Neu Dell Xps M1530 Teil 2
Das neue XPS M1530 seteht bald in den Startlöchern
Intel® Core™ 2 Duo (Merom) and
T7800 — 2.6 GHz, 4 MB
T7700 — 2.4 GHz, 4 MB
T7500 — 2.2 GHz, 4 MB
T7250 — 2.0 GHz, 2 MB
T5450 — 1.66 GHz, 2 MB
T5250 — 1.5 GHz, 2 MB
System chipset Crestline GM965 / PM965 Memory DDR2 667 MHz Memory min/max 1024 MB / 4096 MB at 667 MHz
LCD types CCFL backlit
15.4-inch WXGA TrueLife™ (1280x800)
15.4-inch WXGA+ TrueLife (1440x900)
15.4-inch WSXGA+ TrueLife (1680x1050)
LED backlit (post-RTS)
Video NVIDIA® GeForce® 8400M GS NVIDIA® GeForce® 8600M GS Video memory 128 MB or 256 MB dedicated memory with variable TurboCache™
Audio SigmaTel® STAC9228 (Azalia codec)
USB support Two left side connectors
One right side connector
Hard drive interface SATA Media bay options Slot-loading 8x DVD+/-RW ,Blu-Ray Disc™
Wireless options WLAN
Dell™ Wireless 1490 a/b/g Mini-Card
Dell Wireless 1505 a/b/g/n Mini-Card
Intel 4965 a/b/g/n Mini-Card
WWAN
Dell Wireless 5720 Mobile Broadband Mini-Card (various providers)
Dell Wireless 5520 Mobile Broadband Mini-Card (various providers)
Dell Wireless 5510 Mobile Broadband ExpressCard (various providers)
Bluetooth support Dell 355 Bluetooth®
Camera Lite-On® 2.0 Megapixel
NIC (LOM) Broadcom® BCM5906M 10/100 Integrated Ethernet
Modem External USB modem (optional) I/O card slots Ricoh® R5C833 Cardbus Controller
IR support Consumer IR (receive only) Connectors Power
Video (VGA)
S-Video
Consumer IR
RJ-45 (network)
HDMI™
USB 2.0
IEEE 1394a (4-pin)
Audio (headphone and mic)
Media card reader
ExpressCard slot Operating system Microsoft® Windows Vista™ Home Premium 32-bit
Windows Vista Business 32-bit
Windows Vista Ultimate 32-bit Docking support USB docking solution AC adapter 65 W* Battery 6-cell "smart" lithium-ion (56 WHr)
9-cell "smart" lithium-ion (85 WHr) Weight ~4.0 pounds (1.81 kg)
Achja, falls es zwischen all dem Rumgeheule bzgl. der NB-Preise überhaupt noch interessiert: ich habe das A07-Bios aufgespielt und es funktioniert noch alles. ;) Schön einfache Vorgehensweise, die Dell da für Bios-Updates nutzt.
Ich muß allerdings noch genau schauen, was durch das Bios ev. verändert wurde. Neben dem Technikerbesuch heute, bei dem die Medialeiste getauscht und die Scharniere festgezogen wurden, hatte ich nicht sonderlich viel Zeit fürs Noti.
Mal eine frage zum TV-Out am XPS. Was für ein Kabel brauche ich da? Ein Adapter lag bei mir nicht bei um zb. über SVHS an den Fernseher zu kommen :(
Ich glaube sowas hier brauche ich, aber wo kriege ich das her?
normal ist die buse so dsignt dass ein svhs kabel auch direkt rein passt.. nicht beötigte kontakte werden dann nicht benutzt
Also die Sache ist ganz einfach! SVHS-Kable nehem, das eine Ende am XPS einstecken und das andere Ende am Fernseher;) Das war es schon. Nur noch am Fernseher den richtigen AV-Kanal wählen...
Bei mir hat es jedenfalls wunderbar gefunzt...:xmas:
ich habe heute dieses Angebot bekommen.
