[Sammelthread] DDR5 Info- & Laberthread 2025
DDR5 - Ein Überblick
DDR5 Tests & WWW Reviews
DDR5 Links & weiterführende Informationen
(@even.de)
(@Reous)
  • Preisvergleich: https://geizhals.de/?cat=ramddr3&xf=15903_DDR5
  • DRAM Hersteller:
    - Hynix : DDR5
    - Micron : DDR5
    - Nanya : DDR5
    - Samsung : DDR5
  • JEDEC DDR5 Standard: JESD79-5 (paywalled)
  • Informationen zu den DDR5 Timings und JEDEC Speed Bins: Insights into DDR5 Subtimings and Latencies @ AnandTech
  • Intel Extreme Memory Profile DDR5 Standard: Ver 3.0 (Microsite | XMP 3.0 - Certified Memory List)
  • SPD Fixing (ASUS Method): https://www.overclock.net/threads/corrupted-ddr5-spd-fix-tutorial.1795935/
  • Single vs Dual Rank DDR5 Tested (AMD Ryzen 7 7800X3D & MSI MEG X670E ACE)
    https://www.purepc.pl/test-pamieci-ram-ddr5-single-vs-dual-channel-single-vs-dual-rank-amd-am5
  • OC Guides (general)
    1) https://www.tomshardware.com/how-to/overclock-ddr5-ram
    2) https://www.igorslab.de/wie-ueberta...r-richtig-basic-und-tutorial-fuer-das-ram-oc/ (für DDR4, enthält aber die Basics)
    3) https://github.com/integralfx/MemTestHelper/blob/oc-guide/DDR4 OC Guide.md (für DDR4, enthält aber die Basics)
  • OC Guides (AMD)
    1) https://www.overclock.net/threads/amd-hynix-ddr5-overclocking-guide.1801842/
    2) https://www.igorslab.de/amd-ryzen-7...m-praxistest-mit-benchmarks-und-empfehlungen/
    3) https://skatterbencher.com/2022/09/26/raphael-overclocking-whats-new/
    4) AM5 Memory Performance Scaling @ Techpowerup
  • OC Guides (Intel)
    1) https://skatterbencher.com/2021/11/04/alder-lake-overclocking-whats-new/
    2) https://vintologi.com/threads/ddr5-overclocking-nightmare.1229/
    3) https://www.overclockers.com/ddr5-overclocking-guide/
  • OC Guides (Video)
    1) Intel 13th Gen K series & DDR5 overclocking insights and demos @ ASUS
    2) Finding the timing limits of Samsung DDR5 16Gb B-die at 6400Mbps (Intel) @ AHOC
    3) Finding the limits of Hynix DDR5 at 6666Mbps (Intel) @ AHOC
    4) DDR5-6800 CL34 OC with just 1.45V on the MSI Z690 Unify X @ AHOC
    5) Easy memory timings for Hynix DDR5 with Ryzen 7000 @ AHOC
1) 2x16GB DDR4-4000 CL14 vs 2x16GB DDR6-6000 CL36
2) 2x8GB DDR4-3733 CL17 vs 2x8GB DDR5-5600 CL40 (Patriot Viper Steel vs Patriot Viper Venom)
3) 2x16GB DDR4-3600 CL18 vs 2x16GB DDR5-4800 CL40 vs 2x16GB DDR5-6000 CL36 vs 2x16GB DDR5-7200 CL34 (TeamGroup T-Force Delta RGB FF3D516G7200HC34ABK)
4) 4x8GB DDR4-4000 CL15 vs 2x16GB DDR5-7200 CL34 (G.SKILL Ripjaws V F4-4000C15Q-32GVK vs Trident Z5 RGB F5-7200J3445G16GX2-TZ5RK)
Hardwareluxx: Corsair Dominator Platinum RGB CMT32GX5M2B5200C38-PK1 | G.Skill Ripjaws S5 F5-5200U4040A16GX2-RS5W | Kingston Fury Beast KF552C40BBK2-32 (vs DDR4-3200/4000, Corsair Vengeance CMW32GX4M4C3600C18)
1) Corsair Dominator Platinum RGB CMT32GX5M2B5200C38 (vs Corsair Dominator Platinum RGB DDR4-3600 16-16-16 ???)
