[Sammelthread] Foxconn Inferno Katana (GTI) (Intel P55)
Foxconn Inferno Katana (GTI) ***Sammelthread***
Bilderquelle: www.foxconnchannel.com
inhInhaltsverzeichnis:
1. Spezifikationen
1.1 Inferno Katana GTI
1.2 Inferno Katana
2. Ausstattung
3. WaKü-Zubehör
4. BIOS
5. Kompatiblität
5.1 Speicherkompatibilität
6. Overclocking
7. Downloads
7.1 BIOS für Inferno Katana GTI
7.2 BIOS für Inferno Katana
7.3 Treiber
7.4 Utilities
7.5 Handbuch
8. FAQ
9. Links
1.1. Spezifikationen
1.11.1 Inferno Katana GTI
Processor: Intel® Core™ i7,Core™ i5 processors, Socket LGA1156
Chipset: Intel® P55
Memory: Dual channel DDR3 1800(oc)/1600(oc)/1333 x 4 DIMMs, Max. 16GB
Expansion Slots: 3x PCIe2.0 x16 (x16 / x8+x8, x4), 2x PCIe2.0 x1, 1x PCI slot
IDE: 1x ATA133
Serial ATA(SATA)/RAID: 6x SATAII w / RAID 0, 1, 5, 10; Intel® Matrix storage technology
Audio: 7.1 channel High Definition Audio
LAN: Gigabit Lan
Back Panel I/O Ports:
1x PS/2 keyboard port
1x S/PDIF Coaxial port
1x S/PDIF Optical port
1x Clear CMOS Button
1x Audio jack supports 6 jacks
1x RJ45 LAN port
8x USB 2.0 ports
Internal I/O Connectors:
1x ATX 24-Pin power connector
1x 8-Pin ATX 12V power connector
1x 4-Pin CPU Fan connector
5x 3-Pin System Fan connectors
2x Onboard On/Off/CCMOS buttons
2x S/PDIF out headers
1x Onboard power_LED
1x IDE connector
3x USB 2.0 connectors support additional 6 ports
6x SATAII connectors
1x Front Audio Header
1x Front Panel header
1x Speaker header
1x CD-in connector
BIOS Features: 8Mb flash EEPROM w/ LAN boot PnP, ACPI, WfM, DMI
Support CD: Drivers, Adobe Reader, SuperUtilities, Norton Internet Security
Standards/Manageability: PCI 2.3, USB2.0, DMI 2.5
Form Factor: ATX (12" x 9.6")
1.21.2 Inferno Katana
Chipset: Intel® P55
IDE: 1x ATA133
Serial ATA(SATA)/RAID: 6x SATAII + 2x eSATA w / RAID 0, 1, 5, 10; Intel® Matrix storage technology
Audio: 7.1 channel HDA support Dolby & DTS Surround sound technology
LAN: Gigabit Lan
IEEE1394: 2x IEEE1394a
2x eSATA ports
1x RJ45 LAN port
8x USB 2.0 ports
1x IEEE1394a port
3x Onboard On/Off/CCMOS/Force Reset buttons
1x IDE connector
1x Speaker header
1x CD-in connector
1x IEEE1394a header
2.2. Ausstattung
Die grundsätzlichen Unterschiede zwischen dem großen "Schwert" Inferno Katana und dem abgespeckten "GTI-Dolch" sind folgende Features, die das GTI nicht aufweist:
- 12 Phasen PWM (8 Phasen PWM beim GTI)
- Force Reset Button
- Dolby & DTS Surround sound technology
- 2x eSATA
- 2x IEEE1394a
3.3. WaKü-Zubehör
Bis jetzt keine kompatiblen Kühler bekannt...
4.4. BIOS
Bilderquelle: www.tomshardware.com
Grundsätzlich sind sämtliche BIOS-Optionen alte Bekannte. Mit einer Flut von Einstellungsmöglichkeiten à la DFI sollte man allerdings nicht rechnen...
Die Vcore kann über einen "Dynamic Mode" und einen "Fixed Mode" gesteuert werden. Bei letzterem sind allerdings die Stromspartechniken der CPU deaktiviert.
