Gigabyte MA-790FX-DS5
Spezifikationen
Hyper Transport Bus :
AMD Phenom™FX processor/ AMD Phenom™ processor/
AMD Athlon™ 64 FX processor/
AMD Athlon™ 64 X2 Dual-Core processor/
AMD Athlon™ 64 processor/AMD Sempron™ processor
5200/2000 MT/s
1. North Bridge: AMD 790FX
2. South Bridge: AMD SB600
1. 4 x 1.8V DDR2 DIMM sockets supporting up to 16 GB of system memory (Note 1)
2. Dual channel memory architecture
3. Support for DDR2 1066(Note 2)/800/667 MHz memory modules
4. Support ECC Memory
1. Realtek ALC889A codec
2. High Definition Audio
3. 2/4/5.1/7.1-channel
4. Support for DTS (dts NEO:PC)
5. Support for S/PDIF In/Out
6. Support for CD In
1. Realtek 8111B chip (10/100/1000 Mbit)
Storage Interface South Bridge :1. 2 x PCI Express x16 slots supporting ATI CrossFireX™ technology
(The PCI Express x16 slots conform to PCI Express 2.0 standard.)
2. 3 x PCI Express x1 slot
3. 2 x PCI slots
Interne I/O Anschlusse :1. 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
2. 4 x SATA 3Gb/s connectors (SATAII0, SATAII1, SATAII2, SATAII3)
supporting up to 4 SATA 3Gb/s devices
3. Support for SATA RAID 0, RAID 1 and RAID 0+1
2 x GIGABYTE SATA2 chip:
1. 2 x SATA 3Gb/s connectors (GSATAII_1, GSATAII_2) supporting up to 2 SATA 3Gb/s devices
2. 2 x eSATA 3Gb/s ports on the back panel supporting up to 2 SATA 3Gb/s devices
3. Support for SATA RAID 0, RAID 1, and JBOD
iTE IT8718 chip:
1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive
IEEE 1394 T.I. TSB43AB23 chip
1. Up to 3 IEEE 1394a ports (2 on the back panel, 1 via the IEEE 1394a bracket connected to the internal IEEE 1394a headers)
USB Integrated in the South Bridge
1. Up to 10 USB 2.0/1.1 ports (6 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Rear Panel I/O :1. 1 x 24-pin ATX main power connector
2. 1 x 8-pin ATX 12V power connector
3. 1 x 4-pin PCIe 12V power connector
4. 1 x floppy disk drive connector
5. 1 x IDE connector
6. 6 x SATA 3Gb/s connectors
7. 1 x CPU fan header
8. 2 x system fan headers
9. 1 x power fan header
10. 1 x North Bridge fan header
11. 1 x front panel header
12. 1 x front panel audio header
13. 1 x CD In connector
14. 1 x S/PDIF In header
15. 1 x S/PDIF Out header
16. 2 x USB 2.0/1.1 headers
17. 1 x IEEE 1394a headers
18. 1 x parallel port header
19. 1 x power LED header
20. 1 x chassis intrusion header
I/O :1. 1 x PS/2 keyboard port
2. 1 x PS/2 mouse port
3. 1 x serial port
4. 1 x coaxial S/PDIF Out connector
5. 1 x optical S/PDIF Out connector
6. 6 x USB 2.0/1.1 ports
7. 2 x IEEE 1394a ports
8. 1 x RJ-45 port
9. 2 x eSATA 3Gb/s ports
10. 6 audio jacks (Line In / Line Out / MIC In/Surround Speaker Out (Rear Speaker Out) /
Center / Subwoofer Speaker Out / Side Speaker Out)
H/W Monitoring System voltage detection :1. iTE IT8718 chip
BIOS :1. CPU/System temperature detection
2. CPU/System/Power fan speed detection
3. CPU overheating warning
4. CPU/System/Power fan fail warning
5. CPUfan speed control
Unique Features :
1. 2 x 4 Mbit flash
2. Use of licensed AWARD BIOS
3. Support for Dual BIOS™
4. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Bundle Software :1. Support for @BIOS
2. Support for Download Center
3. Support for Q-Flash
4. Support for EasyTune (Note 3)
5. Support for Xpress Install
6. Support for Xpress Recovery2
7. Support for Virtual Dual BIOS
Operating System :
* Gigabyte Tools; Gigabyte C.O.M., EasyTune Pro 5@BIOS, Gigabyte FaceWizard, Gigabyte i-Cool and DMIView
* Adobe Reader and DirectX 9.0C
* Kapersky Anti-Virus
* Norton’s Internet Security 2007
Form Factor :
1. Support for Microsoft Windows Vista/XP/2000
Note :1. ATX Form Factor; 30.5cm x 24.4cm
(Note 1) Due to Windows XP 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
(Note 2) Whether 1066 MHz memory speed is supported depends on the CPU being used.
