[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
was willst Du da noch reduzieren, meine 3090 läuft im Desktop Betrieb mit 28W - 34W, die 4090 vermutlich noch weniger.
Ok, gibt es denn überhaupt ne Möglichkeit den Verbrauch im Desktop zu begrenzen?
Bei einem kompatiblen Mainboard die iGPU verwenden (sprich: das Monitorkabel am Mainboard anstecken und im UFEI aktivieren, das sowohl iGPU als auch die zusätzliche Grafikkarte aktiv sein sollen).
Bei 3D-Last wird dann trotzdem die nVidia-Grafik verwendet und bei 2D-Last müsste der Verbrauch dann nochmal geringer ausfallen.
G-Sync geht dann vermutlich leider nicht.
Bei z.B. 12900k und 3090 ging das letztes Jahr noch (der User @Trill hatte das damals mit Erscheinen von Z690 getestet, soweit ich mich erinnere).
Edit eventuell ist es auch schon länge her (Z590-Mainboard).
mit der HWInfo Beta 7.31-4885 fixed das Problem bei MSI Karten , das HWInfo immer die RGB beleuchtung ausmacht.
Das hat auch mein Problem gefixt, dass mein MSI Board die Lüfter nicht mehr anhand der CPU Temp gesteuert hat, weil HWInfo den Sensor "blockiert" hat und der nichts mehr ausgelesen hat.
Auch die Leute die undervolten und einen hohen Takt sehen glauben geil und so , aber die Karte scheinen dennoch weniger Leistung zu haben.
Der8auer hatte das im letzten Video zur Strix mal erwähnt.
Dann ist sie zu stark undervolted. Das optimale undervolten senkt nur den Verbrauch und nicht die Leistung.
Die Karte erreicht ja mitunter den selben Takt wie ohne UV, liefert als Ergebnis aber trotzdem leicht weniger Leistung. Deswegen soll das skalieren einfach über das PL ja besser sein.
Weshalb wird eigentlich keine ASUS Strix angeboten?
Bisher habe ich noch nicht ein einziges Angebot gelesen.
es gab bereits dops der Karte, bei Saturn z.B. und beim Asus e-shop direkt hab ich es mitbekommen, glaub aber auch schon woanderst.
VRAM OC Frage
Manche haben ja auf Ihren VRAM hier 1800Mhz drauf gepackt.
Bei 1000Mhz schmiert meine Tuf ab und mein Rechner bild bleibt schwarz und ich mus resetten.
Ich vermute mal, dass durch die dicken Thermalpads der Tuf mein Vram an einer Stelle zu heiß wird.
Hat das Problem noch jemand?
Sicher dass es VRAM OC ist oder ggf doch nicht ganz stabiles Core OC?
Uff, ob das gut ausgeht? Ohne China wäre es doch gar nicht möglich solche Grafikkarte wie die 4090 herzustellen. https://www.heise.de/news/Neue-US-S...Halbleiterbranche-abzuschlachten-7309772.html
Warum soll das nicht - mehr - möglich sein. Es gibt genug Kapazität in anderen Ländern und ob die GraKa nun 100€ mehr kostet spielt in der Preisliga kein Rolle mehr. Es sollte nur endlich einmal umgedacht werden. Es gibt genug Kapa in Osteuropa, selbst dort gibt es Steueroasen, Polen und Rumänien sind da sehr gut drinnen ihre eigenen Leute zu Billiglöhnen im eigenen Land arbeiten zu lassen. Ebenso gibt es genug Kapa in anderen Schwellenländern dort sind alle großen EMS vertreten.
Guten Morgen zusammen. Weiß einer von euch zufällig wo der be quiet! 12VHPWR Adapter vorrätig ist?
Hat jemand von euch schon A Plague Tale : Requim gespielt ? Ruckelt das bei euch in den zwischen Sequenzen auch so abartig ? Ganze Game Lauft Nativ mit +-90 FPS, mit FG 117FPS( G-Sync Limit ) nur wenn die Zwischen Sequenzen anfangen ( InGame ) Grafik ruckelt sich das Game bei unter 20fps einen ab. Versucht mit FG und oder Ohne
Hilft dir jetzt zwar nicht bezüglich deines Problems, aber laut Digital Foundry hast du ein massiv erhöhtes Inputlag wenn die FG in dein Framelimit läuft. Falls du DLSS3 nutze willst, versuche die Einstellungen so zu setzen, dass du mit deiner maximalen Framerate unter dem FPS Limit bleibst.
Würde mich mal interessieren wie die VRam Temps der anderen User so sind.
So mal ein erstes Fazit zu meiner 4090 FE: Bis auf die Lüfter alles gut.
  • Verarbeitung: Soweit Top. Wirklich super stabil (Backstein) und macht einen wertigen Eindruck. Im Vergleich zur 3090 FE würde ich aber meinen, dass Nvidia etwas an den Kosten optimiert hat und die Lüfter iwie weniger massiv sind.
  • Kühler: In etwa gleich groß wie bei der 3090 FE. Kühlleistung solange man bis 500W geht gut. Ich habs nicht wirklich bis 600W getrieben aber alles was gegen 80°C geht finde ich nicht mehr gut. Bei 600W wird wird sie sehr wahrscheinlich 70% Lüftergeschwindigkeit benötigen. Bei mir im durchlüfteten und geschlossenen Gehäuse @Stock um die 68°C, @OC 72°C und mit gesenktem Powerlimit um die 65°C Speicher bleibt nun ebenfalls Kühl und i.d.R. zwischen 70°C und 80°C.
