[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Viele wo die Strix kaufen bauen auf Wakü um und da ist meist die chance am ehesten auf nen schnellen block
Aber ja, wer auf Lukü bleibt kann theoretisch alle nehmen.
Sehe ich genau anders.
Wer auf Wasser umbaut kann eigentlich jede nehmen wo es en gescheiten Block für gibt.
Bei der aktuellen Gen kommt es nur auf den Chip an was geht weil du nicht für einstellen kannst.
Bei dir ist immer jede Grafikkarte eine Wunderkarte. Die Leute lachen sich bereits schlapp, weil genau das hat man von dir nämlich erwartet:
Jede Karte wird in den Himmel gelobt und anschließend erzählen Käufer wie @andi0138 (weiße 3090 Strix), dass die gepriesenen Taktraten von dir gar nicht laufen, nicht mal ansatzweise.
Nimm doch mal ein Game wie Deathloop oder Division 2. Anschließend sollte man es auch einen Tag mindestens spielen um überhaupt eine Aussage über Stabilität zu tätigen.
Für dich ist alles stabil, was einen 3D-Mark Run hinter sich lässt.
Darunter verstehe ich auch, dass man andere nicht in die Irre führt.
Genau wegen Leuten wie dir, denken andere Käufer, sie haben in der Chip-Lotterie Pech gehabt und kaufen X Karten, die X-mal retourniert werden.
GameStable ist für mich der MetroBenchmark im 20er Loop laufen zu lassen. Mir RT und DLSS. Bisher der härteste Test für mich. Ich habe mal 4 Stunden Battlefield mit RT gezockt mit einer Taktrate, welche aber nicht Stabil war im Metro Benchmark.
24/7 Setting ist natürlich was anderes. Das kommt die Tage.
Wen es später zu einem Defekt kommt hast du spaß mit der Garantie Abwicklung.
Hat dich dann auch 2100+ gekostet.
timespy extreme
Asus RTX4090 TUF Gaming vs Asus RTX3090 Strix OC
tobi
Könntest du mal AC Vallhalla (falls vorhanden) mal auf Vollanschlag in 4k mit deinen OC Taktraten testen, dass würde mich mal interessieren.
Das Spiel crashed innerhalb von ein paar Minuten, wenn das OC unstable ist.
  • Danke
Reaktionen: SH
@SH kannst du mit mit "ThermSpy" schauen, wie hoch der Realtakt ist?
3GHz ist ja nicht der eff. Takt
@alle mit 3080/3090/4090 TUF
Die TUF Non-OC ist ja, exakt baugleich, wie die TUF OC, richtig?
Würde das TUF OC-BIOS auf der Non-OC laufen? (ich vermute ja)
Nimm Deathloop oder Division 2. Man muss es aber auch zocken und dementsprechend Freizeit opfern - und nicht den Benchmark loopen.
Meine 3090 Strix hat bei Metro 1965 oder 1980 MHz gemacht und bei Deathloop musste ich auch 1845 MHz runtergehen. Divison 2 waren es 1875.
Aber genau da bestätigst du die weiße Strix: Du sagst, GameStable MetroBenchmark im 20er Loop. Andi spielt Divison 2 und Treiber-Reset :shot:
Nach allen Erkenntnissen ist das logisch - kann gar nicht anders kommen.
Da haste recht Benchmark loopen für Stable ist schwachsinn, einfach zocken.
Ja geiler Scheiß, Gratz von meiner Seite. Ich werde Morgen meine Suprim X auf Herz und Nieren Testen. UND nein ich bin NICHT traurig das es NUR nen 520Watt Bios hat.
Wirds denk auch nicht brauchen. Ab 3 GHz gibts Bildfehler und da war er noch iwo bei ~450W rum?
Außerdem werden nach der Benchmarkralley die meisten versuchen maximale FPS bei möglichst geringem Stromverbrauch zu bekommen. 2023 soll der Strompreis ja nochmal steigen. Dann sind wohl die 0,60€/kWh Standard.
Idr. hat man keine Lust, dass das Spiel dann mehrmals Abstürzt bevor man vernünftige Settings hat. Deshalb testet man meist mit Benchmarks.