ACHTUNG: Vor dem Wechsel zwischen "Dynamic Mode" und "Fixed Mode" muss man die Vcore wieder auf "Default" setzen und dann nach anschließendem Neustart erst wieder einen manuell gesetzten Wert eingeben. Ansonsten wird die Vcore extrem übervoltet (bis zu 0,4V!)!!! :fire:
Ich habe Foxconn bereits angeschrieben und hoffe auf ein BIOS-Update...
Das BIOS bietet die gewohnten Spannungsfenster für Vcore und VTT. Bei der PLL-Spannung sowie Vdimm und Vref hätte man bei Foxconn allerdings noch etwas spendabler sein können. Die PLL-Spannung lässt sich nur auf 1,70V, die Vdimm auf 1,40V und die Vref auf 0,69V absenken.
Zur Minimierung der Abwärme beim OC ist die PLL-Spannung so niedrig wie möglich zu halten - ich hoffe, dass Foxconn an dieser Stelle nacharbeitet.
Anders bei der Vdimm: hier wird Foxconn nochmal Hand anlegen müssen, da es bereits diverse ECO-Speicher mit 1,35V Vdimm am Markt gibt.
Neben den üblichen Optionen bietet das BIOS unter anderem auch die Möglichkeit verschiedene Profile abzuspeichern. Es stehen insgesamt 8 Slots zur Verfügung, die mit vordefinierten Bezeichnungen versehen werden können.
Zwischen den BIOS Versionen P01 bis P05 habe ich auf den ersten Blick keine Abweichungen hinsichtlich der OC-Optionen finden können - lediglich die Einstellung des QPI-Link-Multiplikators ist später hinzugefügt worden.
5.5. Kompatiblität
5.15.1 Speicherkompatiblität
Kompatibilitätsliste der hier im Forum getesteten Speicher:
4GB Corsair Dominator GT DDR3-1600 CL7 [OK]
6.6. Overclocking
In Arbeit...
7.7. Downloads
7.17.1 BIOS für Inferno Katana GTI
Version: 97AF1P01 Updated: 09/14/09
Description: New BIOS.
Download: 97AF1P01.zip
Version: 97AF1P02 Updated: 09/21/09
Description: Modify DMI Slot information.
Download: 97AF1P02.zip
Version: 97AF1P03 Updated: 09/21/09
Description: Modify BIOS for WLK 1.4.
Download: 97AF1P03.zip
Version: 97AF1P04 Updated: 11/10/09
Description: Update BIOS code for support Clarkdale C2 steping CPU.
Download: 97AF1P04.zip
Version: 97AF1P05 Updated: 11/30/09
Description: Fixed Lynnfield 750 CPU(CPUID:106E5) show wrong core count.
Download: 97AF1P05.zip
Weitere Links:
Foxconn Support Homepage
Quantum Force Homepage
7.27.2 BIOS für Inferno Katana
Version: 979F1P01 Updated: 09/14/09
Download: 979F1P01.zip
Version: 979F1P02 Updated: 09/14/09
Description: Removed DMI type 3 information.
Download: 979F1P02.zip
Version: 979F1P03 Updated: 09/21/09
Download: 979F1P03.zip
Version: 979F1P04 Updated: 11/10/09
Download: 979F1P04.zip
Version: 979F1P05 Updated: 11/30/09
Description: Fixed Lynnfield 750 CPU show wrong core count.
Download: 979F1P05.zip
Weitere Links:
7.37.3 Treiber
Intel Chipset Driver
Intel Matrix Storage Manager
High Definition Audio Codecs
7.47.4 Utilities
AEGISPANEL 2.1.2.68
FOXLiveUpdate 1.0.9.5
7.57.5 Handbuch
Inferno Katana Series Manual V1.0
8.8. FAQ
Frage:
Antwort:
9.9. Links
TweakTown Preview
NinjaLane Preview
AnandTech Review
[benchtec] Review
Legit Reviews
Tom's Hardware LGA1156-Vergleichstest
So.... bios reingesteckt und nun läuft er wieder... aber..
nun habe ich was neues... der rechner sagt mir unter windows das von meinen 4gb ram nur 2 gb nutzbar sind...
