[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
Hallo Jean-Luc,
ich hätte da einen Vorschlag bzw eine Bitte an dich. Was hälst du davon deinen Sammelthread auch noch um ein zwei andere Modelle der Z77 Reihe zu erweitern? Ich hatte da an das G43, G45 und GD55 gedacht. Die Speicherkompatbilität dürfte sich bei den Modellen nichts nehmen und Fragen zum UEFI usw lassen sich auch quer zwischen den Modellen beantworten.
Dann gehts hier im Thread bestimmt auch richtig ab ;)
Unabhängig davon schon mal danke für das Erstellen des Threads. Ich werde ihn direkt mal in der Übersicht verlinken =)
Edit: Das G3 kannst du dir bei den Modellen sparen, das ist ein Relikt aus Z68 Zeiten^^
Jo werde es heute Abend mit hinzu fügen die anderen boards
Gesendet von meinem HTC Sensation Z710e mit der Hardwareluxx App
Suuper Thread :hail:
Dann kann ich mich hier gleich mal ausheulen :heul:
Ich habe das GD55 auch wegen Intel LAN gekauft - und nun zickt das rum. Immer, wenn ich Windows7 starte ist die Chanche 50%, ob der LAN Treiber gestartet werden kann - ich habe dann einfach kein Netzwerk.
Installiert hatte ich die Version von der MSI Homepage (v16.8 oder so) und nun die v17.0 von der Intel Seite. Das Problem ist aber immer noch da :-(
Unter Linux (Suse 12.1 64bit) funktionierte LAN bisher immer.
PS: habe das 1.30 BIOS drauf
PPS: weiß jemand, warum MSI die BIOSse vom GD55 und GD65 anders nummeriert?
Wie ist denn das UEFI bei den neuen MSI-Boards?
Immer noch "so schrecklich" wie beim H67 und Co.? (von der Optik)
Naja, gibt jetzt ClickBIOS 2 - Ist von der Effizienz immer noch nicht an der Konkurrenz (v.a. Asus) dran, aber macht optisch schon etwas her.
ah ok - hab bei Youtube ein Video gefunden. Sieht schon mal besser aus als bei den H67-Brettern (sah ja aus wie Flashwerbung mit Knubbelbuttons und Spielen...)
Hey, hab das Bord (GD 65) auch seit letzter Woche konnte es leider noch noch nicht ausprobieren, da noch kein Netzteil da ist. Hab allerdings vorab schonmal ne Frage: Wenn ich nur eine Grafikkarte benutze wird diese dann an jedem PCIe Slot mit 16x angebunden oder beim obersten ?
Aja: prolimatech megahalems passt ohne Probleme aufs Bord drauf
Beim GD55 sind am untersten Slot nur 8x verkabelt. Das kann man an den Leiterbahnen auf der Rückseite sehen.
Hast Du schon mal ins Handbuch geschaut, was dort steht?
Betreibe auf dem Board 2x CML16GX3M2A1600C10, laufen soweit problemlos. Ein Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut.
Mit nem 3770 non-K, 2+2 Lüfter auf ~700 U, m4 SSD und 2 uralte HDD liege ich bei 40-45 Watt idle mit einem Monitor (Energieverbauch nicht inkludiert) an der iGPU. Die Platten fliegen raus sobald ich Zeit hab mein System neu aufzusetzen, danach messe ich nochmal mit beiden Monitoren.
So, Z77MA-G45 bestellt :)
Hab mich auf die schnelle mal wieder für MSI entschieden. Mein H67 lief zwar nicht so rund, aber dafür H55 und P55 davor. Also, erneut eine Chance für MSI ;)
habe das MSI Z77A-GD65 mit einem i5-3570K@4200MHz, 2x8GB GEIL (7F7F7F1300000000) PN:CL10-10-10 D3-1600 und 2x4GB Corsair PN:CMX8GX3M2A1600C9 am laufen.
Weiter sind noch eine HD6950, 1x LSI9750-8i, 1x QLogic QLE2640 und eine X-Fi Titanium im System.
Mit dem ersten Bios hat das Board den FC-HBA nicht erkannt, beim aktuellen 10.5 Bios läuft alles super!
gerade in Betrieb genommen: i5-3570k + Z77MA-G45 + 2x4 GB Corsair 1333 MHz + neue Crucial M4.
Ein Traum! 7 Minuten Windows 7 Installation bis zum Desktop (vom USB-Stick). Gerade BF3 wieder draufgezogen - läuft wesentlich angenehmer! V.a. die Mapladezeiten mit der SSD...
Speedfan macht noch Mucken, Lüfter lassen sich regeln, aber die Automatik mag (noch?) nicht. Hab jetzt auch keine große Lust mehr rumzuprobieren.
hast du keine treiber probleme mit deiner X-Fi Titanium?
@all
hat einer noch ein paar bilder vom MSI-Z77A-GD65-GD55-G45-G43? würde mein gd65 ausbauen hab aber leider keine cam
Mit dem neusten Bios für's z77a-gd65 funktioniert bei mir kein Dual channel mehr... getestet mit RipJaws 1600 und Geil Value 1333 - bin wieder zurück auf das vorige bios.
