[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Grundsätzlich keine schlechte Idee. Allerdings möchte ich 3 Monitore anschließen und der mittlere ist kaputt, die anderen 2 funktionieren. Ich kann das ganze erstmal umgehen in dem ich HDMI benutze, allerdings taktet die GPU nicht runter wenn man Displayport und HDMI mischt. Das macht 45 watt unterschied, bei 16 Stunden Betriebszeit pro Tag macht sich das schon bemerkbar :LOL:
Vielleicht warte ich wirklich noch ein paar Tage ab und hoffe das die Verfügbarkeit besser wird.
So sieht das nebenbei aus. Falls es nach 20 mal ein und ausstecken Bild gibt.
Ich würde da auch erstmal abwarten. Kann auch ein Treiberproblem sein. Meine 3090FE hatte auch ein ähnliches Problem mit den Displayports zum Release. Und hat sich dann irgendwann gegeben mit neueren Treibern.
War die ganze Woche auf Dienstreise und hab die Tests nur am Rande verfolgt. Sehe ich das Richtig: im Schnitt zwischen 400W und 450W Verbrauch, d.h. damit könnte mein 750W-NT evtl. doch noch reichen aber eigentlich nix verfügbar. Welche Karte sollte man nun nehmen?
850 Watt solltest Du Minimum haben, selbst beim PowerLimit reduzieren würdest Dein PSU an der Kotzgrenze laufen, und Netzteile wollen nie am Limit laufen, sondern immer so bis 80% rumgurken, am liebsten 50-65%.
Ich kann ja nur zwei PCI E anschließen. Hab am stright Power 11 Platinum 850W nur zwei Buchsen. Einmal für das Y Kabel und einmal für das einzelne. Mehr hab ich ja gar nicht.
Edit. Falschen Stecker eingesteckt 😅🤭
Was sagen die Besitzer der Asus TUF Non OC zur Performance und Werte samt Lautstärke ect. ?
Liebe Grüße
wollen das die netzteile oder die nutzer der netzteile?
dem netzteil ist das eher egal.
und über 80 % wird auch nur die effizienz etwas schlechter... und es wird vermutlich ein wenig lauter.
Hey mein Gehäuse ist in Zustellung. Also kann ich dich meine Gigabyte heute testen ♥️
So geil wie du die Gigabyte persönlich anspricht 😂
Alles was ich gemacht habe ist bei geizhals zu filtern und zwar nach Netzteilen mit 12VHPWR gesucht.
Da kam das Seasonic Prime TX-1300 im Suchergebnis.
Ich werde es dann schon sehen, wenn meine zwei MSI Suprim geliefert wurden.
Jo aber release ist leider erst im. Dezember..
@SH ich komm dir näher :)
  • Danke
Reaktionen: SH
mit dem Straight Power 11 kannst Du das Kabel von be quiet! verwenden.
die karte rennt mit gesenktem powertarget deutlich effizienter dazu
Ich hab jetzt 75% CPU Auslastung in Cyberpunk in 3440x1440p WTF das ist mal wild. Ist ein 10900k mittlerweile nicht mehr zeitgemäß ???
Es sind genug FPS für Dich: Zeitgemäß
Es sind nicht genug FPS für Dich: Nicht mehr Zeitgemäß
Dabei spielte der Name der Hardware noch nie eine Rolle. Es ist immer der User und seine Ansprüche.
Ich hab mir die CPU-Last gar nicht angesehen.
Ich bin in 4K mit DLSS auf Qualität und alle Regler bis auf Screenres auf volle Pulle jetzt endlich über 60 FPS. DAS ist es was zählt^^
Die Halterung von Fractal ist echt super!
Yey meine FE ist nun auch gekommen :) :fresse2: :fresse2: :fresse2:
Die ist nochmal in einem Umkarton mit ein Paar Infos drauf
Von Foxcon, Biosversion, Package 197/200, Total Package 200.
Ich denke aber mal das ist ne Charge und heißt nicht dass NBB nur 200 bekommen hatte.
Hast du sie "normal" bestellt oder nach Registrierung?
Entspricht dem was man von der Performance von einer NonOC-Karte erwartet und das Geräusch ist für eine Luftkühlung recht angenehm. Ich weiß ja nicht was Du hören möchtest, aber die 4090 sind brutal, und sie takten genau dort wo sie laut Verpackung takten sollen.
Was etc ist weiß ich leider nicht.
Moin
hab jetzt das Problem, dass die Karte im Idle nicht mehr runter taktet, Speicher und Chip bleiben auf vollem Takt.
Woran könnte das liegen und wie kann man das am besten lösen?
Wieviele Monitore dran?
Welche Auflösungen?
Mal nur einen z.B. 4K nur mit oder weniger 100Hz einstellen!
Fastboot ist hoffentlich auch aus. Hatte das auch schon beim Wechseln von Performance zum Silentbios wenn Fastboot an war.
Ansonsten viele Bildschirme mit hohen Bildwiederholfrequenzen hindert die Karte auch dran runter zu Takten …
