[Sammelthread] MSI Z77A-GD65 / GD55 / G45 / G43 (Intel Z77)
So da es noch kein Msi-Z77A-GD65(G3) Military Class III Sammelthread gibt mach ich mal ein auf
Sammelthread MSI-Z77A-GD65-GD55-G45-G43
Bilder
Hides This Text
Lieferumfang
Hides This Text
Spezifikationen
CPU
• Supports 3rd Gen Intel® Core™ i7 / Core™ i5 / Core™ i3 / Pentium® / Celeron® processors for LGA 1155 socket
Please refer to CPU Support for compatible CPU; the above description is for reference only.
Chipset
• Intel® Z77 Chipset
Main Memory
- Unterstützung von DDR3 DIMMs 1066/1333/1600/1866*/2000/2133*/2200*/2400*/2600*/2667*/2800*(OC) DRAM (max. 32GB)
- Unterstützung des Dual-Channel Modus
* zur Unterstützung von DDR3 2200/2400/2600/2667/2800(OC) muss eine 22nm CPU von Intel installiert sein!
Slots
• 3 x PCIe 3.0 x16 slots
• 4 x PCIe 2.0 x1 slots
On-Board SATA
• SATAIII controller integrated in Intel® Z77 chipset
- Up to 6Gb/s transfer speed.
- Supports two SATA ports (SATA1~2) by Z77
• SATAIII controller integrated in ASMedia® ASM 1061 chipset
- Supports two SATA ports (SATA7~8) by ASM 1061
(If you set external SATA 6Gb/s ports to AHCI mode, we highly recommend that you install Windows 7.)
• SATAII controller integrated in Intel® Z77 chipset
- Up to 3Gb/s transfer speed.
- Supports four SATA ports (SATA3~6)
• RAID
- SATA1~6 ports support Intel Rapid Storage Technology enterprise (AHCI / RAID 0/1/5/10) by Intel Z77
USB 3.0
• 2 USB 3.0 rear I/O ports by Intel® Z77
• 2 USB 3.0 onboard connector by Intel® Z77
Audio
• Chipset integrated by Realtek® ALC898
- Flexible 8-channel audio with jack sensing
- Compliant with Azalia 1.0 Spec
LAN
• Supports one PCI Express LAN 10/100/1000 Fast Ethernet by Intel® 82579V
Multi-GPU
• Supports ATI® CrossFire™ Technology
• Supports NVIDIA® SLI™ Technology
• Supports Lucid® Virtu Universal MVP
Internal I/O Connectors
- 3 x USB 2.0 connectors
- 1 x USB 3.0 connector
- 1 x IEEE 1394 connector
- 1 x Multi BIOS Switch
- 1 x TPM Module connector
- 1 x Front Panel connector
- 1 x Front Panel Audio connector
- 1 x Chassis Intrusion connector
- 1 x Voice Genie connector (optional)
- 1 x MultiConnect Panel connector (optional)
- 1 x V-Check Points Set
- 1 x Power button
- 1 x OC Genie button
- 1 x Reset button
- 1 x Clear CMOS jumper
- CPU x 1 / System x 4 FAN connectors
Back Panel I/O Ports
- 1 x PS/2 keyboard/mouse port
- 1 x Clear CMOS button
- 1 x Coaxial S/PDIF-out port
- 1 x Optical S/PDIF-out port
- 4 x USB 2.0 ports
- 2 x USB 3.0 ports
- 1 x RJ45 LAN jack
- 1 x 6 in 1 audio jack
- 1 x HDMI® port with max. resolution up to 1920x1200 @60Hz
- 1 x DVI-D port with max. resolution up to 1920x1200 @60Hz
- 1 x VGA port with max. resolution up to 2048x1536 @75Hz
MSI Reminds You...
• HDMI, DVI-D & Graphics Card support dual-display function by any two output ports (HDMI+DVI, DVI+VGA or VGA+HDMI).