Dass paar Loops ohne Crash nicht stable sind, sollte klar sein. Glaub bei meiner 3090 bin ich 50mhz vom max Takt in Benchmarks runter und dann war die auch über nen Jahr in allen Anwendungen stable.
Habt ihr den Aufbau der vrms bei der suprim gesehen ich bin mir sicher das ding kann die 600 Watt.. Könnte mir vorstellen mit nem anderen bios wirds möglich
Wollt gerade sagen, dass ist ja erstmal der "Quick"-Benchmark um zu sehen ob 3 GHz überhaupt erreichbar sind etc. Von daher alles im grünen Bereich.
Game Stable braucht sehr viel Zeit :fresse2:
Das Problem is doch die Voltage :d kannst normal nicht mehr drauf hauen wie dir die Programme her geben. Die reichen bisher nicht aus um 600 Watt zu erzeugen
Meint ihr es ergibt Sinn morgen früh mal zu MediaMarkt zu fahren? Ich will so n Teil!
Also unser Mediamarkt hatte tatsächlich bei den 3090er Karten immer mal wieder ne Trio von MSI da und das obwohl online nichts da war.
Ach, dafür wurde die 4090 gebaut :d
Finde auch Tests/Benches interesant, bei dem man das PL soweit reduziert, dass man die gleiche FPS-Lesitung einer 3090 bekommt
Da würde mich die Aufnahmeleistung interessieren...
Nein, das meinte ich natürlich nicht^^. Aber wegen 5 FPS 150W mehr raushauen würde ich dann gut abwägen. Im Lieblingsgame wo man grad so am 60 FPS Limit häng ggf. Aber nicht im Dauereinsatz bei jedem Spielchen so dass man dann mit 150 statt 144 FPS zockt. .
300W senken um grad so noch die 60FPS zu bekommen .. ja schön wenn das mit der 4090 dann bei 100W iwie geht aber dafür würd ich sie auch nicht kaufen.
Wird wohl eher schwierig werden. Denke im Markt wird man da kaum Glück haben, zumindest nicht als Lagerware. Eventuell mit Bestellung und warten. Ich denke morgen bei den Shops hat man höhere Chancen. Eventuell droppt MF ja ihre Bestände, die waren noch gar nicht dabei. Gerade eben war wieder eine Gainward bei Alternate verfügbar
AHHHH hab ne Gainward und ne Zotac im Warenkorb aber beide Karten will ich eigentlich nicht. Zotac 2189€ wird mit Block etwas teuer und die Gainward 1999 klingt nach Billoteil und vermutlich kein Block :unsure:
Er meinte es ja nicht böse und ich habs ihm auch nicht übel genommen, @SH ist immer der fairste Verkäufer hier im Luxx und gibt sich extrem viel Mühe, siehe Erstellung der Sammlerthreads, Datenzusammenfassung etc. und er ist ein richtig netter Kerl und er ist so wie wir alle hier Enthusiast der PC Hardware liebt. Lassen wir doch den Hate hier sein und genießen unser Hobby gemeinsam :)
3015MHZ easy im ersten Test
54 Grad Max
Ohne Voltage Erhöhung. Einfach nur +200 GPU und +500 auf MEM
Yeah. Bester Deutscher für heute Abend :P Platz 22.
Deswegen nimmt man auch einen Hersteller wie MSI, der explizit sagt, im deutschen Markt ist der kühlwrwechsel kein Problem, solange bei defekt der alte wieder drauf kommt
Das weiß ich doch. :) alles gut
Wo auf der Seite von Msi steht das ?
Link?
Ich hab den Support angeschrieben und es schriftlich ;)
Sie können bei Grafikkarten die Wärmeleitpaste oder Kühler Tauschen. Dieser muss jedoch die gleiche oder eine besser Leistung besitzen.
Daher bitte beim Kühler Tausch, alle Schrauben und Kühler aufheben sonst kann eine Garantie abgelehnt werden.
Dies gilt für alle MSI Grafikkarten welche in Deutschland und Österreich von MSI Deutschland vertrieben wurden.
Jetzt wäre echt noch interessant wie gut crossflashes funktionieren. So ein Strix Bios auf einer msi gaming non x Trio, ob das mit den 600 Watt Powerlimit dann klappt und ob das pcb und die Kühlung der Trio das packen würden
Ähnliche Themen