Ich Idot hab natürlich erst Bios 1 dann 2 und danach meinen Ivy geköpft - dachte dann natürlich ich hab ihn kaputt gemacht ^^ Puh war doch nur das Bios ;D
der CPU-Sockel ist bei den Boards weiter Richtung PCIe gewandert oder?
Ich hab mein P55M noch nicht ausgebaut, aber es sieht schon danach aus.
Macht die Kühlerwahl nicht leichter. Der boxed ist mit dem i5-3570 ziemlich überfordert ;)
Das GD65 sollte doch SLI mit 8x/8x PCI 3.0 können? Warum zeigt mir GPU-Z dann 4x 2.0 an Oo ?? CPU ist natürlich nen Ivy
Edit: 2x gtx680
bei mir geht dual channel mit den neuen bios
nein, dachte ich mal, das Problem liegt aber der Endstufe des Motiv5.
ich hab nur probleme mit der karte
Wenn ich überhaupt so weit kommen würde ^^
Bei mir kommt Fehler 55 und er geht wieder aus.. nur im single channel konnte ich booten bzw. nur solange der Ram nur in Slot 1 und / oder 2 Steckte.
Ja und mit dem alten Bios stecken sie jetzt auch wieder da und alles funktioniert wie gehabt.
Mit dem 10.5 ging nur der 1 ( blau ) und der 2 ( schwarz ) oder auch beide zusammen. Sobalt was im 3 oder 4 steckte ging nix mehr -> Fehler 55 -> neustart -> und wieder von vorne ... Monitor ging dabei garnicht an.
Edit: Hab jetzt aber noch nen anderes Problem mit dem Board/CPU - wahrscheinlich ist eins von beidem kaputt...
Edit2: Habe jetzt viel rum getestet - hab zwar nen Problem mit dem ersten pci16x Steckplatz.. aber die Sache mit dem RAM lag wohl doch am Bios.
2x8GB GeIL Black Dragon DIMM Kit 16GB PC3-10667U CL9-9-9-24 laufen bei mir problemlos im Z77A GD55.
---------- Post added at 22:37 ---------- Previous post was at 21:47 ----------
Zum Übertakten habe ich im BIOS ne feste Vcore eingestellt. Damit taktet das GD55 im idle zwar runter, senkt aber nicht Vcore ab (den LEDs nach zu urteilen, bleiben auch alle Phasen an). Stellt man Vcore auf Auto, wird bei meiner 3570K CPU Vcore auf 0,936V (CPU-Z) abgesenkt. Mich hat interessiert, wie viele Watt man spart, wenn man die Absenkung der idle Vcore nutzt...
Gestestet @4,2GHz
BIOS Vcore [V]CPU-Z Vcore prime[V]idle [W]prime [W]
AUTO1,16051,0129,5
1,1801,16055,8130,4
Die AUTO Einstellung spart also ca. 5W im idle. Irgendwie schafft das Board auch ohne Absenkung der Spannung sparsam zu bleiben.
4,2GHz habe ich benutzt, weil bei AUTO die Vcore nur auf 1,160 (CPU-Z) hoch geht. Damit denke ich, schafft meine CPU nicht 4,3GHz stabil (auch wenn Prime ne Weile lief).
Hardware:
3570K
2x8GB Geil DDR3-1333 @1,5V
MSI Z77A GD55
MSI HD5850
640GB HDD
128GB SSD GSKILL Falcon
240GB SSD Winkom Sandforce
LiteOn DVD Brenner
FSP Aurum Gold 500W
Corad Energy Check 3000
@mibo
Kannst du nicht einfach dein System mit Auto-VCore booten und für den normalen Alltag benutzen, aber sobald du Rechenpower brauchst, einfach über MSI Control Center ein vorgespeichertes Profil mit 4,5 Ghz und fester VCore während des Windowsbetriebs auswählen? Sobald du die Rechenpower nicht mehr brauchst einfach dein Alltags-Profil wieder auswählen?
Hab meine Kiste gerade zusammengebaut, weiß jemand was das für ne kleine LED ist die über den Power anschlüssen ist ( Power, Power LED usw. ) ? Die Blinkt bei mir in unregelmäßigen Abständen.
Bis jetzt sind noch keine Probleme mit dem Arbeitsspeicher Aufgetreten
Crosair Venegeance Lp CML8GX3M2A1600C9
Msi z77 gd55
da ich mein MSI P67 GD65 Board gerne gegen ein Z77 tauschen möchte,um noch ein paar Watt im Idle zu sparen,würde ich gerne wissen:
1.Kann ich mit dem Z77-GD55 noch ein paar Watt sparen oder
2.Muss ich zu einem Z77 ITX Board (Asrock?)greifen,damit es deutlich sparsamer wird?
MFG
@mibo
Zum Laden eines anderen Profils muss ich aber Booten, oder? Damit könnte ich ja auch im BIOS direkt das Profil umschalten.
Ich finds halt schade, dass das Board im idle nicht runtervoltet.
Prinzipiell würden natürlich auch 4,2GHz reichen, aber dafür habe ich doch kein 150€ Board und ne "K" CPU gekauft ;-)
MFG
Verbrauchswerte MSI Z77A GD55 vs. GD65
http://www.hardwareluxx.de/communit...5-h77-q77-q75-b75-807580-49.html#post18799280
