geo2k1
meint ihr das da drauf World of warcraft oder everquest 2 läuft ??????
Processor
Intel® Pentium® 4 Processor at 3.2 GHz
On-die 1 MB KB cache (L2)
32 KB internal cache (L1)
800MHz front side BUS
Intel® 865PE Chipset
Operating System
Microsoft® Windows® XP Home
Memory
1024 MB of 400MHz Dual Channel DDR SDRAM
2 SoDIMM sockets, both are user-accessible
I/O Ports
IEEE 1394 integrated port
4-USB 2.0 (Universal Serial Bus) compliant 4-pin connectors
Digital Video Interface (DVI)
Serial infrared communications port (lrDA-1.1 compliant)
Video: 15-pin monitor connector
S-Video: 7-pin mini-DIN connector
Audio jacks: Stereo headphones/speakers miniconnector (same as line-out), microphone miniconnector
Chassis
15.4-inch Wide-Aspect WXGA, SXGA+ and UXGA displays: Height: 2.0-inch (50.8 mm)
Width: 14.1-inch (359 mm)
Depth: 10.8-inch (274 mm)
Weight: approximately 8.92 lbs. (4.05 kg).
Power
Battery: 12 Cell Lithium Ion Primary Battery with Integrated Subwoofer
AC Adapter: Input voltage: 90 to 264 VAC
Input current (maximum): 1.7A
Output current: 4.5A max at 4-second pulse, 3.5A continuous
Output power: 150W standard
Dimensions (H x W x D): 1.6-inch (40mm) x 3.4-inch (85mm) x 6.7-inch (170mm)
Weight (with cables): lbs. ( kg)
Power Management
Suspend-to-RAM mode
Suspend-to-disk mode
Stand-by mode (turns off LED and HDD)
Slots
Connectors: (1) Type I or Type II card
3.3 and 5 V cards supported
Warm-swap Capable
Display
15.4 inch Wide-Aspect UltraSharpTM TFT Active Matrix displays in WXGA ( 1280x800)
Graphics
128MB DDR ATI® MobilityTM RADEONTM 9800
Hard Drives
60 GB Ultra ATA hard drive
Optical Devices
Combo Drive - 24x/10x/24x CD-RW and 8x DVD-RW
Floppy Drive
None
Sound
Integrated stereo sound
Integrated subwoofer
Modem
Integrated v.92 56K capable1 modem
Network Interface
Integrated 10/100 Ethernet
Wireless Networking
Dell 1350 internal wireless solution (802.11b/g)
Productivity Software
WordPerfect® Productivity Pack including WordPerfect® and Money®
Processor
Operating System
Memory
I/O Ports
Chassis
Power
Power Management
Suspend-to-RAM mode
Slots
Warm-swap Capable
Display
Graphics
Hard Drives
Optical Devices
Floppy Drive
None
Sound
Modem
Network Interface
Wireless Networking
