ATX12V v2.2
Another minor revision. Added 8-pin connector for PCIe graphics cards, that delivers another 150 watts.
ATX12V v2.3
The most recent revision, effective March 2007. Efficiency recommendations were increased to 80% (with at least 70% efficiency required), and the 12 V minimum load requirement was lowered. Higher efficiency generally results in less power consumption (and less waste heat), and the 80% recommendation brings supplies in line with new Energy Star 4.0 mandates.[14] The reduced load requirement allows compatibility with processors that draw very little power during startup.[15] The absolute over current limit (240VA per rail) is no longer present, enabling 12V line to provide more than 20A per rail.
Das eine ist mit, das andere ist ohne Kabelmanagement. Sind wohl beide ok, aber nicht herausragend. Das be quiet! ist wohl das effizientere und entspricht dem neuesten Standard, das OCZ hat halt Kabelmanagement. Welches lauter ist wird dir kaum jemand sagen können. be quiet! NTs sind in der Regel leise, das OCZ hat allerdings einen größeren Lüfter.Welches von den beiden ist besser?
