Funktioniert auf jeden Fall schlechter, als mit einem neutralen, hochauflösenden Hörer.![]()
Wie oft muss ich sowas noch lesen?
Naja ich mach mir die Mühe nichtbda rennt man sowieso gegen Wände.
Gesendet von meinem GT-N7100 mit der Hardwareluxx App
Weiß vielleicht einer von euch wann das Modmic 2.0 mit mute bzw. das 3.0 rauskommt?
kann es sein das die Höhen beim DT 990 aggressiver sind wie beim dt 880?
(Quelle: Mad Lust Envy's Headphone Gaming Guide)The DT880s had a problem accurately depicting sounds that come from between 5 o clock to 7 o clock. Pretty much everything behind you. It actually sounds closer to the center, as opposed to sounding like it's actually behind you. With practice you can LEARN the distinct signature a rear sound makes with the 880s, but it will take you a split second to register that it's coming from behind you. That split second is enough to get you killed in an FPS game. Trust me. This is an issue with all models of the Premium DT880s, as I have compared with a few of my AVS friends who have owned different versions. They all came with the same conclusion. Some others don't experience this problem, but they also don't have the experience I have with headphones that DO have a much better sense of rear sound pinpointing (like say the 770 Pro 80s or K701).
Solche Einschätzungen sind zu einen grossen Teil individuell (von Person zu Person verschieden). Da hilft nur selbst testen.
Nochmal:
Sennheiser Hd600/650, Hifiman He300
Beide mit mehr Bass und weniger Höhen als die Beyer.