(Note 3) Use of a CPU that supports ECC is required if you wish to install ECC memory.
(Note 4) Available functions in Easytune may differ by motherboard model.
(Note 5) The adjustable CPU voltage range depends on the CPU being used.
Layout
BIOS :
Supportet Phenom CPU´s
Bios Downloads :
Download F7E 2008/12/12
1. Update CPU ID
Download F6 2008/05/21
Download F5 2008/03/271. Update CPU ID (Support AM2+ Phenom 9950 CPU)
Download F4 2008/03/031. Fix CPU compatibility issues (Sometimes booting failed after reset)
Download F3 2007/12/211. Update CPU ID (Support AM2+ Phenom Triple Core CPU)
Download F2 2007/11/231. Regarding the patch of L3 cache's TLB erratum in AMD Phenom CPU, default setting is [Enable]
and also add option of [Disable] for various usage
2. Added bootblock checksum support (The back up bios will be updated)
Download F1 2007/10/011. Improve DDR2 1066 memory support for AM2+ CPU
2. Add x0.5 ratio option in BIOS for AM2+ CPU
1. First Release
2. Support AMD OverDrive utility
Warnung:
Da ein BIOS Update möglicherweise ein Risiko für das System sein kann, wird davon abgeraten, ein BIOS Update durchzuführen
wenn keine Probleme mit der derzeitigen Version auftreten. Wenn sie das BIOS dennoch aktualisieren möchten, tun sie dies mit Bedacht.
Ein unpassendes BIOS kann zu einer Fehlfunktion des Systems führen.
Was bedeutet das Update der CPU ID/Micro Codes im BIOS?
[1.]Unterstützung einer neuen CPU Serie oder [2] Unterstützung bisheriger CPUs aber mit neuen Steppings.
CPU Unterstützung is abhängig vom BIOS und Hardware Design, um eine detaillierte
Information über CPU Unterstützung zu erhalten, sehen sie bitte die CPU Support List.
Was ist ein BETA?
BETA beschreibt eine neue Version, die zwar zuverlässig läuft, aber noch nicht zwingend alle Eigenschaften des Endproduktes enthält.
In dieser Phase werden noch neue Eigenschaften getestet und Kundenrückmeldungen gesammelt, um das Produkt zu optimieren.
FAQ - Frequently Asked Questions:
Wo finde ich die erweiterten Bios Option ?
Im Bios STRG+F1 Drücken .
- Einstellung für Ram-Timings (tRAS und tRC) wird nicht übernommen. (Behoben ab F4f)
- S3-State funktioniert nicht (Windows Vista; mit F5 behoben)
- teilweise USB-Bug (Saitek Eclipse-Tastatur); Mit F6-BIOS behoben.
- Einstellung für CPU-NB-Spannung fehlt (Phenom)
- Einstellung für Northbridge-Takt fehlt (Phenom)
- VCore für Phenom-CPUs lässt sich nur erhöhen (kein undervolten im BIOS möglich)
- Rechner schaltet sich immer beim Drücken irgendeiner Taste einer Tastatur (USB-Tastatur über Adapter am PS2) ein (BIOS F5).
- "precharge time" lässt sich manuell nicht auf 4 oder höher einstellen
- AutoXPress-Features stehen nach dem einschalten wieder auf Disabled, obwohl sie aktiviert sind
- OC-Problem: Bei Verändern des Multi kein Boot mit Einstellungen möglich, die per AOD einstellbar sind (B3-Stepping)
- (teilweise) Probleme mit 9850: x kein Kaltstart bei OC (mit F6 behoben)
x unregelmäßige Reboots/Freezes
- kein Boot von eSATA-Festplatten am JMicron als Master möglich, wenn AHCI aktiviert ist (Platte wird im BIOS nicht gelistet; als Slave schon).
Treiber Downloads :
Download
Lister Unterstützer Speicher Riegel PDF Format :
Download
**Klick Offiziele Seite zum Board **Klick
Reviews zum Board :
Neoseeker
Technic3D
OverclockersClub
Links im Forum :
**KlickPhenom OC FAQ von Motkachler+Marineflieger**Klick
AMD Phenom X2/ X3/ X4 Overclocking- Liste + Diskussion von ataridelta9
Das war es soweit fürs erste alles weiter kommt von euch bzw werde ich nach und nach Eintragen.