BIOS
• The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically.
• The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications.
Dimension
• 30.5cm(L) x 24.5cm(W) ATX Form Factor
Übersicht
Military Class III
MSI Mainboards stehen für Stabilität und Zuverlässigkeit. Mit Military Class III hat MSI die neueste Generation des Military Class Qualitätsstandards erreicht. Neben dem Einsatz von Hi-c CAP, SFC, und Solid CAP, integriert MSI nun zusätzlich DrMOS II, die Wieterentwicklung des bewährten DrMOS. Ein doppelter thermischer Schutz maximiert die Lebenserwartung der eingesetzten Komponenten. Alle Military Class III Komponenten haben die anspruchsvollen Prüfungen zum MIL-STD-810G Standard erfolgreich durchlaufen. Das MIL-Std-810G Zertifikat steht stellvertretend für die hohe Qualität der MSI Mainboards.
featurePic
OC Genie II
OC Genie II macht erstmals auch für ganz normale Anwender optimale Übertaktung möglich. Ohne Kompromisse für die Stabilität des Systems, werden CPU und Speicherleistung maximiert Einfach per Knopfdruck werden optimale Tuningwerte für die CPU und den Systemspeicher eingestellt. Einmal aktiviert katapuliert OC Genie II eine Core i 7 CPU der zweiten Generation auf MSI X79 Mainboards auf einen Standardtakt von 4.0 GHz. Hohe Leistung ohne Vorkenntnisse und vor allem ohne Risiko.
- OC Genie II erkennt die bestehende Hardware-Konfiguration automatisch
- OC Genie II setzt automatisch optimale Hochleistungswerte für CPU, Hauptspeicher und iGPU*
- In nur 1 Sekunde ist Übertaktung für jeden möglich.
*Die OC-Optionen von OC Genie II können je nach Modell variieren
featurePic
Die weltweit erste PCI Express Gen 3 Mainboard Marke
Mit einer Bandbreite von 32GB/s bietet PCI Express 3.0 (Gen 3) die doppelte Tranferrate von PCIe 2.0. PCIe 3.0 ist die Grundlage für extreme Spieleleistung der neuen Grafikgeneration
Vorteile von PCIe 3.0:
- Doppelte Bandbreite
- Höhere Effizienz und Kompatibilität
- Höchste Leistung für aktuelle und zukünftige PCI Express Karten
featurePic
Das erste UEFI + Software Grafik-Interface
MSI ClickBIOS II ist eine einheitliche Benutzeroberfläche, die sowohl über das UEFI BIOS als auch auf Windows-Ebene mit Maus, Tastatur oder per Touchscreen bedient werden kann.
Vorteile:
- Grafikoberfläche mit Touchscreen-Unterstützung
- Einfache Bedienung mit Mausklick oder Bildschirmberührung
- Volle Systemkontrolle inklusive Übertaktungsoptionen und Sicherheitseinstellungen
featurePic
Gaming Optimized
Increasing the thickness of the gold-plated layer in the 2-in-1 PS2 and optimized USB ports to 30um to meet the demand of professional gamers. Besides enhancing mouse sensitivity in games, these improved interfaces deliver a longer lifespan and better stability of connectors and total solution for e-sports mouse control in UEFI BIOS.
featurePic
VIRTU MVP
Uncompromised Game Response Performance
Boosts gaming responsiveness performance by intelligently reducing redundant rendering tasks in the flow between the CPU, GPU and the display.
Benefits
- Boosts responsiveness to the game at any frame rate
- Improves gaming frame rates
- Increases Vsync frame rates
- Sharpens visual quality without tearing
- Works seamlessly with hundreds of game stations
featurePic
THX TruStudio PRO
THX ist die eingetragene Marke eines High-End Video-/Audio-Wiedergabestandards für Filme, Heimkinos, PC-Lautsprecher und andere Audiogeräte. THX zertifizierte Audio-Geräte sind konzipiert um dem Anwender eine Live Atmosphäre beim Betrachten von Filmen und Vdeos zu gewährleisten. HD-Inhalte werden ultrarealistisch durch THX TruStudio Pro Qualitätssound.
