazität her würden mir 48GB schon eher zusagen als 32GB um auf der sicheren Seite zu sein.
Wo liegt der Sweetspot für Ryzen aus Preist/Leistungssicht ?
Ich plane mir auch Zen5 zu holen, also darf der RAM ruhig auch ein paar Jahre halten/aktuell bleiben.
Eventuell schafft Zen5 ja auch höhere Taktraten beim Speichercontroller aber das werden wir natürlich erst in der Zukunft sehen.
sorry wenn ich hier falsch bin und die frage nicht erlaubt ist. Gibts hier im Forum irgendwo ne Liste von DDR5 Kits, die aktuell zu empfehlen sind? Ich meine bezüglich Preis/Leistung, verbaute Chips usw.
Ich such was schnelles für nen z790 Board und 13900k. Am liebsten gleich 2x32 GB mit schnellem Takt und guten Timings, die auch für einen anfänger ohne OC ambitionen schnell und unkompliziert laufen.
Gibts sowas überhaupt? :)
Hab mir grad die hier gekauft: https://geizhals.at/g-skill-trident...5-6800j3445g32gx2-tz5rk-a2962214.html?hloc=at
Fuern 13700k auf einem Asus Prime Z790-P.
Was soll ich sagen, laufen nicht fehlerfrei mit dem XMP Profil. Kackt beim Karhu Ram Test immer nach ein paar 100% ab.
Aber mit MT 6666 lief ein Karhu Test mit 4000% mal durch. Und das bei getunten Timings: CL32-40-40-52
Hört sich aber abenteuerlich an, 6800er xmp mit adies auf bem 13er und z790 sollten mmn spielend laufen. Ist meines Wissens nach auch bis 7200 angegeben.
Evtl mal Spannungen anpassen, ka was das Teil an Autospannungen anlegt oder mal nen bios Update durchführen falls noch nicht geschehen.
Ne mein System mag keine hohen Ramtakte. Hatte ja vorher das 2x16GB 6800er Kit, und es war auch mit ultralahmen Timings und allem moeglichen Rumprobieren nicht auf 7200 stabil zu bekommen.
6800 lief, sogar mit guten Timings.
Viel mehr als 1-2 Tage nebenher tunen, will ich aber auch nicht an Aufwand reinstecken.
Welchen RAM hast du dir damals gekauft?
Ich bin halt an 48GB Kits interessiert aber da gibts es scheinbar noch nicht viele Erfahrungsberichte.
Dual Ranked (32GB Module) laufen aber schlechter (vereinfacht weil doppelt so viele Chips) als "neue" single ranked 24GB Module mit "auch nur" 8 Chips pro Riegel.
Glaskugel sagt, 48GB Kit würde 6800 schaffen.
Für die 2x32 braucht es ein besseres Board (1DPC) um überhaupt in die Nähe von 7000 zu kommen
Würde es tendenziell Probleme bei der Erstinbetriebnahme des Systems geben wenn ich mir ein 48GB Kit mit beispielsweise 7200 kaufen würde, weil die AM5 Plattform das offiziell nicht unterstützt oder würde das System anfänglich sowieso mit deutlich geringerem Takt booten?
Vor ein paar Monaten hatten AM5 Boards ja wohl noch Probleme mit 48GB Kits aber es gab wohl BIOS Updates für viele (alle?) Boards, welche die Unterstützung für 48GB Kits brachten.
Wäre nur dumm wenn ich jetzt ein Board bestelle, das vielleicht noch ein altes BIOS hat und ich dann nicht booten oder ins BIOS kann weil noch eine alte Version drauf ist. Ohne RAM kommt man ja auch nicht ins BIOS, nehme ich mal an. ^^
Ist es in der Theorie richtig, das ein Board mit nur 2 RAM Slots bessere Timings/Taktraten beim RAM erreicht, selbst wenn das Board zu der günstigeren Sorte gehört?
Wie beispielsweise bei diesem 150 Euro ASUS Board mit 2 RAM Slots?
Alle Boards starten eh erstmal in eine Fail-Safe-Mode wo der RAM mit niedrigen 4800 getaktet wird.
Erst dann musst du EXPO, XMP oder manuell den RAM hochziehen.
Bzgl der 2 RAM Slots soll das beim GENE so sein, allerdings würde ich die Ergebnisse nicht unbedingt auf das verlinkte B650M-K übertragen
Ich glaube seit Fred Feuerstein fahren alles Boards des Planeten mit SPD ab Werk hoch. Einen Ryzen Brecher allerdings in so ein niedliches Brett zu stopfen und dann RAM-OC zu betreiben halte ich nicht für besonders intelligent, außer natürlich man muss mobil sein und hat eine entsprechende Kühllösung parat.
Welches Board würdet ihr denn empfehlen?
