[Sammelthread] MSI Big Bang XPower II MS-7737 (X79)
MSI Big Bang XPower II (MS-7737)
LGA2011 / Intel X79
Produktlink: MSI Big Bang Xpower II | MSI Microsite
Preisvergleich: MSI Big Bang XPower II (gelistet ab 360,- Euro, Stand 12.01.2012)​
Spezifikationen & Ausstattung
  • Processor Support
    • LGA 2011 Socket
    • Second Generation Core i7 Models
  • Chipset
    • Intel X79, PLX PEX8608, ASMedia ASM1480
  • Memory Support
    • 8x DDR3 DIMM, bis zu 128GB
    • DDR3-1066 / 1333 / 1600 / 1866 (OC) / 2133 (OC) / 2400 (OC)
    • XMP Profiles
    • Quad Channel
  • Networking
    • Intel 82579V GbE LAN (10/100/1000)
    • Intel 82574L GbE LAN (10/100/1000)
  • IEEE 1394 (Firewire)
    • VIA VT6315N
    • 1x IEEE 1394 extern (Backpanel)
    • 1x IEEE 1394 intern
  • Audio
    • Creative Soundblaster X-Fi MB2 (Realtek ALC892 ALC898)
    • 8 Channel HD Audio & Jack Sensing
    • EAX Advanced HD 5.0
    • THX TruStudio Pro
  • SATA
    • 4x SATA-II (SATA3~6, Intel X79)
    • 2x SATA-III (SATA1~2, Intel X79)
    • 4x SATA-III (SATA7~10, ASMedia 1061)
    • RAID
      • Intel Matrix Storage Technology (SATA1~6)
      • Modes: AHCI, RAID 0 / 1 / 5 / 10 (Intel X79)
  • USB 3.0
    • 1x USB 3.0 intern (NEC D720200)
    • 4x USB 3.0 extern (NEC D720200)
  • Multi-BIOS II
    • 2+1 Chips (1x socketed), graphical UEFI (Click BIOS II)
    • Windows Interface
  • Form Factor
    • XL-ATX
    • 345mm x 264mm ( L x W )
Connectors & Buttons
  • Back panel
    • 1x PS/2 Keyboard / Mouse
    • Clear CMOS Button
    • 1x Coaxial S/PDIF-Out
    • 1x Optical S/PDIF-Out
    • 1x IEEE 1394
    • 4x USB 3.0
    • 6x USB 2.0
    • 2x RJ45
    • 6x Audio
  • On-Board
    • 3x USB 2.0 Pin Header
    • USB 3.0 Pin Header
    • IEEE 1394 Pin Header
    • Chassis Intrusion
    • S/PDIF-Out (3pin)
    • Front Panel Audio
    • Debug LED
    • Voice Genie connector (optional)
    • MultiConnect Panel connector (optional)
    • Power button
    • Reset button
    • OC Genie button
    • Multi BIOS button
    • Base clock buttons
    • Over-Voltage Switch
    • Voltage Check Point Set
    • 4x PCI-E CeaseFire Switches
    • 1x Multi-BIOS Button
    • 1x OC Genie Button
    • 1x Reset Button
    • 1x Power Button
Mainboard - schematisch
Backpanel
Features (Links werden nachgetragen)
  • Nvidia 4-Way SLI (Anbindung: 16+8+8+8 PCIe 3.0 Lanes, Quelle: Preisvergleich)
  • AMD Quad CrossfireX (Anbindung: 16+8+8+8 PCIe 3.0 Lanes, Quelle: Preisvergleich)
  • MSI APS (Active Phase Switching)
  • MSI Winki 3 (Quick Boot OS, feat. Browser, Messenger, Office, Backup...)
