Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
Hi everyone! My Macbook Pro's USB Port is Not Working. I tried in all ports but facing the same issue. I resetted the USB port but still facing the same issue.
I had faced the same problem before. You have to perform few steps to get rid of it completely. First of all, do basic hardware testing. If it not gets resolved then Reset USB Ports. After doing both these steps and if you still face the same problem then Reset SMC. If you still face the same problem then follow this link . I hope this will help you.
