[Sammelthread] Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI / (Z77)
Willkommen im
Gigabyte (GA-) Z77X-D3H / UD3H / UDH3-WB WIFI / UD5H / UD5H-WB WIFI (Z77) - Sammelthread​
xxxInhaltsverzeichnis:
xxxGigabyte GA-Z77X - D3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
1.Support for Intel® Core™ i7 processors/Intel® Core™ i5 processors/ Intel® Core™ i3 processors/Intel® Pentium® processors/Intel® Celeron® processors in the LGA1155 package
2.L3 cache varies with CPU
(Please refer "CPU Support List" for more information.)
Chipset
1.Intel® Z77 Express Chipset
Memory
1.4 x 1.5V DDR3 DIMM sockets supporting up to 32 GB of system memory
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB.
2.Dual channel memory architecture
3.Support for DDR3 1600/1333/1066 MHz memory modules
4.Support for non-ECC memory modules
5.Support for Extreme Memory Profile (XMP) memory modules
(Please refer "Memory Support List" for more information.)
Onboard Graphics
Chipset: 1.1 x D-Sub port
2.1 x DVI-D port, supporting a maximum resolution of 1920x1200
* The DVI-D port does not support D-Sub connection by adapter.
3.1 x HDMI port, supporting a maximum resolution of 1920x1200
Audio
1.VIA VT2021 codec
2.High Definition Audio
3.2/4/5.1/7.1-channel
4.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
1.1 x PCI Express x16 slot, running at x16 (PCIEX16)
(The PCIEX16 slot conforms to PCI Express 3.0 standard.)
* For optimum performance, if only one PCI Express graphics card is to be installed, be sure to install it in the PCIEX16 slot.
* The PCI Express x16 slot supports up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
2.1 x PCI Express x16 slot, running at x8 (PCIEX8)
* The PCIEX8 slot shares bandwidth with the PCIEX16 slot. When the PCIEX8 slot is populated, the PCIEX16 slot will operate at up to x8 mode.
3.1 x PCI Express x16 slot, running at x4 (PCIEX4)
* The PCIEX4 slot shares bandwidth with the PCIEX1_1/2/3 slots. The PCIEX1_1/2/3 slots slots will become unavailable when a PCIe x4 expansion card is installed.
4.3 x PCI Express x1 slots
(PCIEX8, PCIEX4 and PCIEX1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slots
Multi-Graphics Technology
1.Support for 2-Way AMD CrossFireX™/NVIDIA SLI technology (PCIEX16 and PCIEX8)
* The PCIEX16 slot operates at up to x8 mode when AMD CrossFireX™/NVIDIA SLI is enabled.
Storage Interface
Chipset: 1.2 x SATA 6Gb/s connectors (SATA3 0/SATA3 1) supporting up to 2 SATA 6Gb/s devices
2.4 x SATA 3Gb/s connectors (SATA2 2~SATA2 5) supporting up to 4 SATA 3Gb/s devices
3.1 x mSATA connector
* The SATA2 5 connector will become unavailable when the mSATA connector is installed with a solid state drive.
4.Support for RAID 0, RAID 1, RAID 5, and RAID 10
* When a RAID set is built across the SATA 6Gb/s and SATA 3Gb/s channels, the system performance of the RAID set may vary depending on the devices being connected.
1 x Marvell 88SE9172 chip: 1.2 x SATA 6Gb/s connectors (GSATA3 6/GSATA3 7) supporting up to 2 SATA 6Gb/s devices
2.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports can support up to USB 2.0 transfer speed.
2.Up to 6 USB 2.0/1.1 ports (2 ports on the back panel, 4 ports available through the internal USB headers)
VIA VL800 chip: 1.Up to 4 USB 3.0/2.0 ports on the back panel
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the VIA USB 3.0 controller driver is installed.
