Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
Hi guys, Can i fit the alpenföhn 240 or 280 liquid coolers in the Bequiet!pure base 500dx case?
According to the manual 240 mm is the max for a top radiator, but a 360 mm front radiator is possible. But a front radiator will reduce the space for a GPU. I've got 2 of these cases - in one I use a Noctua NH-U14S, in the other one a Noctua NH-D15. Both work very well. Btw. I think AIOs are crap.
Hi there!
I got an Arctic Liquid Freezer II 280 for a 5700X in the front of the BQ 500DX and it fits perfectly well.
280mm won't fit at the top, 240mm is max there.
Not sure if a 240 will handle the 5800X thgh!?!