Eigenschaften
- Ein HIFI-Standard zur AUdio-Wiedergabe
- Perfekte Wiedergabe hochwertiger Audioinhalte aus Filmen, Musik und Spielen.
featurePic
Super Charger
Die Nutzung mobiler Anwendungen gewinnt immer mehr an Bedeutung. Smartphones und Tablet-PCs sind ein wichtiger Teil der täglichen Informationsbeschaffung sowie der Kommunikation in der eigenen Community. Im täglichen Gebrauch verlangen die mobilen Geräte allerdings auch Energienachschub. Das Laden des Akkus über einen normalen PC USB-Ausgang dauert aber häufig lange , da die Ladefunktion nicht ausreichend gesichert ist. MSI Super Charger läuft als Programm unter Windows und sorgt für die bereitstellung der notwendigen Ladeenergie. Einmal mit dem speziellen USB- Anschluss verbunden, initiiert Super Charger über ein Signal den Ladevorgang und sorgt so für ein besonders einfaches und schnelles Laden des Smartphones oder Tablets.
Eigenschaften
- Schnelle Erkennung des angeschlossenes Geräts
- Green Power: CPU und Systemkühler werden automatisch für maximale Energieersparniss konfiguriert
- Smart Mode: 4 OC-Modi
featurePic
USB 3.0
USB 3.0 bietet mit 5Gb/s eine 10-fach schnellere Datenübertragung als USB 2.0 (480Mbps), so dass z.B. die Übertragung eines kompletten BuluRay Spielfilms weniger als eine Minute dauert. MSI stellt außerdem ein Frontpanel mit USB 3.0 ANschlüssen zur Verfügung um die Nutzung von USB 3.0 einfacher zun machen.
Eigenschaften:
- 10X schneller als USB 2.0
- Bis zu 5Gb/s Datentransferrate
- Optimal für die datenübertragung zwischen PC und externen Datenträgern
featurePic
HDMI v1.4
HDMI (High-Definition Multimedia Interface) ist das digitale Video/Audio Interface, dass 1080p High-Definition Video und 8-Kanal Surround Sound wie Dolby Digital oder DTS über einen Verbindungsstandard ermöglicht. HDMI unterstützt zudem HDCP_Schutz von BluRay-Inhalten, mit HDMI 1.4 wird die Übertragung von 3D-Inhalten möglich.
Eigenschaften:
- Voll digitale Schnittstelle für Full-HD Video, 3D-Video und 8-Kanal Audio.
- Ein Kabel für alle digitalen Inhalte
(HDMI 1.4 wird nur ab der zweiten generation der Intel® CoreTM Prozessoren unterstützt, Pentium- und Celeron-Prozessoren unerstützen HDMI 1.3)
featurePic
SATA 6Gb/s
SATA 6Gb/s bietet die doppelte Bandbreite des tarditionellen SATA 3Gb/s und erhöht die Übertragungsrate zwischen dem mainboard und internen Speichergeräten wie Festplatten mit 7200U/Min und 10.000 U/Min sowie SSDs. SATA 6Gb/s ist außerdem der zukünftige Standard für die schnelle datenübertragung mit internen Geräten.
Eigenschaften:
- 2X schneller als SATA 3Gb/s
- Bis zu 6Gb/s Datentransferrate
- Zukunftstsicherer Standard für High Speed verbindungen zu internen HDDs/SSDs
featurePic
Winki 3
Winki 3.0 ist ein kostenloses Linux basiertes Tool. Mit ultraschnellem Startverhalten und einer intuitiven mehrsprachigen Oberfläche stellt Winki 2.0 provides eine einfach anzuwendende Umgebung dar, die alle wichtigen Funktionen zur Verfügung stellt wie Internet-Zugang, Multimedia-Funktionalität, web email und Messenger.