Internal I/O Connectors
1.1 x 24-pin ATX main power connector
2.1 x 4-pin ATX 12V power connector
3.4 x SATA 6Gb/s connectors
4.4 x SATA 3Gb/s connectors
5.1 x mSATA connector
6.1 x CPU fan header
7.3 x system fan headers
8.1 x front panel header
9.1 x front panel audio header
10.1 x S/PDIF Out header
11.1 x USB 3.0/2.0 header
12.2 x USB 2.0/1.1 headers
13.1 x serial port header
14.1 x Clear CMOS jumper
15.1 x Trusted Platform Module (TPM) header
Back Panel Connectors
1.1 x PS/2 keyboard/mouse port
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x HDMI port
5.6 x USB 3.0/2.0 ports
6.2 x USB 2.0/1.1 ports
7.1 x RJ-45 port
8.1 x optical S/PDIF Out connector
9.5 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
1.iTE I/O Controller Chip
H/W Monitoring
1.System voltage detection
2.CPU/System temperature detection
3.CPU/System fan speed detection
4.CPU overheating warning
5.CPU/System fan fail warning
6.CPU/System fan speed control
* Whether the CPU/system fan speed control function is supported will depend on the CPU/system cooler you install.
BIOS
1.2 x 64 Mbit flash
2.Use of licensed AMI EFI BIOS
3.Support for DualBIOS™
4.PnP 1.0a, DMI 2.0, SM BIOS 2.6, ACPI 2.0a
Unique Features
1.Support for @BIOS
2.Support for Q-Flash
3.Support for Xpress Install
4.Support for Xpress Recovery2
5.Support for eXtreme Hard Drive (X.H.D)
6.Support for Auto Green
7.Support for ON/OFF Charge
8.Support for Q-Share
9.Support for 3D Power
10.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
1.Norton Internet Security (OEM version)
2.Intel® Smart Response Technology
3.Intel® Rapid Start Technology
4.LucidLogix Virtu MVP
* Make sure the monitor cable has been connected to the integrated graphics port on the back panel.
Operating System
1.Support for Microsoft® Windows 7/XP
Form Factor
1.ATX Form Factor; 30.5cm x 24.4cm
Remark
1.Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website.
2.Most hardware/software vendors may no longer offer drivers to support Win9X/ME/2000/XP SP1/SP2. If drivers are available from the vendors, we will update them on the GIGABYTE website.
Links:
- Preisvergleich
- Produktseite / Info beim Hersteller
- Downloads: Bios, Treiber, Handbuch,...
xxxGigabyte GA-Z77X - UD3H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600
Audio
1.VIA VT2021 codec
LAN
1.Atheros GbE LAN chip (10/100/1000 Mbit)
Expansion Slots
(The PCIEX16 and PCIEX8 slots conform to PCI Express 3.0 standard.)
* The PCI Express x16 slots support up to PCI Express 2.0 standard when an Intel 32nm (Sandy Bridge) CPU is installed.
* The PCIEX4 slot shares bandwidth with all PCI Express x1 slots. All PCI Express x1 slots will become unavailable when a PCIe x4 expansion card is installed.
(The PCIEX4 and PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
Storage Interface
2.4 x SATA 3Gb/s connectors (SATA2 2~5) supporting up to 4 SATA 3Gb/s devices
Marvell 88SE9172 chip: 1.2 x eSATA 6Gb/s connectors on the back panel supporting up to 2 SATA 6Gb/s devices
USB
Chipset: 1.Up to 4 USB 3.0/2.0 ports (2 ports on the back panel, 2 ports available through the internal USB header)
2.Up to 6 USB 2.0/1.1 ports (available through the internal USB headers)
* Due to a Windows 7 limitation, please connect your USB device(s) to the Intel controlled USB port(s) (located below the RJ-45 LAN port) before the VIA USB 3.0 controller driver is installed.
