[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
CP77 mit pathtracing saftet auch ganz gut
hat auf meiner TUF 460w laut msi ab angezeigt @ default PT
Coil Whine hält sich ziemlich in grenzen.
Hab verschiedenste Spiele probiert mit 90-300FPS.
Komischerweise nur bei BF und NFS sind die Spulen deutlich zu hören.
Ich hatte +33 % PT eingestellt auf meiner TUF. Ist aber trotzdem Voltage limitiert.
Wenn du es wirklich testen willst, dann starte Red Dead Redemption 2 und dreh voll auf.
Dann heulen die eigentlich bei jedem, auch im Menü wenn das Game gestartet ist.
Warum auch immer das so ist bei diesen Spiel, kein Plan.
Bis 1,1 V kann man einstellen. Stock sind 1,05V
Reicht auch völlig. Selbst für unter Wasser.
Selber finde ich Stock vollkommen ok.
Mehr Voltage und 600W PL nur zum Benchen und testen angewendet .
Dafür ist es halt nett.
Hab ich leider nicht explizit nach geschaut. Ich frag mal den Kollegen ob er schauen kann.
Beste Grüße
Leider mag meine ASUS TUF dafür nicht über die 3,1 GHz Takt. Im Arschbrenner bin ich mittlerweile bei + 275 MHz und trotzdem ist bei 3090 MHz Schluss.
Sorry, ich sollte das im Übertakten Forum absetzen.
Muss ich erstmal runterladen.
Na ich check das mal.
Ist doch ganz ok.
Meine macht dieses in den ganzen Benches von 3dmark auch bei Extreme ohne abzukacken.
30 MHZ mehr geht oder geht mal nicht bei GPU.
Superposition geht immer mehr sogar bis 3115 MHZ .
Alltags OC habe ich keines und das muss man lange testen fürs Gaming.
Mir reicht da Stock , aber finde die 3dmark Tests gut um mit anderen zu vergleichen und etwas zur orientierung zu haben
und halt bisschen spaß an der Sache.
Ist doch ganz ok.
Da bin ich sogar drüber, was die GPU Punkte betrifft.
Offensichtlich ist meine CPU der Schwachpunkt.
Teste mal mit Dead Space in 6K DLDSR + DLSS Quality, alles andere ist lachhaft bzw. taugt wirklich nichts.
Die wenigsten Karten schaffen 3 GHz wirklich stable.
Hab ich eben für 18,52€ bei Steam gekauft :)
Hast du sonst noch was eingestellt? Oder schieb mal das config-file rüber :d
Ich hab sogar das alte "Dead Space". Da gibt es die Optionen nicht.
Cpu Bug sollte in w11 eigentlich weg sein.
Gerade kurz getestet, 27825 cpu Punkte mit 5,6ghz und 4,3 auf den Pcores.
https://www.3dmark.com/spy/40089103
W10 liegt da meine ich auch, das ist nen run mit mehr ramtakt, daher besserer score als genannt.
Kann ich dir nicht sagen, habs irgendwann mal vor paar Wochen nach einem Update getestet und festgestellt das sie endlich mal gefixed haben.
Ja, deine CPU schneidet "zu schlecht" ab. Selbst mein unübertakteter 13700k ist da höher. Ich meine ich habe das schon einmal gesehen.
Sind bei dir VBS-Status und HVCI-Status auf "disabled"?
Wenn nein, dann dürfte es daher kommen. Das kommt über die Kernisolierung. Schalte das mal testhalber ab und teste damit.
Ähnliche Themen
