[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
Der Macho ist doch so konzipiert, dass der Lüfter rechts montiert werden kann, auch wenn hohe Riegel verbaut werden. Das ist der Vorteil dieses eigenwilligen Konzepts. Du kannst natürlich als weitere Option den Lüffi links montieren.
@romeon
hattest du vor deinem prime-run spannung im gtl oder et6 geändert???
du könntest probleme haben weil du eine offset-spannung verwendest...eventuell mal etwas die llc verschärfen
Also bei mir liegt dieses Problem mit der Stromüberspannung auf dem USB Hubanschluss definitiv am Frontpanel. Das ich das Gehäuse Carbide 500r zweimal besitze, konnte ich das andere Panel mit demselben Board testen, an dem das erste nicht lief. Und siehe das es läuft. Also liegt es nicht am Board. Eher am Kabel oder den minderwertigen Anschlüssen des Frontpanels.
Also ich hatte ja diese Meldung auch, weiß aber nicht welcher USB-Port letztlich betroffen war. War glaub ich der unterste der im HUB des Gerätemanagers angezeigt wurde.
Habe das USB 3.0 Fronteinbau-Kit von Gigabyte in Verwendung!
@omc1984: ich hab definitiv nix gemacht und hatte den Rechner in der Zwischenzeit auch schon öfter aus bzw. auf standby und immer lief er wieder an (vorhin auch wieder 3mal problemlos). Ok, beim Ausloten der Spannungen in den ersten Tagen hatte ich auch schon mal Bootloops, wo ich dann den CMOS über die interne Taste resetten musste. Aber seitdem der PC imo stabil läuft, gabs nix mehr. LLC hab ich aus. Als es noch aktiv war, hat es mir fast die CPU abgefackelt *g, weil das dermaßen die vCore automatisch hochgesetzt hat. Alles mit LLC ausloten, dass ich lt. CPU-Z wieder bei 1,320v vcore @load rauskomme, dürfte etwas dauern .... ich werde das mal weiter beobachten.
Edit: was ich noch nicht gemacht habe: die Ram-Timings noch nicht fix eingegeben, der läuft noch über XMP mit meinem G.Skill 1866. Vielleicht hatte er auch da was in den falschen Hals bekommen.
mich haben heute früh auch die Bootloops heimgesucht (UD3H mit 11b, 2500k @4,4 mit +0,005 vcore, 14h primestable) :rolleyes:. Hab kplt ausgemacht und wieder an, dann kam ich irgendwann ins Bios (Warnung: evtl nicht stabil). Dort mit F10 gespeichert und jetzt läuft es wieder ... mhmm.
genau wie beim X79...
ich glaube da muss man sich fast schon dran gewöhnen...
alle 2 tage die warnung, bios, speichern, gut.
boahh, grade schon wieder. Das geht einem vielleicht was auf die Ketten. Als hätten die vorher noch nie Boards gebaut ...
@romeon
bitte gib mal deine bios-settings komplett en detail (spannung, 3d power, ram)durch!!
stell bitte einen lüfter vor die platine, damit sie zusätzlich gekühlt wird
Der Macho-Lüfter sollte natürlich auch in Richtung Heck/Gehäuselüfter blasen. Der Rahmen ees Lüfters hat eine Pfeilmarkierung, die die Strömungsrichtung der Luft anzeigt - so montieren, dass der Pfeil zum Kühler zeigt.
dann würde der lüfter doch doch die luft nicht wegpusten sondern ansaugen? langsam bin ich verwirrt :d
ja ich denke ich werde den lüfter rechts montieren, mein gehäuse (corsair graphite 600t) hat ja noch einen großen lüfter in der decke. jetzt muss ich nur noch rausfinden ob er rein oder rauspustet :). wenn die lüfter oben rauspusten kann ich den macholüfter ja rechts montieren. da dürfte der airflow passen
hier meine Bios-Settings:
und prime:
Rechner:
2500k@x.x, Gigabyte Z77X-UD3H F11b, Kühler U120eXtr., G.Skill 8GB-1866, Sapphire 5750
Das Gehäuse ist gut durchlüftet (4x 80er: 1 vorn, 1 oben, 2 hinten, alle mit Widerstand direkt am Netzteil angeschlossen) und das Netzteil selbst kam eigentlich überall gut weg (Corsair HX520). Und wie gesagt tritt es "nur" auf, wenn ich den Rechner anschalte (ausgeschaltet oder S3), er also vorher relativ kalt war.