2) Corsair Vengeance CMK32GX5M2B5200C38 (vs ADATA XPG Gammix D20 AX4U36008G18A-DCBK20)
3) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs verschiedene Ripjwas V / Trident Z DDR4 in G1/G2)
4) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs Crucial Ballistix Max RGB BLM2K16G44C19U4BL)
5) G.SKILL Trident Z5 RGB F5-6000U3636E16GX2-TZ5RK (vs G.SKILL Trident Z Royal F4-3600C16D-32GTR?)
6) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W (vs G.SKILL Trident Z Royal Elite F4-3600C14D-32GTESA)
7) G.SKILL Ripjaws S5 F5-5200U4040A16GX2-RS5W vs G.SKILL F4-3600C14D-32GTESA @ i2hard.ru
8) Kingston Fury KF552C40BBK2-32 vs G.Skill Trident Z RGB F4-3600C16D-32GTZR @ Guru3d
9) Corsair Vengeance CMK64GX5M2A4400C36 vs Corsair Vengeance LPX CMK32GX4M4K4000C19 - Linux Performance @ Phoronix
10) G.SKILL Trident Z5 F5-6000U4040E16GX2-TZ5S (OC 6200 CL38) vs G.Skill Trident Z Neo F4-4000C16D-32GTZNA(?) @ CapframeX (mit AMD Vergleichswerten für 5900X & DDR4-3733 CL14)
1. Analyse @ TechPowerUp
2. Cooling DDR5 Server Memory with a Corsair Vengeance Airflow @ Phoronix
Die ist eine verkürzte Schreibweise, mit der man sich auf einen bestimmten IC Typ bezieht.
Zusammensetzung (am Beispiel von H16M): DRAM Manufacturer (Hynix) | IC Denisity in Gbit (16Gbit) | Die Revision (M-Die)
Häufig verwendete Kürzel:
M16A - Micron 16Gbit A-Die
H16A - Hynix 16Gbit A-Die
H16M - Hynix 16Gbit M-Die
S16B - Samsung 16Gbit B-Die​
Die Kürzel können auch generationsübergreifend verwendet werden. Dabei wird die DDR-Generation vorangestellt. Beispiele:
4S8B = Samsung 8Gbit B-Die DDR4
4S16B = Samsung 16Gbit B-Die DDR4
5S16B = Samsung 16Gbit B-Die DDR5
CorsairG.SKILL
Ver3.43.01 = Micron 16Gbit A-Die (Q1 | Q2 | Q3)
Ver3.43.02 = Micron 16Gbit ?-Die (Belege gesucht)
Ver3.43.04 = Micron 16Gbit D-Die (Q1)
Ver3.53.02 = Micron 24Gbit B-Die (Q1)
Ver4.43.13 / .02 = Samsung 16Gbit B-Die (Q1 | Q2 | Q3)
Ver4.43.19 = Samsung 16Gbit P-Die (Belege gesucht)
Ver5.33.01 = Hynix 16Gbit A-Die 8Gbit Downbin (laut OC-Test @)
Ver5.43.01 = Hynix 16Gbit A-Die (Q1)
Ver5.43.13 = Hynix 16Gbit M-Die (Q1 | Q2 | Q3)
Ver5.53.13 = Hynix 24Gbit M-Die (Q1)
What integrated circuits ICs are used on my Corsair memory?
Lot Code
-88... = 8Gbit Downbin eines 16Gbit ICs, -8821A entspricht also einem 5H16A Downbin
-S810B = Samsung 16Gbit B-Die (Q1)
-S82*A = Hynix 16Gbit A-Die (Q1)
-S82*M = Hynix 16Gbit M-Die (Q1)
-S83*A = Micron 16Gbit A-Die (Q1)
-R810B = Samsung 24Gbit B-Die (Q1)
-R82*M = Hynix 24Gbit M-Die (Q1)
-R83*A = Micron 24Gbit A-Die
KingstonPatriot
Production Code: ETM[M][08]A2104
H - Hynix
K - Chips wurden relabeled / ICs have been relabeled by Kingston
M - Micron (Spectek)
N - Nanya
S - Samsung
04/08/16 = Anzahl der auf einem Modul verbauten DRAM Chips.