egal in welche bänke ich stecke ändert sich nix... nun weis ich nicht ob das prob bekannt ist oder ob nun auch 2 rambänke im arsch sind..
und was noch dazu kommt... ich wollte einfach nochmal drüber flashen um sicherzustellen das es da keine probs mehr gibt... aber ich kann kein update machen weil irgendwas gelockt ist....
weis hier jemand rat?
jup... bringt alles nichts sogar ram bänke wechseln.... bringt nix ... er erkennt nur 2 gb und auch egal mit welchem modul von den 2 modulen.. also der ram is nicht kaputt...
und wie gesagt... bios update kann ich keins machen weil mir das dos tool sagt das das bios gelockt ist... keine ahnung ey.. ich verzweifell....
Das DOS-Tool behauptet, das BIOS sei gelocked? Seltsam. Alle Parameter bzw. Batch-Datei verwendet?
Welchen Flash-Speicher hast du eigentlich getauscht? Sind ja zwei auf dem Board...
den oberen.. wo ich den unteren auch getauscht habe ging nix.. der muss also bleiben...
hmm batch datei habe ich noch nicht probiert... hmmm
also das board erkennt keine 2 rams mehr .. die cpu läuft nur noch mit 1200 mhz..
das bios lässt sich nicht mehr flashen... das ding ist reif für die tonne...
fette 170 euro in den arsch gemacht... coole sache....
naja... nun darf ich erstmal paar ebay auktionen planen damit ich nochmal an ein neues Board komme.... weis noch nicht ob ich mir nochmal das Foxconn nehme.
Hi Leute.Ich habe ja auch das Foxconn Inferno Katana,und auch Start Probs.Wenn ich den Rechner vom Strom hatte,geht er nicht sofort an und beibt beim Code 05 hängen.Erst beim 2 mal Start er dann.Wenn ich ihm am Netzt laße geht er sofort an.
SYS:4 GB ram
Intel i7-860
4 mal 1TB
Wasserkühlung.
AMD 5870
Es nervt mich ein wenig.
ALso ich habe im windows einen kommischen befehl eingegebn... in dem cmd flash tool....
naja... ich glaube das war halt eben der falsche...
aber ey egal... das board wird als deffekt verscherbelt ... ich denke jemand kann das board wieder hinbekommen... und wen er sich die 2 neue chips bei foxconn ordern muss...
mir kommt nun erstmal ein neues board rein damit der rechner läuft... vielleicht schreib ich ja sogar foxcon an... mal schauen.
Joa ich schein wirklich alles kaputt geflashed zu haben...
Sorry bezüglich deines Angebots..es ist schon ein neues Unterwegs.
Also bei mir bleibt er dann beim ersten Starten bei dem Code 05 stehen.Das 05 bedeutet das er Start bereit ist lol.
ja das weiß ich,aber kann doch nicht sein sowas.Hat einer schon das Beta Bios vom 23.6.2010 drauf?
So neues Board da.... neue CPU da... 500 euro später... der Rechner läuft wieder.
Und was lernt man aus solchen unötigen Umrüst Aktionen mal wieder?
Ach wäre das schön wenn man ein anderes Hobby hätte ;-)
Bitte um Hilfe:
Im Bios gibts ne möglichkeit die Rams auf 1600 zu stellen... wenn ich das tuhe laufen die aber regulär im 1333 modus.
Hab ich da was falsch gemacht? Ich habe eben 2000 mhz rams und möchte gern so viel wie möglich der geschwindigkeit nutzen... Was muss ich einstellen?
wenn du die rams auf 2000mhz haben willst, geht das nur wenn du bclk anhebst, also 200
ram teiler dann auf den höchsten, kommt genau 2000 dabei raus
je nach verwendeten ram und timings funktioniert das dann auch
und wie schauts mit 1600 aus? kann ich das machen ohne zu übertakten?
bzw du meinst bclk auf 200 und multi runter dann oder?
1600 geht auch ohne cpu ocing wenn ich mich noch richtig erinnere
ja wenn du bclk hoch schraubst solltest du testweise den multi senken
naja genau das meine ich ... wenn ich einfach so 1600 einstelle übernimmt der glaub garnicht und die rams laufen weiterhin mit 1333...