Eigenschaften:
- Anwendungen unmittelbar nach dem Start einsetzen ohne Wartezeit
- Internetzugang auch ohne zusätzliches Betriebssystem
- Mehrsprachige Oberfläche
featurePic
APS (Active Phase Switching)
Active Phase Switching: Die APS Technologie ist eine intelligente Innovation, die hilft Energie zu sparen. Es entspringt der Idee, das Netztteil des Computers auszuschalten, sobald keine Energie mehr benötigt wird. Bei erneutem Strombedarf justiert APS die Stromzufuhr automatisch. APS erkennt die Prozessorlast selbstständig und ist in der Lage die Stromzufuhr entsprechend einzustellen. Die MSI-Technologie zur Leistungsüberwachung und -Einstellung unterscheidet sich in Zuverlässigkeit, Genauigkeit und Effizienz deutlich von den sonst üblichen softwaregestützten Lösungen. .
featurePic
M-Flash BIOS-Flash per USB-Stick
Im Vergleich zu herkömmlichen Mainboards mit zwei BIOS-Chips, zeichnet sich die M-Flash-Lösung durch zwei wichtige Vorteile aus. Neben der Vermeidung eines zusätzlichen Bausteins können die Daten auf einem mobilen Speicherstick gespeichert werden. M-Flash ermöglicht nicht nur das BIOS per Speicherstick zu aktualisieren oder zu sichern, sondern fungiert zusätzlich als mobiler BIOS-Chip, der flexibel eingesetzt werden kann.
Eigenschaften:
- Backup/Wiederherstellung des BIOS über einen beliebigen USB-Speicherstick
- Sicheres Aktualisieren des BIOS über USB
- Einfache Handhabung und mobile verfügbarkeit des BIOS-Backups
featurePic
Live Update 5
MSI Live Update 5 ist eine nützliche und leistungsfähige Software um BIOS-Versionen und Treiber ohne Risiko unkompliziert auf den neuesten Stand zu bringen. Anwender können Live Update 5 mit der Treiber-CD installieren oder per download auf den Computer laden.
Eigenschaften
- Automatische Erkennung von BIOS/Treiber/Utility Update
- Unterstützung für Microsoft Windows 98SE/ME/2000/XP/Vista/ 7 32Bit
featurePic
AMD CrossFireX
ATI CrossFireX™ ist die AMD-Lösung für den Einsatz mehrerer Grafikkarten zur Erhöhung der Grafikleistung in einem PC. ATI CrossFireX ermöglicht eine Skalierung der Grafikleistung durch den Einsatz von bis zu vier Grafikkarten gleichen Typs mit AMD-Grafikchip.
featurePic
Live Update Online
MSI Live Update Online ist eine nützliche Applikation zur Aktuialisierung von Software-, Treiber- und BIOS-Versionen. Mit dem Live Update Online Service wird die Aktualisierung einfacher und vor allem sicherer. Anwender müssen sich lediglich mit dem Download Center verninden und die Live Update-Funktion aktivieren um ein vollautomatischse Online-Update zu starten. Dank der benutzerfreundlichen Update-Funktion erhalten alle Anwender Zugang zu den neuesten Applikationen, Treibern und BIOS Versionen und können so sicherstellen, das ein Maximum an Leistung des Systems jederzeit zur Verfügung steht.
featurePic
NVIDIA SLI
Die SLI-Technologie erlaubt den Einsatz mehrerer Nvidia-Grafikkarten in einem PC. Der Anwender benötigt dazu ein Mainboard mit mindestens 2 PCI-Express 16x Steckplätzen sowie zwei gleiche Nvidia Grafikarten, die SLI-fähig sind. Mit dem Einsatz der SLI-Technologie ist eine wesentliche Leistungssteigerung insbesondere bei 3D-Spielen möglich.