2.1 x 8-pin ATX 12V power connector
3.1 x PCIe power connector
4.2 x SATA 6Gb/s connectors
5.4 x SATA 3Gb/s connectors
6.1 x mSATA connector
7.1 x CPU fan header
8.4 x fan headers
9.1 x front panel header
10.1 x front panel audio header
11.1 x S/PDIF Out header
12.3 x USB 2.0/1.1 headers
13.1 x USB 3.0/2.0 header
16.1 x power button
17.1 x reset button
18.1 x Clear CMOS button
19.1 x Voltage Measurement Points
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
4.1 x optical S/PDIF Out connector
5.1 x HDMI port
6.1 x DisplayPort
7.2 x eSATA 6Gb/s connectors
8.6 x USB 3.0/2.0 ports
9.1 x RJ-45 port
10.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
5.Support for EasyTune
* Available functions in EasyTune may differ by motherboard model.
6.Support for eXtreme Hard Drive (X.H.D)
7.Support for Auto Green
8.Support for ON/OFF Charge
9.Support for Q-Share
10.Support for 3D Power
11.Support for LAN Optimizer (Intelligent optimization network management tool)
Bundle Software
2.Intel® Rapid Start Technology
3.Intel® Smart Connect Technology
4.Intel® Smart Response Technology
5.LucidLogix Virtu MVP
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD3H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
1.VIA VT2021 codec
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
8.4 x fan headers
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
2.1 x D-Sub port
3.1 x DVI-D port
5.1 x HDMI port
6.1 x DisplayPort
9.1 x RJ-45 port
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
4.1 x DisplayPort, supporting a maximum resolution of 2560x1600p
Audio
1.Realtek ALC898 codec
2.Support for X-Fi Xtreme Fidelity® and EAX® Advanced HD™ 5.0 technologies
3.High Definition Audio
4.2/4/5.1/7.1-channel
5.Support for S/PDIF Out
LAN
1.1 x Atheros GbE LAN chip (10/100/1000 Mbit) (LAN1)
2.1 x Intel GbE LAN chip (10/100/1000 Mbit) (LAN2)
Expansion Slots
* The PCIEX4 slot is available only when an Intel 22nm CPU is installed.
* The PCIEX4 slot shares bandwidth with the PCIEX8 and PCIEX16 slots. When the PCIEX4 slot is populated, the PCIEX16 slot will operate at up to x8 mode and the PCIEX8 will operate at up to x4 mode.
(The PCIEX16, PCIEX8 and PCIEX4 slots conform to PCI Express 3.0 standard.)
(All PCI Express x1 slots conform to PCI Express 2.0 standard.)
5.1 x PCI slot
1.Support for AMD CrossFireX™ / NVIDIA SLI technology
Storage Interface
2 x Marvell 88SE9172 chips: 1.3 x SATA 6Gb/s connectors (GSATA3 6/7/8) supporting up to 3 SATA 6Gb/s devices
2.1 x eSATA 6Gb/s connector on the back panel supporting up to 1 SATA 6Gb/s device
3.Support for RAID 0 and RAID 1
USB
Chipset: 1.Up to 2 USB 3.0/2.0 ports (available through the internal USB headers)
Chipset + 2 VIA VL810 Hubs: 1.Up to 8 USB 3.0/2.0 ports (4 ports on the back panel, 4 ports available through the internal USB headers)
* In Windows XP, the Intel USB 3.0 ports and VIA VL810 HUB can support up to USB 2.0 transfer speed.
* Due to a Windows 7 limitation, please connect your USB device(s) to the USB 2.0/1.1 port(s) before the Intel USB 3.0 controller driver is installed.
