[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
danke für die Rückmeldungen!
Eigentlich wollte ich ne Palit nehmen, weil die nicht so lang ist aber
Palit/Gainward scheinen laut zu sein/Lüfterproblem zu haben
bei einigen anderen Herstellern fiebt die Spule
das bei dem Preis....da warte ich jetzt doch weiter in der Hoffnung, dass die zweite Charge besser wird.
gar nichts wird da besser. wenn es die hersteller nicht angehen ist das einfach nur lotto
Manche haben hier neben Spulefiepen (Coil Whine) auch Spulenrasseln erwähnt. Ich habe das zuvor noch nie gehört. Was Fiepen ist, ist mir klar, aber RASSELN? Muss ich mir das so vorstellen, wie es klingt? :LOL:
ALLE GPUs haben Spulenfiepen.
Die Frage ist nur, wie intensiv. Und wann bzw. bei welcher Anwendung / welchem Workload tritt dieses Fiepen wie intensiv aus, d.h. wann wird es für den Menschen hörbar bzw. grenzt sich von anderen Geräuschen als unangenehm auf/ab. Natürlich gibt es hier bei Herstellern große Unterschiede. Manche Karten fallen durch die Bank weg eher negativ auf, andere eher weniger. Bei manchen Karten kann sich die Intensität des Coil Whines auch mit der Zeit verändern.
Wobei wir hier auch von Verkaufszahlen sprechen müssen. Ein Beispiel:
5.000.000 Asus werden verkauft, 2000 Leute melden Probleme.
5.000 EVGA werden verkauft, 500 melden Probleme.
Auf Papier haben die EVGA jetzt weniger Probleme ("Netzmeinung"), Asus finden die Leute scheiße; aber in faktischer Hinsicht wären die EVGA natürlich viel anfälliger! Die Wahrscheinlichkeit, bei einer Asus Coil Whine zu bekommen, wäre also in dem obengenannten Beispiel viel, viel niedriger. Aber in subjektiver Hinsicht denken die Menschen jetzt: EVGA geil, Asus schlecht. Das geschieht, wenn nicht genug Datenpunkte analysiert werden. Dann kommt es zu solchen Falschmeldungen bzw. Fehlerkenntnissen.
Dabei ist die Frage auch noch ganz wichtig, was für einen Anwender haben wir hier?
Jemand mit einem offenen Gehäuse direkt neben dem Bildschirm?
Jemand mit einem geschlossenen Gehäuse unter einem Tisch?
Jemand mit einem geschlossenen Silent-Gehäuse am anderen Ende des Raumes?
Und dann auch noch: wie empfindlich ist der Mensch? Wie gut hört der Mensch? Ist das Gehör noch voll funktionsfähig? Und dann auch noch: Wieviele andere Störgeräusche gibt es im Raum?
Bevor man nicht eine vernünftige, zufriedenstellende Menge an Informationen hat, würde ich auf dieses "neigt zu Coil Whine" - Gerede wenig Wert legen.
Das Master hat seinen Meister gefunden 1000D
beides das gleiche
nochmal. es ist völliges glück spiel. bei dem einen klingt es so, bei dem anderen so.
je höher die fps und die last desto höher der ton. rasseln = tiefes fiepen
jedes exemplar unterschiedlich
Stell dir einfach nicht so einen hohen Ton vor
Die Karte wirkt geradezu winzig :) Hängt aber ganz schon durch.. Machst du da noch ne Stütze oder nen Bracket hin?
da hängt nix.
da hat gigabyte beim "kühler" mehr plastik vorne gemacht als hinten und somit sieht das so aus.
er hat sogar ne stütze montiert
Mal die TUF OC im Desktop betrieb nach einer Stunde Desktop/Browse/Videos
Lüfter waren die ganze Zeit aus. (offener Aufbau)
Speicher Temp ist bei 58°C laut HWINFO.
Wird mal Zeit das neue GPU Z version kommt, aber HWINFO kann alles auslesen.
