My query is related to this model of RAM memories.
Model: G.Skill Trident Z5 RGB 32GB 2x16GB 6400MHz CL32 - DDR5
Code: PROD-026117
EAN: 4713294231369
Part Number: F5-6400J3239G16GX2-TZ5RK
Timgins :
XMP 3.0: 6400
Freq: 3200
tCL: 32
tRAS to CAS: 39
tRAS Precharge: 39
tRAS: 102
tRC: 141
Volt: 1.400V
The problem is that my motherboard supports the maximum overclocking frequency:
1DPC 1R Max speed up to 6000+ MHz
1DPC 2R Max speed up to 6000+ MHz
2DPC 1R Max speed up to 6000+ MHz
2DPC 2R Max speed up to 5400+ MHz
With Timings config by "MSI memory try it" at 6000Mhz - 32-40-40-86, It works until the first reboot, when the board crashes and you have to restore the bios to default.
With other "MSI memory try it" options at 6000Mhz, the result is the same. What manual configuration do you think may be the correct one for everything to work perfectly?
Sorry for my engilsh ;-) and Thnks!!!
Sorry, my motherboard is MSI PRO X670-P WIFI
Code: PROD-026117
EAN: 4713294231369
Timgins :
XMP 3.0: 6400
Freq: 3200
tCL: 32
tRAS to CAS: 39
tRAS Precharge: 39
tRAS: 102
tRC: 141
Volt: 1.400V
