• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Du hast eine über dieses angeblich faire System bekommen, merkste was?
Noch nicht, AB steht noch aus ;)
Dieses System ermöglicht es halt auch "normalen" Leuten ohne großartige IT-Kenntnisse und eingeschränkter zeitlicher Verfügbarkeit an eine Karte zu kommen.
Klar hat es sicherlich auch seine Nachteile, aber im Gegensatz zum Drop-Prinzip, wo es Leute gab die sich jeden Drop x Karten bestellt haben, ist es eine deutliche Verbesserung.
Ich favorisier aktuell eine FE weil se wohl recht wenig fiept… 😬
Gut das man inzwischen das Fiepen auf die Modelle ausweiten kann und es nicht wie früher einfach bei jeder Karte mal war oder nicht. Es ist ja auch bekannt das es keine Karten gibt die bei User 1 fiepen und bei User 2 nicht. Es wird auch sicher gut sein wenn man den Einzelmeldungen hier zum Thema fiepen glaubt und es gar nicht erst probiert mit einem Modell. Gut das die meisten nur TUF und Strix haben :)
Und jetzt kommt sogar noch was komplett verrücktes: Ich habe Gerüchte gehört das Foren nur die halbe Wahrheit sind, weil sich meist nur Menschen zu Wort melden die ein Problem mit etwas haben. Während andere einfach die Sachen benutzen und von den Problemen die in Foren zu Weltuntergängen führen nichts bemerken. Aber wer glaubt schon den Gerüchten.
PCB der FE höherewertiger weiß ich jetzt nicht. Ob das 5 oderb7 jahre hält interessiert wohl kaum einen. Was juckt mich das außerdem, wenn die dinger evtl. so fiepen wie die schrottige 3090 FE, 2080 ti, 1080 ti usw
Wenn die TUF zu groß ist, würd ich mir eher ein anderes case kaufen.
Du bist lächerlich in dem du weiter Öl ins Feuer gießt.
Deine reaktion war halt alles andere als erwachsen und egoistisch ich bezogen. Ich dachte mir auch meinen teil als ich das gelesen hab und hab mich gefragt wie man das ernst meinen kann.
Mal wieder ein beispiel, egal was nv/nbb macht es gibt immer einen der sich aufregt.....
Gibts eigentlich was die Leistung angeht schon irgendwo einen Vergleich zwischen TUF und Strix?
Gibt es schon so einen mittel Wert was man so+ fahren kann bei Ram über den AB?
Hab mir das hier nicht so genau angesehen weil Benche nur ingame :-) Ram habe ich aktuell nur auf+500 laufen und nicht weiter probiert!
Zum Glück sind die Ram Temps bei der 4000ner Serie kein Thema mehr!
Bei meiner FE aktuell so +1500 auf Mem. Das ist so der Max. +1600 hatte schon Bildfehler im Unigine Benchmark
Seit der 4090 hab ich ein Problem mit HDR aktiv dann verfärbt sich der ganze Bildschirm gelb, hat das noch jmd. ?
what alter Verwalter ?
Ist das der Schnitt oder Max Wert?
Wo ist bei dir Schluss stable?
Daten Fakten lass uns nicht am langem Arm verhungern :wink:
Im Schnitt, sind viele die 1500 erreichen. Meiner läuft bei 1600 problemlos danach Skaliert der aber nicht mehr so toll
wenn es aber nur geht wenn man sich in die benachrichtigung eingetragen hat, isses leider fürn eimer. das muss nvidia halt vorher bekannt geben und nicht im nachhinein
Meine suprimeX macht das leider nicht was den Speicher angeht habe ich Pech gehabt dafür lässt sich der Chip sehr hoch takten ....
Hängt aber auch davon ab was man als Basis nimmt. Bei der FE gehen +1500 auf Mem. bei einer Suprime wird der Speicher schon von Haus aus übertaktet sein. Dass da dann nimmer so viel geht ist normal^^
Mahlzeit! Hat einer seine Karte im thermaltake Core p6 vertikal eingebaut? Überlege vom O11 Xl umzusteigen da horizontal nicht passt (mit Fenster)und für vertikal müsste ich mir die Halterung holen. Für das Geld kann man sich ja fast nen neues Case holen.
Habe mir gerade extra für die beiden 4090 das o11d xl gekauft, weil mein Carbide 540 natürlich zu klein ist. Dann geht das direkt wieder Retoure. 🤨 Vertikal ist durch zwei Karten ja keine Option.
Meine Asus 4090 tuf non oc läuft aktuell daily bei -25% PT +150 Mhz Core Clock + 900 Mhz Mem Clock, hat damit in allem, was ich getestet habe etwas mehr Leistung (1-2%) als Stock bei Peak 360 Watt statt vorher Stock 443 Watt. Läuft super stabil, da würde sicherlich noch etwas gehen, aber mir ist die Systemstabilität in jeder Situation wichtiger als die 1-2 % Mehrleistung. Natürlich profitieren auch die Temperatur und die Lüftergeschwindigkeit ein wenig, allerdings sind die beiden Punkte sowieso kein Problem. Wie optimiert ihr eure Karte? Lieber UV statt PT runterdrehen? Meiner Erfahrung nach bringt UV wenig, vor allem ist das Verhalten der Karte komplett anders als man es von Ampere kennt.