Ach ja, die "Nebenspannungen" hatte ich auch vor Prime schon etwas erhöht, mehr so zur Sicherheit, weil bei leicht negativem offset (-0,010 & -0,005) nach 3-4 Stunden Prime einen Fehler brachte. Dann hab ich den offset auf +0,005 und die Nebenspannungen minimal rauf. Die Drehzahl vom CPU-Lüfter (3polig) wird auf "silent" nicht richtig ausgelesen, er dreht bei load ca. auf 1400.
Vielleicht habt ihr noch eine Idee, ich bin momentan ratlos.
jap....habe ne idee...versuch mal 1600 mit 9-9-9-24
bitte den turbo auf disabled!...die kerne auf auto lassen...
außerdem unter 3d-power: perf, balanced, 4x high, 2x auto, 4x high...in der reihenfolge
dann erstmal idle testen und anschließend prime oder linx oder aida(genau die spannungen überwachen per multimeter oder in aida!!!)
ok, werde ich probieren, thx! Kann halt ein paar Tage dauern, bis ich sicher bin bzw. der Fehler wieder kommt.
So, gerade kam wieder diese Strom-Fehler Meldung an USB 3.0, dabei hab ich nichts an USB 3.0 angeschlossen.
Hier mal ein Pic:
Kann mir jemand sagen, um welchen Anschluß es sich handelt und was man evlt. im Bios umstellen könnte ?
@JZ: Kennst Du das Problem ?
hmm.. ich hätte mal eine frage. hier ließt ja jz mit richtig ?? alos ich hab immernoch bootloops. hatte die jetzt nur etwa einmal alle 20 pc starts, was nich so tragisch war. aber heute is es schlimmer geworden. der rechner hat 6 mal neugestartet und dann kam im bios ne warnung wegen bios failure oder so und mein bios hat sich resetet. da stand irgendeine hardwareconfig solle nich gut sein oder so.
nun wunder ich mich das es grade jetzt nach 3 wochen schlimmer geworden ist.
was könnt ich nun testen ? kanns am ram liegen, oder am sandy ? ich wüsste sonst nich was kaputt sein kann, weil eigentlich alles perfekt läuft o_O kommt irgendwann mal nen bios für das z77x-ud5h das die bootloops fixed ? (ich nehme mal an das is weiterhin nen biosbug in verbindung mit den sandys und dem ud5h) solangsam bin ichs nämlich leid.
meint ihr es bringt was neuen ram zu kaufen und mit anderem ram zu testen ?
/e: das netzteil kanns ja eher nicht sein oder ?? ich mein würd mich schon wundern wenn SO ein netzteil da probleme macht ?!? graka hab ich ne neue jetzt und es kamen bootloops mit meiner alten 460er sowie mit der neuen jetzt, von daher kanns nich an der graka liegen.
@cincei
probier mal die riegel einzeln...und andere ram-slots
stell den sandy mal auf standard-taktraten und die bios-settings für 3d power...so wie ich sie oben für romeon angegeben habe!
den ram bitte fix auf command-rate 2t stellen!
hoi
habe jetzt nur die letzten Paar Seiten dieses Thread abgegrast...
Haben hier viele Leute probs mit Boot Failure/ Boot loops und dem UD5H??
Das Brett nervt mich langsam...habe es mit 16gb corsair vegeance LP am laufen und bekomme sporadisch ständig ON OFF ON OFF boot loops mit anschließend Boot Failure - seltsamerweise obwohl es vorher immer lief.
Passiert @stock und auch mit OC.
BIOS F8d!
Das Billig Asrock z77 macht keinerlei Mucken....
ahhja.. ich hab mich mal durch die posts gewühlt und ich muss hier sagen das ich genaud as gleiche hab.
hab nr 8gb des corsair vengeance lp rams. hab das f7 bios ! das erste mal heute hatte ich halt nen boot failure im bios stehen.. vorher waren alle bootloops immer gleich und zwar 4mal neuegstartet. erstes loop direkt nach bios beep, zweiter loop vorher, dritter loop war interessant:
da kam ich ins bios rein, aber das bios war immer leer. sprich nur der hintergrund des bios war da, aber es gab garkeine daten. das verblieb dann so 5 sekudnen und dann gabs den dritten loop. beim vierten start dann ging der rechner normal an. das war bisher immer so (etwa 5 mal bisher). erst heute wurds schlimmer mit 6 mal loopen und boot failure mit bios reset -.- solangsam hab ichs auch satt mit dem board.. kommt da irgndwann in absehbarer zeit mal nen bios das halbwegs bugfrei is ? oder liegt es nich am bios ?