IEEE 1394
VIA VT6308 chip: 1.Up to 2 IEEE 1394a ports (1 port on the back panel, 1 port available through the internal IEEE 1394a header)
4.5 x SATA 6Gb/s connectors
8.4 x system fan headers
12.3 x USB 3.0/2.0 headers
13.2 x USB 2.0/1.1 headers
16.1 x power button
17.1 x reset button
19.1 x heatsink LED power connector
20.1 x BIOS Switch
21.Voltage Measurement Points
1.1 x D-Sub port
2.1 x DVI-D port
3.1 x optical S/PDIF Out connector
4.1 x HDMI port
5.1 x DisplayPort
6.1 x eSATA 6Gb/s connector
7.4 x USB 3.0/2.0 ports
8.2 x USB 2.0/1.0 ports
9.1 x IEEE 1394a port
10.2 x RJ-45 ports
11.6 x audio jacks (Center/Subwoofer Speaker Out, Rear Speaker Out, Side Speaker Out, Line In/Mic In, Line Out)
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxGigabyte GA-Z77X - UD5H - WB WIFI
Layout:
weitere Bilder:
Spezifikationen:
CPU
Chipset
Memory
Onboard Graphics
Audio
LAN
Expansion Slots
5.1 x PCI slot
Storage Interface
USB
IEEE 1394
16.1 x power button
17.1 x reset button
20.1 x BIOS Switch
1.1 x D-Sub port
2.1 x DVI-D port
4.1 x HDMI port
5.1 x DisplayPort
10.2 x RJ-45 ports
I/O Controller
H/W Monitoring
BIOS
1.2 x 64 Mbit flash
Unique Features
1.Support for @BIOS
Bundle Software
Operating System
Form Factor
Remark
Links:
- Preisvergleich
xxxWeitere Infos und nützliche Links:
Infos:
Per Software (Speedfan) regelbare Lüfteranschlüsse: (über ITE IT8728)
Sys_Fan1: Ja
Sys_Fan2: Nein
Sys_Fan3: Nein
Sys_Fan4: Nein
CPU_Fan: Ja
Links:
- Gigabyte Z77 motherboards shown off at CES
- Die offiziellen Z77 Pressenews aus dem Gigabyte Forum
- GIGABYTE CeBIT 2012 Highlight
xxxKompatibilität Arbeitsspeicher:
xxxKompatibilität CPU Kühler:
Liste mit passenden Lüftkühler:
- Noctua NH-D14 (Sockel 775/1155/1156/1366/AMD/AM2/AM2+/AM3/AM3+/FM1)
- Phanteks PH-TC14PE (Sockel 1155/1156/1366/AM2/AM3) alle Richtungen montierbar
- Prolimatech Genesis Kühlkörper (Sockel 775/1155/1156/1366/AM2/AM2+/AM3/AM3+/FM1) / überdeckt den 1 PCIe Slot / RAM-Höhe beachten!
- Thermalright True Spirit 140 (Sockel AM2/AM2+/AM3/775/1155/1156/1366) verdeckt nicht den 1.Slot
Liste mit passenden Wasserkühler:
- So wie ich das bei meinem UD5H sehe, kann man den Heatkiller 3.0 wieder in allen Richtungen beim Z77X montieren. Beim Gigabyte Z68X waren ja Kondensatoren im Weg!
xxxReviews / Unboxing:
xxxSupport JZ electronic:
Infos:
- Einstellung Lüftersteuerung:
Links:
- BIOSe und News von JZ electronic
Gruß -Elle-
...ich weiß nicht woher eure bootloops kommen, aber bei mir tritt das nicht auf... mache täglich sets mit den boards und z.Z. habe ich zwei mit UD3H, eins mit UD5H und ein X79-UD5 am probelaufen...
ich kann nur eins sagen, dass ich noch nie soviele neue speicher defekt hatte :-((((((
Achja, CiNCEi, spar dir die Zeit und Nerven... (und uns die langen Texte) :d
Ich hatte genau die selben Probleme, habe 4 Ram Kits ausprobiert.... No way.
Du hast imo 3 bzw. 4 sinnvolle Optionen:
- Bau dir nen Ivy ein und die Loops hören sofort auf.
