[Sammelthread] Foxconn Inferno Katana (GTI) (Intel P55)
Foxconn Inferno Katana (GTI) ***Sammelthread***
Bilderquelle: www.foxconnchannel.com
inhInhaltsverzeichnis:
1. Spezifikationen
1.1 Inferno Katana GTI
1.2 Inferno Katana
2. Ausstattung
3. WaKü-Zubehör
4. BIOS
5. Kompatiblität
5.1 Speicherkompatibilität
6. Overclocking
7. Downloads
7.1 BIOS für Inferno Katana GTI
7.2 BIOS für Inferno Katana
7.3 Treiber
7.4 Utilities
7.5 Handbuch
8. FAQ
9. Links
1.1. Spezifikationen
1.11.1 Inferno Katana GTI
Processor: Intel® Core™ i7,Core™ i5 processors, Socket LGA1156
Chipset: Intel® P55
Memory: Dual channel DDR3 1800(oc)/1600(oc)/1333 x 4 DIMMs, Max. 16GB
Expansion Slots: 3x PCIe2.0 x16 (x16 / x8+x8, x4), 2x PCIe2.0 x1, 1x PCI slot
IDE: 1x ATA133
Serial ATA(SATA)/RAID: 6x SATAII w / RAID 0, 1, 5, 10; Intel® Matrix storage technology
Audio: 7.1 channel High Definition Audio
LAN: Gigabit Lan
Back Panel I/O Ports:
1x PS/2 keyboard port
1x S/PDIF Coaxial port
1x S/PDIF Optical port
1x Clear CMOS Button
1x Audio jack supports 6 jacks
1x RJ45 LAN port
8x USB 2.0 ports
Internal I/O Connectors:
1x ATX 24-Pin power connector
1x 8-Pin ATX 12V power connector
1x 4-Pin CPU Fan connector
5x 3-Pin System Fan connectors
2x Onboard On/Off/CCMOS buttons
2x S/PDIF out headers
1x Onboard power_LED
1x IDE connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x Front Audio Header
1x Front Panel header
1x Speaker header
1x CD-in connector
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader, SuperUtilities, Norton Internet Security
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12" x 9.6")
1.21.2 Inferno Katana
Chipset: Intel® P55
IDE: 1x ATA133
Serial ATA(SATA)/RAID: 6x SATAII + 2x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology
Audio: 7.1 channel HDA support Dolby & DTS Surround sound technology
LAN: Gigabit Lan
IEEE1394: 2x IEEE1394a
2x eSATA ports
1x RJ45 LAN port
8x USB 2.0 ports
1x IEEE1394a port
3x Onboard On/Off/CCMOS/Force Reset buttons
1x IDE connector
1x Speaker header
1x CD-in connector
1x IEEE1394a header
2.2. Ausstattung
Die grundsätzlichen Unterschiede zwischen dem großen "Schwert" Inferno Katana und dem abgespeckten "GTI-Dolch" sind folgende Features, die das GTI nicht aufweist:
- 12 Phasen PWM (8 Phasen PWM beim GTI)
- Force Reset Button
- Dolby & DTS Surround sound technology
- 2x eSATA
- 2x IEEE1394a
3.3. WaKü-Zubehör
Bis jetzt keine kompatiblen Kühler bekannt...
4.4. BIOS
Bilderquelle: www.tomshardware.com
Grundsätzlich sind sämtliche BIOS-Optionen alte Bekannte. Mit einer Flut von Einstellungsmöglichkeiten à la DFI sollte man allerdings nicht rechnen...
Die Vcore kann über einen "Dynamic Mode" und einen "Fixed Mode" gesteuert werden. Bei letzterem sind allerdings die Stromspartechniken der CPU deaktiviert.
ACHTUNG: Vor dem Wechsel zwischen "Dynamic Mode" und "Fixed Mode" muss man die Vcore wieder auf "Default" setzen und dann nach anschließendem Neustart erst wieder einen manuell gesetzten Wert eingeben. Ansonsten wird die Vcore extrem übervoltet (bis zu 0,4V!)!!! :fire:
Ich habe Foxconn bereits angeschrieben und hoffe auf ein BIOS-Update...
Das BIOS bietet die gewohnten Spannungsfenster für Vcore und VTT. Bei der PLL-Spannung sowie Vdimm und Vref hätte man bei Foxconn allerdings noch etwas spendabler sein können. Die PLL-Spannung lässt sich nur auf 1,70V, die Vdimm auf 1,40V und die Vref auf 0,69V absenken.
Zur Minimierung der Abwärme beim OC ist die PLL-Spannung so niedrig wie möglich zu halten - ich hoffe, dass Foxconn an dieser Stelle nacharbeitet.
Anders bei der Vdimm: hier wird Foxconn nochmal Hand anlegen müssen, da es bereits diverse ECO-Speicher mit 1,35V Vdimm am Markt gibt.
Neben den üblichen Optionen bietet das BIOS unter anderem auch die Möglichkeit verschiedene Profile abzuspeichern. Es stehen insgesamt 8 Slots zur Verfügung, die mit vordefinierten Bezeichnungen versehen werden können.
Zwischen den BIOS Versionen P01 bis P05 habe ich auf den ersten Blick keine Abweichungen hinsichtlich der OC-Optionen finden können - lediglich die Einstellung des QPI-Link-Multiplikators ist später hinzugefügt worden.