Daraus ergibt sich auch die Organisation:
04 = 1Rx16
08 = 1Rx8
16 = 2Rx8
Nach aktuellem Stand hat sich Patriot offenbar dazu entschieden den seitlichen Produktionscode auf dem Label zu entfernen. Die bisher abgelichteten Kits hatten statt dessen an dieser Stelle alle nur noch fünf Sternchen (*****). Damit ist also an Hand des Labels keine Identifikation der ICs mehr möglich.
CrucialMicron
Zusammensetzung: SKU.Suffix
SKU: CT16G56C46U5 - Part Number des Moduls
( Hier eines von zwei Modulen aus einem Kit vom Typ CT2K16G56C48U5. )
Suffix: .M8G1
M - DRAM Manufacturer: (M)icron, (H)ynix, (K/S)amsung
8 - Anzahl ICs: 4 = 1Rx16, 8 = 1Rx8, 16 = 2Rx8
G - Die Revision: A (Rev A / "A-Die"), G (Rev G / "G-Die")
1 - PCB Revision
Die Speicherdichte lässt sich aus der Kapazität des Moduls und der Anzahl der DRAM Chips ableiten. Ein 16GB Modul in 1Rx8 und ein 32GB Modul in 2Rx8 Organisation sind beispielweise aus 16Gbit ICs produziert.
Speed Bin & Die Revision
Beispiel 1 (32GB UDIMM): MTC20C2085S1EC56BG1R = Rev G (DDR5-5600)
Beispiel 2 (32GB UDIMM): MTC20C2085S1EC48BA1R = Rev A (DDR5-4800)
Beispiel 3 (16GB UDIMM): MTC10C1084S1EC48BA1R = Rev A (DDR5-4800)
Der DRAM Hersteller ist üblicherweise in das SPD programmiert und wird von CPU-Z (SPD Tab) angezeigt. Wenn die Die Revision programmiert ist, kann sie per Software z.B. mit HWinfo (ab 7.26) oder Thaiphoon Burner* ausgelesen werden. Ist sie nicht hinterlegt, wird im entsprechenden Feld je nach Programm nur "0.0" oder "N/A" (not available) angezeigt.
corsair-ddr5-7200-cl34-hwinfo_1920px.png HWInfo64_DRAM_Stepping_7.40.5000 [2].png
*Die Verwendung erfordert unter Windows 11 zur Zeit die temporäre Deaktivierung der Windows Kernisolierung und Speicherintegrität (02/2023).
So, hier noch die versprochene Excel-Tabelle. Einfach den gewünschten Takt eingeben, und die Primarys, dann rechnet es die anderen aus. So mal als Hilfe. Kann auch gerne in den Startpost angepinnt werden.
Download Im Anhang.
Code:
https://www.dropbox.com/scl/fi/tgtf06sufmnwuf833fo53/DDR-5_entry-guide-by-pakhtunov.pdf?rlkey=bvfwi5sj1hy1g0mzsnh1ws20v&dl=0
Das Original ist nicht mehr verfügbar. Eine Übersetzte Fassung gibt es zum Download bei Overclock.net (Link).
Vereinfachte Übertaktungstabelle DDR5 (erste Version):
Hinweise
tCL - beliebig, aus dem Intervall 22 bis 66
tWR - ein Vielfaches von 6, aus dem Intervall 48 bis 96
tRTP - gültige Werte 12, 14, 15, 17, 18, 20, 21, 23, 24
CCDL - beliebig, aus dem Intervall 8 bis 16
CCDLWR - entspricht dem Doppelten von CCDL, ergo nur gerade Zahlen aus dem Intervall 16 bis 32
Micron DDR5 Table.png DDR5_Performance_Preview.png ddr5_micron_infographic.png Intel XMP 3.0 Standard.jpg GSK_DDR5_Lot_Code_RCR.jpg Kingston_DDR5_Lot_Code_RCR.jpg AMD-Roadmap-Leak.jpg Intel Alder Lake Mobile Lineup.jpg PDF Final Intel ISC June 18 Deck for Press Briefing -page-017.jpg JEDEC_DDR5_10.png JEDEC_DDR5_RDIMM_12.png JEDEC_DDR5_09.png
Einige Informationen noch vorläufig. Bitte tagged mich für Korrekturen/Ergänzungen zum Startbeitrag und verlinkt immer auch die originale Quelle. Danke!
  • simpletable2forDDR5.zip
ok, also ohne irgendwelche modifikationen, welcher RAM hat die besseren temps?