  • MSI OC Dashboard
  • MSI OC Genie II (CPU & Memory)
  • MSI V-Switch (Overvoltage Switch)
  • MSI PCIe CeaseFire Switch (PEG Control, Disable/Enable)
  • MSI Super Charger (bis zu 1.5A, iPhone, iPad, Smartphones, auch in S1/3/4/5)
  • MSI Superpipe (8mm Heatpipe)
  • MSI Control Center II (feat. Instant OC)
  • MSI Military Class II (Microsite)
    • getestet nach MIL-STD-810G
      1) Temperature Shock Test – MIL-STD-810G Method 503.5
      2) Humidity Test - MIL-STD-810G Method 507.5
      3) Vibration Test - MIL-STD-810G Method 514.6
      4) Low Pressure test - MIL-STD-810G Method 500.5
      5) High Temperature Test - MIL-STD-810G Method 501.5
      6) Low Temperature Test - MIL-STD-810G Method 502.5
      7) Shock Test - MIL-STD-810G Method 516.6
    • Next-Gen DrMOS
      • Renesas 20655 Driver Mosfets
      • 22x Phasen für CPU
      • maximale Belastbarkeit ~ 770 Watt
    • Super Ferrite Chokes (SFC)
    • Tantalum Hi-C Caps (CPU, Memory, PCH)
    • Aluminium Solid Caps (restliches Board)
  • Phase LED (for CPU, Memory, PCH, VTT, SA)
Lieferumfang & Zubehör
  • Mainboard
  • Datenträger Treiber & Utilities
  • Handbuch (PDF-Download)
  • Software Application Users Guide
  • Quick Installation Guide
  • Quick Reference Guide
  • 6x SATA cables
  • I/O Shield
  • V-Check Probes
  • USB3 Slotblende, Front-USB3 Adapter
  • eSATA Dual Slotblende (mit 2x eSATA Stromkabel)
  • 3x SLI-Bridges (ein mal extra lang)
  • CrossFireX Brücke
  • M-Connector
  • MSI X79 Overclocking Guide
Click BIOS / UEFI (Updates, Einstellungen, Bilder)
Updates: MSI Downloads
BETA Thread @ MSI-Forum: BETA-UEFI/BIOS-Versionen [E7737IMS.1xx-Releases]
Verfügbare Spannungseinstellungen:
  • CPU Core Voltage
  • System Agent Voltage (SA)
  • CPU I/O Voltage
  • CPU PLL Voltage
  • DDR CH_A/B Voltage
  • DDR CH_C/D Voltage
  • DDR CH_A CA Vref Voltage
  • DDR CH_B CA Vref Voltage
  • DDR CH_C CA Vref Voltage
  • DDR CH_D CA Vref Voltage
  • DDR CH_A DQ Vref Voltage
  • DDR CH_B DQ Vref Voltage
  • DDR CH_C DQ Vref Voltage
  • DDR CH_D DQ Vref Voltage
  • PCH 1.1 Voltage
  • PCH 1.5 Voltage
Optik
Reviews, News, Links
Kompatibilitätslisten
1) CPU-Kühler
  • Corsair H100 (Review: Vortez)
  • Noctua NH-D14 SE2011 (User: Dragon667)
  • Phanteks PH-TC14PE (User: DragonClaVV)
  • Wakühler: MSI XpowerII XSPC WaterBlock Set (14541) @ Aquatuning
  • INKOMPATIBEL Prolimatech Armageddon (User: Dragon667 - kolidiert mit Kühlkörpern)
  • INKOMPATIBEL Zalman CNPS 12X (User: Mac78 - kolidiert mit Kühlkörpern)
2) Arbeitsspeicher
  • 16GB G.Skill RipJawsZ DDR3-2133 CL9 Quad Kit (F3-17000CL9Q-16GBZH) (Review: Guru3d)
  • 16GB Corsair Vengeance Black DDR3-1866 CL9 Quad Kit (CMZ16GX3M4X1866C9) (Review: Hardware Heaven)
  • 16GB Corsair Vengeance Red DDR3-1866 CL9 Quad Kit (CMZ16GX3M4X1866C9R) (Review: Vortez)
  • 16GB G.Skill Sniper DDR3-1866 CL9 Quad Kit (F3-14900CL9Q-16GBSR) (Review: Overclockers)
  • 16GB G.Skill RipJaws-X DDR3-1866 CL9 Quad Kit (F3-14900CL9Q-16GBXL) (User: J1nX3rS)
  • 16GB G.Skill Ares DDR3-1600 CL9 Quad Kit (F3-1600C9Q-16GAO) (User: ElitePilot)
  • 8GB Corsair Vengeance LP weiß DDR3L-1600 CL9 Dual Kit (CML8GX3M2A1600C9W) (User: J1nX3rS)
3) Gehäuse (weitere Vorschläge willkommen!)
  • AeroCool Strike-X ST
  • Aerocool XPredator (User: Dragon667)
  • Antec Eleven Hundred
  • Antec P280
  • Akasa VenomToxic (AK-TOX-01BK)
  • BitFenix Shinobi XL
  • Cooler Master Cosmos II (RC-1200-KKN1)
  • Coolermaster HAF X (RC-942-KKN1)
  • Cooler Master CM Storm Trooper (SGC-5000-KKN1-GP)
  • Cubitek HPTX-Tank
  • Cubitek XL-Tank
  • HEC 98 R9BB
  • Mountain Mods Ascension*7
  • Nox Hummer USB 3.0
  • NZXT Switch 810
  • Lian Li PC-A77F
  • Lian Li PC-P80(R/N)
  • Lian Li PC-V2120
  • Lian Li PC-X500FX TYR
  • Lian Li PC-X1000 TYR
  • Lian Li PC-X2000F TYR
  • Lian Li PC-Z70
  • Silverstone Temjin SST-TJ07 (User: J1nX3rS)
  • Silverstone Temjin SST-TJ11B-W
  • Xilence Interceptor
  • Xilence Interceptor Pro
  • Xigmatek Elysium
Update: 08/2011 (aus dem Sammelthread / User-Review vom Big Bang Marshal)
Achtung: Alle Angaben ohne Gewähr.
Anhang A) Die möglichen Konfigurationen der PCIe Lanes
Aus dem Handbuch:
Nach Verwendung (Anbindung von oben nach unten):
Dieser Thread ist noch in Bearbeitung. Berichtigungen sowie Ergänzungen (jeweils unter Angabe der Quelle) und eure Unterstützung bei der Pflege dieses Threads ist ausdrücklich erwünscht. Danke & Gruß, emi
Sorry, bin am Arbeiten und habe leider keine Zeit dafür mir das genauer anzusehen.