featurePic
Instant OC
• Mainboard Informations-Tool
• Intelligentes automatisches Tool zur Justierung von CPU- sowie Speichertakt und zur automatischen Einstellung der Spannung
• Smart Modus: 4 Übertaktungsmodi
featurePic
3TB+ Infinity
3TB+ Infinity durchbricht nicht nur das Limit eines traditionellen BIOS. Neben der Unterstützung der neuesten 3TB Festplatten, wird außerdem die Möglichkeit aktiviert auf einer 3TB Festplatte als Boot-Disk ein 64-Bit Betriebssystem zu installieren.
Eigenschaften:
- Alle verfügbaren 3TB Festlatten werden unterstützt
- Aktivierung einer 3TB festplatte als Boot-Disk eines 64Bit Betriebssystems.
Kompatibele RAMs
Code:
Corsair DIMM 16 GB DDR3-1333 Quad-Kit-(CMX16GX3M4A1333C9, XMS)
G.Skill DIMM 16 GB DDR3-1600 Quad-Kit-(F3-1600C9Q-16GAB, Ares-Serie)
Corsair 2 x 16GB (CML16GX3M2A1600C10)
2x8GB GEIL (7F7F7F1300000000)
2x4GB Corsair PN:CMX8GX3M2A1600C9
kompatibelen LuftKühler
Code:
Noctua NH-D14 CPU-Kühler - 140/120mm
Prolimatech Genesis passt in horizontaler Ausrichtung (Überdeckung der RAM Bänke) gut
review
MSI Z77A-GD65 motherboard review
Preisvergleich
Hardwareluxx - Preisvergleich-MSI-Z77A-GD65
Tools/Treiber/Bios/Manual/Herstellerseite
Bios
Utility
Driver
Manual
Herstellerseite MSI-Z77A-GD65
Danke
Habe gerade mit Eup aus getestet das schon mal nicht
Gesendet von meinem GT-I9300 mit der Hardwareluxx App
Naja EUP aus ist die Vorraussetzung, sonst darf der PC wenn er aus ist nur unter 0,1w ziehen. Damit ist laden natürlich nicht drin.
Danke
Also, bei mir klappt es ohne Probleme mein Handy über den JUSB1 und Slotblende zu laden.
Das geht ohne Die Software und auch mit heruntergefahrenen PC.
Folgendermaßen ist USB konfiguriert:
Übrigens habe ich Eup aktiviert ;)
---------- Post added at 16:24 ---------- Previous post was at 16:15 ----------
Er scheint es wohl zu erkennen und gibt dann wohl doch Strom drauf. Jedenfalls läd er mein Handy. Kann aber sein, dass es dann nicht so schnell geht (das kann ich leider nicht sagen).
Wie macht ihr nen Screenshot im BIOS, oder ist das über Windows, wenn ja dann wundert es mich noch mehr da meins etwas anders aussieht (also Click BIOS II und Control Center)
^^iPod lässt Grüßen^^
Im UEFI geht das über F12, die Bilder werden dann auf einen eingesteckten USB-Stick gespeichert.
Die letzten Screens habe ich aber übers Click BIOSII unter Windows gemacht.
Werde das mal in 1,5 Std testen muss aktuell noch arbeiten
---------- Post added 17.02.13 at 01:51 ---------- Previous post was 16.02.13 at 22:27 ----------
gut vielen dank. also mit dem roten USB anschluss funktioniert es einwandfrei.
---------- Post added at 02:32 ---------- Previous post was at 01:51 ----------
ich dreh noch am rad. warum verstellt sich im OS immer die Vcore obwohl ich die fest eingestellt habe. könnte da jemand bitte eine erlärung abgeben für mich verständlich.. :( danke
@XoXo: Das was du einstellen kannst ist die maximale Spannung.
