GNOME 3 live CD / USB test image
Link zum ISO:
Index of /repositories/GNOME:/Medias/images/iso
Quelle:
Frederic Crozat blog: GNOME 3 live CD / USB test image
:edit
GNOME Shell 2.91.6 released
Changes since 2.91.5
* Implement new calendar design with Evolution Data Server integration
to show calendar appointments [David, Maxim]
- Bug fixes [Adel, Florian]
* Add DBus-activatable shell-themed dialogs for lgout and shutdown [Ray]
* Add buttons to search via Google or Wikipedia to the search
results in the overview. OpenSearch XML files can be used
to extend the options. [Maxim]
* Add a keyboard layout selector to the system status area that
shows up when a keyboard with multiple layouts is configured
[Giovanni]
* Switch the default font for the shell UI to Cantarell (distributions
that have Cantarell configured as the default for sans-serif should
patch gnome-shell.css in packaging to specify sans-serif only for
better language/font matching.) [Jakub, Owen]
* Accessibility (exposing UI via ATK to assistive technologies) [Alejandro]
- Initialize accessibility
- Add accessibility support for StWidget and StLabel
* Improve shadow support in St [Ray]
- Allow border images and gradients to be combined
- Split st-shadow into box-shadow/st-background-image-shadow/icon-shadow
- Clip background and any shadows of the background to the border
* Use Clutter effects and GL shaders to properly implement faded edges
for StScrollView [Adel]
* Work around problems with keyboard input when IBus is in use [Owen, Daiki]
* Centralize application launching and display errors in the mesage tray [Dan]
* Add a generic modal dialog base class used for run dialog and
for new system dialogs [Ray]
* Require shell extensions to declare the versions they are
compatible with [Giovanni]
* Fix ShellRecorder to work again and switch the default format to webm [Adel]
* Fix drawing of "bubbles" when pointing to items near a corner [SardemFF7]
* Add Main.get/setThemeStylesheet for extensions to modify [SardemFF7]
* UI tweaks
- Add a timeout when mousing over the application switcher popup [Adel]
- Improve "swipe scrolling in the overview" by allowing swiping anywhere
on the background and extending it the the app/search views
as well as the workspace vie w[Florian]
- Make it easier to activate a window by hovering during inter-app
drag-and-drop [Adel]
* Visual tweaks [Florian, Jon M, Luca, Owen, Ray]
* Miscellaneous bug fixes
[Adel, Bastien, Cosimo, Dan, Florian, Giovanni, Marina, Maxim, Vincent]
* Code cleanups [Adel, Florian, Marina, Maxim, Vincent]
* Build fixes [Adel, Colin, Dan, Florian, Jonathan S, Maxim]
Quelle:
http://mail.gnome.org/archives/gnome-announce-list/2011-February/msg00002.html