---------- Post added at 11:21 ---------- Previous post was at 11:20 ----------
@omc: ok danke für deine erläuterungen. werd ich mal probieren. ähm. was soll das dann helfen ? also wenn ich dann keine bootloops mehr hab, an was liegt es dann ? problem is halt nur das ich alle paar tage nur einen bootloop hab. bedeutet das es durchaus paar wochen lang dauern könnte mitm testen :(
achso der rechner is in dem zustand in dem die bootloops kommen 12 stunden primestable und 60minuten linxstable usw o_O
klingt entweder nach defekt auf der platine...oder defekter periferie
spiel mal noch das aktuelle bios auf und achte darauf, dass ein bios-reset gemacht wird und die dmi gelöscht (alternativ die batterie entfernen)
außerdem solltest du so viel wie möglich vom rechner entfernen...usb, graka (bild über igpu), drucker - eben nur das nötigste auch die frontusb und den reset-sw und power-sw
PS: dein problem klingt etwas nach problemen mit dem ram (bitte mal details zum ram posten)
-> oder auch wahrscheinlich ist, dass du ne offset-spannung nutzt...und beim wechseln last zu idle oder in die andere richtung der pc dann abschmiert...
hmm ok.. also kanns durchaus das mobo sein das defekt ist ? das wäre ja mal nen supergau xD welches is das aktuelle bios ? das F8 von jz ? da sthet ja keine empfehlung bei manchen sachen hmm..
graka kanns wie gesagt nich sein weil es sowohl mit ner 460er als auch mit ner 670er passiert ;) ich hab nochn xbox 360 hd-dvd laufwerk dran.. vllt liegts daran ? mir is aufgefallend as vor einem bootloop beim ersten mal immer das laufwerk nich initialisiert wird und dann der loop kommt (also normalerweise wirds vor dem beep initialisiert, aber beim loop passiert das nicht)
/e: details zum ram: 2x4gb corsair vengeance lp. vdimm fix 1.5v eingestellt. alle timings fix eingestellt auf 9-9-9-24 im bios :)
ich nutz kein offset. ich hab mit fixer vcore geoced. vcore hab ich im bios auf 1.285 gestellt (hab kein gutes oc exemplar vom sandy erwischt, was mir aber egal ist).
3d power habich alles auf auto.
pll, imc usw hab ich alles fix auf intels default werte eingestellt. wie gesagt der rechner is primestable usw. nur alle 20 starts etwa gibts nen 4x bootloop nd heute zum ersten mal nen härteren. erst dacht ich das es nur bei nem absoluten kaltstart vorkommt, also wenn der rechner komplett abgekühlt ist in einem kühlen zimmer, aber es is auch schon ne halbe stunde nachm ausschalten des rechners passiert wo es bei mir auch nich kalt war im zimmer o_O
/e2: eine frage dazu.. können diese bootloops irgendwas an meinem rechnr auf dauer kaputt machen oder in irgendeiner form beeinträchtigen ?? alos kann das schädlich sein für meinen rechner ?
command rate is das tCMD im bios oder ? das stand nämlich auf auto. was bewirkt der unterschied. habs mal auf 2 gestellt
z77x-ud5h boot failure - Page 6
das is vllt interessant zum bootloop problem. vllt könnte jz was dazu sagen ??
anscheinend gibts nämlich laut dem typen da (und naja da er der admin is wird er vermutlich auch gute ahnung haben) mit jeder bios version in verbindung mit den sandys bootloop. also vllt doch kein hardwaredefekt, sondern einfach nur die unfähigkeit von gigabyte das zu fixen ? o_O
aber zum F8 bios, das ja anscheinend das neuste zu sein scheint für das ud5h. da steht ja keine empfehlung bei blabla und ähnlichem. was bedeutet das und ähnlichem ? auf welche komponenten bezieht sich das ? denn ich kann ja schlecht raten ^^ leider find ich im forum keine infos, bin aber auch nich angemeldet bei jz. wäre cool wenn jemand mir hierzu infos geben könnte.
und ggf. ob nen neues bios bald am start is für das ud5h ?