5.5. Kompatiblität
5.15.1 Speicherkompatiblität
Kompatibilitätsliste der hier im Forum getesteten Speicher:
4GB Corsair Dominator GT DDR3-1600 CL7 [OK]
6.6. Overclocking
In Arbeit...
7.7. Downloads
7.17.1 BIOS für Inferno Katana GTI
Version: 97AF1P01 Updated: 09/14/09
Description: New BIOS.
Download: 97AF1P01.zip
Version: 97AF1P02 Updated: 09/21/09
Description: Modify DMI Slot information.
Download: 97AF1P02.zip
Version: 97AF1P03 Updated: 09/21/09
Description: Modify BIOS for WLK 1.4.
Download: 97AF1P03.zip
Version: 97AF1P04 Updated: 11/10/09
Description: Update BIOS code for support Clarkdale C2 steping CPU.
Download: 97AF1P04.zip
Version: 97AF1P05 Updated: 11/30/09
Description: Fixed Lynnfield 750 CPU(CPUID:106E5) show wrong core count.
Download: 97AF1P05.zip
Weitere Links:
Foxconn Support Homepage
Quantum Force Homepage
7.27.2 BIOS für Inferno Katana
Version: 979F1P01 Updated: 09/14/09
Download: 979F1P01.zip
Version: 979F1P02 Updated: 09/14/09
Description: Removed DMI type 3 information.
Download: 979F1P02.zip
Version: 979F1P03 Updated: 09/21/09
Download: 979F1P03.zip
Version: 979F1P04 Updated: 11/10/09
Download: 979F1P04.zip
Version: 979F1P05 Updated: 11/30/09
Description: Fixed Lynnfield 750 CPU show wrong core count.
Download: 979F1P05.zip
Weitere Links:
7.37.3 Treiber
Intel Chipset Driver
Intel Matrix Storage Manager
High Definition Audio Codecs
7.47.4 Utilities
AEGISPANEL 2.1.2.68
FOXLiveUpdate 1.0.9.5
7.57.5 Handbuch
Inferno Katana Series Manual V1.0
8.8. FAQ
Frage:
Antwort:
9.9. Links
TweakTown Preview
NinjaLane Preview
AnandTech Review
[benchtec] Review
Legit Reviews
Tom's Hardware LGA1156-Vergleichstest
wenn du die rams auf 2000mhz haben willst, geht das nur wenn du bclk anhebst, also 200
ram teiler dann auf den höchsten, kommt genau 2000 dabei raus
je nach verwendeten ram und timings funktioniert das dann auch
mal xmp versucht?
Bittte weiter um Hilfe...
Ich habe jetzt den XMP versucht... und ram voltage manuel eingestellt.
und habe 200 bclk eingestellt und den multi runter gesetzt damit der proz auf standard 2,8 läuft.
also alles eigentlich nach Vorgabe...
doch zum windows hochfahren kommt es garnicht erst. Der Recher stürtzt dabei ab. Ich versteh es nicht... Mit dem Asus Maximus war das alles kein Prob.
also hab jetzt andere Rams 1600er
aber auch da keine chance die ohne bclk zu verändern auf 1600 stellen.
Ich habe das Beta Bios drauf vielleicht liegt es daran?
Bei meinem vorherigen Asus Board konnte ich alles einfach so einstellen. Vielleicht mehr Ram Teiler oder was is da los?
Das Board ist ja eigenlich ein witz,
Es hat keine Tempsensoren, ich bekomm keine Vcore im Win angezeigt.
Aber warum kann ich den Multi vom CPU nicht verstellen ?
Sicher hat es Temperatursensoren, du musst halt das Programm von Foxconn installieren, das zeigt dir auch gleich die Lüfterdrehzahlen und die Spannungen an ;)
Naja ich will aber keine Programme installieren, das soll einfach von everest oder ähnlichem ausgelesen werden.
Wenn ich das gewusst hätte was für ein mist das ist,hätte ich es mir nicht geholt.Wer will tauschen^^
Das ist ja mal eine qualifizierte Aussage. Na ja, bei der Rechtschreibung ;)
Hi
Habe ein Problem mit meinem Katana GTI. Die Vcore kann ich nicht einstellen - egal was ich tue, sie bleibt immer "dynamic" und auf default.
...desweiteren bootet mein Board auch nicht wenn ich den Speicher im Dualchannel reinstecke (Fehler EA) - aber das ist erstmal nebensache. Das Ding mit der vcore bereitet mir mehr Kopfzerbrechen.
BIOS ist aktuell. Hat das einer von euch auch?
das mit dem dualchannel prob hatte ich auch mal ... da war die cpu deffekt.. bzw der dual channel controller in der cpu... achte aber drauf das du die rams in die bänke 1 und 3 steckst. geht nur so.
an sowas gruseliges habe ich auch schon gedacht. 1 und 3 funktioniert wie gesagt nicht. naja, erstmal läuft die Mühle. Auch wenn es mich nervt^^. Jetzt am WE werde ich nochmal danach schauen.
Bioschip wechseln Foxconn Katana
Hallo und hi,
Bin seit heut hier dabei,und brauche auch sofort eure Hilfe.
Ich wolte den neuen Bioschip fürs Katana MOBO wechseln,
Habe aber wenn das Board vor mir liegt das Prob das da 2 Chips sind,
Nun die 10000000 € frage
Ist es nun der Obere oder der Untere
Vorab bedanke ich mich schon mahl
Mfg Beo:hail:
Hat jemand ein Inferno Katana rumfliegen? Suche eins PN Bitte :)
