[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habe mit einem frischen Windows getestet, selbes Problem
Würde die GPU Spannung @ Stock laufen lassen und als erstes den Ram Takt um 500 MHZ senken und wenn es immernoch abkackt die GPU um 200 MHZ senken.
Solltest du bei deinen 7950X3D UV betreiben , dann würde ich das auch einfach raus holen sicherheitshalber.
Ansonsten kann es auch ein Software/Treiberproblem sein.
Alles Stock. Naja, spiele ich halt auf der Workstation WoT, ist ja genügsam das Spiel.
Optimus Signature 4090 STRIX/TUF REV2​
Weltrekordleistung unter den Kühlblocks für Grafikkarten​
Dieser GPU-Block setzt neue Maßstäbe, wenn es um Kühlleistung geht. Mit seinem Optimus Microfin-Desing bietet er eine 2- bis 3-mal größere Oberfläche als vergleichbare Wasserblöcke. Das bedeutet eine viel effizientere Wärmeableitung und damit kühlere Temperaturen für deine Grafikkarte, egal wie anspruchsvoll deine Anwendungen sind.
Ja der Preis ist schon abgehoben. Beim Terminal auch lieber Acetal meiner Meinung nach.
Naja Gott sei dank bin ich mit meinen Luftkühler zufrieden.
Das es Optimus nun nach Deutschland geschafft hat ist ja eigentlich ne schöne Sache.
Ich habe noch 5 Meter EK ZMT im Keller.
Der Schlauch ist ok sonst lieber WC Produkte kaufen oder Aquacomputer hat auch gute Sachen im Sortiment.
Die wird genauso ein Rohrkrepierer wie die ACER 4090 mit hybrid kühler
vermutlich 6-8°C kühler als ne standart 4090 mit luftkühler das wars und ohne wasser vermutlich selbes niveau oder so gar schlechter als ne normale 4090
Ich will mir gar nicht vorstellen was für ein Klopper von Kühler die 5090 haben wird. :oops:
Glaub kaum, dass der kleiner werden wird.
Die jetzigen Kühler der 4090 sollen ja schon für 600W ausgelegt sein. Ich tippe daher auf ungefähr selbe Größe aber deutlich lauter :sneaky:
Man muss schauen wie es mit UV aussieht.
Wüsste jetzt auch nicht was besser wäre außer die starken Vapor Chamber Lösungen die am Markt sind außer natürlich Wakü mit ordentlich Radi Fläche dahinter. (Mora etc.)
Vielleicht haut ja Asus zb. auch mal die Noctua Edition für die großen Karten raus.
Ich denke da wird sich kaum was tun im Bereich Kühler, gerade weil sie schon bis 600W ausgelegt waren/sind.
Da wird also alles beim alten bleiben, weder lauter noch leiser, sondern just the same.
Auch Spulenfiepen wird easy weiterhin ein Thema bleiben. Versprochen.
Selbst wenn das passieren sollte, hast du trotzdem ne nervige Karte wegen den Spulen, hatte selber mal die Noctua Karten hier, ist echt eine Zumutung, wie kann man sowas so hart verkacken. Da mach ich lieber ne Ghetto Mod selber mit den "no name" Karten, ist billiger und leiser.
Asus kannste mittlerweile eh in die Tonne treten. ^^
Ja mit den Spulenfiepen ist nicht fein.
Ist schon witzig, dass die billig Stromversorgung mit den hohen Spulen so leise ist.
Hatte bei der 3090 ne Gainward GS mit einem WC Block drauf.
War schon mit das beste was Spulenfiepen angeht.
Die hier ist ja eigentlich die einzig gute Karte was Spulenfiepen und guten Kühler angeht.
Bei dem rest gibt es leider immer was zu bemängeln. Selbst die FE soll ab einer gewissen U/min brummen.
Die Tuf hat aber ne gute Kühlung und gute Lüfter verbaut. Die Spulen machen natürlich diese positive Sache bisschen kaputt, aber persönlich bin ich zufrieden mit meiner Karte.
Meinst du die billig TUF mit Ampere Board und kleineren Kühler?
ist die TUF-OG
von TUF1 oder TUF2 hab ich auch noch nix mitbekommen
Ähnliche Themen