Top, danke das werde ich gleich als nächste bei der FE versuchen.
Hab sie in CB soweit dass sie ohne PL Anhebung mit~420W auf 2,8-2,9 Ghz läuft. PwerLimit +VCore anheben bringt bei den FPS einfach fast nix. Hatte 2-3 FPS mehr und gleichzeitig auch 100W mehr Verbrauch dafür dass sie dann fast 3 GHz hatte.
Aber wenn man an der FE interessiert ist, dann ist es doch naheliegend, sich in die Nvidia Mailingliste bezüglich des Launches der RTX 4090 einzutragen?
Irgendwie muss Nvidia ja an die Interessenten der Karten herankommen.
Deutlich besser als meine 3090FE mit weniger FPS und 350W.... :d
Ja 2000€ mögen viel sein, aber man muss schon sagen die 4090 liefert ab.
Hmm was ist da eigentlich dran mit dem dass man die 4090 nicht undervolten soll? Der Bauer erwähnt es auch aber so richtig drauf eingegangen ist er nicht.
ist im nachhinein vielleicht leicht gesagt, aber ich persönlich melde mich nicht für jeden newsletter an.
vor allem das es jetzt keine option mehr gibt sich dafür anzumelden....
So 1450mhz geht noch dann wird wird instabil ....
Ich würde mir da keinen Kopf machen an Deiner Stelle, dafür geht Dein Chip ziemlich gut und das bringt mehr als der Speicher. 1450 ist jetzt ja auch kein schlechter Wert.
ja einfach vorher bekanntgeben dass es das gibt und darüber funktioniert.
denn newsletter abonniere ich nicht aus spaß :d
Ich hätte ja schon ganz gerne mal ein Gehäuse mit vertikaler GPU... Aber in den meisten Cases hat man dann keinen Platz mehr für einen Luftkühler (Aus diversen Gründen nutze ich kein Liquid).
Gibt es irgendwelche Empfehlungen für ein Gehäuse mit genug Platz für vertikale GPU + dicker Luftkühler?
nzxt h7?
aber ka wie groß die gpu sein darf damit noch ein lukühler passt
simon / itraid hatte das case gezeigt
wird nicht viel gehen sehe ich gerade. leider
Da hat es angefangen mit den +1500
Hatte es bei ein paar hier gesehen
Bei der FE 4090 geht sogar noch ein bisschen mehr, aber brauchen tut man das nicht wirklich. Hab meine Karte jetzt auf 70% PL & +959 MHz Memory, das macht fast exakt 1100 GB/s. Richtung 1500 wird dann die Temperatur höher und der Kühler sagt mir zu häufig hallo, so ist die Karte aktuell - selbst beim Gaming - quasi unhörbar.
Einfach nur krass, was ein überdimensionierter Kühler so macht. Die letzten Jahre mit NVIDIA Karten gab es beim Gaming Betrieb bei mir immer lautstarke Lüfter (3090, 2080, 980, 780 etc), aber jetzt kann man in 4K zocken und braucht nichtmal Sound, um die Lüfter zu übertünchen.
Einfach nur Hut ab vor soviel Effizienz. Schade, dass die Generation so maßlos überteuert ist - ich kann mich zwar über die Karte freuen, aber bei dem Preis kann ich das niemandem wirklich empfehlen. Auch wenn mir das persönlich das Geld wert ist, hätte sogar lieber selbst noch viel mehr VRAM; am liebsten 48 GB. Mir laufen die 24 GB schnell voll.
Macht aber so rum mehr Sinn, es werden halt die belohnt die vorher schon interessiert waren die FE zu kaufen und sich dafür benachrichtigen lassen.
Im Nachhinein könnten sich ja dann auch zig Scalper anmelden, so schließt man die direkt aus.
Klar alles nicht perfekt ...
Mist! Hab jetzt bei mir im Experience Account geschaut und gesehen, dass ich natürlich weder das Reward-System noch den Newsletter abonniert habe. Habe jetzt einfach mal Häkchen gesetzt, aber die Chance auf ein Invite ist wohl vertan :(
Ich sehe das genau wie du. Hätte er den link bekommen, wäre das system gefeiert worden. :rolleyes2: Ziemlich lächerlich sein verhalten.
Warum man aber unbedingt die FE will verstehe ich nicht. Gibt doch bessere karten. Die TUF zum gleichen preis wäre mir schon viel lieber.
Design (Geschmackssache), Größe und Stabilität. OC dürfte egal sein weil dass mit der FE auch ausreichend geht.
Was alle Customs je nach Modell besser können ist die Temperatur, Lautstärke und auch das Design (RGB usw... wieder Geschmackssache)
Ich teste/spiele gerade wieder mit meiner 3090 FE (rum). 1h Horizon Zero Dawn, alles max 1440p, UV/OC, Lüfter gehen nicht über 1200rpm hinaus. Wie hoch dreht die 4090 FE so bei max Last?
Ähnliche Themen
