[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich hatte vor dem Bios Update schon die Probleme mit dieser Fehlermeldung.
Den Curve Optimizer habe ich gestern ja nochmal angepasst. Gestern lief es auch ohne Probleme. Es tritt halt sporadisch auf.
Okay, aber das schließt trotzdem nicht aus, dass das System CPU/RAM seitig einfach nicht 100% stabil ist.
Werde morgen nochmal ein paar Tests machen. Mit OCCT Combined CPU und GPU Test gestern einige Minuten laufen lassen. Ohne Fehler. Weiß aber nicht wie zuverlässig das ist.
hmm versteh nicht wieso du zuerst mal ohne RAM Tuning und Curve Optimizer probierst und wenn es dann stabil ist, hast Du ja gefunden woran Du rumspielen musst.
Wenn das Problem dann immer noch vorhanden ist, kann man sich mal um die Karte kümmern. Diese Maxtests zeigen oft nicht ob ein System stabil läuft, das zeigt nur das es gerade unter Volllast stabil läuft.
Aber Spiele haben sehr variable Lasten sowohl auf RAM, CPU und GPU.
Den RAM habe ich ganz normal auf Expo II gestellt. So wie es schon immer war. Aber hast recht. Ich nehme mal den Curve Optimizer raus und dann mal schauen was passiert.
Curve Optimizer Probleme sind immer sporadisch. Eventuell verträgt da ein Kern die Einstellung nicht unter bestimmten Bedingungen.
Man kann aber mit Prime 95 ohne AVX relativ schnell und einfach herausfinden wenn es so ist. Bei mir liefen allcore -25 in Spielen und im Alltag stabil bei Prime95 ist mir aber nach 10-20 min ein Worker ausgestiegen. Wahrscheinlich hätte sich das auch irgendwann im Alltag gezeigt, bei - 20 war dann der Spuk schon vorbei.
Hatte jetzt keine Lust die Kerne einzeln auszuloten da ich mit -20 eh fast immer die 5050 MHz in Spielen sehe, kann man aber zum Ausoptimieren durchaus machen.
Lässt jmd Videos mit Hilfe von AI bearbeiten?
Hab schon länger "Topaz Video AI", aber die Auslastung, der 4090 liegt gerade mal bei durchschnittlichen 33% und 170W
Um ein 30-minütiges Video von 720p/25fps/unstabilisiert auf 1440p/50fps/stabilisiert hochzuskalieren, dauert etwa 4h. :rolleyes2:
Bei Vollauslastung wäre ich schon mit 2h Bearbeitung zufrieden...
Falls jmd was anderes, mit ähnlicher oder besserer Leistung kennt - her damit
Gesucht wird kein Web-AI, wo man Bilder/Videos hochladen kann. Sind meist Abo´s
Mal, wenn nicht eh schon drauf, den Studiotreiber installieren, der bringt ab und an Programm-Optimierungen mit, die gerade in dem Bereich wo Du gerade unterwegs bist sich bemerkbar machen und in dem Game-Ready nicht enthalten sind.
@Dwayne_Johnson
Wie hoch sind denn die VRAM- und PCIe-Schnittstellen-Auslastung während der Bearbeitung?
Äussern tut es sich dadurch das Spiele hängen bleiben und ich auf den Desktop zurückgeschickt werde.
Ich hatte ein sehr sehr ähnliches Problem:
Ehrlich gesagt weiß ich bis heute nicht was wirklich die Lösung war? Probler aber mal bitte folgendes aus:
In der Nvidia-Systemsteuerung > 3D-Einstellungen > 3D-Einstellungen verwalten > Globale Einstellungen : Setze "Energieverwaltungsmodus" auf "Maximale Leistung bevorzugen"
Das hatte wohl vielen geholfen, hatte ich in irgendeinem Forum gefunden. 3Dguru glaube ich.
Eine neue 5080, die wahrscheinlich ein bisschen schneller sein wird, kostet vermutlich kaum mehr als das. Wer 1200€ für eine gebrauchte 4090 da zahlt ist schon recht dumm. Die wird gebraucht sicherlich unter 1000€ rutschen vorausgesetzt die Verfügbarkeit der neuen Karten ist ok. Vor allem die 2 Jahre alten Karten.
eine 5080 wird Locker 1500€+ kosten und wird die Absolute Speerspitze in der Midrange darstellen aber weniger Speicher haben nämlich 16GB und bei vermutlich mageren 10% mehr Leistung als eine 4090
Da wird eine 4090 mehr als Interessant für Leute die Upgraden wollen alleine wegen den 24GB ram und der sehr guten Effizienz im UV
Wenn du glaubst das Jen dir eine 5080 für 1200€ gibt dann Träum weiter die 4080 hat schon 1470€ UVP damals gekostet zum Launch und das ist nur eine FE gewesen wolltest du ne Strix haben und Co waren das mal eben 1700€
Mal abwarten, die 4080 Super ist ja schon deutlich günstiger gewesen. Ich glaube nicht, dass die UVP der 80er Karte wieder so hoch sein wird aufgrund des € Kurses und der generell schwachen Verkäufen anfangs. Eine 1600€-1700€ 4080 hat einfach keinen Sinn gemacht wenn man für 1900-2000€ schon ne PNY 4090 oder so bekommen hat.