- Probier nen anderes NT, die Gigabyte Boards sind da wohl etwas zickig. Mit Seasonic NT scheinen sie meist problemlos zu laufen
- Hol dir nen anderes Mainboard
- Warte und Hoffe auf nen UEFI Fix, aber da JZ_ und andere Leute diese Probleme nicht haben weiß ich nicht ob das überhaupt auf GBs TODO Liste steht bzw. für sie Priorität hat.
/edit: Lese grade Blend Test Freeze... auch bei Stock? Das darf/sollte nicht sein!
Also ich hab mit meinem UD5H auch noch nicht einen Bootloop gehabt, keine RAM Probleme.
Nur halt diese Meldung USB-Überspannung, die ich nicht einschätzen kann. Es liegt dort aber immer Spannung an, auch wenn kein Gerät dranhängt ? Gibt es hier Einstellmöglichkeiten im Bios ?
@JZ_: Wir sind doch alle froh, das Du alle so in Sachen Gigabyte unterstützt. Vielen Dank nochmals dafür. Ne PN hab ich auch nicht geschrieben, muß auch nicht sein. Du wirst genug zu tun haben.
...habe auch viele kunden, die noch sandy damit nutzen und noch keine probleme damit gehört
kann gerne mal ein UD3H/UD5H mit ner 2600K testen... was soll ich einstellen ?
oder besser das neueste BIOS drauf machen ...beim UD3H das F11b und beim UD5H das F8d... dann das profil abspeichern und mir per email zu kommen lassen und ich prüfe das dann :-)
ok danke für eure antworten.
@jz: ja das problem is ja nich das es täglich passiert oder einfach alle 5 starts. es passiert so selten, das ich nich weis inwiefern du das überhaupt austesten kannst. ausser du schaltest jede konfig die betroffen sien kann (also potentielle problemkandidaten) min. 30-50 mal ein. denn bei 30-50 starts hab ich in etwa 2 bootloops o_O nich viel, aber ich mach mir nur sorgen das diese bootloops nix anderes auf dauer kaputt machen. ich mein wenn mir jemand bestätigt das die bootloops keinerlei einfluss haben auf andere komponenten und der rechner auch so 5 jahre lang laufen kann, würde mich das nich soo stören :)
@ralle: ja ok.. ich weis das keiner mich hier mag.. is mir auch gleichgültig :) ich bin auch gleich wieder raus aus dem thread und ihr habt wieder ruhe von mir ;)
mitm ivy sind die loops 100%ig gefixed ? also das is ne sichere sache ? vllt wechsel ich dann doch noch kurzfristig.
an meinem nt sollte es eigentlich nicht liegen oder ? ich mein ich hab so eins der besten seasonic aufm markt von daher o_O
n anderes mobo holen hm.. ja ^^ ma schaun ne.. so langsam hab ich die schnauze voll von gigabyte.
/e: das F8d is besser als das F8 ?? hab jetzt das F8 draufgeflashed vorhin.. alles einstellungen identisch gesetzt wie vorher mitm F7er. wie speichert man profile auf usb stick oder ähnliches ?
F8 kannste lassen... ist identisch mit der F8d bis auf die Logitech G510 / Corsair USB Tastatur Fixe...
hä, du kannst doch bei "Save Profile" ein USB Stick auswählen... vielleicht sehe ich was in deiner einstellung und kann dir damit helfen...
So war das nicht gemeint. Nur sind die langen Texte ohne Groß- und Kleinschreibung sowie Satzzeichen wirklich sehr schwer zu lesen. Außerdem holst du immer sehr weit aus.... prinzipiell ist das natürlich dein gutes Recht, aber wenn man Hilfe sucht nicht unbedingt ideal - denn die meisten Leser werden dadurch erstmal vom Lesen abgeschreckt (und selbst ich, der dir wirklich gerne helfen will, musste mich seeeehr stark überwinden mich durch deine Posts zu kämpfen).
