[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Ich freu mir…. :) auch wenn es nur ne gamerock ist anstatt die FE..
Also das Kabel das gestern hier gezeigt wurde kann man ohne bedenken bestellen oder? Das 2 Stecker vom Netzteil auf den neuen geht?
Klar, das ist ja dafür gedacht. Wenn du ein empfohlenes Netzteil von bequiet hast. Und das von be quiet bestellt hast.
Ich bekomme auch "nur" ne GameRock, hatte immer nur die "einfachen" Karten, auch bei der 3090Ti schon. Waren immer Top.
Beste Grüße
Meine Gainward wurde heute auch von Alternate verschickt. Hat noch jemand das relativ aktuelle Corsair AX1000 Titanium (1000w) ? Kann man hier einfach alle 4 PCI-e anschließen mit dem Adapter oder sollte man sich das Kabel von Corsair kaufen? Ich habe immer noch nicht verstanden ob das eher optik ist als alles andere.
dieses hier:
oder direkt aus dem be quiet! shop:
Quelle: pcgh
Guten Morgen!
Meine Gainward befindet sich in der Zustellung und ich habe jetzt schon mal den Rechner vorbereitet wobei sich noch eine Netzteil Frage ergeben hat:
Ich habe aktuell das Sharkoon Silent Storm 850W Netzteil. Das Netzteil hat PCI-E Anschlüsse nativ und es liegen zwei 6+2 Doppelstecker Kabel mit dabei, also insgesamt 4x 8 Pin. Jetzt habe ich hier gelesen, dass man auf keinen Fall Doppelstecker verwenden soll, aber an dem Netzteil habe ich keine andere Möglichkeit. Meint ihr das ist problematisch? Ich betreibe seit 2 Jahren eine 3090 auf vollen 350W mit einem Doppelstecker, angeschlossen an einer Buchse am Netzteil. Ich vermute also mal, 2 Doppelstecker würden dann auch gehen? Zumal ich das PL eh auf 80% stellen werde.
Guten Morgen!
bitte diesen chinaböller austauschen !!!!
Einfach an den Adapter dran vom Netzteil aus. Die 4090 braucht weniger wie ne 3090, also nicht so ängstlich ;)
Beste Grüße
Fake. Wie immer bei diesen Videos.
Guten Morgen!
Was sagt deine Anleitung wieviel ampere liefert eine Buchse?
Hab mir das Bequiet! Straight Power 850W Platinum bestellt. Laut Hompage soll es ja mit den neuen Kabel reichen für die 4090. hab ja nur nen 12400 i5 der zieht nicht viel.
Kabel habe ich noch keines sind ja ausverkauft
Ich nehme niemals dieses Adapter Kabel. Ich nehme die beiliegenden zum Netzteil. Das Adapter Kabel der 3090 hat doch gar nicht die 4 zusatzpins. Sieht man auch an den Kabeln die auf dem Boden fotografiert sind.
Das ist das ominöse adapterkabel, das man NICHT für die 4090 nehmen darf.
Das funktioniert eh nicht, da bei dem Kabel beide Sense-Pins dann offen sind. Das hieße maximal 150W für die GPU.
In dem Fall die beiliegenden hässlichen pcie Kabel nehmen. ;D, wie ich.
Ja bis das Kabel wieder lieferbar ist auf jedenfall…
Wurde ihr die Gigabyte windforce testen oder gleich versuchen ne tuf zu kriegen. Kann man ne geöffnete Karte auch wieder zurück geben?
Mega frech von Caseking für die tuf fast 300 Euro mehr zu nehmen als alle anderen Shops! Im Asus Shop gibt's die zum uvp Preis
300€ aufpreis bei einen 2000€ Artikel sind gerade mal 15% Aufpeis und das ist eigentlich der ganz normale CK Aufpreis.
Eigentlich sind bei CK alle Artikel ca. 20% teurer als in anderen Shops.
Kann man zurückgeben ja, aber vielleicht bist du ja mit der Gigabyte glücklich, dann brauchts keine andere ;)
Was erwartest du dir davon die Gigabyte zurück zu schicken und ne TUF zu nehmen? Die nehmen asich alle nichts untereinander.
Beste Grüße
Das hoffe ich. Bin nur wegen Lautstärke skeptisch. Hatte ja bis jetzt nur TUF Karten aber mit PL 350W und guten Airflow plus lüfterkurve dürfte die auch nicht zu laut sein.