Nvidia hat es versucht aber die 4080 funktionierte nicht als Enthusiasten-Karte jenseits der 1500€ was zu einem recht schnellen Preisverfall und letztendlich einer deutlich reduzierten UVP bei der Super Karte geführt hat. Ich rechne daher damit, dass Nvidia die 5080 wieder so wie jetzt die 4080 Super platzieren wird. Ist halt schlecht für 4090 Besitzer die verkaufen wollen aber ich sehe eigentlich keinen Grund wieso ne 5080 noch teurer werden sollte als damals die Launch 4080. Die hat damals schon kaum einer gekauft und war jederzeit lieferbar. Es ist ja nicht so, dass die Karte weg ging wie warme Semmeln wie die 4090. Wer so viel bereit ist zu zahlen greift halt eh ganz oben ins Regal und das hat Nvidia ja offensichtlich auch gemerkt.
Aber jetzt ist ja nach oben hin noch Luft, also kann man die 5090 weit teurer setzen.
Dann gibt es auch keine Probleme mehr mit ner 5080 über 1500€. :oops:
Worauf ich ja gespannt bin, ist, inwieweit deren KI / AI Zeug bei den Consumer / Gamer RTX Karten mit einfließen wird, wenn dann gerade auch in Sachen Preisgestaltung. Aus Leistungssicht erst recht, u.a. auch da ja immer mehr von AI generierten Games geschrieben wird. Mir kann das ja meinetwegen eigtl. alles gestohlen bleiben^^... Es sei denn, es entstehen dadurch Möglichkeiten, komplett neue Wege zu eröffnen in Sachen Welten-, Charakter- und Storygenerierung. Das könnte dann schon durchaus interessant werden. Hmm, wieder mal so eine ambivalente Sache :d
edit: eigtl ja offtopic, glaub ich, sorry :)
Vollkommen richtig jetzt wo AMD nix anbieten kann gegen eine 5080/90 kann Nvidia ihre Preise gestalten wie sie will und eine 5080 geht locker für 1500€ zum Release über den Tisch und da verstehe ich viele die sage warum 1500€+ für eine 16GB Karte und die gerade mal 10% schneller als eine 4090 ist
und bei den 1500€ rede ich von keiner Strix und Co sondern Founders oder vlt noch ne PNY
Die Zeiten haben sie so Extreme geändert zum RTX 4000 Release und kann man auch nicht mehr vergleichen dank KI Boom hat Nvidia das komplette Monopol in sachen GPU Markt und bittet uns alle zur Kasse wer eine 5080/90 will getreu nach dem Motto: "Friss oder Stirbt"
Jen juckt es null ob der Preis angebracht ist oder nicht obwohl sie keine Konkurenz haben das Geld verdient Nvidia schon lange mit KI Karten und die werden ihnen aus den Händen gerissen egal zu welchen Preis
Die 4090 wird noch lange für 1000-1200€ auf dem Gebrauchtmarkt zuhaben sein frühestens Q2/25 denke ich gehen die Preise langsam runter
Mal eine Frage in die Runde, ob es nur mir so geht...
Ich bin, was Grafik anbelangt, sehr verwöhnt. Deshalb war die 4090 FE für mich ein Day 1 Kauf und dass trotz Preisen von über 2.000 Euro.
Mit der RTX 4090 lassen sich alle Spiele mit 4K max. Settings inkl. RayTracing Ultra flüssig spielen. Selbst Spiele mit der Unreal Engine 5 laufen butterweich (Flüssig = 60 FPS+).
Sollten die Frames wie in ALAN Wake II bei ca. 50fps liegen, dann lässt sich immer noch DLSS aktivieren und man erhält ohne Grafikeinbußen die fast doppelte Anzahl an FPS.
Daher die berechtigte Frage, warum und wer benötigt bitte eine 5er RTX? Die Mehrleistung braucht doch kein Mensch, wenn sich die RTX 4090 in allen Spielen langweilt?!
Und versteht mich nicht falsch. Bei PC-Hardware bin ich auch meist vorne mit dabei, neuste, schnellste Hardware zu kaufen. Aber bei der neuen RTX Generation erschließt sich mir (aktuell) der Sinn nicht.
Dreh mal bei Alan Wake 2 und Cyberpunk Alles auf maximal inklusive Pathtracing, dann siehst du selbst mit DLSS und sogar FG keine 60 FPS.
Und wer braucht eine 5090? Keine Ahnung, wer braucht Grafikkarten wirklich zum überleben?
Wer will eine 5090? Da bin ich nicht der einzige.
PS:
Es gibt jetzt 4K/240 OLED Monitore, die wollen auch gefüttert werden 🤘
Dreh mal bei Alan Wake 2 und Cyberpunk Alles auf maximal, dann siehst du selbst mit DLSS und sogar FG keine 60 FPS.
PS:
Sehe ich auch so. Alan Wake 2 und Cyberpunk haben meine 4090 auch in die Knie gedrückt.
Mehr Leistung ist immer gut.
Ich bin da bescheidener, ich bin aktuell mit 4K@120 zufrieden. Und auch dafür benötigt man bei (vielen) AAA Games eine 5090 😎
Ähnliche Themen
