[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Fals jemand intersiet Black Myth Wukong hat einen gratisbenchmark auf steam
Und schon mal wer getestet was die 4090 so bringt in dem Game?
Ok hab gerad noch mal reingeschaut wird rechts im bild angezeigt wie viel schärf was ist.
z.b. 25% -39% Ultra leistung 40-54% Leistung 55% -61% ausbalanciert 62%-89% qualität 90%-100% =Dlaa
Finds sehr komisch.
Ja denke auch der "Schärfe" Slider ist für die Auflösung das haben sie irgendwie schlecht übersetzt :ROFLMAO:
Muss sagen das mich die grafik im benchmark aber nicht an jeder stelle überzeugt manche texturen find ich komisch.
Hab auch grad neu benchmarks gemacht hatte ihn meine ersten einen fehler hab nich neugestart was man führ volles raytracing machen muss hatte daher viel mehr fps
mit max und dlss quali fg 4k 60fps. ohne bei über 100fps.
Es gab ein Update für den Benchmark :)
Könnten bitte ein paar User GPU-Z-Screenshots vom Reiter "Sensors" ihrer RTX 4090 im Idle posten?
Das wäre nett, danke. :)
Da musst du nichts großartig vergleichen. Das ist nicht gut!
bei mir z.Z.:
Idle: 47/57°C
450W Last: 70/82°C
Auch der "exclusive Vollbildmodus" den man in machen Spielen auswählen kann?
Die MS-Entwickler können das besser als ich erklären^^
With the release of Windows 10, we added Fullscreen Optimizations – which takes full screen exclusive games and runs them instead in a highly optimized borderless windowed format that takes up the entire screen.
Der Grund ist, dass die Hotspot-Temperatur meiner RTX 4090 mit bis zu 110 °C durch die Decke schießt und ich im Idle schon 62,4 °C erreiche.
Fließt wahrscheinlich (wie bei allen anderen, wenn man das Forum aufmerksam ließt) die WLP davon.
bei mir z.Z.:
Idle: 47/57°C
450W Last: 70/82°C
Dass die Hotspot-Temperatur nicht gut ist, ist mir bewusst.
Nur leider habe ich keinen Vergleich im Idle-Modus.
Deshalb danke! :)
So ist es.
Ich habe die Videos von Igor gesehen.
Das ist grobe Fahrlässigkeit, wenn nicht sogar Vorsatz der Boardpartner und einfach inakzeptabel!
Muss ich heute Nachmittag auch mal schauen
Hier mal meine Screenshots. Bei 110°C Hotspot-Temperatur kannst du uns mal zum Grillen einladen... ;)
Deshalb danke! :)
So ist es.
Was hast denn für eine TUF/Strixx ?
Ok kann man schlecht vergleichen, weil andere Karte , aber hier 7 Minuten Betriebszeit und 24°C Raumtemperatur @ TUF OC.
Habe Gestern nach einer Stunde WoT mal geschaut, war bei 26°C Raumtemperatur 43°C auf der GPU und 53°C Hotspot
also ich habe meine Tuf wassergekühlt als ich den orginal Kühler abgebaut habe hat die echt schlechte Wärmeleitpaste gesehen karte war vor wasserumbau ca 1 1/2 jahre in Betrieb und ist am schluss auch mit den hotspot auf ca 95 Grad gegangen
wann lässt du endlich mal die auflösung aus dem spiel?^^
der vorsprung ist in 16k immer noch derselbe weil die cpu nicht für die auflösung zuständig ist
hauptmenü dönert mit full load durch:ROFLMAO:
3440x1440
DLSS 66%
FG: OFF
KINO
3440x1440
Texturen: Kino
Rest: Hoch
DLSS: 66%
FG OFF
50% mehr fps durch 2 stufen settings runter. und es sieht kaum schlechter aus.
TUF OC
80grad hotspot beim wukong bench 2 runden ohne RT
der stellt jedesmal von 66 auf 65% zurück
66% is quality.
Halte allgemein den Benchmark aufgrund ruhiger Szenerie für nicht besonders aussagekräftig. Die Kämpfe sahen in bisherigen Trailern schon sehr effektreich aus, sodass ich mal gespannt bin, wo die Fps bei full Action Szenen stehen.
für einen reinen hardwarevergleich ist es nicht wirklich wichtig was genau gezeigt wird.
ob das die realität wiederspiegelt wie es dann im gesamten spiel ist, ist wieder was anderes
Ähnliche Themen
