//http://enbdev.com
THIS IS HLSL FILE FORMAT FOR EXECUTING ADDITIONAL
POST PROCESSING EFFECTS. MAKE THE COPY BEFORE CHANGING IT!
//keyboard controled variables
float tempF1;
float tempF2;
float tempF3;
float tempF4;
float tempF5;
float tempF6;
float tempF7;
float tempF8;
float tempF9;
float tempF0;
//global variables, already set before executing this code
float ScreenSize; //width of the display resolution (1920 f.e.)
float ScreenScaleY; //screen proportions (1.333 for 1920/1080)
//textures
texture2D texColor;
sampler2D SamplerColor = sampler_state
Texture = <texColor>;
MinFilter = LINEAR;
MagFilter = LINEAR;
MipFilter = NONE;//NONE;
AddressU = Clamp;
AddressV = Clamp;
SRGBTexture=FALSE;
MaxMipLevel=0;
MipMapLodBias=0;
struct VS_OUTPUT_POST {
float4 vpos : POSITION;
float2 txcoord : TEXCOORD0;
struct VS_INPUT_POST {
float3 pos : POSITION;
VS_OUTPUT_POST VS_PostProcess(VS_INPUT_POST IN)
VS_OUTPUT_POST OUT;
float4 pos=float4(IN.pos.x,IN.pos.y,IN.pos.z,1.0);
OUT.vpos=pos;
OUT.txcoord.xy=IN.txcoord.xy;
return OUT;
//--------------------Fast Approximate Anti-Aliasing --------------------------
// FXAA v2 CONSOLE by TIMOTHY LOTTES @ NVIDIA
// Ported to ENBSeries by MysTer92 (Svyatoslav Gampel)
float4 PS_PostProcess(VS_OUTPUT_POST i) : COLOR
#define FXAA_SUBPIX_SHIFT (1.0/8.0)
#define FXAA_REDUCE_MIN (1.0/32.0)
#define FXAA_REDUCE_MUL (1.0/16.0)
#define FXAA_SPAN_MAX 15.0
half2 rcpFrame = half2(1/ScreenSize, 1/(ScreenSize/ScreenScaleY));
half4 posPos;
posPos.xy = i.txcoord.xy;
posPos.zw = posPos.xy - (rcpFrame.xy * (0.5 + FXAA_SUBPIX_SHIFT));
half3 rgbNW = tex2D(SamplerColor, posPos.zw ).xyz;
half3 rgbNE = tex2D(SamplerColor, posPos.zw + half2(rcpFrame.x, 0.0) ).xyz;
half3 rgbSW = tex2D(SamplerColor, posPos.zw + half2(0.0, rcpFrame.y) ).xyz;
half3 rgbSE = tex2D(SamplerColor, posPos.zw +rcpFrame.xy ).xyz;
half3 rgbM = tex2D(SamplerColor, posPos.xy).xyz;
half3 luma = half3(0.299, 0.587, 0.114);
half lumaNW = dot(rgbNW, luma);
half lumaNE = dot(rgbNE, luma);
half lumaSW = dot(rgbSW, luma);
half lumaSE = dot(rgbSE, luma);
half lumaM = dot(rgbM, luma);
half lumaMin = min(lumaM, min(min(lumaNW, lumaNE), min(lumaSW, lumaSE)));
half lumaMax = max(lumaM, max(max(lumaNW, lumaNE), max(lumaSW, lumaSE)));
half2 dir;
half lumaNWNE = lumaNW + lumaNE;
half lumaSWSE = lumaSW + lumaSE;
dir.x = -((lumaNWNE) - (lumaSWSE));
dir.y = ((lumaNW + lumaSW) - (lumaNE + lumaSE));
half dirReduce = max( (lumaSWSE + lumaNWNE) * (0.25 * FXAA_REDUCE_MUL),
FXAA_REDUCE_MIN);
half rcpDirMin = 1.0/(min(abs(dir.x), abs(dir.y)) + dirReduce);
dir = min(half2( FXAA_SPAN_MAX, FXAA_SPAN_MAX),
max(half2(-FXAA_SPAN_MAX, -FXAA_SPAN_MAX),
dir * rcpDirMin)) * rcpFrame.xy;
half3 rgbA = (1.0/2.0) * (
tex2D(SamplerColor, posPos.xy + dir * (1.0/3.0 - 0.5) ).xyz +
tex2D(SamplerColor, posPos.xy + dir * (2.0/3.0 - 0.5) ).xyz);
half3 rgbB = rgbA * (1.0/2.0) + (1.0/4.0) * (
tex2D(SamplerColor, posPos.xy + dir * (0.0/3.0 - 0.5) ).xyz +
tex2D(SamplerColor, posPos.xy + dir * (3.0/3.0 - 0.5) ).xyz);
half lumaB = dot(rgbB, luma);
if((lumaB < lumaMin) || (lumaB > lumaMax))
return half4(rgbA, 1.0);
return float4(rgbB, 1.0);
//--------------------Fast Approximate Anti-Aliasing Techniques -------------
technique PostProcess
pass P0
VertexShader = compile vs_3_0 VS_PostProcess();
PixelShader = compile ps_3_0 PS_PostProcess();
FogEnable=FALSE;
ALPHATESTENABLE=FALSE;
SEPARATEALPHABLENDENABLE=FALSE;
AlphaBlendEnable=FALSE;
FogEnable=FALSE;
SRGBWRITEENABLE=FALSE;
technique PostProcess2
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess3
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess4
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess5
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess6
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess7
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess8
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess9
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess10
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess11
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess12
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess13
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess14
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
technique PostProcess15
pass P0
FogEnable=FALSE;
FogEnable=FALSE;
