Hallo ich habe gerade erst Windows 10 neu aufgesetzt und habe nun mit LatencyMon die DPC Latenzzeiten überprüft. Könnte mir jemand sagen ob die soweit ok sind? Was etwas seltsam ist das LatencyMon Windows 10 als Windows 8 erkennt. Und bei der CPU Frequenz nur 1mz erkannt. Obwohl die CPU auf 4,3hz übertaktet ist und alle c-states ausgeschaltet sind. Core temp zeigt aber soweit alles normal an. Ist das einfach nur ein Fehler in LatencyMon ? Sind die DPC Werte ok?
OS version: Windows 8 , 6.2, build: 9200 (x64)
Hardware: Gigabyte Technology Co., Ltd., Z77X-UD3H
CPU: GenuineIntel Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz
Logical processors: 8
Processor groups: 1
RAM: 16344 MB total
_________________________________________________________________________________________________________
CPU SPEED
Reported CPU speed: 3503 MHz
Measured CPU speed: 1 MHz (approx.)
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
MEASURED INTERRUPT TO USER PROCESS LATENCIES
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 115.744327
Average measured interrupt to process latency (µs): 1.761449
Highest measured interrupt to DPC latency (µs): 114.575192
Average measured interrupt to DPC latency (µs): 0.570369
REPORTED ISRs
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 49.317728
Driver with highest ISR routine execution time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Highest reported total ISR routine time (%): 0.037035
Driver with highest ISR total time: dxgkrnl.sys - DirectX Graphics Kernel, Microsoft Corporation
Total time spent in ISRs (%) 0.037074
ISR count (execution time <250 µs): 97157
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
REPORTED DPCs
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 430.108764
Driver with highest DPC routine execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 372.70 , NVIDIA Corporation
Highest reported total DPC routine time (%): 0.024027
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 372.70 , NVIDIA Corporation
Total time spent in DPCs (%) 0.037537
DPC count (execution time <250 µs): 469867
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 89
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 0
DPC count (execution time >=4000 µs): 0
REPORTED HARD PAGEFAULTS
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: svchost.exe
Total number of hard pagefaults 20013
Hard pagefault count of hardest hit process: 12969
Highest hard pagefault resolution time (µs): 1031780.852698
Total time spent in hard pagefaults (%): 0.410085
Number of processes hit: 14
PER CPU DATA
CPU 0 Interrupt cycle time (s): 2.559532
CPU 0 ISR highest execution time (µs): 49.317728
CPU 0 ISR total execution time (s): 1.198288
CPU 0 ISR count: 97116
CPU 0 DPC highest execution time (µs): 430.108764
CPU 0 DPC total execution time (s): 1.026245
CPU 0 DPC count: 366667
CPU 1 Interrupt cycle time (s): 0.118177
CPU 1 ISR highest execution time (µs): 38.759064
CPU 1 ISR total execution time (s): 0.000640
CPU 1 ISR count: 41
CPU 1 DPC highest execution time (µs): 349.962033
CPU 1 DPC total execution time (s): 0.013609
CPU 1 DPC count: 4450
CPU 2 Interrupt cycle time (s): 0.145244
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 73.276049
CPU 2 DPC total execution time (s): 0.037223
CPU 2 DPC count: 24712
CPU 3 Interrupt cycle time (s): 0.123570
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 76.588067
CPU 3 DPC total execution time (s): 0.028427
CPU 3 DPC count: 10748
CPU 4 Interrupt cycle time (s): 0.141225
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 72.591493
CPU 4 DPC total execution time (s): 0.038386
CPU 4 DPC count: 24348
CPU 5 Interrupt cycle time (s): 0.103547
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 72.634028
CPU 5 DPC total execution time (s): 0.008204
CPU 5 DPC count: 4494
CPU 6 Interrupt cycle time (s): 0.149272
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 72.380531
CPU 6 DPC total execution time (s): 0.045531
CPU 6 DPC count: 26623
CPU 7 Interrupt cycle time (s): 0.112189
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 72.366828
CPU 7 DPC total execution time (s): 0.016266
CPU 7 DPC count: 7914
