[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@SH
Hattest du jetzt was zur Lautstärke gesagt bzgl. Spuhlenfiepen und Taktverhalten bei der Waterforce?
Na toll :)
Die Waterforce ist fast so krass schnell wie meine STRIX, hat aber auch bessere Temps :)
Welche behalte ich jetzt? :d
Mindfactory zuverlässig und schnell wie immer.
Kann ich leider nicht bestätigen, hängt bei mir seit gestern auf "Elektronische Ankündigung", weil MF es erst nach 16 Uhr geschafft hat sie zu verpacken (trotz Gold Support). Daher geht sie wohl erst heute nach 16 Uhr raus. Dabei hätte ich Zeit am Wochenende gehabt. Schade aber natürlich kein Drama.
Na toll :)
auf Dauer?
Vermutlich keine von beiden.:d
  • Haha
Reaktionen: SH
TUF non OC +200 / +500
Hmm, wegen des blöden Adapters habe ich die Seitentür vom PC etwas auf. Leider höre ich ziemlich deutliches Spulenfiepen von meiner TUF im Spiel. Wie sieht das bei euch aus?
Die PCI E Bandbreite liegt bei 3.0 jetzt statt bei der 3090 7-12% jetzt bei 18% . UHD passt der 10900k noch sehr gut .
Danke für die Info! Wie meinst Du das genau mit den 18%? Das habe ich nicht ganz verstanden.
Ich bin nämlich auch noch auf einem (RAM-getunten) 10900K mit PCIE 3.0 und der RTX 3090 und will mir die RTX 4090 Ti holen, wenn sie rauskommt. Die meisten meiner Freunde haben mir gesagt, dass ich unbedingt eine neue CPU brauche, (natürlich auch wegen PCIe 4.0) weil ich sonst hart bottlenecken würde mit der CPU. Ich möchte nun aber noch bis Meteor Lake (oder Arrow Lake) ausharren.
Monitor ist ein LG UHD@144Hz by the way. Mir reichen 120-140 FPS und das pacht die CPU in den meisten Spielen.
das ist die schönste aus meiner Sicht, schlicht Edel. Alles andere sieht aus wie Spielzeug...RGB, Plastik Kristalle..das ist nix für mich.
Ne, finde die auch schick, aber das war es dann. Aus technischer Sicht wäre mir fast jede andere lieber. Verstehe den Hype um die Karte nicht. Lauteste Spulen, Kühler ok, aber nicht der beste. Die TUF zum gleichen Preis würd ich immer bevorzugen.
Welche Karte ist denn die bessere Wahl: die TUF oder die Suprim?
also ich hatte 3x die 3090 FE 2davon waren sau leise, nichts Spulen oder Fieben! Kann nur positiv darüber reden. Die Tuf hätte ich auch kaufen können....für mich nur FE
Habs mal angehangen. Musste es zippen, da sonst nicht erlaubt :-)
  • Gainward Lüfterschaden.zip
da könnt IHR mir ja sagen ob das "normal" ist
vorsicht wer soundanlage etwas zu laut hat ich hab GAIN +30db da hört ihr auch das richtig. für mich ein extrem unangenehmes nebengeräusch! bei 20sek geht die karte erstmal auf 0 u/min hatte kleinen schluckauf beim start der aufnahme
Ich hab genau das gleiche ...
18% von der max. Bandbreite von PCI e 3.0
Wenn ich mir das so anschaue kann man eigentlich auf wakü Block verzichten 😊
Bisschen CPU Limit habe ich aber auch festgestellt , aber die Frames sind ok . Hier BF2042 .Also 120-140 FPS packt ein 10900k auch noch .
Werde bei Meteorlake auch zuschlagen , weil bisschen mehr CPU Power kann die 4090 schon vertragen .
Das hatte ich mal, damit gab es Bildaussetzer und Restarts, weiß nicht ob das jetzt ne neue Gen ist von den Kabeln
Ich bau mir doch nicht freiwillig eine "Antenne" zwischen MB und GPU
Und wenn die Frau den Rührfix schwingt = Blackscreen oder wie bei dir? Nee Danke
Show-Case gut und schön, aber auf Stress im Case hätte ich keine Lust
TUF aus dem Asus Shop gerade angekommen und ins O11 Dynamix XL eingebaut. Ohne 90 Grad Adapter für den Stromanschluss bekommt man nicht wirklich die Seite zu.
Ganz schöner Backstein. Aber Verarbeitung ist sehr gut.
ja lul ist halt unangenehmes sägen tbh
Absolut... als ich die Karte eingebaut habe ist mir das Grinsen vergangen... So habe ich eigentlich kaum Coil Whine. Die Karte sieht super aus... bin sehr zufrieden, aber dieses Sägen geht mir richtig auf den Sack! Hast du bei Alternate gekauft?
Ähnliche Themen