Das sie im Idle niedriger ist als unter Last liegt an den Energiesparmodie und ist auch gut so.
Nur höher, als die eingestellte, sollte diese unter Last nicht sein.
Ansonsten brauchst du dir keine Gedanken machen.
vielen dank
ich hatte grad den durchblick... der Prozessor läuft zwar auf 4,5 Ghz stabil nun braucht dafür jedoch um einiges mehr an spannung. aktuell lasse ich grad mit allen einstellungen auf auto, so das er sich im idle auch runtertaktet, mit 4,3 Ghz laufen welches mir mehr als genügt.
Die 200 Mhz mehr machen den Kohl auch nicht fett. Was auch von mir missverstanden wurde ist das der VID Wert im Core Temp der Wert für Vcore der CPU und der int.GPU zusammen ist. hoffe ich liege damit richtig
Könnt ihr mir vllt helfen?
Ich bin gerade dabei meinen i5 3570K zu übertakten. Habe das Z77 G45. Um überhaupt übertakten zu können, muss ich im UEFI den OC GenieII aktivieren.. dann läuft das ganze mit 4,2GHz. Interessanterweise taktet die CPU aber im Idle nicht runter (laut CPU-Z & CoreTemp). Bleibt also auf 4,2GHz - die Spannung geht hingegen runter auf ca 0,8V.
C1E und EIST sind aktiviert.
Warum zur hölle kann ich denn eigtl. nicht ohne OC Genie übertakten? Wenn ich den Multi ändern will (also doppelt drauf klicke) passiert einfach nichts. Es bleibt also auf Auto! Erst wenn ich den OC Genie aktiviere kann ich was ändern, allerdings auch erst, wenn ich ins OC Genie Customize Menu gehe. Alles sehr dämlich gelöst! Da wünsche ich mir echt ein einfaches BIOS zurück...
Hab übrigens das neuste UEFI drauf (2.9 afaik)
Killuah das gleiche problem hatte ich auch
probiere mal die + und - taste zum verstellen des Multis
Hallo, bin gerade am verzweifeln.
Welche OC Einstellungen sind beim G45 notwendig damit ein i5-3570K im Idle runter Taktet?
Edit:
gerade gelesen das killuah mit dem gleichem Problem kämpft.
Edit:
Logisch gesehen würde ich dann mit dem Turbo übertakten, aber warum wollt ihr das ihr das er sich im Idle runtertaktet? Zwischen 1,6 GHz und 3,8GHz (beides im Idle) Liegen ganze 2Watt Unterschied, sind die euch so wichtig?
Sind das echt so wenig o_O?
Ich hatte vorher einen Q6600 und da war es deutlich mehr :)
Wie genau übertaktet man denn am besten? Hab ichs mit dem OC GenieII Zeug richtig gemacht? Oder geht das auch ohne diesen Modus?
Ich finds übrigens interessant, das der Lüfter auf meinem Kühler gar nicht erst dreht. Trotzdem wird die CPU max. 62°C warm @4,2GHz unter LinX & Prime ^_^
Wtf dann hast du aber ne gute Frostbeule erwischt. Ich wollte aber erstmal nich OC, wegen Garantie und da der noch genügend power hat muss man es ja nicht riskieren. Ich hab mich noch nicht so damit beschäftigt, aber als ich das mal getestet habe, habe ich das über das Click BIOS II gemacht und ich glaube wenn du im BIOS einstellst Adjust CPU Ratio in OS (oder so ähnlich), dann musst du auch nicht jedes mal rebooten, aber wie gesagt habe es selbst noch nicht getestet.
