[Sammelthread] Dell Studio XPS 1340 & Studio XPS 1640
Engadget
In all-too-familiar fashion, Dell's new Studio XPS laptops have snuck onto the company's store with nary a press release to keep them company. The 1340 is obviously the Studio XPS 13 we saw last month, while the 1640 is naturally the 16-inch version of the leather accented system. Both machines are (oddly) hitting at the same $1,199 pricepoint, with Core 2 Duo processors and the typical smorgasbord of options. The base model of the 1340 includes a P8400 processor, Vista Home Premium, a 13.3-inch WXGA LCD, 2 megapixel webcam, 4GB of DDR3 SDRAM, 320GB 7200rpm SATA drive, slot-loading DVD burner and NVIDIA GeForce 9400M G graphics, while the 1640 is similar, but with ATI Mobility RADEON M86XT graphics.
http://www.engadget.com/2009/01/07/dells-studio-xps-1340-and-studio-xps-1640-sneak-onto-the-scene/
via NotebookReview.com
http://forum.notebookreview.com/showthread.php?t=339394&page=65
Studio XPS 1340
http://configure.us.dell.com/dellst...&oc=DYDEGF3&s=dhs&dgc=EM&cid=39422&lid=997565
Deutsche Links:
http://www1.euro.dell.com/content/p...dio-xps-13?c=de&cs=dedhs1&l=de&ref=lthp&s=dhs
Notebookcheck Dell Studio XPS 13 Test
http://www.notebookcheck.com/Test-Dell-Studio-XPS-13-Notebook.14075.0.html
Notebookjournal Dell Studio XPS 13 Test
http://www.notebookjournal.de/tests/notebook-test-dell-studio-xps-13-791
Studio XPS 1640
http://configure.us.dell.com/dellst...&oc=DYDEFF3&s=dhs&dgc=EM&cid=39422&lid=997564
Deutsche Links:
http://www1.euro.dell.com/content/p...aptop-studio-xps-16?c=de&cs=dedhs1&l=de&s=dhs
Notebookreview Studio XPS 16 Test:
http://www.notebookreview.com/default.asp?newsID=4764
Notebookcheck Dell Studio XPS 16 Test
http://www.notebookcheck.com/Test-Dell-Studio-XPS-16-Notebook.14412.0.html
Notebookjournal Studio XPS 16 Test
http://www.notebookjournal.de/tests/test-dell-studio-xps-1640-790
Notebookjournal Studio XPS 16 Lesertest
http://www.notebookjournal.de/tests/test-dell-studio-xps-16-804
Benchmarkwerte des Studio XPS 16
http://www.forumdeluxx.de/forum/showpost.php?p=11340472&postcount=253
Heise: Multimedia-Notebook Dell Studio XPS 16 mit farbkräftigem Display
Test 20.08.2009 http://www.heise.de/mobil/artikel/Dell-Studio-XPS-16-mit-farbkraeftigem-Display-222545.html
Notebookjournal: Studio XPS 16 wird zum heißen Gamer
Test 28.08.2009 http://www.notebookjournal.de/tests/review-dell-studio-xps-16-ati-4670-976/
Notebookcheck: Dell Studio XPS 16 (ATI HD4670)
Test 05/10/09 http://www.notebookcheck.com/Test-Dell-Studio-XPS-16-ATI-HD4670-Notebook.21328.0.html
Heise (26.01.2010): Performanceprobleme bei einigen Dell-Notebooks mit Core i7
http://www.heise.de/newsticker/meld...inigen-Dell-Notebooks-mit-Core-i7-913571.html
PS: Wenn es interessante Testberichte / Usertests oder andere für die Allgemeinheit interessante Informationen gibt, kann ich diese gerne am dieser Stelle einfügen / verlinken.
(Benachrichtigung per PN / ICQ)
Last Update: 02.02.10
Also wenn du die Variante mit zusätzlichem Chip nimmst sinken die Chancen auf lüfterlosen Betrieb sehr schnell, aber schon die integrierte 9400M ist laut benchmarks ziemlich performant. Was Starcraft angeht, kann dir noch niemand was über die Systemvoraussetzungen sagen...
