benchmarking utility, written by intel_hasser
Version C 1.1.8.10
Timer Resolution: 2801104568 Hz
Compiled for AMD K7
dhrystone 2 benchmark:
VAX rating: 4075.8863 VAX MIPS
dhrystone rating: 7161.3322 kilo dhrystone/s
integer mandelbrot benchmark:
calculated area (-0.300,0.450)-(0.300,1.050) every 0.015 with maxdepth of 255
result: 995.1951 it/s
integer result: 6771.4933 MOPS (million operations per second)
data throughput: 24601.9596 MB/s (register/cache/ram - only data)
whetstone benchmark:
result: 2138.6992 MWIPS
floatpoint mandelbrot benchmark:
result: 1049.9908 it/s
float result: 2019.0188 MOPS (million operations per second)
data throughput: 21124.4874 MB/s (register/cache/ram - only data)
memory bandwith benchmark:
measurement 1
blksize int32 read int32 write int64 read int64 write float64 read float64 write
1 kB 15249.2 MB/s 21334.0 MB/s 17622.0 MB/s 15978.4 MB/s 15095.7 MB/s 14528.1 MB/s
4 kB 21948.0 MB/s 21340.2 MB/s 17428.9 MB/s 15832.5 MB/s 16992.8 MB/s 15066.6 MB/s
8 kB 23327.9 MB/s 20972.9 MB/s 17693.7 MB/s 16049.0 MB/s 17077.6 MB/s 15351.8 MB/s
16 kB 24483.9 MB/s 21148.8 MB/s 17839.9 MB/s 16151.7 MB/s 17390.1 MB/s 15538.8 MB/s
24 kB 24898.3 MB/s 21155.3 MB/s 17803.4 MB/s 16124.6 MB/s 17505.6 MB/s 15586.3 MB/s
32 kB 25112.3 MB/s 21245.0 MB/s 17905.0 MB/s 16203.6 MB/s 17562.2 MB/s 15617.3 MB/s
48 kB 25321.7 MB/s 21278.8 MB/s 17928.0 MB/s 16228.7 MB/s 17607.7 MB/s 15638.9 MB/s
64 kB 25300.2 MB/s 21270.2 MB/s 17799.3 MB/s 16019.7 MB/s 17548.2 MB/s 15476.3 MB/s
96 kB 12214.2 MB/s 10644.4 MB/s 9989.1 MB/s 7338.2 MB/s 9029.8 MB/s 7288.4 MB/s
128 kB 12143.8 MB/s 10563.8 MB/s 9882.5 MB/s 7230.9 MB/s 8804.5 MB/s 7185.4 MB/s
192 kB 12145.8 MB/s 10562.7 MB/s 9892.5 MB/s 7225.1 MB/s 8812.1 MB/s 7188.7 MB/s
256 kB 12158.6 MB/s 10566.8 MB/s 9900.8 MB/s 7229.1 MB/s 8808.6 MB/s 7191.4 MB/s
384 kB 12156.6 MB/s 10567.4 MB/s 9902.2 MB/s 7228.7 MB/s 8817.4 MB/s 7185.8 MB/s
512 kB 12126.7 MB/s 10539.3 MB/s 9900.4 MB/s 7215.2 MB/s 8794.2 MB/s 7188.2 MB/s
768 kB 4658.2 MB/s 3269.3 MB/s 4258.4 MB/s 3086.2 MB/s 4209.6 MB/s 3090.2 MB/s
1024 kB 4654.1 MB/s 3268.2 MB/s 4256.5 MB/s 3086.8 MB/s 4207.4 MB/s 3093.1 MB/s
1536 kB 4657.7 MB/s 3273.2 MB/s 4255.7 MB/s 3091.4 MB/s 4210.5 MB/s 3095.2 MB/s
2048 kB 4653.2 MB/s 3265.3 MB/s 4251.9 MB/s 3081.7 MB/s 4202.3 MB/s 3093.1 MB/s
3072 kB 4583.0 MB/s 3264.5 MB/s 4244.9 MB/s 3062.0 MB/s 4142.0 MB/s 3069.4 MB/s
4096 kB 4548.7 MB/s 3252.5 MB/s 4214.4 MB/s 3046.8 MB/s 4105.8 MB/s 3057.0 MB/s
measurement 2
datasize COPY ADD SCALE TRIAD
float64 3304.2 MB/s 3278.6 MB/s 3872.1 MB/s 3516.0 MB/s
int32 3509.0 MB/s 1791.6 MB/s 3683.4 MB/s 2362.9 MB/s
int64 3499.4 MB/s 1624.5 MB/s 3303.3 MB/s 1690.6 MB/s
average speed
memory read: 12137.2588 MB/s
memory write: 10463.7217 MB/s
memory operation: 2952.9727 MB/s
average memory speed: 8517.9844 MB/s
bubble sort memory benchmark:
sorting random list with 655360 32bit entries
result: 897.6268 it/s
integer result: 4117.8757 MOPS (million operations per second)
data throughput: 20196.6005 MB/s (register/cache/ram - only data)
integer matrix benchmark:
using 14x14 32bit integer matrices
rating: 542.5806 it/s
prime filtering benchmark (M3):
searching all primes up to 20000000
primes found: 1270607
result: 6.1828 it/s
integer result: 1916.8445 MOPS (million operations per second)
data throughput: 11723.3807 MB/s (register/cache/ram - only data)
prime filtering benchmark (M4):
result: 3.5695 it/s
integer result: 836.8122 MOPS (million operations per second)
data throughput: 5263.9896 MB/s (register/cache/ram - only data)
prime filtering benchmark (M6):
result: 3.8419 it/s
integer result: 1620.0874 MOPS (million operations per second)
data throughput: 8057.1795 MB/s (register/cache/ram - only data)
floatpoint matrix benchmark:
rating: 414.0303 it/s
image operation benchmark:
image size of 1024x1024
rating: 131.3116
integer result: 688.7205 MOPS (million operations per second)
float result: 1376.9022 MOPS (million operations per second)
data throughput: 11032.7461 MB/s (register/cache/ram - only data)
Rating:
Rel. Rating (Calc/Mem, Cache/Mem): 1.44/0.70 0.86/1.16
Abs. Rating (Int, Float, Mem): 76.12 121.76 68.95
Category Rating (Office, MMedia): 77.10 85.87
Overall Rating (Average): 81.92