/e: also ich hatte grad nen system freeze nach etwa einer stunde im blend test bei prime. worauf deutet das nun hin ?? isses tatsächlich was mitm ram ? vllt nich 100%ig kompatibel mit dem board ? oder kein plan.. ich hab vorher als ich den rechner neu hatte sowohl nen ganzen custom run gemacht (mit 10 minuten pro test und nich 15) als auch nen linx run mit 4096 ram eingestellt und 60 minuten (mehrmals) und blendtest auch 2-3 stunden laufen lassen und alles war 100%ig stable o_O
ich verabschiedet sich langsam das board ? bin echt enttäuscht mittlerweiel von dem dreck -.-
@cincei
flash doch einfach mal das f8! ist doch kein problem! zur not hast ja noch das backup bios!
und klemme mal alle geräte ab, die nicht unbedingt für den rechner gebraucht werden!!! auch die laufwerke, frontusb, drucker...
am besten so viel wie möglich ausbauen oder abklemmen und dann nur ncoh maus und tastatur!
jo das kann und werd ich auch gleich/nachher machen. aber wieso habich im blendtest nen freeze gehabt jetzt ?? also ich versteh nix mehr, denn anfangs lief der rechner perfekt. hab jetzt nur eine sache geändert, nämlich die command rate auf 2t gesetzt ovn auto vorher so wie du gesagt hast.
wegen temps konnte es 100%ig nich sein, ich hab nich merh als 60° im prime.. beim blendtest 55° auf cpu.. sonst bleibt alles auch kühl. im event log gibts nur einen critical eintrag ohne jegliche infos -.- nen minidump wurde auch nich erstellt hmpf :/
/e: jetzt hab ich mal das bios geflashed auf F8, aber ich hab genau das problem das andere in anderen foren beschrieben. die maus ruckelt jetzt durchgehedn und fühlt sich laggy an -.- echt lächerlich :(
/e2: mir ist noch was eingefallen. vllt hilft dir/euch das ja weiter. als ich den rechner nagelneu zusammengebaut hatte und alles! @stock laufen gelassen hab und mal den blend test angemacht habe, is mein rechner auch einmal gefreezed nach etwa ner stunde. ich wunderte mich, aber hab dann weitergetestet und er funktionierte perfekt dannach. wie gesagt, 12 stunden custom run und etliche stunden blend test usw. also nur das eine mal bei allem @stock o_O
vllt liegts doch am ram oder am board ? weil merkwürdig das er bei allem @stock einmal gefreezed is beim blend test
...was schreit ihr immer nach mir ???
ansprechpartner sind eure händler... ich kann euch auch nicht helfen (auch per PM nicht), wenn eure händler einfach die boardreklamation mit dem verweis "PINs im Sockel verbogen" oder "Kein Fehler feststellbar" zurückschicken und jetzt das board ganz kaputt ist... ob und wie das passiert sein kann, sagt auch meine glaskugel nicht... nur häufen sich leider die fälle und man will ja nichts böses denken :-/
Für alle die das selbe plagt oder plagen wird: Die Lösung war bei mir nicht die VTT- oder die IMC-Spannung...Ich musste die VDimm etwas erhöhen von 1,5V auf 1,52V im UEFI!
Jep, war bei meinem Ram ab 1866 auch so. Liegt vermutlich daran, dass Vdimm eine eigene Loadline mit Vdroop hat, d.h. die Spannung unter Last etwas abfällt.
@jz: ich hab dir noch nie irgendeine pm geschrieben ^^ ich hab meine pms ausgeschaltet. ich dacht nur da du ja mit den biosschreibern bei gb da kontakt hast könntest du vllt weiterleiten das es immernoch bootloops gibt mit dem 2500k z.b. und da ich mein problem ziemlich ausführlich beschrieben hab (bis ins detail) könntest du das ggf. weiterleiten.
aber wie auch immer, wenn nich dann halt nicht ^^ mir ist das egal im endeffekt.. bringt ja eh nix -.- (bootloops sollten schließlich schon ab F6 gefixed sein, was sie definitiv nicht sind und ich bin da nich der einzige wie man in anderen foren ließt)
Ich hate gerade auch eben 8 Versuche den PC zu booten. Nach getauschtem RAM Kit bin ich dennoch der Meinung, dass das am Board liegt. Ich denke, wenn sie da nicht bald was tut seitens Gigabyte werde ich leider auf ein anderes umsteigen müssen.
Gelegentlich hab ich die auch noch mit dem F11a auffem UD3H ... 2700K.
Nach 2 Wochen heute mal wieder, ich weiß nicht wo es herkommt und irgendwie bezweifle ich das Gigabyte das jemals in den Griff bekommen wird.
Warum zum Teufel nutzt man "UEFI" wenns ein einzige Bughaufen ist? Einfach das gute alte blaue BIOS, dann hätten wir diese ganze Scheisse jetzt sicher nicht...