  • Danke
Reaktionen: A6
Also die Tuf OC ist im Idle ca. 42°
In einem Test stand die RTX 4090 haben einen hohen Idle Verbrauch.
Also bei mir hat die nur den halben Verbrauch der 3090 im Idle.
Meine TUF nimmt sich im Desktop idle gute 20 Watt. Finde ich okay für diese große Karte.
Muss ehrlich sagen bin bis jetzt sehr zufrieden mit der Gigabyte. Klar das Fiepen nervt schon etwas aber ist nicht lauter wie die PS5 eher etwas leiser.
So mein bequiet Kabel ist da.
Ich hab jetzt mal im Afterburner das Auto OC laufen lassen mit 70% Power Target... Karte (TUF) taktet in Cyberpunk auf 2680MHz statt 2770MHz, säuft dadurch ca. 50W weniger bei nahezu gleicher Leistung.
Hat wer eigentlich schon rausgefunden, wie man bei der Gainward Phantom die Stütze installiert? Ich glaub ich bin zu blöd dafür ... :P
Na los howt rein beim PC Scalp. (y)
Mal sehen, wie lang die Karten verfügbar sind! Die Zotac von NBB ist seit gestern auch noch verfügbar. Denke so langsam haben einige ihre (nicht Wunsch-) Karte.
Leute mit meiner suprim x….wie warm ist eure Karte im desktobetrieb? Bei mir wird wird sie 54 grad….kommt mir etwas zu hoch vor
24-25 Grad mit Gaming Bios und manueller Lüftereinstellung im Afterburner. Vermutlich bei Dir "Silent Bios" und die Lüfter drehen vermutlich im Desktopbetrieb nicht.
Vorher
Gar nicht gesehen. Wenn ich nicht wieder gerne einen Heatkiller hätte, würde ich wieder eine Zotac nehmen, fünf Jahre Garantie sind jetzt nicht so übel. Aber nicht für den Preis...
Lässt immerhin hoffen, dass sich die Preise nicht mehr so weit nach oben entwickeln, wenn die Karten jetzt schon mit moderaten Aufschlägen nicht unbedingt gekauft werden :-)
Mfg
Kiryu
Edit: In den Warenkorb kann man sie nicht legen, also vielleicht doch nur ein Anzeigefehler und gar nicht auf Lager?
Hier und da liest man über dieses Kabel. Geht es hier nur um die qualitative Beschaffenheit der Kabel? Der beigelegte Adapter reicht doch auch vollkommen aus, oder missverstehe ich was?
Das reicht. Es geht um die Ordnung im Gehäsue. Da ist nur 1 Kabel und nicht 4 kleine Schreihälse angenehmer.
also!
Bei 70% Power Limit habe ich so maximal 315-320W bei 10% Weniger Leistung
Bei UV 0,975 @ 2750Mhz + 600Mhz Speicher bis zu 380W was ich gesehen habe mit +1-3% Leistung.
Werde erstmal 70% Laufen lassen da mir das überall hin reicht und dazu noch Lüfter Kurve etwas anpassen.
Entspricht dem was man von der Performance von einer NonOC-Karte erwartet und das Geräusch ist für eine Luftkühlung recht angenehm. Ich weiß ja nicht was Du hören möchtest, aber die 4090 sind brutal, und sie takten genau dort wo sie laut Verpackung takten sollen.
Was etc ist weiß ich leider nicht.
Du meinst, es sind ausschließlich alle Boardpartner Karten Sau gut unterwegs und unterscheiden am Ende nur in Sachen Kühlung ect. ?
Gibt ja durchaus Karten die eine Vapor Chamber haben und einige nicht ….
Das sieht ganz schön kurz aus.
also!
Undervolting ist immer besser als PL. Beim Powerlimit rennt die karte permanent da rein und taktet hin und her. Bei UV hast Du eine konstante Taktrate und es läuft smoother. Versuch mal 0,95V bei 2760.
Ja gibt mit und ohne Vaper Ch...
Klar reicht der aus, aber schön ist anders. ;)
Ähnliche Themen