Nicht böse gemeint, nur so als Denkanstoß ;)
Ich hatte mit Sandy fast in 50% aller Fälle diese Bootloops. Ab BIOS F5 Final dann nur noch, so wie du beschreibst, bei 50 Boots 1-2 mal. Seit ich Ivys teste hatte ich bei 5 CPUs und ca. 200-300 Boots keine einzige Bootschleife mehr.
Ist ne Vermutung, soll schon Abhilfe geschaffen haben. Wär aber mehr oder weniger nen "Gamble" - also nen Schuss ins Dunkle. Kann helfen, muss aber nicht.
Seh ich langsam ähnlich, aber derzeit nur wegen dem eSATA Anschluss, der nach wie vor Probleme mit 3TB Platten mit GPT Partitionen hat. Aber da haben auch andere Hersteller wie ASRock und ASUS Nachbesserungsbedarf, den ASMedia Chip den sie verbauen kannst du auch in der Pfeife rauchen, wenn du eSATA oft und zuverlässig nutzen willst. MSI verbaut gar keinen mehr.... vllt. muss auch einfach nur ich umdenken und meine eSATA Dockingstation durch ein USB 3.0 Pendant ersetzen :(
F8d ist dem F8 wohl vorzuziehen.
@JZ_: Wenn du diesen Bootloops mal auf den Zahn fühlen willst. Bau nen System mit nem BQ Netzteil, Corsair Ram und ner Sandy CPU. Damit dann 50-100 mal booten, dann wirst du mit etwas "Glück" irgendwann ne Bootschleife bekomme :d
Hier wär mein BIOS. UD3H mit 2500K bei 4,5 GHz
Aber ich bin ziemlich sicher, dass es nicht wirklich an den Einstellungen liegen wird.
Hätte ich mein Geld nicht für ein 2500K verpulvert würde ich mir Ivy kaufen aber damit habe ich jetzt erstmal pech gehabt. Also wird diese Fehlerlösung für mich nicht zutreffen.
ahhh ok.. thx :) werd das mal machen und ähm.. wie dir zusenden ? am besten irgendwo kurz uploaden ne ?! ich bin grad am blend test machen weil ich damit vorhin nach ner stunde nen freeze hatte (falls du es nich gelesen hast was ich vorhin schrieb. mein rechner lief sonst 12 stunden primestable, linxstable usw. nur 2 mal hatte ich beim blendtest nach etwa ner stunde nen freeze. einmal am ersten tag mit allem auf stock und einmal vorhin). wenn er freezed odr durchläuft werd ich dann mal das profil speichern :)
hehe ok :) naaj das problem is halt das das einfach mein schreibstil is und ich den seit über 10 jahren im inet habe ;) (entwickelt durch stundenlange irc sessions früher mal als ich noch inner schule war ^^ da gabs keine groß und kleinschreibung und wenn man 5-8 stunden täglich dransitzt über jahre hinweg kommt schon was zusammen an geschriebenem :P da gewöhnt man sich halt stark an den schreibstil). ich werd versuchen mich kürzer zu fassen :)
Ich hatte mit Sandy fast un 50% aller Fälle diese Bootloops. Ab BIOS F5 Final dann nur noch, so wie du beschreibst, bei 50 Boots 1-2 mal. Seit ich Ivys teste hatte ich bei 5 CPUs und ca. 200-300 Boots keine einzige Bootschleife mehr.
hm ok gut zu wissen. ich denke mal früher oder später wechsel ich dann doch noch auf den ivy. am liebsten wäre mir erst so in nem jahr wenn vllt n neues stepping gekommen ist (wer weis ob eins kommt ^^ ich hoffe ja drauf).