1 N03X5310 823,57 823,57 S
XPS M1530 CORE 2 DUO T8300 2.40GHz,800,3M 1 S
Display 15.4" WXGA+ Widescreen (1440x900) TFT with Truelife 1 S
CCFL backcover blue & 2.0mp camera 1 S
Memory Dual Channel 3.0GB (1X2GB + 1X1GB) 667 MHz 1 S
DDR2 SDRAM
Graphics Card 256MB NVIDIA GeForce Go 8600M GT
Hard Drive 320GB SATA (5400rpm) 1 S
8xDVD+/-RW Slim Slot-Load Drive, including SW 1 S
AC Adapter 90W - 3 Pin 1 S
Battery XPS Primary 9-cell 85WHr Li-Ion 1 S
Für 980 Euro. Ist der Preis OK.
Und reicht die Graka aus für mittlere Spiele. Also kein High End?
Niro96
Joa, schaut ganz nett aus, das Angebot.
Laut PenisMark ist die 8600M GT mit GDDR3 sogar doppelt so schnell wie meine alte 7600Go (4400 vs. 2200 PKt.). Was auch immer das "in echt" heißen mag, reichen sollte es für einfaches spielen. Zur Not guck' mal in den Test auf notebookcheck
Jede im Dell XPS M1530 verbaute Karte hat DDR3 Speicher, Nicht aber andere Notebook Modelle (z.B Vostros haben nur DDR2)!
Es ist DA!!! :xmas:
Hatte schon Befürchtungen, dass das Rot zu hell ist, aber gefällt mir echt gut. Aber ein Problem ist mir aufgefallen: Der Lüfter läuft teilweise alle 10-20sec für 2-3sec und geht wieder aus. Schon etwas komisch... Hoffe, das lässt sich mit weniger Vcore beheben. Oder ist da was kaputt? :(
DDR2 SDRAM
Niro96
is ja n sehr gutes angebot...ich zahl für die gleiche konfig 999€ :( obwohl ich da schon mit meinem berater reden musste weil seine ersten angeboten lagen so bei 1050€
solche spacken warum machen die nicht für jeden den gleichen preis...
kannst du mir mal deine angebotsnummer schicken...dann schreib ich meinem berater mal was das soll
heute war der techniker da. In der ID steht Lpldf00. Hab nun endlich ein LG... Wie sieht mit den anderen aus der "Liste" aus?
Komischerweise fand ich es unter XP, recht blendend, das schwarz war mehr grau, aber bei Vista, ist das Schwarz optimal... seltsam..
DDR2 SDRAM
Niro96
Ich habe das nochmal Online eingegeben. Da komme ich auf 1300 Euro. Über 300 Euro Rabatt? Wie geht das? :hmm:
Jo, empfehl' ich dir auch, ein viel besseres Angebot wirst du wohl kaum kriegen. Und die aktuellen Angebote sind ja nur noch bis morgen, oder?
So, ich würd' dann jetzt mal gern Vista neu aufsetzen, da ist mir eindeutig zu viel Kram drauf (1,06GB Speichernutzung im Leerlauf :hmm: ). Muss ich da irgendwas beachten oder retten? Muss ich den MediaDirect-Kram auch neu installieren, wenn ich mir damit nicht mein System zerschießen will? Und kann ich XP noch zusätzlich auf 'ne Partition packen?
Normal würd' ich ganz einfach ausprobieren, aber 1. ist das diesmal mein eig. Notebook und 2. haben hier vllt. ein paar Leute schon Ahnung davon ;)
:banana::banana::banana:
Was ist den bei Dell los? Am 1.3.08 bestellt, heute am 4.3.08 in Phase 5.
Warum gibt es eigentlich für die XPS1703er Reihe ein 64BIT OS und für die 1503 nicht?
kannst du mir deine angebotsnummer nicht mal geben? Die bei dell sagen das es ****** sei was hier geschrieben wird. Ich solle eine Angebotsnummer mir geben lassen dann würden sie mir denn gleich preis machen.
Folgendes Angebot habe ich heute machen lassen:
XPS M1530 CORE 2 DUO T9300 2.50GHz,800,6M 1 S
Fingerprint Reader Biometric with BLACK accent 1 S
Internet Sparvorteil - Money Off -70 Euro brutto 1 S
Memory Dual Channel 3.0GB (1X2GB + 1X1GB) 667 MHz DDR2 SDRAM 1 S
Battery XPS Primary 6-cell 56WHr Li-Ion 1 S
Graphics Card 256MB NVIDIA GeForce Go 8600M GT 1 S
Dell Travel Remote control 1 S
European - Dell TrueMobile 355 internal Bluetooth Module 1 S
Intel® Next-Gen Wireless-N Mini-PCI Card, EUR 1 S
Base Warranty - 1 Year XPS Premium Hardware Support (incl. Gaming and On-Site Support) 1 S
1052€
Zusätzliche Rabatte gingen laut Beraterin nicht mehr, aber das stört mich kaum. Der Preis ist super und ich kann mich nicht beschweren...
