Laut Inquirer hat es Nvidia angeblich geschafft das "Bios Problem" zu lösen und es den Board Herstellern bereits mitgeteilt haben.
Die Hersteller sollen mal hinne machen
The fault lay in the manufacturers missing off a jumper that Nvidia had specified on the Nforce 2 reference design.
Hard Tecs 4U, a German site, unwittingly uncovered the missing jumper. They had reviewed six Nforce 2 motherboards from different manufacturers and managed to kill all of them. The only one that was easy to recover was an MSI K7N2-L board which has the jumper. Using the jumper sets the BIOS back to a 100MHz FSB safe mode.
However, what we do know is that a fix will soon be at hand for everyone. Nvidia has managed to create a fix for the BIOS on Nforce 2 motherboards that will solve the issue. That fix has already gone to several manufacturers who should be able to supply an updated version of the BIOS for their specific motherboards soon.
Nvidia has said that it managed to get that BIOS fix to Shuttle the next working day after our initial article. Hats off to Nvidia for getting the problem sorted so quickly.