@Sepp: Würdest du mir den "Aufpreis" nennen, gerne auch via PN.
Werde bei Dell auch Druck auf ein Upgrade machen, wenn sich rausstellt, dass das 1340 fiepfrei ist.
@B.XP
Hey - danke für die Antwort!
Aber, das ist doch ne Grafikswitch-Lösung. Dem zu folge müsste doch im Officebetrieb nur die Onboardlösung laufen und die 9500 GS nicht laufen. Also dürfte das doch keine Auswirkungen auf den Lüfterbetrieb haben, oder steh ich jetzt auf der Leitung???
@Dauerposter:
Das kann ich dir noch nicht sagen. Das einzige was ich bis jetzt habe ist die in einer Email mitgeteilte Meinung eines Technikers, dass der Tausch in ein anderes NB möglich sein müsste. Da das meine gerade mal ne Woche alt ist und da ansonsten der Techniker mit neuem Mainbord, Lüfter und Festplatte anrücken müsste gehe ich davon aus, dass ich lediglich die Differenz zwischen den beiden Neupreisen berappen muss. Evtl. geht ja noch was mit handeln - vorausgesetzt der Techniker hat keinen Mist erzählt bzw. geschrieben.
Gruß. Sepp
Beiträge zusammengeführt, da Antwort auf eigenen Beitrag innerhalb von 4 Stunden:
Und - wie abonniere ich hier das Thema??
Wunderbar! Habs gefunden!
ist euch mal aufgefallen, dass das Upgrade auf 8GB DDR3 Ram 118.868,81€ kostet??
Überzogen oder?^^
hier ein Screenshot:
Nicht schlecht.^^
Wie schauts denn aus mit meiner Theorie zum Lüfterbetrieb bei Grafikswitchlösung! Keiner eine Idee?
Gruß. Sepp
Das ist nur so teuer weils noch nicht lieferbar ist. Aber komische Sache dass DELL Sachen die nicht lieferbar sind extrem teuer macht :fresse:
Viel bringt der Grafikswitch nicht, in anderen Notebooks so 15 min mehr Akkulaufzeit. Auch im Lüfterverhalten ändert sich wohl nicht soviel.
Nicht schlecht.^^
Gruß. Sepp
Der Switch schaltet keinen der Chips komplett ab. Er verteilt nur die Last anders und kann einen Chip in einen schlafmodus versetzen. Im Gegenzug macht es die Softwareentwicklung (treiberebene) ziemlich viel komplizierter. Deswegen werden wohl solche Hybridlösungen von Win7 nicht unterstützt.
Rein hypothetisch: Das M1530 wäre mit komplett abgeschalteter 8600M auch nicht lüfterfrei gewesen. Warum? Weil der Chipsatz heizt! Es gab ja die Versuche mit Untervolting von CPU und GPU, da haben sich dann vll. die Intervalle minimal verschoben.
Rein theoretisch ist es unmöglich wirklich lüfterlosen Betrieb zu fahren, mit aktuellen komponenten und ohne Einschränkungen (undervolting, taktbeschränkung). Ganz einfach weil das Kühlsystem auf Heatpipe mit kleinem Kupferkühler am ende Ausgelegt ist. Und das geht so lange gut wie ein Luftstrom herrscht, ansonsten führt das System keine Wärme ab. Würde jetzt die Luft natürlich durch die Kühler strömen, oder die ganze Bodenfläche als Kühler mitwirken, wäre das wieder was anderes!
Komisch! Wenn ich mich recht entsinne, hab ich in diesem Forum schon ein paar Mal gelesen, dass ein paar Leute lüfterlosen Officebetrieb mit dem XPS M1330 haben. Wahrscheinlich mit onbord-grafik?!?
In puncto Lüfterverhalten des Studio-XPS weiß noch keiner was - oder?
Haben die Geforce-karten der Serie 9 auch dieses Problem, dass sie mit den Start von Programmen in den 3d-Modus für längere Zeit schalten und deshalb andauernd der Lüfter läuft!