Wer kriegt schon ein Notebook mit den Komponenten von einem anderen Hersteller für den Preis?
Ungefähr 9 € Aufpreis zu meinem alten System (T7500 2,2Ghz, 250GB, Handablage mit weißen Flecken; siehe Signatur unten)
Die Rückgabe meines alten Systems hat sich so gesehen für mich gelohnt.
dell xps m1530 oder asus vs1
Hallo!
Hat wer Erfahrung mit diesen beiden Geräten gemacht:
dell xps m1530 und asus vs1
Es gibt natürlich verschiedene Konfigurationen bei dell und somit ist ein Vergleich schwierig. Aber es gibt bestimmt Vorzüge bzw. Nachteile bei den einzelnen Laptops, die man kurz auflisten kann. Nach Durchsicht der Foren düfte zumindest auch mir klar sein, dass der Service bei dell besser ist.
Danke
Grüße Ferdi
Bei mir steht in der Eingangsbestätigung 7.4. drin, der Berater meinte nach Geldeingang gehts noch 2 1/3 bis 3Wochen bis zur Lieferung.
Ich würde da nicht so viel drauf geben.
...Ich würde da nicht so viel drauf geben.
Jop, seh ich auch so. Mein Notebook sollte am 20.03. bei mir eintreffen (bestellt am 25.02. per Vorkasse). Am Samstag war es fertig produziert und wurde an UPS übergeben, die als "geplanten Termin" den 06.03. angaben. Naja, ratet mal, von wo aus ich gerade schreibe... ;)
Auch wenn ich grad ein bischen Oftopic gerate, was haltet ihr von folgendem Gerät/Preis
ThinkPad T61p
Prozessor: Intel Core 2 Duo T9300 (Penryn) 2.5 GHz, 6 MB Cache
HD: 250GB / 5400RPM
RAM: 2GB (1 x 2GB)
Display: 15.4" - 1680 x 1050 (matt)
Graphik: nVidia Quadro NVS FX570M (256MB DDR3)
Batterie: 9 Zellen Akku
Laufwerk: DVD +- R/W integriert
Betriebssystem: Windows Vista Business Multilanguage (32)
Recovery DVD/CDs: für Vista und XP Pro
3 Jahre weltweite Garantie
Preis: 2350 CHF (~1400 Euro)
Hallo!
Danke
Grüße Ferdi
Ich habe Erfahrung mit dem V1s...
1. Sehr gut verarbeitet und sehr gut ausgestattet.
2. Ein mittelmäßiges Display (farbarm und hat auch den von matten Displays bekannten "Grainy Effekt")
3. Schwerer als das Dell.
4. Dell ist leistungsmäßig besser.
5. Der Service bei Asus ist wirklich das allerletzte (und ich untertreibe gerade).
6. Eventuell funktioniert die Grafikkarte nicht richtig...
Reicht das?
Mich würde interessieren ob jemand den Aufpreis vom T7250 zum T8300 kennt?
Oder n komplettpreis mit T8300, WXGA+, 2GB, 250HDD ?
bei mir warens 20€ aufpreis zum T8300(im ersten angebot sogar 30€)...bei manchen anderen warens 0€ das macht leider jeder berater wie er lustig ist :hmm: :mad:
eigetlich müssten es 0€ sein
Du meinst wohl vom T7500 zum T8300 müsstens 0€ sein. Vom T7250 gibt es schon einen aufpreis, weiß aber net wie viel.
Das wurd' schon ein oder zweimal aufgegriffen.
T7500 -> T8300: ca. 20€
T7250 -> T8300: ca. 100€
Bestelldatum: 26.02.2008
Voraussichtliches Lieferdatum (am oder vor dem): 13.03.2008
Noch nicht produziert, Stand 26.02.2008
Komisch, wieso steht bei mir immer noch Stand 26.02. ? :confused:
Lt. meinem Berater ist das Gerät längst in Produktion.