Ich würde Spannung mal auf 1,2 setzten und Multi auf 4,5GHz und gucken ob's klappt. Wenn er bootet, sollte er wenn du keine Krücke hast, dann kannst ja mal Prime in 864k und Hacken bei Run in fft oder so setzten. Aber ich würde mir vorher mal den OC Guide durchlesen. Bin gleich am Pc, dann kann ich dir bissel Ausführlicher helfen ;)
Ich übernehme für keine folgeschäden Haftung, nur zur Absicherung :fresse: :P
---------- Post added at 15:09 ---------- Previous post was at 14:51 ----------
So hab jetzt mehr Rechenleistung, kann also losgehen :d
Netzteil: be quiet! 680W Straigt Power E9
CPU: Intel Core i5-3570k (boxed)
Mainboard:MSI Z77A-GD55
Graka:Gigabyte GTX 660 Ti OC
RAM: Corsair Vengeance LP 2*4 GB low profile 1600mhz
Monitor: Medion AKOYA X55089 + Belina 17"
Medion: 100% Kontrast+Helligkeit= 23.6W
0% Kontrast+Helligkeit= 13.4W
"Aus"= 0.3W
Belina: 100% Kontrast+Helligkeit= 31.7W
0% Kontrast+Helligkeit= 12.7W
"Aus"= 0.4W
Pc*: 38xIdle 1xMonitor(Medion)= 55.4W
38xIdle 1xMonitor(Belina)= 55.5W
38xIdle 2xMonitor= 56.7W
34xIdle 1xMonitor(Medion)= 54.9W
34xIdle 1xMonitor(Belina)= 55.0W
34xIdle 2xMonitor= 56.1W
EIST+Idle 1xMonitor(Medion)= 54.4W
EIST+Idle 1xMonitor(Belina)= 54.3W
EIST+Idle 2xMonitor= 55.6W
Last: 240W MSI Kombuster+Prime95
210W Crysis höste Einstellungen FullHD (Ohne Monitor/en)
*Als Pc habe ich noch die Eingabegeräte hinzugezählt bzw. die Monitore nicht mit hinzugezählt und zwar eine Genius-Tastatur, keine LEDs, und eine Gigabyte M6980x mit allen LEDs, weiß jetzt nicht ob das so nen unterschied macht :d
LOL. Das der Lüfter nicht lief, lag nicht an der Temp. Eins von den drei kleinen Kabeln war irgendwie aus dem Stecker gerutscht. Jetzt läuft er ^_^
Ich lass grad Prime mit 864K und Run FFT in Place laufen. Ich poste gleich mal nen Screen, weil das sieht relativ kühl aus o_O Wundert mich ein bisschen.
Danke für den Guide, mir gings aber vorallem um die Frage: wie übertaktet man richtig mit dem MSI Board :d Ich hatte vorher ein Gigabyte P35 Boad und den Q6600 @3.6GHz. Im BIOS habe ich mich deutlich besser zurecht gefunden. Ich dachte beim MSI Board eigentlich, dass man diesen OC Genie quark nicht benötigt, aber scheinbar doch?!
Hier mal ein vorläufiger Screen:
Irgendwie kommt mir die VCore sehr niedrig vor (die in CPU Z angezeigt wird).
CoreTemp und HWInfo zeigen 1.17V an (was stimmen sollte, da ich im UEFI auf 1.8V gestellt habe)
Ne brauchst du nicht, ich zumindest nicht. Habe im Click BIOS II einfach den Multi eingestellt und fertig und ich glaube wenn du einfach den Knopf zum Auto OC drükst und dann ins BIOS gehst kannst du auch dort den Multi frei einstellen, wie gesagt ich selbst habe es noch nicht ausgetestet und Lust jetzt nochmal ins BIOS zu gehen habe ich auch nicht :d
..., aber warum wollt ihr das ihr das er sich im Idle runtertaktet? Zwischen 1,6 GHz und 3,8GHz (beides im Idle) Liegen ganze 2Watt Unterschied, sind die euch so wichtig?
Bei deinem Ipod mag das mit den 2 Watt hinhauen beim PC hast du aber eine Null vergessen.