Am pmic die tg. Auf den ics sollten beide gleich sein, denn dort sitzt kein tempsensor.
Also vom oc Verhalten ist es komplett latex, denn ics sind bei beiden mit den hs gekühlt.
Also wenn du aufs oc anspielen willst ist es völlig egal. Wenn es dein Gewissen beruhigt, dann die tg. Ist aber unterm Strich völliger Blödsinn.
ok, und diese 48 GB kits sind neu und deshalb teuerer oder auch einfach besser?
Und zu den Mainboards noch was:
Ist es immer noch so, dass RAM in boards mit 2xDimm Slots besser läuft als auf boards mit 4xDimm slots? Also ein Asus ITX Gaming mit 2xdimm vs ein asus z790 mit 4x dimm?
Schaffen meist einfach nur mehr takt. Musst aber dafür ein zwei Timings lockern. Aber daily sicher die bessere Wahl. Dürfte für die meisten das bessere Gesamtpaket bieten, was man so bisher sehen konnte.
Ob es am ende jeden boot stable ist, was man so im Netz sieht, kann ich leider nicht sagen. Bei 2x16gb ist realistisch bei den meisten bei 8000 ende.
Bau die gskill runter, pack nen pad drauf und Vergleich dann. Dann weißt du welcher hs besser ist. Werden sich wahrscheinlich alle nichts tun.
Mag sein. Ich habe G.Skill demontiert, die Heatspreader sind dünnstes Blech. Vielleicht sind die alle so. Aber wie du schon sagst, am Ende ist es auch Wumpe.
Ist bei den tg nicht anders. Die einzigen dicken die ich bisher hatte sind die Hermes.
Sollte am ende aber für die wärmeabgabe auch völlig Wurst sein.
Ohne hs sind sie meist eh Kühler als mit, egal bei welchem Hersteller. Also die hs sind schlussendlich nur Optik.
Einzig und alleine unter ln2 oder mit Wasser gekühlt macht so ein hs Sinn. Oder wie iron schon sagt, bei den domis. Sind glaube ich auch die einzig sinnvollen stock hs.
Göttliche Preise ?
Ka was die kosten, bekommst du meines wissens nach noch nicht in Deutschland. Aber die 6800er laufen echt gut und die Qualität der hs ist auch extrem gut.
Für die meisten hier aber wahrscheinlich eher uninteressant 😅.
Hermes 8400
Göttliche Preise ?
KA wo er seine her hat, die machen sich aber wirklich nicht schlecht auf dem EVGA Z790 DARK.
8400c32 machen sie auch.
Auf dem apex und auf dem tachyon.
Meine sind aus taipei. Hatte 3 Stück, aber eins musste ich an Clemens und eins an luumi abdrücken 🤣.
10-LAYER PCB DESIGN FOR BETTER STABILITY 8-)
ich nochmal :)
geht um folgende Kombination:
hab im UEFI keine möglichkeit gefunden den RAM per XMP Profil zu betreiben. Er zeigt nur dieses mir noch unbekannte "EXPO" Profil an. Wenn ich dies aber aktiviere startet der PC nicht mehr, bzw es kommt die Meldung dass RAM OC fehlgeschlagen ist.
Liegt das an dem RAM Kit, weil das nur für AMD gedacht ist? Was kann ich machen, damit der RAM auf seinen 6000 Mhz und den entsprechenden Timings läuft?
Wenn man den RAM manuell einstellt, sollte es denke ich gehen. Nur bin ich bzw. mein Kumpel (dem gehört das Zeug) nicht so fit darin. Welche Werte müsste man im UEFI alles anpassen, damits läuft?
- DRAM Spannung auf 1,35V
- DRAM Takt auf 6000 Mhz
- sonst noch spannungen anpassen? Wenn ja, welche?
Gibt es auf Deinem Mainboard vom Hersteller voreingestellte Profile? Die könnte man ggfs. laden. Die Timings manuell einstellen geht sicher aber wird Zeit und Wissen erfordern. Denke am einfachsten ist es, Dir XMP Ram zu besorgen und den RAM entweder zurückzugeben oder zu verkaufen.
Hat wer schon Infos zu den neuen Corsair Titanium? Ich warte seit Ankündigung auf Die aber bisher nichts gesehen, außer den Infos auf der Page. Überlege die Viper oder TG 8200er zu holen aber würde gern die Corsair haben, jedoch nicht Ewigkeiten warten und dann gibt es nur 10 Kits, die sofort ausverkauft sind und man wieder 2-3 Monate warten muss (war bei den 7600ern damals auch so :().
