[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Sehe ich schon so wenn ich festellen muss, dass wenn man nicht 1-3 Minuten nach gelistet gekauft hat alles weg ist.
Sry,aber man muss schon auf Zack sein um eine Karte am ersten Tag zu kaufen.
Wenn es eine bestimmte sein soll wird es schwierig.Hatte trotzdem heute nach Feierabend 3 gute Karten zum Test im Warenkorb(TUF OC/Suprim/Gigabyte OC) und hätte ohne Probleme kaufen können.Einzig die FE war heut der Rohrkrepierer laut Forum.
Und bestimmt werden die Leute auch dort wieder zu Scalperpreisen kaufen ...
War abzusehen das am Anfang alles weggeht, bin gespannt wie es sich die nächsten Wochen entwickelt.
Ich kanns mir einfach immer noch nicht vorstellen dass das funktionieren wird. Auf ebay gibts gerade ne 3090 FE für 1000€ Sofortkauf. iwelche Customs findet man sicher auch iwo unter 1000€
Warum also nem Scalper 1000€ geben wenn man 2 High End GPUs haben könnte? ne 3090 zum überbrücken und iwann die 4090.. danach die 3090 wieder verkaufen.
Also nem Scalper würd ich die 1000€ sicher nicht schenken!
CB Zitat:
"Asus hat die GeForce RTX 4090 TUF OC übertaktet. So beträgt der durchschnittliche Boost-Takt 2.565 MHz, das sind 45 MHz mehr als nach Nvidias Spezifikationen. Mittels des Tools GPU Tweak III kann softwareseitig ein OC-Mode aktiviert werden, der den Takt weiter auf 2.595 MHz anhebt. Der 24 GB große GDDR6X-Speicher arbeitet mit den gewöhnlichen 10.502 MHz.
Asus hebt das Power-Limit der Grafikkarte nicht weiter an, nach wie vor sind hier 450 Watt der Werkszustand. Per Software kann dieser auf bis zu 600 Watt erhöht werden. Der neue 16-Pin-Stromstecker (12VHPWR) ist für den Betrieb notwendig, um die 600 Watt gewährleisten zu können. Asus legt einen Adapter bei, der auf vier 8-Pin-Stromstecker geht. Mit allen vier sind ebenso 600 Watt möglich. Mit nur drei Steckern startet die Grafikkarte ganz normal, dann lässt sich jedoch das Power-Limit nicht über die normalen 450 Watt setzen."
Ja 600watt Power Limit haben die Karten , aber soweit ich weiß geht die Spannung bis 1,1 V max. (Stock glaube 1,05v ) und da muss man höher kommen um mehr von der GPU raus holen zu können . Aber immerhin 3ghz hat man schon unter Luft gesehen was beeindruckend ist . Denke ne TUF oder Strix die Dual BIOS hat bietet sich doch an für ein XOC BIOS .
Das sehe ich anderst. 🤷‍♂️
Im Warenkorb ist das eine, ein erfolgreicher kauf etwas anderes.
Wieviel bestellungen wurden storniert ? Mehr als genug
So, ich habe zum frühen Abend meine Versandmitteilung von Proshop für die Gigabyte Gaming OC erhalten. Dummerweise steht dort aber nun eine andere Ortschaft mit der selben Postleitzahl drin als wie in der Bestellbstätigung. Hoffe der Kundendienst kann da noch was machen morgen. :-\
Naja ich hoffe Mindfactory und andere Stores schieben jeden Tag immer schön nach so dass dieses ganze gescalpe dieses mal nicht funktioniert.
Aber in dem Fall wenn man sich auf ebay und EK umschaut sind wieder einige dabei. Durchschnittlicher Scalperpreis: 3000€
Ist halt echt Mist das die 1,1V limitieren.
Jetzt hat man ein Fettes powerlimt aber zu wenig V und die Top Luftkarten langweilen sich bei den Temps trotz 540 W Peak bei 3GHZ
Weiß halt auch nicht für welche Karten man einen Wasserblock erwarten kann... gerade war die Palit kurz verfügbar :unsure:
:ROFLMAO: :ROFLMAO: :ROFLMAO: :ROFLMAO:
Das ist doch alles nur noch WTF!!?!?!
Die "einfache" Gaming OC für 3,4k!!!! Musste schnell gehen, Scalpen wird nicht lange funktionieren, also Bildschirm fotografiert oder wie? :fresse:
Um´s "Nachschieben" mache ich mir keine Gedanken
Eher darum, wie hoch sie die Preise "schieben"
Sicher und auch bereits (vor)bestellbar sind bisher welche für die FE, Asus (Strix+TUF), Gigabyte (Master+Gaming OC) sowie die Referenz (nach aktuellen Stand Inno3D).
Erlaubt ebay es denn, dass man Waren einstellt, die man noch garnicht besitzt? :rolleyes2:
niemals. denn wenn das ding verkauft wird und er nicht liefern kann weil der händler die karte nicht liefert hat er ein problem mit ebay
Ähnliche Themen