Dinge die mir unwichtig sind:
-Anzahl USB
-PCIe5.0 bei GPU
-onboard Sound
-drölftausend SATA Anschlüsse
-bunte LED Lichter
-optik
Vielleicht wird es das Board hier:
Warum findet man im Internet eigentlich nichts zu Gaming oder generell Benchmarks jetzt mit neuem Bios und höheren RAM-Taktungen?
top dann kann ich ja meinen wahrscheinlich RAM mit Samsung Chips beruhigt drinne lassen :d
Ich plane zur Zeit den Kauf eines ASUS ROG Strix X670E-A und weil das nebenher als Backupserver laufen wird, soll ECC RAM drauf. ASUS listet Kingston Server Premier DDR5-4800 als einziges ECC RAM für das Board und bis vor einem Monat war das auch fast das einzige DDR5 ECC DIMM auf dem Markt. Inzwischen gibt's von Kingston auch DDR5-5200 und DDR5-5600 Varianten. Das sollte doch mit hoher Wahrscheinlichkeit auch funktionieren?
gibts hier irgendwo nen Kaufberatungs-Thread zum Thema DDR5? Wenn nicht, darf ich hoffe ich hier nochmal nachfragen und bitte um Empfehlung für ein gutes Kit. Folgende Eckdaten zum geplanten System:
- ASUS ROG Strix Z790-I Gaming WIFI
- Intel Core i9-13900K, 8C+16c/32T, 3.00-5.80GHz
- DDR5 Speicher
Der Speicher sollte 32 GB haben und gute Chips für evtl späteres OC, was ich aber noch nicht sagen kann obs wirklich mal zum OC kommt. Ich such daher lieber etwas teureren Ram, den ich über XMP Profil laden kann und der dann ohne Ärger stabil und schnell läuft.
Folgender RAM steht evtl zur Verfügung, Kumpel will den für Neupreis verkaufen an mich da er bei ddr 4 bleibt
Ansonsten hab ich mal über Preissuchmaschine gesucht und als Laie auf folgende Kits gekommen:
Die 3 Kits sind von unterschiedlichen Herstellern aber von den Spec sehr ähnlich. Sind dann auch die selben Chips verbaut denke ich? Kann man sowas kaufen oder ratet ihr mir mehr auszugeben und was andres zu holen? Wäre super, wenn ihr ein paar empfehlungen für mich hättet, ich kenn mich echt nicht aus mit RAM. Gerne auch aus verschiedenen Preisklassen, ich geb gern mehr aus, wenn es sich lohnt :)
Grobe Faustregel: "Triple-36" (36-36-36 - wie das Kit deines Kumpels) oder "Triple-40" bei DDR5-6000 rum ist Samsung B-Die, die möchte man auf einer Intel-Plattform tendenziell eher nicht wenn man auf Tuningeigenschaften wert legt.
SK Hynix M-Die oder A-Die ist wünschenswert, mit Tendenz zu A-Die bei einem Z790 Board um DDR5-7200 rum anzupeilen (ggf. DDR5-7600, aber das packen auch A-Die die niedriger gebinnt wurden, müsste man sich eben mit der Materie beschäftigen und manuell einstellen). Alle Kits ab DDR5-6800 aufwärts werden SK Hynix A-Die sein, da der Aufwand des Binnings mit M-Die (die 7000 rum schaffen können) für die RAM-Anbieter höher ist als dies mit A-Die zu realisieren. Ergo nutzen sie für diese Kits direkt A-Die. Demnach kannst du von den drei Kits das kaufen das dir am meisten zusagt (RGB oder Non-RGB, Anbieter etc.).
Bei den G.Skill Trident Z5 RGB kann man festhalten das diese durch die Beleuchtung relativ warm werden können, TeamGroup hat die besseren Heatspreader. Ich persönlich würde von den Dreien wohl die Teamgroup nehmen.
wow, das ist doch mal ne Antwort, mit der ich was anfangen kann. Vielen lieben Dank!
Rein interessehalber noch die Frage:
was wäre der nächsthöhere Schritt? Ich möchte später evtl auch noch auf die 14. Gen und 15. Gen von Intel wechseln und dann sollte der RAM von der Geschwindigkeit immer noch top sein. Oder bin ich mit den genannten 7200er Kits auf der sicheren seite?
Dieses Kit hier ist zwar leider Gskill RGB und da hast ja gesagt der Heatspreader ist nicht so gut. Aber lohnt sich der Mehrpreis von knapp 40€ zu den 7200ern?
Oder so ein 48GB kit, auch wenns teuer ist?
Oh die TG 8200er sind schon lieferbar, wusste ich nicht, danke. Will eigentlich auf die neuen Corsair warten, aber da sieht man ja nix, obwohl Juli angegeben wurde.
Das stimmt nicht, tg verbaut einfach nur ein pad auf dem pmic. Deshalb sind die Temperaturen am tempsensor besser. Gskill tut dies nicht.
Bau die gskill runter, pack nen pad drauf und Vergleich dann. Dann weißt du welcher hs besser ist. Werden sich wahrscheinlich alle nichts tun.