Auch mit Onboardgrafik war bei meinen drei M1330 KEIN lüfterloser Officbetrieb möglich. Spätestens nach 30 Minuten ging der Lüfter mal an.
Mittels ik8fangui ist ein lüftleroser Betrieb meist möglich.
Ich hab mich auf das M1530 bezogen ;) Dass mit dem M1330 absolut lüfterloser dauerbetrieb möglich ist bezweifle ich an der Stelle nicht, aber nur bei Onboardgrafik und nicht allzugroßer CPU.
Also beim R560 Madril vom Kumpel konnte ich das beim Einrichten nicht beobachten, beim M1530 übrigens auch nicht...
Zum Studio-XPS müsste man einfach noch ein paar tests abwarten, wirklich viel ist da noch nicht bekannt.
Also der PowerMizer läuft unter der 9600 GT bestens.
Der Lüfter läuft aber trotzdem, verabschiede dich von lautlosen Notebooks in dieser Leistungsklasse. Sowas gibts nicht.
Noch keiner ein Studio XPS bestellt ?
Kommt allgemein nicht so gut an wie mir scheint.
Mi diesem ik8fangui läuft mein M1330 abartig heiß, trotz Energiesparmodus. Die Wärme ist sehr deutlich am Gehäuse fühlbar. Aber zugleich verrät das Programm einem den Übeltäter --> nämlich die Grafikkarte. Chipsatz und CPU sind absolut im Normalbereich.
Ich weiß, dass das Programm häufig die Chipsatz und Grafikkarten Temp verwechselt. Ich habe deshalb einfach mal das ATI-Tool nebenbei laufen lassen und klar gesehen, welche Temperatur schnell anstieg --> Grafikkarte
Was ist denn eigentlich daraus geworden: http://www.forumdeluxx.de/forum/showthread.php?t=457970&page=2
@Larkin: Wenn ich Recht informiert bin, ist Dell recht langsam mit der Produktion. Ein paar Testzeitschriften bekommen es erst Mitte Februar ins haus.
Habe gerade mal ein StudioXPS 13" konfiguriert. Leider wird der 10% Gutschein nicht angenommen. Normalerweise kommt eine Fehlermeldung. Jetzt kommt nichts.
zwischen Displaydeckel(geoeffnet) und Luftschlitz sind es gut und gerne 1,5cm...
Äh wie stellt sich Dell den vor, wie die warme Luft entweichen kann wenn der Deckel fast den ganzen Schlitz blockiert bzw dann die ganze Hitze aufnimmt ?:stupid:
Wenn der Abstand passt geht die luft nach oben ... ;) Rein optisch (von der Seitenansicht) würde der Abstand auf jeden Fall reichen. Und nein das Display nimmt davon auch keinen Schaden.
das ist doch genau das selbe prinzip wie beim studio und da funktioniert es ohne probleme.
Im XPS Forum hat jemand schon sein 1340. Er berichtet, der Lüfter liefe permanent auf niedrigster Stufe und das Teil werde an der Unterseite sehr heiß.
Doch kein Fortschritt zum 1330?
Super. Danke dir. Aber wirklich aufschlussreich ist ja das noch nicht. ;-)
Mal sehen, wie sich das in den nächsten Tagen entwickelt.
Wegen den ständig laufenden Lüfter hät ich noch folgendes zu sagen:
Im XPS 1330 läuft ja auch ein Lüfter immer --> der stört mich nicht die Bohne, erst wenn
der zweite anspringt, dann find ich das etwas nervig.
Jetzt bleibt nur noch die Frage zu klären, von welchem Lüfter der Kollege im anderen Forum spricht!
Komisch - bei mir zeigt das i8-dingsbums immer einen zweiten Lüfter an, der mit 922 Umdrehungen konstant drehen soll. Heißt das, dass das Grundrauschen was immer zu vernehmen ist, von der Festplatte stammt?
Ja, ik8fangui ist das ziemlich buggy.
Das Grundrauschen kommt tatsächlich von der HDD.
