[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
Läuft einfach optimal mit 4.5 ... wobei 4.6 selbst unter Luft drin sind - mit maximal 10 Grad höhere Temps auf den Cores.
Habe die selbe Batch zweimal da ... daher Verkauf ich eine wieder ... mal schauen oib die andere auch so geht.
Mein Sandy ist auch bei 4,5 optimal mit Luft ;)
Mehr braucht man auch irgendwie nicht
ich habe die woche mein 3770@4.5ghz mal mit lukü prime gestresst
ca 70°
mit Wakü habe ich 10° weniger im schnitt
Das muss jeder für sich entscheiden .. ich sehe da auch einige Dinge die für Ivy sprechen.
Ich habe zwei gute 2500K da die 5GHz 24/7 unter Luft machen und werde trotzdem eine Ivy behalten, da 4.5 GHz selbst für anspruchsvolle Sachen locker reichen.
@Gamer68
Mit dem 3570K sind es laut Coretemp maximal 65 grad bei 4.5 GHz unter Volllast.
Jo der 3570k sollte auch ein bissl Kühler sein ,wegen der fehlenden smt
Ich habe mal mit cinebench getestet wieviel Takt ich mit dem2600k mehr brauche
3770k@4.5GHz-9.19 pkt
2600k@4.8ghz- 9.14pkt
Ich denke mal der 2600 Brauch ca 350mhz mehr um genau so schnell zusein
Bitte denkt daran, dass es sich hier um den Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77) Sammelthread handelt Leute, und nicht um einen Ram/OC Thread.
Werde morgen die ganzen Beiträge durchgehen und mal aufräumen.
:btt:
Guten Morgen alle zusammen
tut mir leid, dass ich euer Thema so unterbreche, aber ich wollte keinen neuen Thread aufmachen, sondern gleich hier Fragen. Gibt es einen Leistungsunterschied zwischen diesen beiden Modellen auf dem Gigabyte-z77x-d3h Mainbaord?
8GB-Kit G.Skill Ares PC3-14900U CL9-10-9-28
8GB-Kit G.Skill Sniper PC3-14900U CL9-10-9-28
Ich möchte morgen bei mindfactory bestellen, leider haben die nicht den Ares Arbeitsspeicher, sondern nur den Sniper.
Ich kann keine höheren Arbeitsspeicher bestellen, da ich einen be quiet Dark Rock Pro C1 habe und max 40mm Platz sind.
Mein System:
CPU: i5-3570k
Main: Gigabyte z77x-d3h
Grafik: Gigabyte HD7970
AB: ?
Netzteil Sharkoon Silent Storm 560W
Gibt es einen Leistungsunterschied zwischen beiden Modellen, bzw werden bei unterstützt?
Mfg Stephan
Arbeitsspeicher aus verschiedenen Kits zusammen stellen .ist immer Risiko ,wenn du 16gb möchtest dann bestell dir ein 16gb Kit und Verkaufe dein RAM
...welche leistung meinst du, die echte (praxisnah) oder nur die synthetische ???
meiner praxisnahen meinung nach nein, da reichen PC12800 dicke... ist leider nur geldmacherei ;-)
Ich möchte keine Kits kombinieren oder irgend etwas in dieser Richtung machen.
Ich habe lediglich gefragt, ob ich auf dem Gigabyte z77x-d3h beide Arbeitsspeicher betreiben könnte.
Eigentlich hatte ich vor dem 8GB Ares 1866 Mhz Cl9 zu betreiben, leider kann ich diesen nicht bestellen. Daher frage ich euch, ob ich auch den 8GB Sniper 1866 Mhz auf diesem Board (2x4GB) betreiben kann und ob dieser voll unterstützt wird, da er auf der Herstellerseite nur für den z68 Chipsatz ausgelegt ist.
Mfg
Die sollten laufen ... habe die Ripjaws-X da mit 1866 CL9-10-9-29 ... die gehen auch.
Steckt unter den Kits meist sowieso das gleiche ... G.Skill pappt einen neuen "Heatspreader" drauf ... und fertig ist die neue Serie.
Damit wird einfach die Sucht der Hardware-Junkies nach neuem befriedigt. ;)
Am besten Slot 1 und 3 für RAM verwenden oder 2 und 4, ist doch wahrscheinlich latte für das UD5H, oder ?
warum möchtest du deinen i5 3570K verkaufen?
Weil ich zwei da habe mit der selben Batch ... und den zweiten testen möchte :) ... und da ich 2 Ivys und 3 Sandy da habe muss halt einer weg.
@Gamer68 Genau DIMM Slot 2+4 benutzte ich immer ... und habe praktisch nie Probs mit RAMs.
Jap ... passt schon ... wenn man keine Benchmark Rekorde mit 5 GHz oder darüber aufstellen möchte.
Schön ist halt der geringere Stromverbrauch bis 4.5 GHz und PCIe 3.0 im Vergleich zu Sandy Bridge.
Und die böse Temperatur (10-12 Grad mehr als mit Sandy bei gleichem Takt) juckt eh nicht wirklich da sie ja unterm Heatspreader bleibt. :coolblue:
Von daher werde ich auch einen 3570K behalten.
Danke IronAge und Gamer68, dann werd ich auch zunächst mal Slot 2+4 verwenden.
Gibt es eigentlich ne Theorie, warum 2+4 stabiler laufen als 1+3 ?
Nö ,ist meistens aber so das die steckplätze nicht identisch laufen ,bei mein alten ud4 liefen mit Abstand die 1u3 am besten ,denke das hat mit der architektur des mainboard Zutun ,vielleicht kann jz was Zusagen
Jo, wäre interessant, ob es beim UD5H ne generelle Tendenz gibt, ob best. Slots stabiler laufen.
Glaubt ihr es lohnt sich anstatt einem Asrock Extreme 4 Z77 ein Gigabyt UD3H zu nehmen?
Finde das UD3H richtig gut ... 1-2 kleinere Bugs hat das UEFI noch ... aber bin mir sicher JZ_ wird sich darum kümmern.
Woran ich mich immer wieder ergötze ist der schnelle Boot ... und das Layout finde ich auch sehr gut.