Bei mir sind es komplett PC inkl. sämtlicher Peripherie im Leerlauf
feste Vcore/Multi ~128Watt
und mit Absenkung ~ 110Watt
wegen deinen angeblichen 2 Watt Einsparung würde sich weder Intel noch sonst ein MB Hersteller die Mühe machen und solche Mechanismen einbauen.
So hatte dann doch noch lust mal kurz ins BIOS zu hüpfen. Du musst es einfach auswählen und dann mit "+" und "-" deinene gewünschten Multi einstellen. Das mit dem Mauszeiger sollte man nicht so ernst nehmen, ist zwar manchmal ganz nützlich und schön, aber noch nicht ausgereift. Hast du eigentlich schon die BIOS Version 1.8 drauf?
---------- Post added at 15:51 ---------- Previous post was at 15:48 ----------
Was hast du denn für ein hungriges System :eek:?
"Aus"= 0.3W
"Aus"= 0.4W
Entschuldigung es sind 1 Watt
Glaube die 1.8 Version ist für das Z77MA G45
@SlotkuehlerXXL
wie kann ich denn einstellen, dass er den Multi im Idle absenkt? Die VCore wird abgesenkt, nur Multi eben nicht. Dh. er bleibt bei 4,2GHz.
Negativ, fürs MSI-Z77A GD 55 ist 1.8 das neuste.
Ich weiß leider nicht wie,wo und ob man überhaupt mit dem Turbo OC kann, aber warum ist dir das so wichtig, so hast du mehrleistung/bist bissel schneller unterwegs und hast kaum nen höheren Verbrauch.
Direkt über die Ziffern-Tasten kann man den Multi auch eintippen. ;)
Ich habs erstmal bequem übers ControllCenter gemacht und dann den finalen OC im UEFI gespeichert. :angel:(einfacher gehts kaum.)
---------- Post added at 18:32 ---------- Previous post was at 18:22 ----------
Prinzipjell ist deine Denkensweise logisch und richtig, doch leider ist das mit dem Turbo in der Praxis nicht so toll wie in der Theorie.
Der Intel Turbo 2.0 geht leider mit max. 2 Kernen, wobei die anderen (unbenutzten) Kerne im s3 modus sein müssen, bevor der Turbo in Kraft treten kann.
Dazu kommt noch, dass die aktuellen Windowsversionen eher die Last auf alle vier o.ä. Kerne verteilen, statt auf nur zwei. So wird der Turbo kaum aktiv.
Windows schiebt oft auch Prozesse von Kern zu kern, was auch suboptimal ist.
In der Praxis ist der Turbo noch nicht wirklich sinnvoll nutzbar und selten spürbar.
Man hat mehr davon, wenn man unabhängig vom Turbo übertaktet (leider).
Ja das mit den Lasten Verschiebungen bemerke ich Selbst immer wenn der Pc an ist und der Turbo springt bei mir auch fleißig von minimal 1,6 zu max. 3,8 GHz; dazu mal ne Frage:
Ist oder war das nicht zumindest mal ungesund für die CPUs wenn sich ständig die Taktrate und Spannung ändert, also im GHz bereich? Habe in der Richtung mal was gehört, konnte es aber bis dato nicht klären.
Kann man jetzt mit dem G45 über den Turbo OC betreiben? Welche Einstellung ist nötig damit er im Idle runter taktet.
Solange das Silizium nicht schmilzt, wird das schon passen. Bevor die CPU das Zeitliche segnet, geht eher das Mainboard drauf. ;)
---------- Post added at 19:32 ---------- Previous post was at 19:29 ----------
EIST für „Enhanced Intel SpeedStep Technology“ : Intel-SpeedStep-Technologie
Damit EIST geht muss aber der Multi auf Auto stehen. Ich hab EIST sowie C1E an und der Multi steht fix auf 42 (übrigens ohne OC GenieII, danke mindfucked ^^), er bleibt aber dauerhaft auf 4,2GHz.