F8d ist der F8 wohl auf jeden Fall vorzuziehen.
achso F8d is vorzuziehen.. hmmm ok. ich schau mal. jetzt wo ich F8 drauf hab lass ich erstmal laufen damit. wenn was is flash ich auf F8d. könntest du spezifizieren wieso F8d F8 vorzuziehen ist ? also ausser dem was JZ genannt hat irgendeinen weiteren vorteil ?
bzw. zum problem mit dem freeze im blend test vorhin. könnte es ggf. sein das der ram, bzw. die ram.mobo-cpu kombi nich mit 1600mhz klar kommt ? vllt sollt ich mal mit 1333 probieren ? ich mein ich hätte damals vor nem jahr öfters gelesen das es beim sandy und dem p67er chipsatz probleme gab mit 1600er ram
freilich kommen die "Bootloops" nicht immer vor, das wäre ja auch viel zu einfach. Nichtsdestotrotz gibt es sie, den Leuten (inkl mir) ist ja nicht einfach nur langweilig und posten deshalb sowas ;). Aus der Menge der Posts mit solchen Problemen geht doch imo klar hervor, dass die aktuellen Gigabytes noch größere Probleme mit Sandys haben.
genau so ist es romeon. und genau deshalb bin ich der meinung das gigabyte endlich mal ausm pott kommen sollte und das fixen sollte. die bewerben schließlich die mainboards offiziel! sowohl für den ivy als auch für den sandy. folglich darf man auch erwarten das beides gleichgut läuft, was es ja eindeutig nich tut. ich bin echt sauer das gb es nich hinbekommt. ich mein was soll das denn überhaupt, die können doch nich sooo unfähig sein oder ?! mitm ivy haben dies ja auch hinbekommen xD
Werden eigentlich alle USB 3.0 Anschlüsse auf dem UD5H durch einen VIA-Controller verwaltet ?
Dank JZ_ weiß ich nun, das es wohl an dem Zusammenspiel zwischen VIA-Controller und best. Netzteilen liegt, das es zu dieser Meldung bzg. USB 3.0 Überspannung kommt.
Deshalb meine Frage, gibt es auf dem UD5H USB 3.0 Anschlüsse die nicht von VIA stammen? Glaub nicht, oder ?
so.. hier mein profil JZ :)
hat nen bissl gedauert weil anscheinend das F8 bios mehr vcore braucht fürn gleichen oc ?? hast du das "ralle" mal getestet ? weil ich 2 stufen mehr anlegen musste um mein cpu linxstable zu bekommen als mitm F7er bios noch. sehr strange find ich. jetzt mit 2 stufen mehr ist er 40 minuten linx durchgelaufen. alles weitere teste ich heute abend und morgen xD
achso ich hab auch mal meinen ram auf 1333 gestellt. mal schaun ob das ne besserung gibt oder nicht. ich mein nen unterschied in der praxis ist nicht zu sehen bzgl der leistung zw. 1333 und 1600 oder ?
/e: @raffaelo: soweit ich weis sind die 2 roten die vom pch und die 4 blauen die von via
Meine ich auch CiNCEi aber die roten 2.0 am BackPanel sollten doch auch vom ChipSet sein.
We siehts bei den internen USB 3.0 aus ( die int. 2.0 sind ja vom ChipSet )?
Kann es sein, das 1 = ChipSet und 2+3 = VIA sind ?
Und welche genau sind das auf dem Back-Panel und auf dem internen Header ?
Die 4 auf dem Back-Panel sind glaub ich alle VIA, oder ?
Nun, da es keine Treiber gibt, und ich die VIA VL810 Hubs im Gerätemanager nicht sehe, sind die wohl im PCH integriert.
Welche wo sind, erkennt man glaube nur, wenn man im BIOS entsprechend deaktiviert und testet.
Ein neues Bios für das D3H in Sicht ? Ein Bekannter möchte mich steinigen weil ich ihm das Board empfohlen hab.