Okay heißt es also man kann bei diesem RAM kein XMP Profil laden weil es für AMD gemacht ist?
Schau mal in die QVL des Mainboards, wenn der RAM da aufgeführt wird klappt es evtl., kommt auf den Hersteller und das Mainboard an.
ich nochmal :)
neustes Bios ist drauf?
event. klappt ja dann das EXPO Profil, neuere Intel Boards mit aktuellem Bios unterstützen in der Regel auch EXPO anstatt XMP.
Hallo Zusammen,
ich brauche mal kurz eure Kompetenz. Ich hab hier meinen neuen RAM liegen, der soll auf ein Asus X670E-A zusammen mit einem 7950x3d seinen Dienst verreichten.
Da die CPU noch nicht da ist kann ich natürlich nicht genau sehen was für Chips verbaut sind. Aber ich bin mir sicher, dass ihr mir da bestimmt helfen könnt. Bei dem Ram handelt es sich umer G.Skill F5-6400J3239F48GX2-TZ5RW und über der SNr. steht 0T64KXR820M.
Also welche Chips sind verbaut?
Und wenn Ihr erlaubt, welche CL kann ich im 6000er Betrieb damit fahren, wenn ich nicht in der Silikon Lotterie gewonnen habe und das XMP Profil nicht läuft?
Vielen Dank für eure hilfe.
Timmey
Informationen dazu findest du im Startbeitrag.
Und wenn Ihr erlaubt, welche CL kann ich im 6000er Betrieb damit fahren...?
CL28 sollten kein Problem sein. Das ist genau genommen nur eine Frage der Spannung.
Ein solches 6400er XMP läuft auf AM5 so gut wie nie OOB. Wenn du PnP wolltest, hättest du dich an die üblichen Empfehlungen oder den G.SKILL Configurator halten sollen.
Danke, man ersetze das * durch eine 0 und es wird ein R820M. Ich bin einfach zu blind.
Wie meinst du das? Ich möchte ungern über 1,35V gehen. Und welche Subtimings sind das denn? Hab mich damit noch nicht so richtig beschäftigt, bis jetzt.
Das habe ich schon rausgefunden, aber vllt. hift ja das neue AGESA etwas^^ Wobei mir auch 6000 mit guten Timings reichen würde.
Hier mal ein paar Eindrücke:
Gskill X5 6000CL32 M-Die - CL28 mit max 1,375V nicht möglich
Gskill S5 6600CL34 A-Die - CL28 mit max 1,35V nicht möglich
Gskill S5 6800CL34 A-Die - CL28 mit 1,35V möglich
Alle Kits waren/sind 32GB
Das ist natürlich jetzt keine Garantie das auch sämtliche Kits bei - für mich vertretbaren - mit max 1,35V bei CL28 laufen, aber so war es bei den Kits welche ich ausprobiert hatte 🙃
Mit möglich meine ich 24h Prime large FFT allcore bestanden 😇
Ich habe schon sehr lange gesucht bevor ich jetzt hier schreibe.
Gibt es irgendwo einen DRAM-TYP-Schlüssel für die Kingstom RAM?
Die Frage ist, welcher DRAM-Typ ist verbaut. Vermutlich Hynix-M
Ich habe KF556C36BBEK2-64
(Kingston FURY Beast Black EXPO DDR5 64GB (2x32GB) 5600MT/s DDR5 CL36 DIMM Desktop Gaming Speicher Kit mit 2)
Kingston kann nicht mal selbst den Buchstaben K am Schluss aufschlüssen von KF556C36BBEK2-64
Ich habe gestern einen Link von Kingston gefunden für die Aufschlüsselung von KF556C36BBEK2-64 ... das übliche DDR5 - 5600Mt/s usw.
Seite 1, Aufkleber anschauen
Spoiler: IC Identifizierung: Corsair, Crucial, G.SKILL, Kingston, Micron & Patriot
Aber nur der Hersteller ablesbar...
Ansonsten hwinfo könnte es event. sogar per Software auslesen.
Generelle Frage: Wählt ihr die Riegel stets nach QVL des Mainboardherstellers aus oder nach den Chips?
