• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Habt ihr Interessenten der 4090 alle ein 4k >144 Hz Display und min einen 12900k oder ryzen 7xxx ?
Es scheint ja unter 4k wenig Sinn zu machen, weil man selbst mit 12900k im CPU limit ist.
siehe meine sig :)
Es scheint einfach keine User mehr zu geben, die ihre Regler bedienen können. Es scheint mir das es eine unglaubliche Massenpanik davor gibt, das man die Leistung der Graka "verschenken" könnte.
Nein, wird nicht passieren, wenn man sich mal mit den Reglern auseinandersetzen würde.
Puuh MediaMarkt kleckert auch nicht mehr mit den Preisen, das ist schon Alternate Niveau.
Bin aktuell mit einem 120 Hz UWQHD unterwegs. Wenns dann immernoch ins CPU-Limit läuft, kommt ein UHD Monitor mit entsprechenden Hz auf den Tisch.
Edit: Alles immer fein auf optisches Maximum. Endlich kaum noch Kompromisse :hust:
@ralle_h Ist es so wie damals, dass die MediaMarkt Links erst nach paar Minuten gehen? Leider bekomme ich eine Fehlermeldung bei den Links. Danke dir :)
Also ich hab mit meiner 3080ti und uwqhd und 144hz kein Thema. Eher müsste der 5800x dran glauben zb ein 5800x3d.
wo seht ihr media markt links :)
Laut CB kommt die 4090 selbst mit PCI-E 3.0 noch aus...nur 2,1% Einbuße
Wann gibts die FE Karten? 🤷🏻‍♂️
Kein 4k aber triple screen simracing 7680x1440 da kommt die 3090 auch z.b. bei Assetto Corsa Competitione ohne dlss (ist zuschaltbar aber schliert teilweise) an ihre Grenzen.
216 Besucher, es wird immer moar, bin aber einer von denen die hoite nicht zugrapschen werden. Ich lasse erst mal die Opfer ran. (y)
:o
4K144Hz, aber nur nen 11900K :shake:
Reicht aber, bin bisher noch nicht im CPU-Limit. Wird sich zeigen ob sich das mit der 4090 ändert, dann kann ich ja direkt nen 13900K(S) nachschieben :haha:
Hoffe wenn sich mein rig nicht verkauft bekomme , reicht der 5900x aus die 4090 zu befeuern ? Angepeilt sind wqhd 144 /170 Hz.
Ähnliche Themen