  • Lüfter: Bis 50% soweit i.O. aber ab 50% fängt mein hinterer Lüfter mit einem komischen höherfrequenten "Schleifgeräusch" an. Ab 70% hört man dieses Geräusch sehr deutlich heraus und es fängt an zu nerven. 100% sind auf jeden Fall nervig. Es schleift nix und scheint iwie am Lüfter/Lüfterdesign zu liegen. Der Lüfter beim Auslass hat ein "rhythmisches elektrisches Zirpen". Das ist ebenfalls kein Schleifen, scheint nicht mechanisch sondern iwie an der Lüfterelektronik (Spulen) zu liegen. Insgesamt sind die Lüfter (bei meiner FE zumindest) echt keine Glanzleistung und leider eine Enttäuschung bei so einer teuren Karte. Hier können denke ich die Customs gut punkten.
  • Lautstärke: Grob übern Daumen und nach Gehör ist bis 50% alles noch im grünen Bereich und verschwindet im Gesamtrauschen des Systems. ab den 50% kommt dann besagtes Schleifgeräusch dazu das bei ca. 70% nervt und bei 100% jeden Mitbewohner iwann stört. 100% erreicht man i.d.R. Bei mir waren es in den Games 45-50%. Selten mal etw. drüber
  • Spulenfiepen: Ja, ein "leichtes" Spulenfiepen ist vorhanden. Hatte da schon lautere Karten. Bei geschlossenen Gehäuse eher kaum wahrnehmbar wenn man Gehäuselüfter hat die es eh übertönen. Auch bei 150 FPS in AC Valhalla gleichbleibend.
  • Leistung: Top. Besonders die Möglichkeit das Powerlimit bis auf ~73% im Afterburner runterzudrücken + leichtem OC (+150 MHz Core, +800 MHz Mem) und in Cyberpunk nur um die 4-5 FPS verlieren während man 100+W spart ist echt nice. Auch einfach nur schon auf 90% PL + OC hat gereicht um 30-40W zu senken und trotzdem die gleiche Leistung zu erhalten oder gar ein bisschen mehr. Die Temperaturen sind dadurch auch nochmal etwas niedriger
  • OC: Ich denk ist soweit für ne FE i.O. 3030 MHz Core und 12000MHz VRAM war drin. Drüber wird instabil. Das ganze OC Thema macht aber iwie keinen Sinn mehr. Um die 3 GHz zu bekommen zieht die Karte dann 550W in CP und bringt dafür nur 2-3 FPS mehr. Bei 90% PL und etw. OC waren es 380W und eben 2-3 FPS weniger.
Würde mich interessieren ob andere ebenfalls diese Lüfterproblematik feststellen können? :)
Benchmark:
4090 FE Default:
4090 FE mit groben OC (ohne Kurvenanpassung usw.):
AfterBurner Settings die bei mir bisher stabil liefen (nicht auf Benchmarks sondern aufs Gaming ausgerichtet):
OC 1 (~2900 MHz in CP):
OC 2 (~2800 MHz in CP):
PowerSaving 1 (ca. gleiche Leistung wie @Stock ~2700 MHz in CP):
PowerSaving 1 (ca. 3-4 FPS weniger als @Stock ~2500 MHz in CP):
Das ist mit dieser Karte ja fast unmöglich :) Aber wie du bereits sagtest hilft das nicht bei meinem Problem. Und ich finde die Nativen 90 fps ohne FG schon ausreichend. meine MAx fps sind 117fps.
Aber danke für den hinweis mit der FG und dem Limit
So, mein Kabel fürs das Bequiet wurde nun auch von Alternate versendet. :)
caseking hat es nun auch gelistet
demnächst bei caseking
Jetzt werden sogar schon die neuen BeQuiet Kabel verscalped. Echt eckelhaft mittlerweile!
angebot und nachfrage
Aktuell in Metro Exodus einfach nur rumstehen und laufen lassen. Nach ~30 Min und geschlossenem Gehäuse arbeitet sich die 4090 FE bei mir @Stock unter 99% Auslastung auf 67/68°C CoreTemp, 76°C HotSpot und 72/74°C MemTemp hoch
Ein Glück ist Herbst. Bin auf den Hochsommer gespannt. Und was Wasserkühler so bringen werden.
A Plague Tale: Requiem im Test: Richtig schöne Grafik mit enormen GPU-Anforderungen​
Also als 4090-Owner hat man da gar keine Sorgen. Ultra mit DLSS auf Qualität ohne Zwischenbildberechnung ... um die 100 FPS. Mit Zwischenbildberechnung 160 FPS. UND... OMG OMG (Schnappatmung), ich bin im CPU-Limit^^
Na wenn die 3090 / TI mit Luft im Sommer keine Probleme gemacht hat wird es die 4090 erst recht nicht tun.
Hab meine Karte nochmal geprügelt +240/+1800 sind rausgekommen.
Nö er wird ja nicht uncapped spielen sondern auf 142fps cappen oder 118 je nachdem was fürn panel er hat
hast du auch diese übeln ruckler in den zwischen sequenzen ?
@SH gut das du mal da bist :) Welche deiner 4090er behölst eigentlich jetzt ?
Ähnliche Themen