Läuft nicht rund mit Sandy beim ihm @ default - BSOD unter Grafiklast. (GTX 560Ti).
jup mich würd auch interessieren ob nen neues bios für das ud5h in sicht ist ? sprich in den nächsten 2-3 wochen vllt rauskommt ? das F8 gefällt mir nicht. das F7 war besser. jedoch hatte es die bootloops und ich hoffe noch das die beim F8 nich mehr vorkommen (die hoffnung stirbt bekanntlich zuletzt). wenn sie weiterhin vorkommen wechsel ich vermutlich wieder zum F7, da das runder lief. alleine wegen der niedrigeren vcore die ich brauchte für 4ghz o_O
Welches BIOS ist denn aktuell für das UD3H zu empfehlen? Nutze noch das F8G mit einem 3770k und benötige für 4,5GHZ 1,285 Vcore im BIOS (laut CPU-Z 1,260 Vcore). Das erscheint mir noch etwas viel...
Habe nur VTT auf 1,050, PLL auf 1,800 und IMC auf 0,925 gefixt. Host Clock auf 100,00Mhz gefixt, XMP Profil 1 und 16,00 eingestellt. Intel Turbo Boost ausgestellt, PWM Phase Control auf High Perf. und die Ram Spannung auf 1,50 gefixt.
Nutze Vollbestückung ( 4x4 GB Corsair LP)
UD5H:
- alle USB 3.0 Ports am hinteren ATX-Panel sind vom VIA Hub.
- die zwei internen Header auf dem Board unten rechts sind vom VIA Hub
- der interne Header neben dem ATX-Stromanschluss ist vom Z77
Also zum testen einfach das GB Frontpanel am Z77 Header anschließen.
BTW: mein ADATA Nobility Pro 32 GB USB 3.0 Stick wird am Z77-Header nie mit SuperSpeed versorgt :-(
ahh gut zu wissen. thx MacAlex :) wusste ich selbst net das die aufteilung soo aussieht.
mal zu meinem problem. hab vorhin wieder den ram auf 1600mhz gestellt (unglaublich wieviel merh lesitung das bringt. ich dachte beim sandy wäre es egal, aber ich hab im 3dmark dadurch 300pkt mehr bei physics score und beinah 100pkt mehr bei gpu, weshalb auch immer o_O) und nen linx run gemacht über 75 minuten und es war alles stable. ich nehm langsam wieder mehr und merh an das all die kleinen probleme die ich hab (hauptsächlich die bootloops ab und zu und dann die 2 freezes im blend test bei prime) vom bios abhängig sind o_O ich hoffe das gigabyte mal endlich ne gute stabile und halbwegs bugfreie bios version raushaut fürs ud5h. zeit wirds ja ne xD
morgen mach ich noch nen 18 stunden prime custom run. mal schaun was der so ergibt xD ich würde mir dennoch wünschen das vllt jemand der kontakt zu den gigabyte bios schreibern hat (soweit ich das mitbekommen haben is das ja nur JZ hier ?) einfach mal an die weiterleitet das es immernoch bootloops gibt mit dem 2500k und vermutlich auch mti anderen sandys :) ich mein mMn sollte das priorität nr. 1 sein da es keine kleinigkeit is sondern nen großer und erheblicher fehler xD die ganzen kleinigkeiten wie das ein oder 2 "elitetastaturen" nicht funktionieren usw sollten ja dahinter anstehen. zumal das board ja 100%ig kompatibel mit den ivys und den sandys sein soll.
ich hoffe ich hab mich nich zu lang gefasst grade und das es jemand auch ließt was ich geschrieben hab :) (ich merk nämlich schon wieder das es n bissl länger geworden ist -.- ich und kurzfassen is nich grad einfach :P
Ich hab gestern meine neue SSD, eine Samsung 830 bekommen und dann Windows 7 und diverse Anwendungen neu installiert. Dazu kamen diverse Neustarts, gefühlt 20-30. Nicht einmal zickte mein UD5H, keine Spur von Bootloops.
und welchen Sandy hattest du drauf? :rolleyes:
Da bei meinem Board (Z77X-D3H) der interne SATA Chipsatz defekt ist würde mich interessieren ob es ebenbürtigen Ersatz in Form einer Pcie Steckkarte gibt.
