Hardwarekenner
Legende
das neue V-Ranger Tool von Biostar soll es ermöglichen auch die Core Spannung von GPU und RAM zu ändern.
Damit sollte ordentliches OC mit NV Karten möglich sein.
Hat wer schon info ob es auf jeder NV Karte laufen wird?
von Biostar Homepage:
Today, BIOSTAR launches its new tool called V-Ranger for optimizing the best voltage, frequency and temperature values of each individual card. V-Ranger stands for Voltage Ranger, which is the first VGA based dynamic voltage regulation in the world. V-Ranger makes the concept of "power-on-demand" a reality. A powerful tool that can dynamically control the voltage of GPU and memory to achieve either the best overclocking results of the GPU or the lowest power consumption and temperature value of the card. The lower temperature will translate into a longer lifetime of the VGA card with enabled V-Ranger function. The V-Ranger will revolutionize the way power-users can overclock their graphic cards and utilize available power. BIOSTAR has set the new standard for a full VGA overclocking experience high. This technology will finally enable every power-user to control the most important settings of his/her VGA cards.
V-Ranger brings the maximum efficiency to your graphic card. The new function will offer ultimate performance for each GPU and the best possible price/performance ratio. No more risky tricks like hardware modification on their own or re-flashing uncertain BIOS. V-Ranger is the standard in the development of more user-friendly VGA through special hardware design and software control.
http://www.biostar.com.tw/vga/index.php