@be quiet Support könnt ihr prognostizieren, wann euer neues Kabel wieder verfügbar sein wird?
Hab denen auch ne Mail geschickt. Wusste nicht das die auch hier sind
Diese Generation sind alle leise und echt gut gekühlt. Sollte immer so sein, das sie mehr erwarten und die Chips dann effizienter sind. Win win für Hersteller und Kunden. … die paar extra Euro für die teureren Kühler. ;D
@SaiBot62
Das sollte mit dem Silent Storm gut klappen, ist ein Single Rail mit 70A. Wenn die 3090 läuft dann auch die 4090.
Beste Grüße
Moin
Was für ein Durcheinander die letzten Tage
Irgendwie bin ich froh eine RTX 4090 bekommen zu haben aber das Design der MSI Gaming Trio spricht mich nicht wirklich an. 🙄
Bin da wirklich Aorus verliebt…
Jetzt bin ich am überlegen … die Trio einbauen und später mal eine Aorus zu kaufen oder einfach verzichten und einen Wasserblock drauf basteln wodurch die Optik dann gleichbleibend bei jeder Karte dann ist.
Die Gaming Trio hat mich 2019€ gekostet
Wurden dafür schon Blöcke angekündigt weiß man da was
was empfehlt ihr hier ???? die gainward mittels 4er adapter an 2 pci anschlüsse zu hängen ...maximale tdp 450 watt !!!!! peak manchmal höher ...ein PCIe kann 150 watt liefern ..das billo netzteil hat vermutlich nur eine rail auf den beiden pci steckern .... das teil würde vermutlich ständig am und überm limit laufen bis es puff macht und vermutlich mehrere hardwareteile mit in dne tod reisst !!!! warum machen leute sowas ???am falschen ende sparen ,mit ner 1500 Euro karte und jetzt mit ner 2000 euro karte ??!?!? kein geld für nen ordentliches 200euro netzteil ???? affig ....sorry ....
die zuleitungen kansnte beim zocken vermutliuch nicht mehr anfassen so heiss werden die ;D
Dann überlastest du seit 2 Jahren eine PCIE Steckverbindung die auf 150 Watt spezifitiert ist mit ca. 300Watt (ca. 50Watt kommen über den PCIE x16 Steckplatz).
Das kann natürlich funktionieren aber brennt deine Wohnung ab und der PC ist schuld freut sich die Versicherung und du schaust in die Röhre.
Jetzt sei mal nicht so überheblich. Fast alle kommen aus China und unter dem Sharkoon Label steckt sicher ein OEM wie FSP. Würde ich auf jeden Fall erstmal mit dem Adapter ausprobieren.
hat mit überheblich nichts zu tun ..schau dir doch nur mal die stecker an ...typische low end anordnung und sharkoon ...... auch wenn da nen oem hintersteckt ist es die low budget schiene ....
@SaiBot62
Beste Grüße
Danke dir, würde ich auch vermuten. Sooo schlecht ist das Netzteil jetzt ja auch nicht. Ist halt etwas günstiger aber definitiv kein No name China Böller. Hat überall gute Testergebnisse. Wird aber dennoch ausgetauscht sobald mein Thermaltake GF3 1200W mit ATX 3.0 kommt.
ja, ich mein warum soll ich jetzt 2k+ ausgeben für etwas was mir nicht richtig gefällt und ich glaube mit etwas Geduld bekommt man baldig auch das Wunschmodell.
Ich wollte die FE, oder das Metallkleinkind Aorus Master, das Display find ich toll, da kommt das Kind in mir durch. :LOL:
Hübschig fände ich auch noch die Zotac AMP Extreme AIRO.
Da zitiere ich mich mal selber.o_O
Gestern Abend klingelte mich der Distill Web Monitor von der Couch an den PC. (danke an das Forum für den Tipp mit dieser App(y))
Bei Alternate konnte ich dann jetzt eines meiner Wunschmodelle kaufen, die Zotac AMP Extreme AIRO für 2274€, habe soeben die Auftragsbestätigung bekommen.:coffee3:
Meine Frau fragte mich ob auf der Grafikkarte auch Björn Dunkerbeck unterschrieben hätte!? 🏄‍♂️ :rolleyes2:
Ähnliche Themen
